flashjazzcat Posted Tuesday at 07:31 PM Share Posted Tuesday at 07:31 PM (edited) I'm pleased to (finally) announce the release of version 4.2 of my firmware for Incognito, Ultimate 1MB, SIDE, SIDE2, 1088XEL and 1088XLD. https://atari8.co.uk/firmware/ There's also an updated SIDE3 loader, as well as the updated SIDE Loader packaged for AVG's SIDE emulation mode. Not a great deal has been added in terms of functionality, but everything has been updated to match the general look and feel of the new SIDE3 loader. I have fixed the Sophia 2 plugin (users reported lengthy black-screen pauses, and this was caused by a very nasty bug), and the U1MB BIOS now reports the hardware JED version correctly. Needless to say, we should use this thread to discuss any issues or suggestions. Edited Tuesday at 07:38 PM by flashjazzcat 13 10 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 07:33 PM Share Posted Tuesday at 07:33 PM As always, thanks for your hard work 👍 3 Quote Link to comment Share on other sites More sharing options...
woj Posted Tuesday at 08:02 PM Share Posted Tuesday at 08:02 PM So many thanks Jon! Not having any issues yet (surprisingly!), mostly because I need to find some time to flash it and... Yes, that's what I want to say, each time before flashing (my config is 130XE + U1MB + SIDE3) I need to triple check documentations on which options in either have to be on or off for safety. So, my question / request would be, perhaps demanding, a short list of absolute no-no configuration options (if there are any such) and preferred order of flashing in a small "pill" that is easy to remember. No procedures of any kind of which files to mount where, these we should know or know where to look them up. Quote Link to comment Share on other sites More sharing options...
kconan Posted Tuesday at 08:15 PM Share Posted Tuesday at 08:15 PM Thank you very much for this! I'll be flashing this weekend and will report any issues. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 08:28 PM Share Posted Tuesday at 08:28 PM (edited) @flashjazzcat Hi Jon, flashed U1M and Side3 fine, but when I tried the Incognito, I put the .ATR in D1: but I get an error trying to read the disk, so I put the same .ATR as D1: in Altirra and confirms the disk image is not right This is the Altirra error D5:>DIR D1: 144 Write protected or bad sector on my 800 I get ERROR 140 SIO Framing Error this is loaded into an S-Drive-Max, the .ATR loaded into D2: is fine (just a normal DOS disk) so again, looks like the .ATR has some errors Edited Tuesday at 08:29 PM by TGB1718 Quote Link to comment Share on other sites More sharing options...
woj Posted Tuesday at 08:29 PM Share Posted Tuesday at 08:29 PM Actually, I do have an issue, have not even yet started flashing The U1MB PDF documentation link actually points to the firmware plugin source ZIP file. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 08:31 PM Share Posted Tuesday at 08:31 PM @woj that's not where I get to when I open the link, strange Quote Link to comment Share on other sites More sharing options...
woj Posted Tuesday at 08:35 PM Share Posted Tuesday at 08:35 PM 3 minutes ago, TGB1718 said: @woj that's not where I get to when I open the link, strange It points to: https://atari8.co.uk/wp-content/uploads/Firmware-4.2-Plugin-Source.zip Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Tuesday at 08:42 PM Share Posted Tuesday at 08:42 PM (edited) 7 minutes ago, woj said: It points to: https://atari8.co.uk/wp-content/uploads/Firmware-4.2-Plugin-Source.zip it's true. I am sure @flashjazzcat will sort it. Edited Tuesday at 08:43 PM by Beeblebrox Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 08:44 PM Author Share Posted Tuesday at 08:44 PM Link fixed: many thanks for spotting that. Can't see a problem with the Incognito ATR at this end, having downloaded and extracted it. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 08:46 PM Author Share Posted Tuesday at 08:46 PM (edited) 43 minutes ago, woj said: I need to triple check documentations on which options in either have to be on or off for safety. So, my question / request would be, perhaps demanding, a short list of absolute no-no configuration options (if there are any such) and preferred order of flashing in a small "pill" that is easy to remember. No procedures of any kind of which files to mount where, these we should know or know where to look them up. That's why there's a readme file; there aren't any 'no go' configuration settings aside from not disabling flashing on the U1MB, but if there's anything I can add to the readme, let me know. Edited Tuesday at 08:46 PM by flashjazzcat Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 08:50 PM Share Posted Tuesday at 08:50 PM 5 minutes ago, flashjazzcat said: Can't see a problem with the Incognito ATR at this end, having downloaded and extracted it. I'll download again and give it a try, thanks Quote Link to comment Share on other sites More sharing options...
woj Posted Tuesday at 09:01 PM Share Posted Tuesday at 09:01 PM 12 minutes ago, flashjazzcat said: That's why there's a readme file; there aren't any 'no go' configuration settings aside from not disabling flashing on the U1MB, but if there's anything I can add to the readme, let me know. Indeed. Just flashed everything with no problem. What was perhaps sitting in the back of my head was the need to turn off Basic for the (Side3 only?) flashing, and the note in the manual about flashing the U1MB firmware from a mounted ATR. Looked through the PDF (interestingly Google has found the link for me before you fixed it) and there is indeed nothing about any damaging configuration options. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted Tuesday at 09:06 PM Share Posted Tuesday at 09:06 PM What type of jtag programmer do I need for the first run and latest of U1MB and INCOGNITO boards? Will a USB Blaster work? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Tuesday at 09:12 PM Share Posted Tuesday at 09:12 PM (edited) just flashed the new U1MB firmware to my 65XE (U1MB/VBXE). All good with the initial flash mounting the firmware.atr via SIO2PC from my laptop on ReespQt. U1MB fine. U1MBS3.rom used which has VBXE/SIDE3 plugin. However as soon as I popped my SIDE3.1 cart (with the beta firmware), and booted up, where I moved around the menus all of a sudden I had screen glitching and crashing. Prior to the new U1MB firmware install earlier I've not had any issues with this SIDE3.1 cart. See images below. I am not ruling out this 65XE as a possible issue as this machine doesn't yet have the 74F08 installed in place of the 74LS08. I have another XE, a 130XE with just U1MB in it -so I'll flash the new U1MB firmware onto it and try and see if SIDE3.1 (beta loader) has similar issues. ...... just flashing my 130XE's U1MB now.... EDIT: False alarm - see my posts below. Seems my 65XE has issues. No probs with my 130XE Edited Tuesday at 09:59 PM by Beeblebrox Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 09:21 PM Author Share Posted Tuesday at 09:21 PM It's hard to imagine any connection between the two since there are no functional differences in the U1MB firmware aside from the screen layout and the Sophia 2 plugin and JED version fixes. Even more so if you haven't updated the SIDE3 yet. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 09:22 PM Author Share Posted Tuesday at 09:22 PM 15 minutes ago, AtariGeezer said: What type of jtag programmer do I need for the first run and latest of U1MB and INCOGNITO boards? Will a USB Blaster work? Just as before: Xilinx USB platform cable and the Impact programmer from the Xilinx web pack. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 09:24 PM Author Share Posted Tuesday at 09:24 PM 20 minutes ago, woj said: What was perhaps sitting in the back of my head was the need to turn off Basic for the (Side3 only?) flashing Not BASIC, but the flasher should be run with the 'X' command under SDX since the tool only disables the SDX ROM on the SIDE3 (so would otherwise be unable to see the SIDE3 ROM if the U1MB SDX ROM - say - was in the way). 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Tuesday at 09:33 PM Share Posted Tuesday at 09:33 PM (edited) 18 minutes ago, flashjazzcat said: It's hard to imagine any connection between the two since there are no functional differences in the U1MB firmware aside from the screen layout and the Sophia 2 plugin and JED version fixes. Even more so if you haven't updated the SIDE3 yet. Two things to report: Just flashed my 130XE's U1MB successfully, same way. U1MB working fine. Side3.1 cart with Beta loader plugged in - no menu glitching or crashing issues at all. (So assume it's my 65XE causing the earlier issues). Second thing is that I didn't clock there was an updated Side3 loader to flash too. My bad - will do that now. (But just to confirm the beta loader is working fine too). So I'd say all good re the new U1MB firmware from my end. Just need to sort my VBXE/U1MB 65XE Thanks FJC Edited Tuesday at 09:39 PM by Beeblebrox 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 09:37 PM Author Share Posted Tuesday at 09:37 PM (edited) Yeah: I just double-checked a SIDE3 and SIDE3.1 (the latter wasn't updated with the new loader yet) on a 600XL with the latest U1MB firmware and there are no problems whatsoever, but - as I say - it's inconceivable that any of the changes to the U1MB firmware could make the SIDE3 loader crash. That 65XE certainly looks like a candidate for a Phi2 timing tweak (although it grieves me that such things are still necessary). Still - where would we be without a few photos of crashing software to liven up the first page of a firmware update thread. Edited Tuesday at 09:39 PM by flashjazzcat 2 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Tuesday at 09:45 PM Share Posted Tuesday at 09:45 PM 3 minutes ago, flashjazzcat said: That 65XE certainly looks like a candidate for a Phi2 timing tweak (although it grieves me that such things are still necessary). I agree. 74F08 on standby 3 minutes ago, flashjazzcat said: Still - where would we be without a few photos of crashing software to liven up the first page of a firmware update thread. Was this you a few mins who heh heh 1 Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted Tuesday at 09:49 PM Author Share Posted Tuesday at 09:49 PM 4 minutes ago, Beeblebrox said: Was this you a few mins who heh heh Yes, right in the middle of attempting to (finally) do an estate value calculation for a probate application. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Tuesday at 09:54 PM Share Posted Tuesday at 09:54 PM 3 minutes ago, flashjazzcat said: Yes, right in the middle of attempting to (finally) do an estate value calculation for a probate application. noooooooooooooooooooooooooooooooooooooooooooo!! Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 09:58 PM Share Posted Tuesday at 09:58 PM 1 hour ago, flashjazzcat said: Can't see a problem with the Incognito ATR at this end, having downloaded and extracted it. Tried again, same problem, just wont load from an S-Drive, I finally got it to work by copying onto the CF card, mounting in the Loader and booting to SDX, then it worked. (I know, that's probably the correct way to do it ) Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted Tuesday at 10:13 PM Share Posted Tuesday at 10:13 PM 45 minutes ago, flashjazzcat said: Just as before: Xilinx USB platform cable and the Impact programmer from the Xilinx web pack. Thanks Jon, Okay, before I used a Xilinx Parallel Programmer on XP which has died. So now I need a USB programmer for Windows 7. Will this be okay https://www.ebay.com/itm/404091603808 Quote Link to comment Share on other sites More sharing options...
