howerton Posted Tuesday at 09:51 PM Share Posted Tuesday at 09:51 PM I have been having trouble with my gotek I twisted the st ribbon cable upside down and connected like I heard here before. The gotek said cable my be upside down. Is this correct? I have a 1040stfm and I am running a TOS of 1.02 or below. Also what files do I need to put on my usb thumb drive to get it to run? I have flashfloppy 3.30 installed on my gotek. Your help would be greatly appreciated and thank you to all the forum members who have helped me before. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Tuesday at 10:06 PM Share Posted Tuesday at 10:06 PM You need to make sure pin 1 on the ST ribbon goes to to pin 1 on the gotek it's usually red or blue colour one end of the cable. I would assume if the gotek is saying it's upside down, then it probably is You should be able to just copy disk images onto the gotek and use the selector to load whatever you want. There is a config file that you can put on the root of the gotek to change the way it works it's reasonably easy to change, there's lots of info in the config file to tell you what each parameter does. Quote Link to comment Share on other sites More sharing options...
bfollowell Posted Tuesday at 10:21 PM Share Posted Tuesday at 10:21 PM I thought I'd read somewhere that you must be running TOS 1.4 or higher to use a Gotek. I'm not 100% certain that that is actually the case, but I know I've read it somewhere at some point over the years. If someone else knows this to not be true, please pipe in. Quote Link to comment Share on other sites More sharing options...
howerton Posted Tuesday at 10:44 PM Author Share Posted Tuesday at 10:44 PM Thanks everyone. I guess I will sell the gotek on eBay. Does anybody want it here? $30 and shipping. You can pay me through PayPal. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted Tuesday at 11:10 PM Share Posted Tuesday at 11:10 PM 48 minutes ago, bfollowell said: I thought I'd read somewhere that you must be running TOS 1.4 or higher to use a Gotek. I'm not 100% certain that that is actually the case, but I know I've read it somewhere at some point over the years. If someone else knows this to not be true, please pipe in. Only thing I can say for sure, is I used an old version HxC emulator from 2001 with TOS 1.0. I cannot comment on Gotek (or Goex) because that ST now has TOS 1.4 in it. However, the same SD card from the HxC is what I am using in the Goex drive, and I did not change any files or config. Quote Link to comment Share on other sites More sharing options...
ijor Posted Tuesday at 11:31 PM Share Posted Tuesday at 11:31 PM 1 hour ago, bfollowell said: I thought I'd read somewhere that you must be running TOS 1.4 or higher to use a Gotek. I'm not 100% certain that that is actually the case, but I know I've read it somewhere at some point over the years. Not at all. Gotek is a floppy emulator at the hardware level. You can use any TOS, or custom OS for that matter, you want. Now, the firmware has an optional mode that downloads a menu to the computer. This menu, conceivable, in theory, might not work with some TOS versions. In practice I know that with both FF and HxC firmware, it works fine with TOS 1.0 1 Quote Link to comment Share on other sites More sharing options...
howerton Posted Wednesday at 12:53 AM Author Share Posted Wednesday at 12:53 AM A link to this firmware and how to install? Quote Link to comment Share on other sites More sharing options...
howerton Posted Wednesday at 02:08 AM Author Share Posted Wednesday at 02:08 AM Got it working. Just played double dragon. It is no longer for sale. 2 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Wednesday at 09:42 AM Share Posted Wednesday at 09:42 AM I bought a Goex some time back and had the same issues you saw, couldn't get it to work no matter what, you could see the access LED light, but that's all, I even used a scope on all the signal lines and it all looked good, in the end I put it down to it just doesn't work and just put it to one side and almost forgot about it. I did contact the supplier, but he couldn't help initially, he eventually said send it back, (over a year later) he sent a replacement which worked straight out of the box, just my luck to have a duff one Quote Link to comment Share on other sites More sharing options...
bfollowell Posted Wednesday at 12:05 PM Share Posted Wednesday at 12:05 PM 9 hours ago, howerton said: Got it working. Just played double dragon. It is no longer for sale. Good deal. I'm glad you got it working, and I'm glad I was mistaken on the TOS issue. Quote Link to comment Share on other sites More sharing options...
