Tyrop Posted January 27 Share Posted January 27 I am wondering if there is a niftier way to do this than using a lot of branching based on the carry flag, say using ADC?. Or maybe that is already the most efficient way? I am looking to use 3 bytes so the end result will be 3 memory locations reading 00 00 01. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 28 Share Posted January 28 (edited) For a simple count you could use INC or ADC. 3 bytes gives ~ 16 million values. The branch is only needed if doing INC. Use CLD before the ADC sequence if in an interrupt or unsure if you could be in decimal mode. lda count clc adc #1 sta count lda count+1 adc #0 sta count+1 For 3 bytes there you can just repeat the count+1 actions for count+2 Using INC... 3 byte e.g. inc count bne noinc1 inc count+1 bne noinc1 inc count+2 noinc1 Edited January 28 by Rybags Quote Link to comment Share on other sites More sharing options...
+VinsCool Posted January 28 Share Posted January 28 It depends on how exactly you want to make use of it, but I imagine it is not intended to be very complex. If you only want to increment by 1, using the INC and BNE instructions may do a good job for it I think. I was thinking about something like this: counter dta $00,$00,$00 increment inc counter+0 bne increment_done inc counter+1 bne increment_done inc counter+2 increment_done rts Once the counter+2 value had incremented, you will have $00,$00,$01 in memory. [EDIT] Darn, I was a bit too slow, lol 😅 1 Quote Link to comment Share on other sites More sharing options...
Tyrop Posted January 28 Author Share Posted January 28 Thank you for the responses. So in Rybags’ first example, there are 2 ADC’s but 1 CLC. Wouldn’t I have to put a CLC before the second ADC? Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 28 Share Posted January 28 1 hour ago, Tyrop said: Thank you for the responses. So in Rybags’ first example, there are 2 ADC’s but 1 CLC. Wouldn’t I have to put a CLC before the second ADC? No, you specifically need to keep the carry flag to bridge the carry out of the first addition and into the second. That's how the two ADCs combine their 8-bit additions to calculate a 16-bit addition. The CLC at the beginning is needed to prevent joining with some unrelated previous calculation. 2 Quote Link to comment Share on other sites More sharing options...
tebe Posted January 28 Share Posted January 28 (edited) Mad Pascal var e: cardinal; begin for e:=0 to 65536 do ; end; compile, view file *.a65 lda #$00 sta E sta E+1 sta E+2 sta E+3 l_008C ; --- ForToDoCondition lda E+3 cmp #$00 bne @+ lda E+2 cmp #$01 bne @+ lda E+1 cmp #$00 bne @+ lda E cmp #$00 @ scc jne l_0096 ; --- ForToDoEpilog inc E bne @+ inc E+1 bne @+ inc E+2 bne @+ inc E+3 @ jne l_008C l_0096 Edited January 28 by tebe Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 28 Share Posted January 28 @Tyrop Do you need to hold the value 65536 as you could simply detect the loop back to zero instead and only use a 2 byte counter. DoTest JSR ResetCounter TestCounter JSR IncCounter BNE TestCounter AllDone JMP AllDone ResetCounter LDA #0 STA Counter STA Counter+1 RTS IncCounter INC Counter BNE @+ INC Counter+1 @ LDA Counter ORA Counter+1 RTS Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted January 28 Share Posted January 28 You can omit LDA Counter/ORA Counter+1 and it will still work. 1 Quote Link to comment Share on other sites More sharing options...
Tyrop Posted January 28 Author Share Posted January 28 16 hours ago, phaeron said: No, you specifically need to keep the carry flag to bridge the carry out of the first addition and into the second. That's how the two ADCs combine their 8-bit additions to calculate a 16-bit addition. The CLC at the beginning is needed to prevent joining with some unrelated previous calculation. Thank you for the explanation. But there will also be a third ADC because I am counting to 65536. If I do a third ADC and the carry bridges over to the third ADC, won't the third byte increment prematurely, and won't it increment every time the first byte goes past $FF? Quote Link to comment Share on other sites More sharing options...
phaeron Posted January 28 Share Posted January 28 3 minutes ago, Tyrop said: Thank you for the explanation. But there will also be a third ADC because I am counting to 65536. If I do a third ADC and the carry bridges over to the third ADC, won't the third byte increment prematurely, and won't it increment every time the first byte goes past $FF? Nope, because after the second ADC the carry flag will only be a 1 if there was a carry out of the 15th bit. ADC sets the carry whenever the addition result it computes has the 8th bit set, or is >= 256. Any carry state coming in is used and replaced by the new carry state, it's not cumulative. It always reflects whenever there was an extra count overflowed out of the last addition that needs to be added into the next addition of the higher order byte. If you have $0102FF, then the first ADC #1 computes $FF + 1 + 0 = $100, so the first result byte is $00 and C=1. The second ADC #0 computes $02 + 0 + 1 = $03, so the second result byte is $03 and C=0. The third ADC #0 computes $01 + 0 + 0 = $01 and C=0. The full result is then $010300. If you have $01FFFF, then the first ADC #1 computes $FF + 1 + 0 = $100, so the first result byte is $00 and C=1. The second ADC #0 computes $FF + 0 + 1 = $100, so the second result byte is $00 and C=1. The third ADC #0 computes $01 + 0 + 1 = $02 and C=0. The full result is then $020000. 3 Quote Link to comment Share on other sites More sharing options...
Tyrop Posted January 28 Author Share Posted January 28 Ahhh! There was my misunderstanding. I thought once the carry is set, it will remain set until it is cleared. I didn't realize that a new ADC will flip the carry back to 0 if there is no carry. Thank you! Quote Link to comment Share on other sites More sharing options...
