Unknown timer behaviour CONFIRMED
laoo
Sorry for the clickbait title, but what I've found is hard to explain in a title.
I don't actually know whether it's genuinely unknown feature, but I haven't read about it in the docs and author of Handy haven't read about it too, so I suspect it's something new.
tl;dr:
When enabling linking of two timers with higher timer triggering an interrupt and with no reloading, after counter underflows the interrupt is being triggered at each borrow.
When using timer without reloading, after counter underflows the interrupt is being triggered at each timer cycle (i.e. decrement try, or borrow from linked timer).
Long version:
I've wrote a VGM player on Lynx that unintentionally worked on real hardware but did not on Handy nor Felix.
I've looked at it with @42bs few days back and found that the initial bug causing Handy to hang wasn't really a bug in the player but a bug in Handy. The player is interrupt driven and new interrupt is being issued each time previous interrupt triggered. I just needed initial interrupt to get started so the player just writes a value to INTSET that should manually trigger an interrupt. It just seems to not work in Handy.
But the fun part begins later as the player still did not work on any emulator. After further investigation I've discovered a bug that in one specific place the player did not reissue the next interrupt. No interrupt - no playback. Emulators did the right thing. But the hardware played along anyways.
I came up with an hypothesis. I've wrote a piece of software to test it and it confirmed. Emulators behave differently than the real hardware.
The test program at each VBL is setting timer5 and timer7 as follows:
TIMER7_COUNT = 50;
TIMER7_CONTROLA = ENABLE_INT|RESET_DONE|ENABLE_COUNT|AUD_LINKING;
TIMER5_BACKUP = 158;
TIMER5_CONTROLA = ENABLE_RELOAD|ENABLE_COUNT|AUD_1;
Timer5 is counting lines. Just like HCOUNT. It's linked to Timer7 that has no reload (so no backup just count) and triggers an interrupt after finish and is initially set to 50 (about half of the screen). I XOR the green0 color with 15 after timer7 interrupt and reset it to zero at VBL.  As you may have guessed it does not behave like this:
Felix.png.598fc5fec03f9852d127f9f078a673ca.pngHandy.png.8642d0e18b634b2cedf664e4521aeab2.png
But rather like this:
TIMER_DONE does not prevent triggering an interrupt after borrow from previous timer and the interrupt is being triggered each time the previous timer underflows.
That's it. That's the mystery. A minor thing, but a thing. I'll just incorporate the fix into the Felix :)
UPDATE
After more experiments it turned out that linking is not necessary. Only one timer without reload is enough to observe this phenomenon. @MicheleS found that it's even documented
TimerDone.lyx
Edited by laoo
tl;dr:
It is know that Timers are not emulated prefect in Handy, esp audio timers which high frequency are no emulated.
But the linking is a nice find.
so, thw fix is to never set DONE if it is linking?
or is it altogether a problem with single shot timers?
Is it this?
Handy Specification, page 34, last paragraph:
Quote
The interrupt signal comes from the timer when the timer value is zero AND the timer is attempting to perform a ‘borrow’. Based on the control bits, the borrow may not actually occur, but the interrupt signal will.
Timer 7 ("clocked" by timer 5) reaches zero and triggers interrupt on next borrow. Since it's not reloaded, it stays at zero. Now, everytime counter 5 reaches zero and clocks timers 7, the interrupt is triggered again.
Or did i misinterpret your find?
Edited by MichelS
14 hours ago, MichelS said:
Is it this?
I agree, this seems to be the point. So no bug in the HW, but a misinterpreted behavior.
While preparing a fix in the emulator I was investigating it further it turned out to be not related to linking, but single shot timers, i.e. without reload.
So @MichelS is right that IT IS in the docs, and @42bs is right that it's misinterpreted behaviour. RJ Mical did a good job hiding things in the documentation ;)
  • Haha 1
1 hour ago, 42bs said:
sometimes you just need a single shot. For example a timeout.
... but as it does not disable it by itself, there is no large difference or do i miss something?
with RELOAD 49
int every 50 counts
without RELOAD
int after 50 counts, then every count.
For one-shot timers without reload you just need to remember to set INTRST at the end of the interrupt as it will almost certainly shot another time during interrupt handler. Beside this their the same. Frankly, this "feature" feels buggy to me.
On 1/28/2023 at 5:45 PM, Cyprian said:
@laoo does it mean that we can expect a new Felix version?
Generally nobody expects when there will be another version of Felix.
  • I have to migrate the renderer to something multiplatform (OpenGL ES? Vulkan?)
  • I have to fix nasty audio/video synchronization issue
  • I have to add memory viewer debug window
I had an year long break due to fatigue and lack of inspiration, but who knows... my energy level might be high enough now ;)
Edited by laoo
Pretty good link. I love it!
PS. I am toying with the idea of trying to improve on the PSP Lynx emulator. The PSP has such a nice display and fits my hands. Perhaps I could port the felix engine to the Plynx application.
I wonder if the timer done bit is set differently.
Have you ever observed TIMER_DONE bit of CONTROLB timer register?
I'm actually testing it while investigating this issue, and found that it's always zero, regardless if reload is set or not.
Furthermore:  LAST_CLOCK seems to be 1 just before the clock when the counter is decremented (so it's observable with prescaler greater than 1)
BORROW_IN is 1 even when the timer is not being linked but just in every cycle the timer is decremented.
Only BORROW_OUT bit is reasonable and behaves like I expect it to do.
The project is cleanly divided into libFelix that is platform agnistic and just does the emulation, and application itself that does I/O and A/V.
It might be CPU hungry though (as it ultimately aims to be cycle exact without cheating).
unluckily not. but it could explain why comlynx is emulated badly. redeye code uses one shot timers.
yes. but unluckily does not compile under linux yet... will give it a try again after updates.
I would happily include it into sdl-handy
Edited by sage
I believe you have libretro and retroarch running on PSP.
with RELOAD 49
int every 50 counts
without RELOAD
Right, yes. Likely not what was intended.
I tried to compile files in libFelix on Mac, no  chance. <coroutine> is not in Clang (or only experimental). But then, _I_ do not need a native Mac port.
That can be tweaked for time being. But I'm in a process of researching GLFW/Vulkan to get rid of DX11 so I hope that in few months it can be compiled everywhere (with some wrappers on Mac, as it has its own Metal, but Vulkan can be translated to it AFAIK).
Yes, tried it. The came a bunch of new errors. Like not finding "comment". Anyway. I can wait.
I'd rather see code/memory breakpoints, register/memory manipulation. Means a Lua-Console ;-)
Maybe you should set up a Patreon account.
We'll talk about it 😎
It would became a JOB. Pressure = not fun. I come back to Felix when I feel inspiration to do so.
but thats part of the platform part, not emulator core ...
