Reasons for the palette of the PAL VCS ?
Windless
The pal VCS as a weird palette with :
- colors seems "interlaced"
- there are 3 identical gradients of greys
Today I took another look at this, and emited the hypothesis that color are arranged that way because it helps with generating the PAL signal. So I converted the palette to YUV, and here is how the $x0 colors (taken from wikipedia) are translated :
What is there to be seen ? If you compare an odd numbered value with the next (even) one, you will get almost the same luminance, almost same V as the other color, and about opposite U (well, except for $40)...
Could it mean that, instead of shifting the phase of the color, the pal TIA inverts the first bit of the colors on even lines to select a color that is already phase inverted ?
That would also explain why we have two grey scales for $0x and $1x, but not why the last two lines of the palette are also greyscales.
If I understand the Color Select Decode in the NTSC TIA (page 5) corectly, the delay cells are selected based one the color like this :
Delay [ ][ ][ ][ ][ ][ ][ ][ ][ ][ ][ ][ ][ ][ ]
Color  2  3  4  5  6  7  8  9  A  B  C  D  E  F
Where E and F might give the same colors as 3 and 2.
If we want an opposite phase for conecutiv color numbers, the PAL version might look like this :
Color  2  4  6  8  A  C  E  F  D  B  9  7  5  3
but now colors 5 and 3 might be the same as 2 and 4. If you use a counter to generate a gradient, some colors might even be reversed.
Could that be a reason to suppress colors E and F ? Or is there something in the timing of the PAL signal or in the speed of the cells (they don't seem to be synchronized with the 4,453125MHz clock ?*) that would prevent from having two more colors ?
W.
* : or are they ? I'm not strong with reading schematics !
Edited by Windless
  • The title was changed to Reasons for the palette of the PAL VCS ?
