Creativision - a challenge
Andrew Davie
I thought some of the 6502 people onsite might enjoy this challenge...
(my involvement with the CreatiVision console was in contributing ROMs for dumping by Luca - he has been doing an amazing job of archiving and preserving things based on this machine which was popular in a number of countries in the '80s - including Australia.  I'd really like if we could help him out and recover the contents of the EPROM, as explained below...).  Please share results here, too,  if you have a go.
"Diagnostic CPU Test, by Vtech (198x)"
For VTech CreatiVision and compatible computers
(Dick Smith Wizzard, Hanimex Rameses, VTech Funvision)
This 8 KBytes EPROM was originally found in an authentic
cartridge by VTech, for internal use to test
functionality of the 6502 CPU in CreatiVision units.
It is an insanely rare EPROM (one only ever seen in
20+ years of collecting exclusively CreatiVision items)
that I suspect was made in a handful of copies, likely
one per each repair centre in countries where
CreatiVision sold (I would say no more than 10 EPROMs
ever made).
The EPROM was used a handful of times and shows a black
screen with Assembly data in plain text format, being
the test of the CPU commands.
Unfortunately, when de-soldering the EPROM from the
cartridge PCB, two data lines (bit D1 and D6,
or ".X....X.") of each byte were disconnected from the
die. The EPROM data remains intact, but these "bits"
cannot be "dumped".
Therefore, each dump of the named EPROM resulted with
bits 1 and 6 being either all 0 or 1, and this alters
the content of each byte.
The very first dump made (12 January 2009), was limited
to the lowest 4 KBytes and it appears to have at least bit
6 with some significant data, although potentially
fluctuating/unstable.
All following dumps have bits 1 and 6 damaged.
The ROM maps the 8 KBytes between $A000 and $BFFF.
As this EPROM was one-of-a-kind and it went lost
due to mishandling from a MAME team member around 2010,
I fear that the full content of this EPROM is lost forever.
I have decided to release this collection of
"bad" dumps, hoping that someone, one day, will be
able to fix it. I have included a little tool called
"Biteditor" for Windows, that allows to peek into the
EPROM bits and swap 0s and 1s. You may want to use it
to attempt to obtain correct bytes/data.
If you have any useful information on this, or have a
working copy of such EPROM, please do not hesitate to
contact me.
Thanks
Luca Antignano
Founder and webmaster of CreatiVemu
W: www.madrigaldesign.it/creativemu/
E: lucantignano@gmail.com
(5th January, 2023)
diagnosticc.zip
I think there is more broken than just bit 1 and 6.
E.g. look at the first byte of each ROM. We have:
  • 0x20 = 0b00100000
  • 0x22 = 0b00100010
  • 0x62 = 0b01100010
  • 0x6E = 0b01101110
While the first three values fit to the description, 0x6E does not. According to this, _2009-10-18_cpu_bad8k_2_2564.bin seems to be even more broken than the other ones.
Now lets look at of 0x140. Here we have:
  • 0xFF = 0b11111111
  • 0xFD = 0b11111101
  • 0xBC = 0b10111100
Again, the last one doesn't fit to the description. This comes from _2009-10-18_cpu_bad8k_3_2764adaptor_willem.bin
However, overall _2009-10-18_cpu_bad8k_3_2764adaptor_willem.bin looks like a slightly better dump. Bit 6 is at least sometimes correct.
_2009-10-16_cpu_bad8k.bin does look even a bit better:
And _2009-01-12_cpu_4k.bin seems to have bit 6 always correct:
In all other dumps bits 1 and 6 are either set or clear here. So maybe we should concentrate on these three dumps.
Edited by Thomas Jentzsch
The code at the beginning of bank 1 seems to do a lot of writing to 0x3000/1. Looks like some kind of serial protocol.
EDIT: I found two more (working) ROMs, which seem to have similar code. They also use 0x3000/0x3001 frequently.
diagnosticb.zip diagnostica.zip
cannot be "dumped".
I realise that the physical EPROM is missing, but just out of general interest: were the data lines themselves physically disconnected, or did the legs just break off at / inside the package?
If the former, yep, it's decap (or X-ray) time.  If the latter, there's a trick I've used on a couple of occasions to get ICs readable enough for whatever purpose they're needed for.  Obviously this won't be doable when the chip is MIA, but I am speaking in general terms.
True, but that one looks as though bit 6 is always high.  I don't know enough about the system to tell if this is intended behaviour or not.
Granted, it might be possible to synthesise a 'good' dump from multiple bad ones, but it would need to be marked as suspect at the very least.  Munging bad dumps together, calling them good, and sending them out into the wild isn't something I'm particularly keen on.  Causes no end of confusion once they spread. *cough*raflsiau*cough*
If you read further:
A picture of the cart (at the right) exists:
https://gamescollection.forumcommunity.net/?t=60644639
https://photos.google.com/share/AF1QipO-1hlvuoXWQuCP9jlfcJH-vdm9UUDXOTkNfk2yWT4aFnsJoLHlpKFgJTl7hahOHg?key=SzVxRGdlR1N6eEdJX0RvZ1c3Tm9xN3BiY0cyMHFB
It was in Luca's (aka "Madrigal") collection until at least 2018.
No, that's not OK.
100% agreed. And I doubt we could be even remotely sure that what we create here is even close to the original. Maybe, if we could run the result on a real system, we might get closer.
Anyway, as of now I cannot see how we could recreate the original ROM. Opcodes could be guessed with some chance, but the operands are just too random. Maybe we could compare the code to the existing Diag ROMs and find matching pieces of code. But even then, there will be a lot of remaining code and especially non graphics data. IMO.
Hi all - MADrigal here (the owner of the CreatiVision EPROM and person who did the dumps loooong ago)
Firstly, thanks Andrew for bringing this to the attention of the community.
The situation is quite desperate. I understand that my precious EPROM is lost forever. Have been trying to track it for more than 10 years - with no success.
Just providing a few clarifications here
  • The cart is still in my possession, but the EPROM is missing.
  • Yes, the CPU test cart in question came with "Diagnostic A+B" cart - they were part of a single package. No surprise some parts of the code are similar as they were all made for internal use therefore coded by I assume the same persons.
  • The first dump I made (in cronological order) was incorrect in the sense that I dumped the low 4Kb only, so the high 4Kb are missing. On that dump, one only bit is incorrect (bit 1 from memory). So bit 6 is significant - or at least it appears to be.
  • Let's say that missing is: bit 1 in the lowest 4K (first dump) and bits 1 and 6 in the highest 4K (all other dumps). One dump was made after putting the EPROM in the freezer, therefore some data of bits 1 and 6 may be correct or fluctuating - rather than completely incorrect.
  • In relation to writing to $3000 and $3001: this is the CreatiVision VDP address for read/write - see attached "Issue 3" of the Wizzdom fan newsletter containing the entire CreatiVision memory map - needed to understand how the 6502 code is mapped.
  • It is also important to know that the 8K EPROM data end up being "mirrored" in the CPU address space: The 16KB "ROM1" bank ($8000 to $BFFF) is filled up with the EPROM data wtice - which means the same identical content at $8000-$9FFF repeats into $A000-$BFFF. The 6502 can access the same exact content at either $8001 or $A001 getting to the same result.
  • However the ROM code typically assumes the program is at $A000-$BFFF only and the rest is ignored. However there is at least one case of commercial ROM that erroneously points to the "mirrored" area at $8000-$9FFF.
  • When the console boots, the BIOS at $F800 is accessed, the BIOS program does a few inits, then "jumps" in the ROM1 area somewhere around $A000, then the actual EPROM program starts.
  • The BIOS is needed because it tells you where in the ROM1 space the "jump" is (EPROM vector address). The BIOS ROM is available for download from the CreatiVEmu webwsite at: http://www.madrigaldesign.it/creativemu/roms.php
  • All four Wizzdom fanzines contain a lot of info, too, and are tremendously useful: http://www.madrigaldesign.it/creativemu/fanzines.php
  • On a side note - yes the EPROM die is imo intact, but the "traces" between the "legs" (entire) and the actualdie is what I believe went damaged/cut. The idea was for the MAME collaborator to dump via decap, although a bit ambitious because it is not a masked PROM, but an EPROM so I believe the data in the die could look different at microscope.
I hope this helps and I look forward to seeing *ANY* form of improvement, theories, data, attempts to fix the EPROM etc. Best program to test the ROM is MAME, followed by CreatiVision Emulator and FunnyMu Unofficial (by myself).
Thanks
wizzdom3.pdf bioscv.zip
Edited by MADrigal
Good that the dump was able to be made, but I've always had a difficult time trusting ones made like this without having multiple good redumps from the same source.  Then again, if freezing was necessary, something probably wasn't right with the chip to begin with.
Not a criticism - I completely understand that circumstances dictate things like this at times ;-)
That's unfortunate.
The trick I was alluding to earlier was to take a set of cheap feeler gauges, figure out which one fits in the space where the leg entered the package, and modify it so that it can temporarily replace the leg.  This has been successful for me on (literally) a couple of occasions.
Not sure how well that would work if the die-to-leg wires / traces are severed.  It might be possible to get enough push towards the die on the stub of the old leg that it reestablishes contact, but that also seems like a really easy way to destroy the chip.
I have a suspicion - based on the seemingly-fluctuating nature of pins 1 & 6 - that there may be intermittent contact between the die and legs somewhere.  This is academic given that the EPROM is missing, but it may be worth keeping in mind in case it ever resurfaces.
Thanks for your reply!
Unfortunately the "freezing" method was attempted AFTER the damage to the "traces" had occurred.
I believe the 4K (partial) dump was done with cartridge adaptor before desoldering the EPROM.
All other dumps (8K) were done directly with the EPROM desoldered (and hence, damaged). I attempted to get "a slightly better dump" by freezing it, hoping it would "restore" the traces. I believe that is the "best" of the "bad" dumps overall.
I believe if anyone was able to decap the rom, it could be possible to use a laser to re-solder the DIE to the legs - and the problem would be solved.
Anyway I lost hope about recovering that EPROM. :(
Re gauges: very clever. I use those gauges in my job (diagnostics engineer)
Edited by MADrigal
I gave the first bytes of the 4K ROM a try:
Dump:
    SEG     CODE
    ORG     $1000
    .byte   $22 ;.JAM               ;0
    SRE     ram_B2                  ;5
    ISB     $00|$200,x              ;7
    .byte   $22 ;.JAM               ;0
    ANC     #$36                    ;2
    ISB     $c2ab,x                 ;7
    SAX     ram_FA                  ;3
    SAX     $00|$200                ;4
    tsx                             ;2
    LXA     #$42                    ;2
    rol     ram_FA                  ;5
    .byte   $d2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $32b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $72b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $bab7,x                 ;7
    LXA     #$02                    ;2
    rol     $00|$200                ;6
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $32b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $72b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $22b7,x                 ;7
    SRE     ram_B2                  ;5
    sbc     CXP0FB|$200,x           ;4
    and     #$2e                    ;2
    and     (CXP0FB,x)              ;6
    brk                             ;7   = 159
    rol     VDELBL                  ;5
    RLA     (ram_FF,x)              ;8
    LXA     #$7f                    ;2
    SAX     ram_FB                  ;3
    SAX     $00|$200                ;4
    LXA     #$ff                    ;2
    SAX     ram_FA                  ;3
    SAX     RSYNC|$200              ;4
    inc     ram_FA                  ;5
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     L12b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $a7b7,x                 ;7
    NOP                             ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $c6b7,x                 ;7
    NOP                             ;2
    .byte   $32 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $d2b7,x                 ;7
    SLO     (PF1|$40,x)             ;8
    SRE     $a7b7,x                 ;7
    NOP                             ;2
    SBX     #$ff                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $a2b7,x                 ;7
    SLO     (ram_D6,x)              ;8
    NOP                             ;2
    LAX     ram_FB                  ;3
    SBX     #$7e                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $f6b7,x                 ;7
    NOP                             ;2
    LAX     ram_FB                  ;3
    SBX     #$7f                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $f6b7,x                 ;7
    NOP                             ;2
    .byte   $32 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $eeb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    .byte   $32 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $afb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    SBX     #$82                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $ceb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    .byte   $12 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $afb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    SBX     #$7f                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $feb7,x                 ;7
    SLO     ($00,x)                 ;8   = 275
    .byte   $32 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $afb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    SBX     #$82                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $deb7,x                 ;7
    SLO     ($00,x)                 ;8   =  40
    .byte   $12 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $afb7,x                 ;7
    .byte   $02 ;.JAM               ;0
    .byte   $02 ;.JAM               ;0
    SBX     #$7f                    ;2
    .byte   $f2 ;.JAM               ;0
    SLO     (PF1|$40,x)             ;8
    SRE     $22b7,x                 ;7
    SRE     ram_B2                  ;5
    ISB     $00|$200,x              ;7
    rol                             ;2
    RLA     $ff32                   ;6
    .byte   $22 ;.JAM               ;0
    ISB     (ram_A2),y              ;8
    NOP                             ;2
    ror                             ;2
    ARR     #$13                    ;2
    SAX     RSYNC|$200              ;4
    ror                             ;2
    ARR     #$02                    ;2
    SAX     $00|$200                ;4
    ror     RSYNC|$200              ;6
    SEG     CODE
    ORG     $1000
    jsr     $b045                   ;6
    sbc.wx  $00,x                   ;4
    jsr     $362b                   ;6
    sbc     $c2ab,x                 ;4
    sta     ram_FA                  ;3
    sta.w   $00                     ;4
    clv                             ;2
    lda     #$42                    ;2
    bit     ram_FA                  ;3
    bne     L101b                   ;2/3
    jmp     $b75f                   ;3   =  39
L101b
    bmi     L1020                   ;2/3
    jmp     $b75f                   ;3   =   5
L1020
    bvs     L1025                   ;2/3
    jmp     $b75f                   ;3   =   5
L1025
    tsx                             ;2
    lda     #$02                    ;2
    bit.w   $00                     ;4
    beq     L1030                   ;2/3
    jmp     $b75f                   ;3   =  13
L1030
    bmi     L1035                   ;2/3
    jmp     $b75f                   ;3   =   5
L1035
    bvs     L103a                   ;2/3
    jmp     $b75f                   ;3   =   5
L103a
    jsr     $b247                   ;6
    sbc.wx  $00,x                   ;4
    and     #$2e                    ;2
    and     ($00,x)                 ;6
    brk                             ;7   =  25
L1045
    bit     $07|$20                 ;3
    and     (ram_FF,x)              ;6
    lda     #$7f                    ;2
    sta     ram_FB                  ;3
    sta.w   $00                     ;4
    lda     #$ff                    ;2
    sta     ram_FA                  ;3
    sta.w   $01                     ;4
    inc     ram_FA                  ;5
    beq     L105e                   ;2/3
    jmp     $b75f                   ;3   =  37
L105e
    bpl     L1063                   ;2/3
    jmp     $b75f                   ;3   =   5
L1063
    lda     ram_FA                  ;3
    beq     L106a                   ;2/3
    jmp     $b75f                   ;3   =   8
L106a
    dec     ram_FA                  ;5
    bmi     L1071                   ;2/3
    jmp     $b75f                   ;3   =  10
L1071
    bne     L1076                   ;2/3
    jmp     $b75f                   ;3   =   5
L1076
    lda     ram_FA                  ;3
    cmp     #$ff                    ;2
    beq     L107f                   ;2/3
    jmp     $b75f                   ;3   =  10
L107f
    ldx     #$03                    ;2
    dec     ram_FA,x                ;6
    lda     ram_FB                  ;3
    cmp     #$7e                    ;2
    beq     L108c                   ;2/3
    jmp     $b75f                   ;3   =  18
L108c
    inc     ram_FA,x                ;6
    lda     ram_FB                  ;3
    cmp     #$7f                    ;2
    beq     L1097                   ;2/3
    jmp     $b75f                   ;3   =  16
L1097
    inc     ram_FA,x                ;6
    bmi     L109e                   ;2/3
    jmp     $b75f                   ;3   =  11
L109e
    inc.w   $00                     ;6
    bmi     L10a6                   ;2/3
    jmp     $b75f                   ;3   =  11
L10a6
    lda.w   $00                     ;4
    cmp     #$82                    ;2
    beq     L10b0                   ;2/3
    jmp     $b75f                   ;3   =  11
L10b0
    dec.w   $00                     ;6
    bpl     L10b8                   ;2/3
    jmp     $b75f                   ;3   =  11
L10b8
    lda.w   $00                     ;4
    cmp     #$7f                    ;2
    beq     L10c2                   ;2/3
    jmp     $b75f                   ;3   =  11
L10c2
    inc.wx  $01,x                   ;7
    bmi     L10ca                   ;2/3
    jmp     $b75f                   ;3   =  12
L10ca
    lda.w   $00                     ;4
    cmp     #$82                    ;2
    beq     L10d4                   ;2/3
    jmp     $b75f                   ;3   =  11
L10d4
    dec.wx  $01,x                   ;7
    bpl     L10dc                   ;2/3
    jmp     $b75f                   ;3   =  12
L10dc
    lda.w   $00                     ;4
    cmp     #$7f                    ;2
    beq     L10e6                   ;2/3
    jmp     $b75f                   ;3   =  11
L10e6
    jsr     $b247                   ;6
    sbc.wx  $00,x                   ;4
    rol                             ;2
    and     $ff32                   ;4
    jsr     $a2f3                   ;6
The opcodes should be about right, but the operands are mostly guessed. The code seems to make at least some sense, but nevertheless I think it is hopeless to try to reconstruct manually like this.
