Yaron Nir Posted January 31, 2023 Share Posted January 31, 2023 (edited) Hello Atarians, I've decided to cancel my VBXE tutorial page and focus on this new thread providing a step by step VBXE code example in MADs assembly. I will try to provide as much detail as possible for each step, and will include the things i have picked up in the last few weeks with the good help of good AA members. Without them this would have been possible. i was trying to document the code as much as possible, so if you find areas that are wrong, or missing or you don't understand, let me know and i will try to do a better job..... The outcome of this step by step example is the following screen: What you see here is a a hi-res colorful sprite (that monster dude in the middle), overlaid on an ANTIC 4 character background (yes, ugly!) screen. here is the executable to try it out in your altirra or a real hardware (if you have VBXE installed): vbxe.xex ok, let's do the steps. Pre-step - Understanding the VBXE concept My recommendation is to read the VBXE manual. yes, it is hard to understand but gives you at a high level review of the VBXE and its controls and registers. In short, the VBXE can be looked at as an additional graphic screen layer on top of the ANTIC screen with its own memory control and registers. As A8 presented limitation for PMGs and colors, with VBXE you can create hi res colorful graphics and sprites. One thing I will definately use VBXE for is to write games that has Antic 4 background and as many sprite as I want in VBXE. VBXE memory is 512KB. The memory concept is that, you set a RAM A8 memory pointing to a VBXE virtual memory. The RAM memory is called MEMAC (which is short for memory access). You can freely choose where this RAM memory will reside and how big will it be (4 available sizes: 4KB, 16KB, 32KB, 64KB). To operate in this mode you will need to work with MEMAC-A. On the other hand, there is already a pre-defined RAM memory area and fixed size with the address of $4000 and size of $4000 = 16KB. You will need to work with MEMAC-B for that. In my example, I will work with MEMAC-A, meaning I will set the memory address and size of the RAM. Note: This RAM access is mostly referred as MEMAC window. Although this window is not really visible , it will be your direct communication with VBXE memory. Step 1 - Detecting VBXE Here is a code snippet of a routine(s) written in MADS assembly to detect the VBXE: ;********************************************************* ; proc name: check_vbxe ; purpose: as VBXE board has few versions, we need to ; check if locations $D600 or $D700 are used ; if not --> vbxe is not installed ;********************************************************* .proc check_vbxe ; set $D600 into base address ZP variable mwa #VBXE_D600 VBXE_BASE_ADDR jsr detect_vbxe beq exit_check ; if $D600 was not recognized, check $D700 inc VBXE_BASE_ADDR+1 jsr detect_vbxe beq exit_check ; no VBXE installed --> set to 0 mva #$00 VBXE_BASE_ADDR exit_check rts .endp ;check_vbxe ;********************************************************* ; proc name: detect_vbxe ; purpose: check major (core) and minor versions at ; locations base+40 and base+41 respectively ;********************************************************* .proc detect_vbxe ; check FX 1.xx (location $40) ldy #VBXE_CORE_VERSION lda (VBXE_BASE_ADDR),y cmp #$10 bne exit_detect ; check minor version (location $41) ldy #VBXE_MINOR_VERSION lda (VBXE_BASE_ADDR),y ; the following and was recommended to do in ; the VBXE documentation to avoid minor version differences and #$70 cmp #$20 exit_detect rts .endp; detect_vbxe So, the first step is to check if VBXE is installed. it could be installed in either $D600 or $D700 memory address locations. If it is not, your app can not work and you need to display an error message and exit. From the documentation the way to check if VBXE is installed is as follows: Quote When CORE_VERSION = 0x10 - FX v1.xx is running When CORE_VERSION = 0x11 - GTIA emu v1.xx is running Other values are RESERVED for further core types. The value if VBXE is not present is undefined. That is what the code above does, it compares the CORE register (base+$40) with $10 and the moves to check the minor version. From the documentation: Quote Next thing to do is to read MINOR_REVISION. Bit 7 of this register determines whether its a "a" core (bit cleared), or "r" core (bit set). In most cases this information can be discarded, thus 0x7F AND mask should be applied. Bits 6-0 contain BCD coded revision of the core (ie: 0x26 = core v1.26, 0x06 = core v1.06). Compatible cores have bits 6-4 equal, so software for core FX core v1.20 can should run at core v1.24. That is what the code above does. load the minor register (base +$41) AND with $70 and compare with $20. if none of the above works (for both addresses $D600 and $D700) - no VBXE is installed. once VBXE is detected either in $D600 or $D700 , we store the address in a zero page variable that will be acting as he base address for all VBXE registers. it will be easier later on to load into Y register the desired register load the value into accomulator and store it with y index. example: ldy #VBXE_REGISTER lda #VALUE sta (VBXE_BASE_ADDR),y Step 2 - Disable XDL Here is a code snippet of a routine(s) written in MADS assembly to disable XDL: ; call to disable the XDL enable_xdl #VBXE_VIDEO_CONTROL_XDL_DISABLED . . . . ; call to enable the XDL enable_xdl #VBXE_VIDEO_CONTROL_XDL_ENABLED ;********************************************************* ; proc name: enable_xdl ; parameters: 0=disable, 1=enable ; purpose: sets 0/1 in VBXE video control to enable ; or disable the display ;********************************************************* .proc enable_xdl(.byte x).reg ; x-reg holds enable/disable ; enable/disable XDL ldy #VBXE_VIDEO_CONTROL txa sta (VBXE_BASE_ADDR),y rts .endp ; enable_xdl Setting the VBXE_VIDEO_CONTROL (base+ $40, yes same as the core version, but it is not 'write' rather than 'read') with 0 will disable the XDL and with 1 will enable the XDL. XDL is the display list of VBXE (short for extended display list). it is a list of display controls that basically define the VBXE overlay screen. disabling XDL before do anything else is same as turning ANTIC off. you don't want to see graphics gibberish appearing on screen due to memory setup. Step 3 - Set up VBXE memory access Here is a code snippet of a routine(s) written in MADS assembly to setup the memory access: ;********************************************************* ; proc name: setup_vbxe_memac ; purpose: set up MEMAC-A memory for VBXE ; that means set the address space for it ; choose the access (CPU/VBXE) ; and choose the memory size ;********************************************************* .proc setup_vbxe_memac ;------------------------------------------------------- ; set MEMAC-A memory ; set the MEMAC-A window address ; set CPU access ; set 4K size ;------------------------------------------------------- ldy #VBXE_MEMAC_CTRL lda #(>VBXE_MEMC_WINDOW + MEMC_CPU_ENABLE + MEMC_SIZE_4K) sta (VBXE_BASE_ADDR),y rts .endp ; setup_vbxe_memac As mentioned in the pre-step paragraph, the memory access MEMAC-A allows the developer to define on his own where the RAM of the VBXE memory access will reside. in the code example above I chose VBXE_MEMAC_WINDOW address to be $9000 so I enter the high byte order of this address hence the '>' before the address constant. I am adding the state "CPU ENABLED" and that means that VBXE will be accessed by the CPU. I am also adding the size of the VBXE memory access RAM which is 4KB. Besides CPU access there is also ANTIC access so this value can be either CPU or ANTIC or both (CPU & ANTIC) or none. common practice is to set the MEMAC RAM memory to location $8000. I chose $9000 just from a convenient perspective. Now that we have the VBXE memory access RAM in place (starting at $9000 and with the size of $1000=4KB), that means that the VBXE virtual memory (the entire 512 KB) will be divided into chunks of 4KB, where each chunk will be access through the VBXE memory access ram that point each time to a different virtual location in the VBXE memory space area. the switching between these chunks occurs with bank selection. If the VBXE address space is between $000000-$080000 , if we want to access address $00F000 for example, then we need to switch to bank $0F each bank is aligned to $1000 and if we want to access address $0004DE0 then we switch to bank $04. Step 4 - Set up VBXE XDL Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE XDL: ;********************************************************* ; proc name: setup_vbxe_xdl ; purpose: the XDL defines the screen type ; resolution, scanlines and other ; copy xdl data to MEMAC memory window ; and setup xdl addressed in the vbxe memory ; address space ;********************************************************* .proc setup_vbxe_xdl ; since we're using a standard resolution screen ; with 320x192 pixels, and each pixel takes 1 byte ; the standard resolution screen will take ; the address space $000000-$00EFFF (size of $F000) ; in the VBXE memory address space ; so anything else beside the screen memory ; should be above this address (above $00F000) ; to set this address we need to select the proper bank ; each bank is aligned to $1000 ; set XDL to the $00F000 address ; select bank $0F where the XDL will reside ; and enalbe the MEMAC-A window ; store current bank for later use mva #$0F VBXE_CURRENT_BANK ldy #VBXE_MEM_BANK_SEL lda VBXE_CURRENT_BANK clc adc #MEMAC_GLOBAL_ENABLE sta (VBXE_BASE_ADDR),y ; copy the xdl data into the MEMAC-A window address space ; then set the XDL address to point to the VBXE address ; space that will be used for the XDL ldx #(XDL_DATA_LEN-1) loop lda XDL_DATA,x sta VBXE_MEMC_WINDOW,X dex bpl loop ; as explained above, the XDL in VBXE address space will ; reside in $00F000 and on ; but the XDL data was copied to the MEMAC-A window address ldy #VBXE_XDL_ADR0 ; low byte lda #$00 sta (VBXE_BASE_ADDR),y ldy #VBXE_XDL_ADR1 ; mid byte lda #$F0 sta (VBXE_BASE_ADDR),y ldy #VBXE_XDL_ADR2 ; high byte lda #$00 sta (VBXE_BASE_ADDR),y rts .endp ;setup_vbxe_xdl ;----------------------------------------- ; XDL definition XDL_DATA ; top part of screen, overscan lines ; no overlay and repeat for 23 lines dta XDLC_OVOFF | XDLC_MAPOFF | XDLC_RPTL ; first byte dta $0 ; second byte, not used here dta $17 ; repeat data $17=23 ; main part of the screen the ; graphics mode, repeat for 192 scanlines ; setting overlay address $000000 and step dta XDLC_GMON | XDLC_MAPOFF | XDLC_RPTL | XDLC_OVADR ; first byte dta XDLC_ATT | XDLC_END ; second byte dta $BF ; repeat $BF=191 dta $00 ; overlay address $000000 dta $00 dta $00 dta $40 ; step $140=320 pixels per line dta $01 dta XDLC_ATT_OV_WIDTH_NORMAL | XDLC_ATT_OV_PALETTE_01 ; NORMAL = 320 pixel, and VBXE window takes colors from palette 1 dta XDLC_ATT_MAIN_PRIORITY_OVERLAY_ALL XDL_DATA_LEN equ *-XDL_DATA This example demonstrate the concept of VBXE and the use of XDL. In my memory layout, the VBXE screen is located at VBXE addresses $000000 till $00F000. The XDL should reside immediate after at address $00F000. in order to point to the address $00F000 , we need to switch the VBXE memory access to "point" to this address. we do this by bank selection (switching to bank $0F). We copy the XDL to reside in this address $00F000 and we set the VBXE XDL address registers to point to this address (3 bytes = low , mid, high) This example what comprises the XDL. The XDL "describes" the VBXE screen that will be used. in my example the screen has 2 parts. a top overscan part (24 scanlines) with no VBXE usage and a standard resolution screen 320x192 pixels, where the VBXE screen address for this screen is set to $000000 VBXE address space, and it will use palette #1 (and not #0 as the we want ANTIC mode 4 playfield colors to still be changed with the ANTIC PF registers) , we also define the VBXE screen priority to be on top of everything else (PMGs and PFs). in XDL, you first define the XDL controls (XDLC) which are basically the attributes you wish to use, then you set the values for these attributes. Quote dta XDLC_OVOFF | XDLC_MAPOFF | XDLC_RPTL ; first byte dta $0 ; second byte, not used here dta $17 ; repeat data $17=23 The first byte sets the XDL controls: VBXE overlay off - no VBXE usage MAPOFF=disable the color map RPTL = repeating it for 23 next scanlines The second byte also sets XDL controls, but i don't need any here so not in use The third byte sets the control values: RPTL =repeat 23 more scanlines all together 24 Quote dta XDLC_GMON | XDLC_MAPOFF | XDLC_RPTL | XDLC_OVADR ; first byte dta XDLC_ATT | XDLC_END ; second byte dta $BF ; repeat $BF=191 dta $00 ; overlay address $000000 dta $00 dta $00 dta $40 ; step $140=320 pixels per line dta $01 dta XDLC_ATT_OV_WIDTH_NORMAL | XDLC_ATT_OV_PALETTE_01 ; NORMAL = 320 pixel, and VBXE window takes colors from palette 1 dta XDLC_ATT_MAIN_PRIORITY_OVERLAY_ALL GMON=set graphics mode rather than text mode with fonts and charset(s) MAPOFF=disable color attributes RPTL = repeat scanlines $BF = 191 lines , in total 192. (always use Desired-1) OVADR = the VBXE screen start address (3 bytes) $00-00-00. ATT = other screen attributes such as screen width normal (320 pixels) and palette use (#1) and priority (over all) END = the last XDL line to indicate its end. will wait for VBLANK and then start again from the top of XDL (same as in ANTIC display list) Step 5 - Set up VBXE Palette Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE XDL: ;********************************************************* ; proc name: setup_vbxe_palette ; purpose: copy the rgb palette bin file ; data into VBXE memory ;********************************************************* .proc setup_vbxe_palette ; the sprite sheet data contains rgb color data as well ; this is reflected in the palette bin file ; copy the palette bin file data into VBXE rgb registers ; the rgb bin file contains 256 values for ; r,g and b respectively, we copy all of them ; start from palette 1 and color 0 ; palette 1 as we want to use ANTIC background under ; the VBXE and if you choose palette 0 it impact the ; playfield colors of ANTIC ; select palette 1 ldy #VBXE_PSEL lda #1 sta (VBXE_BASE_ADDR),y ; select color 0 ldy #VBXE_CSEL lda #0 sta (VBXE_BASE_ADDR),y ; loop all rgb values ldx #0 loop_rgb ; red ldy #VBXE_CR lda palette_bin,x sta (VBXE_BASE_ADDR),y ; green ldy #VBXE_CG lda palette_bin+$100,x sta (VBXE_BASE_ADDR),y ; blue ldy #VBXE_CB lda palette_bin+$100+$100,x sta (VBXE_BASE_ADDR),y ; color selection (VBXE_CSEL) will increment automatically inx bne loop_rgb rts .endp ;setup_vbxe_palette The code sets the palette to 0 and copy the RGB bin array into the colors registers. there are 256 Reds, 256 Greens, 256 Blues. that is why i use + $100 between each color register. What is the palette? Well, it is the RGB color list that our graphics will use in the VBXE screen. since I am using VBXE to blit sprite on screen, the palette should be the RGB list of colors of the sprite frames. my project contains a file called palette_monster.bin. This file was extracted from my sprite sheet image using a python script. the script reads each pixel in the image and creates the RGB list and convert it into 1 byte array. then you need to copy this byte array of RGB colors into the VBXE palette registers. so first you chose to which palette you want to assign these colors RGBs. I chose palette #1. the reason for that is since i am blitting the sprite over ANTIC mode 4 background, I want to still be able to change the PF colors of that background fields. If I would have chosen palette #0 then the PF color registers would have impacted by the RGB color list I have loaded and that is not good. you also need to set the transparent color RGB. so in my example the sprite is drawn over the ANTIC mode 4 background. I chose black to be the transparent color. Black RGB is 0,0,0. I needed to make sure it was set as the first color in the palette (python script did that) in order for the VBXE use that as the transparency color. Step 6 - Set up VBXE clear screen blitter Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE clear screen blitter: ;********************************************************* ; proc name: setup_vbxe_clear_screen_bcb ; purpose: set up the ZP_SRC to bcb clear screen data ; set up the vbxe address to $00F00E ; the bank will be $0F as the MEMAC window is set ; to 4K size so all banks addresses are ; aligned with $1000 ;********************************************************* .proc setup_vbxe_clear_screen_bcb ; copy the blitter address to ZP source varialbe mwa #BCB_CLEAR_SCREEN ZP_SRC ; set blitter block to $00F00E mva #$0E VBXE_MEM_ADDR mva #$F0 VBXE_MEM_ADDR+1 mva #$00 VBXE_MEM_ADDR+2 jsr setup_vbxe_blitter_block rts .endp ;setup_vbxe_clear_screen_bcb ;********************************************************* ; proc name: setup_vbxe_blitter_block ; purpose: you need to set before calling this proc ; ZP_SRC and 3 bytes for VBXE_MEM_ADDR ; from the VBXE 3 bytes address ; we take the bank , and set it ; and we set the ZP_DST ; and the 3 bytes blitter address ;********************************************************* .proc setup_vbxe_blitter_block ; source was set before the call to this proc ; set the destination ; the VBXE address is with this format ex. $00-F0-00 ; we need to get the half part of the high byte ; and half part of the mid byte to select the proper ; VBXE bank ; load mid byte lda VBXE_MEM_ADDR+1 ; store it temporary sta ZP_TMP ; load high byte lda VBXE_MEM_ADDR+2 ; 4 shifts 4 rolls to get the half byte and half byte asl ZP_TMP rol asl ZP_TMP rol asl ZP_TMP rol asl ZP_TMP rol ; select the bank for this address of VBXE ; restore current bank back ldy #VBXE_MEM_BANK_SEL ; acc holds the bank clc adc #MEMAC_GLOBAL_ENABLE sta (VBXE_BASE_ADDR),y ; we need to add to the MEMAC-A window the offset ; of the VBXE address lda VBXE_MEM_ADDR sta ZP_DST lda VBXE_MEM_ADDR+1 ; extrac the 3rd digit and #$0F ora #>VBXE_MEMC_WINDOW sta ZP_DST+1 ; loop copy ldy #BCB_SIZE-1 copy_loop lda (ZP_SRC),y sta (ZP_DST),y dey bpl copy_loop ; set the blitter address in VBXE memory address space ; VBXE_MEM_ADDR ldy #VBXE_BL_ADR0 ; low byte lda VBXE_MEM_ADDR sta (VBXE_BASE_ADDR),y ldy #VBXE_BL_ADR1 ; mid byte lda VBXE_MEM_ADDR+1 sta (VBXE_BASE_ADDR),y ldy #VBXE_BL_ADR2 ; high byte lda VBXE_MEM_ADDR+2 sta (VBXE_BASE_ADDR),y ; restore current bank back ldy #VBXE_MEM_BANK_SEL lda VBXE_CURRENT_BANK clc adc #MEMAC_GLOBAL_ENABLE sta (VBXE_BASE_ADDR),y rts .endp ;setup_vbxe_blitter_block ;----------------------------------------------- ; blit data for clear screen ;----------------------------------------------- BCB_CLEAR_SCREEN ; BCB is 21 bytes long ; 3 bytes = no source - ignored dta $00 dta $00 dta $00 ; step Y - each change of Y - ignored dta a($0000) ; step X - each change of X - ignored dta $0 ; the address of the VBXE screen top left dta $00 dta $00 dta $00 ; step Y - screen width in pixels $140 (320) dta a($140) ; step X - 1 pixel dta $01 ; width of blitter to copy dta a($140 - 1) ; height of blitter to copy dta $C0-$1 ; AND mask for source dta $00 ; XOR mask for source dta $00 ; AND mask collision detection - ignored dta $00 ; ZOOM value X-Axis Y-Axis - ignored dta $00 ; Pattern fill - ignored dta $00 ; blt ctrl - ignored dta $00 BCB_SIZE equ 21 What is a blitter? Well, it is a fast way to copy things into memory. the usages are mostly to erase, update and draw the graphics on the VBXE screen. The way the blitter work, is you define a blitter control block and you copy it into the VBXE address space and then set the blitter address to point to the VBXE address space where the blitter resides. In order to copy the blitter into the VBXE address space you will need 2 parameters: source=blitter data to copy destination=the VBXE memory address where the blitter block will reside. This code example for clear screen is used to clear the entire VBXE visible screen. and that means, we place transparent color ($00) into the screen memory of the visible VBXE screen which is from address $000000 to $00F000 (320x192 pixels) Source = our blitter block data Destination= VBXE memory , $00F00E. why do we place it at $00F00E? if you recal we have placed the XDL in the address $00F000. XDL size is with the size of $0D. so we can use $0E low byte as the right place to set the blitter block. we use a zero page address (3 bytes) and we store in it the high, mid and low parts of the address to be used to copy the blitter. As explained in early steps, to access memory we need to switch the bank to point to that memory. in our case the bank is $0F as before. but since my code can interpret any address, we extract the bank from the zero page 3 byte address. We select the proper Bank and also we make sure the MEMAC memory access is enabled (we add this flag to the select bank register). We set the destination in the MEMAC-A access memory to the same offset as we explained above ($0E). We loop and copy the data from source to destination. last thing remaining to do is point the blitter block register to the correct address space in VBXE (including the offset $0E). Quote ; BCB is 21 bytes long ; 3 bytes = no source - ignored dta $00 dta $00 dta $00 ; step Y - each change of Y - ignored dta a($0000) ; step X - each change of X - ignored dta $0 ; the address of the VBXE screen top left dta $00 dta $00 dta $00 ; step Y - screen width in pixels $140 (320) dta a($140) ; step X - 1 pixel dta $01 ; width of blitter to copy dta a($140 - 1) ; height of blitter to copy dta $C0-$1 ; AND mask for source dta $00 ; XOR mask for source dta $00 ; AND mask collision detection - ignored dta $00 ; ZOOM value X-Axis Y-Axis - ignored dta $00 ; Pattern fill - ignored dta $00 ; blt ctrl - ignored dta $00 BCB_SIZE equ 21 Each blitter block is always 21 bytes long. source address 3 byte = ignored, as we're clearing the screen there is no source step y 2 bytes = for source, also ignored step x 1 bytes = for source, also ignored add 3 bytes = top left of the VBXE screen (in our case $000000) step y 2 bytes = for our screen, 320 pixels ($140, we always do Desire-1) step x 1 bytes = for our screen, 192 ($C0, we always do Desire-1) AND mask = not in use as we do not have source. keep it $00 XOR mask = the desired outcome, we want to place the transparent color $00 in each byte. so we XOR with this color COLLISION mask = ignored . keep $00 ZOOM = ignored. keep $00. you can use zoom for faster memset operation, but i am not using it here. PATTERN FILL= ignored. keep $00 BLT CONTROL=ignored. keep $00 Step 7 - Start the blitter Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE clear screen blitter: ;********************************************************* ; proc name: start_blitter ; purpose: once blitter is free (not busy) ; start ;********************************************************* .proc start_blitter ; first wait for blitter busy to finish jsr wait_for_blitter ldy #VBXE_BLITTER_START lda #$01 sta (VBXE_BASE_ADDR),y rts .endp ; start_blitter ;********************************************************* ; proc name: wait_for_blitter ; purpose: read the register BLITTER BUSY ; and wait till its not busy anymore ;********************************************************* .proc wait_for_blitter ; read the blitter busy register ; if it is 0 -->it is ready ldy #VBXE_BLITTER_BUSY do_wait lda (VBXE_BASE_ADDR),y bne do_wait rts .endp ; wait_for_blitter There could be other blitters at work, so we must wait until blitter is ready to be used. we test the blitter busy register (base + $53) , read operation, and when it is 0 the blitter is ready to process another block. to start the blitter we set 1 to the blitter start register (base + $53), this time write operation. Note: It is recommended to clear the screen before your main loop and do it one time only. If you don't clear your screen, you may see garbage appearing and that is not desired. Step 8 - copy sprite sheet data into VBXE memory Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE clear screen blitter: ;********************************************************* ; proc name: setup_vbxe_sprite_data ; purpose: copy the sprite bin file data ; into MEMAC-A window memory ; take into account the MEMAC-A window size ; you have defined and see if the sprite sheet ; does not exceed that ;********************************************************* .proc setup_vbxe_sprite_data ; copy the sprite into the MEMAC-A VBXE address ; the offset needs to take into account the XDL ; and the blitter blocks so we set the address ; to be the MEMAC-A window address + $100 as offset ; $100 is enough as we only have 2 blitter blocks ; that takes 2x21 = 42 bytes ; set the bin file hi byte address ; into a ZP source variable mwa #sprite_data ZP_SRC ; set the MEMAC-A window + offset($100) address ; into a ZP destination variable lda #0 sta ZP_DST lda #>(VBXE_MEMC_WINDOW + $100) sta ZP_DST + 1 ; loop sprite height ldx #SPRITE_HEIGHT copy_sprite_row_loop ldy #SPRITE_HEIGHT-1 copy_sprite_byte_loop lda (ZP_SRC),y sta (ZP_DST),y dey bpl copy_sprite_byte_loop clc lda ZP_SRC adc #SPRITE_WIDTH sta ZP_SRC lda ZP_SRC + 1 adc #0 sta ZP_SRC + 1 clc lda ZP_DST adc #SPRITE_WIDTH sta ZP_DST lda ZP_DST + 1 adc #0 sta ZP_DST + 1 dex bne copy_sprite_row_loop rts .endp ;setup_vbxe_sprite_data We copy the sprite sheet data into the MEMAC-A memory access area, so we can later create a blitter block to blit it on screen I've placed it in MEMAC-A memory + $100 as it was enough right after XDL and 2 blitter blocks (one will be listed in the next steps). you can use offset at the exact memory point right after XDL ($0D) blitter 1 ($23) blitter 2 ($38) so you could place it in base+$39 if you want. source = sprite data. what is that? it is a bin file created outside the program using python again and basically reading the image and getting the pixels from it and storing it in a byte array. we copy the byte array into MEMAC-A memory access addresses. each sprite has a width and a height. there could be several frames per sprite in one sprite sheet. It is recommended to set all your sprite of the game in one sheet so you can set the color palette and sprite data once. destination=MEMAC-A memory access + $100. Now whenever we want we can blit this sprite onto the screen. Step 9 - blit sprite on VBXE screen Here is a code snippet of a routine(s) written in MADS assembly to setup the VBXE clear screen blitter: ;********************************************************* ; proc name: setup_vbxe_sprite_draw_bcb ; purpose: set up the ZP_SRC to bcb sprite draw data ; set up the vbxe address to $00F023 ; each blitter block is 21 bytes and last ; block was set to $00F00E ; the bank will be $0F again as the MEMAC window is set ; to 4K size so all banks addresses are ; aligned with $1000 ;********************************************************* .proc setup_vbxe_sprite_draw_bcb ; copy the blitter address to ZP source varialbe mwa #BCB_SPRITE_DRAW ZP_SRC ; set blitter block to $00F00E mva #$23 VBXE_MEM_ADDR mva #$F0 VBXE_MEM_ADDR+1 mva #$00 VBXE_MEM_ADDR+2 jsr setup_vbxe_blitter_block rts .endp ;setup_vbxe_sprite_draw_bcb ;----------------------------------------------- ; blit data for "sprite" ;----------------------------------------------- BCB_SPRITE_DRAW ; BCB is 21 bytes long ; 3 bytes = address of the sprite data we are copying ; our sprite resides in VBXE memory $00F100 dta $00 dta $F1 dta $00 ; step Y - sprite width for each change of Y dta a(SPRITE_WIDTH) ; step X - step 1 byte each change of X dta $1 ; the address of middle of the VBXE visible screen dta $80 dta $50 dta $00 ; step Y - screen width in pixels $140 (320) dta a($140) dta $1 ; width of blitter to copy dta a(SPRITE_WIDTH - 1) ; height of blitter to copy dta SPRITE_HEIGHT - 1 ; AND mask for source dta $FF ; XOR mask for source dta $00 ; AND mask collision detection dta $00 ; ZOOM value X-Axis Y-Axis dta $00 ; Pattern fill dta $00 dta $01 So once again we create a blitter block this time to copy the sprite data from MEMAC-A + $100 memory space to the VBXE screen address space. let's review the blitter block: (Each blitter block is always 21 bytes long) source address 3 byte = now our source will be our sprite data in VBXE memory address space ($00F100) step y 2 bytes = sprite width (always use Desired-1) step x 1 bytes = always 1 pixel ($1) add 3 bytes = destination middle of the VBXE screen (in our case $005080) step y 2 bytes = step of the scree ($140=320 pixels) to move to the next row to draw the sprite. step x 1 bytes = always 1 pixel ($1) AND mask = $FF, in order not to change the sprite data XOR mask = $00, in order not to change the sprite data COLLISION mask = ignored . keep $00 ZOOM = ignored. keep $00. PATTERN FILL= ignored. keep $00 BLT CONTROL=$1 , the main blitter mode. copy source to destination Don't forget to call: jsr start_blitter In order to start the blitter. Other things in my example to consider The DLIST is ANTIC mode 4. the background charset and map are bin files exported from charpad app. Here is the zipped source code. vbxe_step_by_step_example.zip Just run build command in your IDE and that will compile and runt the example. Special thanks to @popmilo who helped me creating this demo. and also to @phaeronwho helped me overcome some of my hurdles. Hope it will be beneficial to you. Cheers, Yaron Edited January 31, 2023 by Yaron Nir 3 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted January 31, 2023 Share Posted January 31, 2023 maybe you could show us the step by step of the two or so games you are working on, getting use of all aspects a 3 for. WonderBoy a Journey into programming with MADS... WonderBoyVBXE a Journey into video extension programming with MADS etc etc. then your are teaching/tutoring while completing your projects at the same time. Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted January 31, 2023 Author Share Posted January 31, 2023 32 minutes ago, _The Doctor__ said: maybe you could show us the step by step of the two or so games you are working on, getting use of all aspects a 3 for. WonderBoy a Journey into programming with MADS... WonderBoyVBXE a Journey into video extension programming with MADS etc etc. then your are teaching/tutoring while completing your projects at the same time. that is a nice thought. I am just experiencing with VBXE so not sure if and how this will go for a full game. wonderboy is in progress but going slowly as there are others involved in this project and there are some setbacks. dragon master is almost ready - for level 1 and once i will be done with VBXE i will release it. 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted January 31, 2023 Author Share Posted January 31, 2023 i am gradually editing the steps that is why you see partial work in the first post. i will send a final message once the steps are done 1 1 Quote Link to comment Share on other sites More sharing options...
Yaron Nir Posted January 31, 2023 Author Share Posted January 31, 2023 Ok, steps are completed. source code also attached. 2 1 Quote Link to comment Share on other sites More sharing options...
