mozzwald Posted February 8 Share Posted February 8 A vulnerability has been found in the TNFSD server that can allow a person to get directory listings outside of the configured TNFS root directory. We were notified of the issue on Jan 31, 2023 and have been working on a fix since that time. The fix is now available as source code and binaries in our Github repo (https://github.com/FujiNetWIFI/spectranet). Binaries at https://fujinet.online/download have also been updated. Anyone running a publicly available TNFS server should update their TNFSD server immediately. The issue occurs when requesting a directory listing with ".." which can allow viewing the file listing in directories above the TNFS root. In our testing we were not able to download or view contents of any files outside of the TNFS root, only get directory listings. The bugfix compares the absolute path of the TNFS root directory with the absolute path of the requested directory and if the requested directory is not inside the TNFS root it will return a listing of the root directory instead. This has been tested on Windows 10 64Bit, Linux 64bit and Raspberry Pi 3B+ armhf. We have also overlooked the fact that the Linux version of TNFSD has built in chroot capabilities already which would prevent this bug from happening in the old vulnerable version. Linux users can run the server with the '-c [username]' flag to start it in it's own chroot (ex: sudo tnfsd /home/tnfs -c tnfs) and we recommend using this option going forward. Windows users do not have the chroot option and must use the updated TNFSD binary. For Linux users running the server with systemd, this is an example script with chroot: [Unit] Description=TNFS Server After=remote-fs.target After=syslog.target # replace /tnfs with your TNFS directory [Service] User=root Group=root ExecStart=/usr/local/sbin/tnfsd /tnfs -c tnfs [Install] WantedBy=multi-user.target We hope our transparency and action to fix the issue shows our commitment to security and to keeping your trust. Thank you for your understanding. 5 1 Quote Link to comment Share on other sites More sharing options...
tsom Posted February 8 Share Posted February 8 I installed my TNFS server onto my raspberry pi using the packaged image posted on here, somewhere (I forget who had set it up). It has a "tnfsupd" script that looks to go out to Github and update itself. It looks like it successfully did, but I'm not sure how to tell if it's the latest version: ``` pi@tnfs:~ $ sudo tnfsupd Stopping TNFSD Updating TNFSD fom GitHub Restarting TNFSD pi@tnfs:~ $ tnfsd -v Starting tnfsd version 20.1115.2 using root directory "-v" Unable to bind ``` My systemd setup has this: ``` [Service] User=tnfs Group=tnfs ExecStart=/usr/local/sbin/tnfsd /tnfs ``` I assume it's ok? (it's also not visible outside my network, so it may be a moot point) Also, looking at the GitHub link, the releases linked there look very old Just want to make sure the latest version is available. Thanks! Quote Link to comment Share on other sites More sharing options...
tsom Posted February 8 Share Posted February 8 Well, the script didn't do the update, as it assumes the code was already downloaded. I ended up doing the steps in the script manually, after cloning the repo and was able to update my local server. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 8 Author Share Posted February 8 @tsom the latest version is 23.0207.1 which is displayed when started. Quote Link to comment Share on other sites More sharing options...
tsom Posted February 8 Share Posted February 8 (edited) Yep. All good now: ``` pi@tnfs:~ $ systemctl status tnfsd ● tnfsd.service - TNFS Server Loaded: loaded (/etc/systemd/system/tnfsd.service; enabled; vendor preset: enabled) Active: active (running) since Wed 2023-02-08 08:47:19 EST; 2h 7min ago Main PID: 29144 (tnfsd) Tasks: 1 (limit: 2178) CGroup: /system.slice/tnfsd.service └─29144 /usr/local/sbin/tnfsd /tnfs Feb 08 08:47:19 tnfs systemd[1]: Started TNFS Server. Feb 08 08:47:19 tnfs tnfsd[29144]: setroot real path: /tnfs Feb 08 08:47:19 tnfs tnfsd[29144]: Starting tnfsd version 23.0207.1 using root directory "/tnfs" ``` Edited February 8 by tsom 1 Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 13 Share Posted February 13 Dumb question. Would this be an issue on a tnfs server running in a docker container? If so will an updated container image be available? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 13 Author Share Posted February 13 41 minutes ago, moonlight_mile said: Dumb question. Would this be an issue on a tnfs server running in a docker container? If so will an updated container image be available? This would be an issue with any way you run the old TNFS server. I not that familiar with docker. Maybe you can just shut it down and replace the binary inside the container? Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 14 Share Posted February 14 I will just take down the Alcatraz server until I can figure out how to update the binary. Pretty busy now. Will work on it. thanks! Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 14 Share Posted February 14 (edited) is it noted who made the docker versions? might be in the threads somewhere. maybe they can do it again, or give a step by step on what a person needs to do in order to create their own from here on out. Edited February 14 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 14 Share Posted February 14 Thomas cherryholmes I am pretty sure. Tschak909 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted February 14 Share Posted February 14 (edited) Sounds like it should be or should have been handled already, I'd give him PM, DM, or Discord shout etc. Seems someone pointed issues of this nature out back when this was all chugging along, So it would be good to see such stuff being addressed. Edited February 14 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 14 Share Posted February 14 I know I pulled a newer version of the container image I just haven’t had a chance to look into it too closely. Let me know if the “-latest” version has the bug fix in it. thanks! Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 14 Author Share Posted February 14 @moonlight_mile the x64 docker image was update by @tschak909 https://hub.docker.com/r/tschak909/tnfsd-x64 1 Quote Link to comment Share on other sites More sharing options...
moonlight_mile Posted February 14 Share Posted February 14 That was the one I downloaded. Thanks so much. I will deploy it asap. 1 Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted February 19 Share Posted February 19 On 2/8/2023 at 7:32 AM, tsom said: I installed my TNFS server onto my raspberry pi using the packaged image posted on here, somewhere (I forget who had set it up). It has a "tnfsupd" script that looks to go out to Github and update itself. It looks like it successfully did, but I'm not sure how to tell if it's the latest version: ``` pi@tnfs:~ $ sudo tnfsupd Stopping TNFSD Updating TNFSD fom GitHub Restarting TNFSD pi@tnfs:~ $ tnfsd -v Starting tnfsd version 20.1115.2 using root directory "-v" Unable to bind 20.1115.2 is outdated. 23.0207.1 is current as of this writing; I just built it out of the source repo, so it's definitely the latest. If you do a `systemctl status tnfsd`, you should see the following output if you're up to date: ● tnfsd.service - tnfs Daemon Loaded: loaded (/etc/systemd/system/tnfsd.service; enabled; vendor preset:> Active: active (running) since Sun 2023-02-19 07:44:18 CST; 1min 13s ago Main PID: 45768 (tnfsd) Tasks: 1 (limit: 4675) Memory: 176.0K CPU: 1ms CGroup: /system.slice/tnfsd.service └─45768 /usr/local/bin/tnfsd /mnt/tnfs/atari/ Feb 19 07:44:18 tnfs systemd[1]: Started tnfs Daemon. Feb 19 07:44:18 tnfs tnfsd[45768]: Starting tnfsd version 23.0207.1 using root On 2/8/2023 at 7:32 AM, tsom said: My systemd setup has this: ``` [Service] User=tnfs Group=tnfs ExecStart=/usr/local/sbin/tnfsd /tnfs ``` Sort of. I'd strongly recommend starting tnfsd with the -c option, however. More: On 2/8/2023 at 7:32 AM, tsom said: I assume it's ok? (it's also not visible outside my network, so it may be a moot point) Your network so your call, but it's generally not good practice to leave known vulnerabilities unmitigated once they are discovered and confirmed present in the environment. You'll need weigh the risk of patching vs. not patching for yourself, but if I were in your shoes I'd absolutely do it, public-facing server or not. Getting back to the systemd service file configuration for a moment: while it can be equivalent to starting tnfsd with the -c option, that is also going to be dependent on certain external factors. Most relevant will be file ownership and permissions on /tnfs, which users are part of the tnfs group, whether or not those users have login capabilities, etc. Assuming that all of these items (and others) are addressed properly, then yes, that configuration should be OK. However, given that tnfsd now specifies a best practice for both the configuration of its service file as well as a startup method, it's probably easiest to move to doing things the current way. Chances are solid that it's not going to revert to the old method. Note that I'm not using the RasPi build, so am not aware of how it may have been configured in regards to the items I've mentioned. Knowing who put it together, however, it's a fairly safe bet that it was done properly. On 2/8/2023 at 7:32 AM, tsom said: Also, looking at the GitHub link, the releases linked there look very old Looks updated to me - check the FujiNetWIFI/spectranet Github page, which should show the tnfsd directory is as having been updated two weeks ago, which is correct based on when I'm writing this. To be fair, it's easy to miss given the number of things around it that haven't been touched as recently. Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted February 19 Share Posted February 19 On 2/7/2023 at 7:50 PM, mozzwald said: We hope our transparency and action to fix the issue shows our commitment to security and to keeping your trust. Thank you for your understanding. My thanks to everyone who handled this. Seeing a solid commitment to security is a huge positive for the project. Out of curiosity, has anyone looked into the possibility of having tnfsd included in some distros' official repos? That would help with the updating aspect, for sure, and potentially widen the userbase. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 20 Share Posted February 20 On 2/19/2023 at 8:37 AM, x=usr(1536) said: My thanks to everyone who handled this. Seeing a solid commitment to security is a huge positive for the project. Out of curiosity, has anyone looked into the possibility of having tnfsd included in some distros' official repos? That would help with the updating aspect, for sure, and potentially widen the userbase. If you can help there, please do so. -Thom Quote Link to comment Share on other sites More sharing options...
E474 Posted February 20 Share Posted February 20 Hi, Newbie question. I have an RPi (3B) install from source from Jan 2022. Do I do: $ git clone https://github.com/FujiNetWIFI/spectranet to over-write the existing (outdated) sources, or should I just delete the current sources and redo the git clone? Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted February 20 Share Posted February 20 1 hour ago, tschak909 said: If you can help there, please do so. That's actually something I've never had to do before Let me see if I can't figure it out; I'm actually curious as to how that process works and the worst that happens is that I get a bunch of 'no' responses. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 20 Share Posted February 20 1 hour ago, E474 said: Hi, Newbie question. I have an RPi (3B) install from source from Jan 2022. Do I do: $ git clone https://github.com/FujiNetWIFI/spectranet to over-write the existing (outdated) sources, or should I just delete the current sources and redo the git clone? if you cloned from git? $ git pull -Thom Quote Link to comment Share on other sites More sharing options...
E474 Posted February 22 Share Posted February 22 Hi @tschak909, Thanks very much for the info. Unfortunately I've encountered some problems, I'm assuming this is a user error, but giving feedback in case otherwise: pi@pi3bp2:~/spectranet $ git pull hint: Pulling without specifying how to reconcile divergent branches is hint: discouraged. You can squelch this message by running one of the following hint: commands sometime before your next pull: hint: hint: git config pull.rebase false # merge (the default strategy) hint: git config pull.rebase true # rebase hint: git config pull.ff only # fast-forward only hint: hint: You can replace "git config" with "git config --global" to set a default hint: preference for all repositories. You can also pass --rebase, --no-rebase, hint: or --ff-only on the command line to override the configured default per hint: invocation. remote: Enumerating objects: 43, done. remote: Counting objects: 100% (43/43), done. remote: Compressing objects: 100% (25/25), done. remote: Total 43 (delta 25), reused 34 (delta 18), pack-reused 0 Unpacking objects: 100% (43/43), 263.62 KiB | 629.00 KiB/s, done. From https://github.com/FujiNetWIFI/spectranet 4157ecb..95c5b55 master -> origin/master Updating 4157ecb..95c5b55 error: Your local changes to the following files would be overwritten by merge: tnfs/tnfsd/bin/tnfsd Please commit your changes or stash them before you merge. Aborting I figured it was simplest to remove the binary it was complaining about, after which it worked, as shown below: pi@pi3bp2:~/spectranet $ git pull hint: Pulling without specifying how to reconcile divergent branches is hint: discouraged. You can squelch this message by running one of the following hint: commands sometime before your next pull: hint: hint: git config pull.rebase false # merge (the default strategy) hint: git config pull.rebase true # rebase hint: git config pull.ff only # fast-forward only hint: hint: You can replace "git config" with "git config --global" to set a default hint: preference for all repositories. You can also pass --rebase, --no-rebase, hint: or --ff-only on the command line to override the configured default per hint: invocation. Updating 4157ecb..95c5b55 Fast-forward tnfs/tnfsd/bin/tnfsd | Bin 85560 -> 0 bytes tnfs/tnfsd/bin/tnfsd.armhf | Bin 0 -> 79860 bytes tnfs/tnfsd/bin/tnfsd.exe | Bin 294364 -> 368984 bytes tnfs/tnfsd/bin/tnfsd.linux64 | Bin 0 -> 96840 bytes tnfs/tnfsd/datagram.c | 21 ++++++++++++++++----- tnfs/tnfsd/datagram.h | 1 + tnfs/tnfsd/directory.c | 72 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------- tnfs/tnfsd/directory.h | 5 ++++- tnfs/tnfsd/errortable.h | 1 + tnfs/tnfsd/main.c | 2 +- tnfs/tnfsd/tnfs_file.c | 23 +++++++++++++++++++++-- 11 files changed, 109 insertions(+), 16 deletions(-) delete mode 100755 tnfs/tnfsd/bin/tnfsd create mode 100644 tnfs/tnfsd/bin/tnfsd.armhf mode change 100644 => 100755 tnfs/tnfsd/bin/tnfsd.exe create mode 100755 tnfs/tnfsd/bin/tnfsd.linux64 Then, following on from the instructions at: https://github.com/FujiNetWIFI/spectranet - I did a make, but got: pi@pi3bp2:~/spectranet $ make make -C syslib make[1]: Entering directory '/home/pi/spectranet/syslib' z80-unknown-coff-as -I../include ui_menu.asm -o ui_menu.o make[1]: z80-unknown-coff-as: No such file or directory make[1]: *** [Makefile:46: ui_menu.o] Error 127 make[1]: Leaving directory '/home/pi/spectranet/syslib' make: *** [Makefile:15: syslib] Error 2 I tried make clean: for dir in syslib rom modules installer utils; do \ make -C $dir clean; \ done make[1]: Entering directory '/home/pi/spectranet/syslib' rm -f -f *.o *.a make[1]: Leaving directory '/home/pi/spectranet/syslib' make[1]: Entering directory '/home/pi/spectranet/rom' rm -f *.o *.module *.bin *.map *.xinc *.tzx *.tap make[1]: Leaving directory '/home/pi/spectranet/rom' make[1]: Entering directory '/home/pi/spectranet/modules' for dir in snapman messages config basext streams allram; do \ make -C $dir clean; \ done make[2]: Entering directory '/home/pi/spectranet/modules/snapman' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/snapman' make[2]: Entering directory '/home/pi/spectranet/modules/messages' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/messages' make[2]: Entering directory '/home/pi/spectranet/modules/config' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/config' make[2]: Entering directory '/home/pi/spectranet/modules/basext' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/basext' make[2]: Entering directory '/home/pi/spectranet/modules/streams' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/streams' make[2]: Entering directory '/home/pi/spectranet/modules/allram' rm -f *.o *.module *.bin *.map make[2]: Leaving directory '/home/pi/spectranet/modules/allram' make[1]: Leaving directory '/home/pi/spectranet/modules' make[1]: Entering directory '/home/pi/spectranet/installer' rm -f *.o *.module *.bin *.map *.xinc *.tzx *.tap make[1]: Leaving directory '/home/pi/spectranet/installer' make[1]: Entering directory '/home/pi/spectranet/utils' rm -f bin2tape bin2tape.o configserv configserv.o make[1]: Leaving directory '/home/pi/spectranet/utils' Then tried make again, but got the same as previously: pi@pi3bp2:~/spectranet $ make make -C syslib make[1]: Entering directory '/home/pi/spectranet/syslib' z80-unknown-coff-as -I../include ui_menu.asm -o ui_menu.o make[1]: z80-unknown-coff-as: No such file or directory make[1]: *** [Makefile:46: ui_menu.o] Error 127 make[1]: Leaving directory '/home/pi/spectranet/syslib' make: *** [Makefile:15: syslib] Error 2 I figure I am missing the assembler, but I'm not sure what the correct dependencies/packages are, and I couldn't find anything in the README.TXT at https://github.com/FujiNetWIFI/spectranet I'm reasonably sure the previous install was from git, but can't be 100% certain as it was over a year ago (there was a .git folder there already, I assume that's not included in the .zip). I tested that the tnfsd server worked by booting via FujiNet-PC before starting the upgrade, so I'm sure it was working originally. Any help would be appreciated, I'm expecting it's a user error, but don't want to guesswork my way to in incorrect, but working, fix. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 23 Author Share Posted February 23 1 hour ago, E474 said: Any help would be appreciated, I'm expecting it's a user error, but don't want to guesswork my way to in incorrect, but working, fix. You're almost there... just move to the tnfsd directory and run make from there cd ~/spectranet/tnfs/tnfsd make OS=LINUX DEBUG=1 You can leave off the DEBUG flag if you don't want the extra messages but you still need the OS flag Quote Link to comment Share on other sites More sharing options...
E474 Posted February 23 Share Posted February 23 Hi @mozzwald, Thanks very much, that built the binary! pi@pi3bp2:~/spectranet/tnfs/tnfsd $ make OS=LINUX gcc -Wall -DUNIX -DNEED_BSDCOMPAT -DENABLE_CHROOT -DNEED_ERRTABLE -c -o main.o main.c gcc -Wall -DUNIX -DNEED_BSDCOMPAT -DENABLE_CHROOT -DNEED_ERRTABLE -c -o datagram.o datagram.c datagram.c: In function ‘tcp_accept’: datagram.c:231:61: warning: pointer targets in passing argument 3 of ‘accept’ differ in signedness [-Wpointer-sign] 231 | acc_fd = accept(tcplistenfd, (struct sockaddr *)&cli_addr, &cli_len); | ^~~~~~~~ | | | int32_t * {aka int *} In file included from datagram.c:34: /usr/include/arm-linux-gnueabihf/sys/socket.h:233:28: note: expected ‘socklen_t * restrict’ {aka ‘unsigned int * restrict’} but argument is of type ‘int32_t *’ {aka ‘int *’} 233 | socklen_t *__restrict __addr_len); | ~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~ datagram.c: In function ‘tnfs_handle_udpmsg’: datagram.c:260:38: warning: pointer targets in passing argument 6 of ‘recvfrom’ differ in signedness [-Wpointer-sign] 260 | (struct sockaddr *)&cliaddr, &len); | ^~~~ | | | int32_t * {aka int *} In file included from datagram.c:34: /usr/include/arm-linux-gnueabihf/sys/socket.h:165:27: note: expected ‘socklen_t * restrict’ {aka ‘unsigned int * restrict’} but argument is of type ‘int32_t *’ {aka ‘int *’} 165 | socklen_t *__restrict __addr_len); | ~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~ gcc -Wall -DUNIX -DNEED_BSDCOMPAT -DENABLE_CHROOT -DNEED_ERRTABLE -c -o directory.o directory.c directory.c: In function ‘_load_directory’: directory.c:663:45: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size between 0 and 255 [-Wformat-truncation=] 663 | snprintf(statpath, sizeof(statpath), "%s%c%s", dirh->path, FILEINFO_PATHSEPARATOR, entry->d_name); | ^~ directory.c:663:3: note: ‘snprintf’ output between 2 and 512 bytes into a destination of size 256 663 | snprintf(statpath, sizeof(statpath), "%s%c%s", dirh->path, FILEINFO_PATHSEPARATOR, entry->d_name); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ gcc -Wall -DUNIX -DNEED_BSDCOMPAT -DENABLE_CHROOT -DNEED_ERRTABLE -c -o tnfs_file.o tnfs_file.c gcc -o bin/tnfsd main.o datagram.o log.o session.o endian.o directory.o errortable.o tnfs_file.o chroot.o fileinfo.o strlcpy.o strlcat.o I copied in the resulting tnfsd to the correct location: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo cp tnfsd /usr/local/sbin/ And edited the tnfsd.service file: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ more /etc/systemd/system/tnfsd.service [Unit] Description=TNFS Server After=remote-fs.target After=syslog.target [Service] User=tnfs Group=tnfs ExecStart=/usr/local/sbin/tnfsd /tnfs -c tnfs [Install] WantedBy=multi-user.target I got a complaint when I started the tnfsd server: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl start tnfsd Warning: The unit file, source configuration file or drop-ins of tnfsd.service changed on disk. Run 'systemctl daemon-reload' to reload units. Then another complaint after the daemon-reload: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl daemon-reload pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl start tnfsd pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl status tnfsd ● tnfsd.service - TNFS Server Loaded: loaded (/etc/systemd/system/tnfsd.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2023-02-23 00:53:50 WET; 41s ago Main PID: 14252 (tnfsd) Tasks: 1 (limit: 1596) CPU: 12ms CGroup: /system.slice/tnfsd.service └─14252 /usr/local/sbin/tnfsd /tnfs Feb 23 00:53:50 pi3bp2 systemd[1]: Started TNFS Server. Feb 23 00:53:50 pi3bp2 tnfsd[14252]: Starting tnfsd version 23.0207.1 using root directory "/tnfs" Feb 23 00:54:22 pi3bp2 systemd[1]: tnfsd.service: Current command vanished from the unit file, execution of the command list won't be resumed. So tried disabling/enabling it, but am now getting a failed state: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl stop tnfsd pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl disable tnfsd Removed /etc/systemd/system/multi-user.target.wants/tnfsd.service. pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl enable tnfsd Created symlink /etc/systemd/system/multi-user.target.wants/tnfsd.service → /etc/systemd/system/tnfsd.service. pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl start tnfsd pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ sudo systemctl status tnfsd ● tnfsd.service - TNFS Server Loaded: loaded (/etc/systemd/system/tnfsd.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Thu 2023-02-23 01:01:38 WET; 6min ago Process: 14929 ExecStart=/usr/local/sbin/tnfsd /tnfs -c tnfs (code=exited, status=255/EXCEPTION) Main PID: 14929 (code=exited, status=255/EXCEPTION) CPU: 13ms Feb 23 01:01:38 pi3bp2 systemd[1]: Started TNFS Server. Feb 23 01:01:38 pi3bp2 tnfsd[14929]: chroot: Operation not permitted Feb 23 01:01:38 pi3bp2 systemd[1]: tnfsd.service: Main process exited, code=exited, status=255/EXCEPTION Feb 23 01:01:38 pi3bp2 systemd[1]: tnfsd.service: Failed with result 'exit-code'. pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ ls -l /usr/local/sbin/tnfsd -rwxr-xr-x 1 root root 52704 Feb 23 00:53 /usr/local/sbin/tnfsd It looks like it was working when I got the Warning about command vanished, as I tested loading an ATR from the tnfsd server. It looks like the fujinet-PC buffered the tnfsd sector data, when I Control-C'd the FujiNet-PC, I got: 01:12:25.487467 > Signal received (2) 01:12:25.490064 > Shutdown handler called 01:12:25.491111 > FileHandlerLocal::close 01:12:25.494045 > delete FileHandlerLocal 01:12:25.494361 > FileHandlerLocal::close 01:12:25.494571 > delete FileHandlerLocal 01:12:25.494814 > FileHandlerTNFS::close 01:12:27.497121 > Timeout after 2000 milliseconds. Retrying 01:12:30.499119 > Timeout after 2000 milliseconds. Retrying 01:12:33.503668 > Timeout after 2000 milliseconds. Retrying ^C01:12:36.508273 > Timeout after 2000 milliseconds. Retrying 01:12:39.509921 > Timeout after 2000 milliseconds. Retrying 01:12:40.510429 > Retry attempts failed 01:12:40.510683 > delete FileHandlerTNFS 01:12:42.517908 > Timeout after 2000 milliseconds. Retrying 01:12:45.518805 > Timeout after 2000 milliseconds. Retrying 01:12:48.520928 > Timeout after 2000 milliseconds. Retrying 01:12:51.521685 > Timeout after 2000 milliseconds. Retrying 01:12:54.525429 > Timeout after 2000 milliseconds. Retrying 01:12:55.525712 > Retry attempts failed 01:12:55.525985 > Stopping web service The /tnfs directory looks OK: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ ls -ld /tnfs drwxr-xr-x 8 tnfs tnfs 4096 Jun 17 2022 /tnfs So I'm not what the problem is with the chroot. This is on a Raspberry Pi 3B+: pi@pi3bp2:~/spectranet/tnfs/tnfsd/bin $ uname -a Linux pi3bp2 5.15.84-v7+ #1613 SMP Thu Jan 5 11:59:48 GMT 2023 armv7l GNU/Linux Quote Link to comment Share on other sites More sharing options...
mozzwald Posted February 23 Author Share Posted February 23 1 hour ago, E474 said: [Service] User=tnfs Group=tnfs ExecStart=/usr/local/sbin/tnfsd /tnfs -c tnfs This ^ is the issue with your systemd script. To use the chroot capability it must be run by root user instead. See the example systemd script in my first post. Quote Link to comment Share on other sites More sharing options...
Kenshi Posted February 23 Share Posted February 23 After compiling, in addition to the expected tnfsd executable, I also have a tnfsd.linux64 in bin that I don't recall being there with the previous version. I'm guessing the former is a 32-bit version and the latter would be the ideal file to copy in 64-bit Linux. And thanks for the chroot info. My TNFS server isn't public, but just changing three measly lines in the startup script is still worth the security. Quote Link to comment Share on other sites More sharing options...
