Fujinet Trusted Root Certificate?
  • 1 month later...
On 2/20/2023 at 2:59 PM, Pmetzen said:
Is it possible to use a trusted root certificate to access the Fujinet website as https?
Are you trying to access the FujiNet Web Configuration via https? The server on the esp32 currently does not support it.
32 minutes ago, Pmetzen said:
but there should be an up-to-date set of root TLS certificates on the device, as part of mbedTLS.
There is an up to date set of root TLS certs on the esp32 which is used for accessing external sites. The web server running on the FujiNet does not support HTTPS.
If anyone wants to try adding in HTTPS support, the relevant code is here:
https://github.com/FujiNetWIFI/fujinet-platformio/blob/master/lib/http/httpService.cpp
And the relevant API documentation for the HTTP server is here:
https://docs.espressif.com/projects/esp-idf/en/v4.3.5/esp32/api-reference/protocols/esp_http_server.html
-Thom
