Setting RESP right after previous RESP causes HMOVE to get reset
Hi,
I want to set position of missile 1 on scanline 37, and position of missile 2 right after on next scanline 38. Is that possible? For some reason the code below causes both missiles to be at same position despite waiting 24 cpu cycles after RESP and strobing HMCLR. If I insert an extra WSYNC+HMOVE in-between it does work but cost now an extra scanline:
NextFrame
    VERTICAL_SYNC  ;  3 lines
; Vertical Blank Area. Add game logic here
    ldx #36
    lda #$0      ; mask last line when we turn on again
WaitVBlank
    sta WSYNC
    sta COLUBK
    dex
    bne WaitVBlank
    lda #0        ; 0 = turn off VBLANK
    sta VBLANK    ;
; we are now at scanline = 36, pixel pos = -32 (next kernel will close this scanline)
; Kernel1
Kernel1_Setup
    ldx #2              ; 2 = M9
    lda #10             ; x = 10
    jsr SetHorizPos
Kernel1_Exit
; Kernel2
Kernel2_Setup
    ldx #3              ; 3 = M1
    lda #11             ; x = 11
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    sta HMCLR           ; 24 cycles after sta RESP
    jsr SetHorizPos
Kernel2_Exit
; Kernel3
; Type: SkipScanlines
Kernel3_Setup
    ldx #1
Kernel3_Loop
    dex
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    bne Kernel3_Loop
Kernel3_Exit
Yes here you go, thanks!
; SetHorizPos - Sets the horizontal position of an object.
; A register = X position
; X register:
;  0: player 0
;  1: player 1
;  2: missile 0
;  3: missile 1
;  4: ball
SetHorizPos
    sec
    sbc #6
    cpx #2                  ; players require extra -1 adjustment
    adc #00
    sec
    sta WSYNC
    sta HMOVE
SetHorizPosLoop
    sbc #15
    bcs SetHorizPosLoop
    eor #7         ; calculate fine offset
    asl
    asl
    asl
    asl
    sta HMP0,X     ; set fine offset
    sta RESP0,X    ; fix coarse position
    ; strobe HMCLR after > 24 CPU cycles after HMOVE
    rts
5 minutes ago, splendidnut said:
Your code is strobing HMOVE before you set HMP0,x.... you need to hit HMOVE after HMP0,x is set.
Ah good catch. And I can only set HMOVE right after WSYNC, correct? If that is the issue I guess there is no way to do this unless I remove HMOVE at next scanline but then I need to blank out first 8 pixels.
WSYNC+HMOVE+RESM0
WSYNC+HMOVE+RESM1 --> this needs HMCLR to avoid adjusting 2x RESM0
WSYNC+HMOVE+HMCLR
Edited by lucienEn
Order of register hits should be:  HMP0,x /  RESP,x / WSYNC / HMOVE / HMCLR.    (HMP0,x and RESP0,x are swappable).
To remove the HMOVE lines, there's the option of doing an "early" HMOVE  (hitting the register on cycle 73/74).  It requires a different of move values.
One of the early discussions can be found here... this has the table with all the places (cycles) where HMOVE could be hit (and what move values are available) :
https://www.biglist.com/lists/stella/archives/199804/msg00198.html
Here's a link to some discussion on AtariAge about using the HMOVE variation:
For Paint The City, I used code by Omegamatrix to do mid-screen sprite repositioning.  Here's the link for that info:
That is clear and working but I want to do another RESP,X on the next scanline. This works below to use instead of HMCLR, only clear RESM0:
Kernel1_Setup
    ldx #2
    lda #10
    jsr SetHorizPos     ; WSYNC + HMOVE + HMM0 + RESM0
Kernel2_Setup
    ldx #3
    lda #11
    jsr SetHorizPos     ; WSYNC + HMOVE (apply HMM0) + HMM1 + RESM1
    nop   ; 6+2 = 8 cycles
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    lda #0   ; 24 cpu cycles
    sta HMM0
Kernel3_Setup
    ldx #1
    sta WSYNC
    sta HMOVE   ; apply HMM1
    dex
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    sta HMCLR ; clear RESM1
2 hours ago, lucienEn said:
WSYNC+HMOVE+RESM0
WSYNC+HMOVE+RESM1+24 cycles+RESM0=0
WSYNC+HMOVE
Are you drawing the missiles on those scanlines, or just repositioning them for when they're drawn further down the screen?  If just repositioning then you can do this:
WSYNC + RESM0 + HMM0 ; set coarse position and adjustment of missile 0
WSYNC + RESM1 + HMM1 ; set coarse position and adjustment of missile 1
WSYNC + HMOVE ; apply adjustment of both missiles
To give some background, I finished my editor to auto-generate all object types. In the editor you can indicate where you want to set the position of an object and with 'generate asm' I confirmed it's working now as expected (but there are lots of combinations so might be still some bugs left for me):
I noticed Pitfall 2 sets the positioning in the vblank area. That's another option to do the above without requiring to blank first 8 pixels and then apply all at once.
