MyTimer127 Posted March 1, 2023 Share Posted March 1, 2023 I got a AV modded Atari 2600 has this fuzzy band that moves from the top of the screen down (as seen in the 2 pictures below). It basically keeps on repeating this. How can I fix this? 1 Quote Link to comment Share on other sites More sharing options...
BillDMatt Posted March 2, 2023 Share Posted March 2, 2023 (edited) I had the same issue also on an A/V modded. Hooked up to a Vizio D series and it did this then I hooked it up to my LG it's gone but still it's a touch blurry. Very playable by all accounts just needs sharpening. Edited March 2, 2023 by BillDMatt 1 Quote Link to comment Share on other sites More sharing options...
+wongojack Posted March 2, 2023 Share Posted March 2, 2023 On 2/28/2023 at 6:31 PM, MyTimer127 said: I got a AV modded Atari 2600 has this fuzzy band that moves from the top of the screen down (as seen in the 2 pictures below). It basically keeps on repeating this. How can I fix this? Assume this is from a flat screen TV? The 2600 is a strange animal and it took advantage of the way that CRTs created an image. Flat screens simply aren't expecting the same signal and you'll get a lot of different results based on the TV (as evidenced in this thread). The real test is to try it on a CRT and see if it does the same thing. The expensive way is to get an S-Video or RGB modded 2600 and then connect it to a high quality upscaler, but I'm too cheap for that, and I hear that there can even be some problems with those. If quality is really important to you - get a small CRT. 1 Quote Link to comment Share on other sites More sharing options...
