Tricky XB Commands .. need a timer.
3 minutes ago, fabrice montupet said:
Focusing on the subject of the thread, is someone uses some other tricks to get a timer on XB?
I use the hidden sprite frequently and had no reason to look for alternatives yet.
Seems that it is the best solution that we use 🙂
The other solution proposed by Harry is really clever too, I will make some tests using it to see the pro and cons of these each tricks.
@fabrice montupet Yes I'd like to test that method too.  I did do a test , unrelated to this game, of the VDP timer in some other code I was doing but I wasn't happy with the results, unless I did it wrong.  I always assume the latter, first, because 9 times out of 10, that is the case :)
The only way I've seen that fail is if there's been too many things going on and the checks have been missed, but if we use position 248 instead of 255 it probably won't fail.
This program counts down from 30 seconds to 0 seconds. It keeps good time. Or would if my Classic99 ran at 60 frames per second. It is running at around 70 frames per second for some reason.
All this does is check the byte at >8379 and obviously your program will be doing many  other things. As long as you do the CALL PEEK more than once per second you should be OK.
100 CALL CLEAR :: SEC=30 :: CALL LOAD(-31879,0)
110 CALL PEEK(-31879,X):: IF X<60 THEN 110
120 X=X-60 :: CALL LOAD(-31879,X):: SEC=SEC-1 :: DISPLAY AT(10,13):SEC :: IF SEC>0 THEN 110
Thanks @senior_falcon I'll put that code in.
In my Timer subprogram I use the value 248 because the main program branches to many other subprograms so have many things to do. In the Timer subprogram I also added the check for the automotion projectile sprites to be prevent appearing on the other side of the screen when they have reached a border.
