Fujinet firmware compilation issue
@mozzwald  @tschak909
Greetings mates,
Finally I managed to find enough time to install all the toolchain,
and follow the tutorial at: https://github.com/FujiNetWIFI/fujinet-platformio/wiki/Board-Bring-Up-Software
But this is the result when I try to build,
what is the problem?
Thanks in advance for your support,
FYI: Computer is Windows 10 based
Executing task: C:\Users\GetacUser\.platformio\penv\Scripts\platformio.exe run --environment fujiapple-rev0
Processing fujiapple-rev0 (platform: espressif32@3.4.0; board: fujinet-v1-8mb; framework: espidf)
Verbose mode can be enabled via `-v, --verbose` option
C:\Users\GetacUser\.platformio\penv\Scripts\python.exe -m pip install Jinja2
Requirement already satisfied: Jinja2 in c:\users\getacuser\.platformio\penv\lib\site-packages (3.1.2)
Requirement already satisfied: MarkupSafe>=2.0 in c:\users\getacuser\.platformio\penv\lib\site-packages (from Jinja2) (2.1.2)
C:\Users\GetacUser\.platformio\penv\Scripts\python.exe -m pip install pyyaml
Requirement already satisfied: pyyaml in c:\users\getacuser\.platformio\penv\lib\site-packages (6.0)
warning: Not a git repository. Use --no-index to compare two paths outside a working tree
usage: git diff --no-index [<options>] <path> <path>
Diff output format options
    -p, --patch           generate patch
    -s, --no-patch        suppress diff output
    -u                    generate patch
    -U, --unified[=<n>]   generate diffs with <n> lines context
    -W, --function-context
    --raw                 generate the diff in raw format
    --patch-with-raw      synonym for '-p --raw'
    --patch-with-stat     synonym for '-p --stat'
    --numstat             machine friendly --stat
    --shortstat           output only the last line of --stat
    -X, --dirstat[=<param1,param2>...]
                          output the distribution of relative amount of changes for each sub-directory
    --cumulative          synonym for --dirstat=cumulative
    --dirstat-by-file[=<param1,param2>...]
                          synonym for --dirstat=files,param1,param2...
    --check               warn if changes introduce conflict markers or whitespace errors
    --summary             condensed summary such as creations, renames and mode changes
    --name-only           show only names of changed files
    --name-status         show only names and status of changed files
    --stat[=<width>[,<name-width>[,<count>]]]
                          generate diffstat
    --stat-width <width>  generate diffstat with a given width
    --stat-name-width <width>
                          generate diffstat with a given name width
    --stat-graph-width <width>
                          generate diffstat with a given graph width
    --stat-count <count>  generate diffstat with limited lines
    --compact-summary     generate compact summary in diffstat
    --binary              output a binary diff that can be applied
    --full-index          show full pre- and post-image object names on the "index" lines
    --color[=<when>]      show colored diff
    --ws-error-highlight <kind>
                          highlight whitespace errors in the 'context', 'old' or 'new' lines in the diff
    -z                    do not munge pathnames and use NULs as output field terminators in --raw or --numstat
    --abbrev[=<n>]        use <n> digits to display object names
    --src-prefix <prefix>
                          show the given source prefix instead of "a/"
    --dst-prefix <prefix>
                          show the given destination prefix instead of "b/"
    --line-prefix <prefix>
                          prepend an additional prefix to every line of output
    --no-prefix           do not show any source or destination prefix
    --inter-hunk-context <n>
                          show context between diff hunks up to the specified number of lines
    --output-indicator-new <char>
                          specify the character to indicate a new line instead of '+'
    --output-indicator-old <char>
                          specify the character to indicate an old line instead of '-'
    --output-indicator-context <char>
                          specify the character to indicate a context instead of ' '
Diff rename options
    -B, --break-rewrites[=<n>[/<m>]]
                          break complete rewrite changes into pairs of delete and create
    -M, --find-renames[=<n>]
                          detect renames
    -D, --irreversible-delete
                          omit the preimage for deletes
    -C, --find-copies[=<n>]
                          detect copies
    --find-copies-harder  use unmodified files as source to find copies
    --no-renames          disable rename detection
    --rename-empty        use empty blobs as rename source
    --follow              continue listing the history of a file beyond renames
    -l <n>                prevent rename/copy detection if the number of rename/copy targets exceeds given limit
Diff algorithm options
    --minimal             produce the smallest possible diff
    -w, --ignore-all-space
                          ignore whitespace when comparing lines
    -b, --ignore-space-change
                          ignore changes in amount of whitespace
    --ignore-space-at-eol
                          ignore changes in whitespace at EOL
    --ignore-cr-at-eol    ignore carrier-return at the end of line
    --ignore-blank-lines  ignore changes whose lines are all blank
    -I, --ignore-matching-lines <regex>
                          ignore changes whose all lines match <regex>
    --indent-heuristic    heuristic to shift diff hunk boundaries for easy reading
    --patience            generate diff using the "patience diff" algorithm
    --histogram           generate diff using the "histogram diff" algorithm
    --diff-algorithm <algorithm>
                          choose a diff algorithm
    --anchored <text>     generate diff using the "anchored diff" algorithm
    --word-diff[=<mode>]  show word diff, using <mode> to delimit changed words
    --word-diff-regex <regex>
                          use <regex> to decide what a word is
    --color-words[=<regex>]
                          equivalent to --word-diff=color --word-diff-regex=<regex>
    --color-moved[=<mode>]
                          moved lines of code are colored differently
    --color-moved-ws <mode>
                          how white spaces are ignored in --color-moved
Other diff options
    --relative[=<prefix>]
                          when run from subdir, exclude changes outside and show relative paths
    -a, --text            treat all files as text
    -R                    swap two inputs, reverse the diff
    --exit-code           exit with 1 if there were differences, 0 otherwise
    --quiet               disable all output of the program
    --ext-diff            allow an external diff helper to be executed
    --textconv            run external text conversion filters when comparing binary files
    --ignore-submodules[=<when>]
                          ignore changes to submodules in the diff generation
    --submodule[=<format>]
                          specify how differences in submodules are shown
    --ita-invisible-in-index
                          hide 'git add -N' entries from the index
    --ita-visible-in-index
                          treat 'git add -N' entries as real in the index
    -S <string>           look for differences that change the number of occurrences of the specified string
    -G <regex>            look for differences that change the number of occurrences of the specified regex
    --pickaxe-all         show all changes in the changeset with -S or -G
    --pickaxe-regex       treat <string> in -S as extended POSIX regular expression
    -O <file>             control the order in which files appear in the output
    --rotate-to <path>    show the change in the specified path first
    --skip-to <path>      skip the output to the specified path
    --find-object <object-id>
                          look for differences that change the number of occurrences of the specified object
    --diff-filter [(A|C|D|M|R|T|U|X|B)...[*]]
                          select files by diff type
    --output <file>       output to a specific file
CalledProcessError: Command '['git', 'diff', '--name-only']' returned non-zero exit status 129.:
  File "C:\Users\GetacUser\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 181:
    env.SConscript(item, exports="env")
  File "C:\Users\GetacUser\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Script\SConscript.py", line 597:
    return _SConscript(self.fs, *files, **subst_kw)
  File "C:\Users\GetacUser\.platformio\packages\tool-scons\scons-local-4.4.0\SCons\Script\SConscript.py", line 285:
    exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
  File "C:\fj_projects\fujinet-platformio\build_version.py", line 11:
    elif len(subprocess.check_output(["git", "diff", "--name-only"], universal_newlines=True)) == 0:
  File "C:\Users\GetacUser\.platformio\python3\lib\subprocess.py", line 424:
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "C:\Users\GetacUser\.platformio\python3\lib\subprocess.py", line 528:
    raise CalledProcessError(retcode, process.args,
================================================== [FAILED] Took 4.11 seconds ==================================================
Environment     Status    Duration
fujiapple-rev0  FAILED    00:00:04.112
============================================ 1 failed, 0 succeeded in 00:00:04.112 ============================================
 *  The terminal process "C:\Users\GetacUser\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'fujiapple-rev0'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
Edited by masteries
