kikipdph Posted March 11 Share Posted March 11 "I'm new to Batari Basic and I've finished my first video game. Now I want to have a version for PAL color TV system. However, when I put the PAL TV set, nothing changes. I found that they recommend not changing the TV set but only the contents, which I did, but the colors are now completely different when viewed through the Stella emulator. Where did I go wrong and what exactly do I need to do to make it work correctly? I forgot to mention that it's for DPC+." Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted March 11 Share Posted March 11 Here's some information that should help you: https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#color_constants_ntsc_pal60 Quote Link to comment Share on other sites More sharing options...
kikipdph Posted March 11 Author Share Posted March 11 7 minutes ago, splendidnut said: Here's some information that should help you: https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#color_constants_ntsc_pal60 I followed all the instructions, but I don't have the opportunity to try it on a TV, maybe that's how it's supposed to be, but Stella shows me completely different colors Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted March 11 Share Posted March 11 You can check to see which TV mode Stella is using by hitting Alt-L to show the Console Info. It will appear in the upper left corner of the window. You can use Ctrl-F to switch TV modes. Stella can be told which TV mode to use with a ROM file by appending _NTSC, _PAL60, _PAL50, etc... to the filename. i.e. MyGame_NTSC.bin Quote Link to comment Share on other sites More sharing options...
kikipdph Posted March 11 Author Share Posted March 11 5 minutes ago, splendidnut said: You can check to see which TV mode Stella is using by hitting Alt-L to show the Console Info. It will appear in the upper left corner of the window. You can use Ctrl-F to switch TV modes. Stella can be told which TV mode to use with a ROM file by appending _NTSC, _PAL60, _PAL50, etc... to the filename. i.e. MyGame_NTSC.bin Thank you very much, you have helped me a lot. It just needed to be changed to the Pal system in Stella. Quote Link to comment Share on other sites More sharing options...
