pixelpedant Posted March 12, 2023 Share Posted March 12, 2023 If any of you use Autohotkey, well, here is an AHK macro for pasting the clipboard into MAME CC-40 BASIC in an automated fashion (which observes relevant keystroke combinations for the emulation). Probably I am the only person on earth who finds this useful. But in case anyone else does, here it is. Simply press INSERT and code contained on the clipboard will be typed into the CC-40. Like so: 2023-03-12 03-27-26.mp4 Some minor error checking is observed (duplicate lines, lines without a number, out-of-order lines which may be indicative of incorrect numbering). Typing will terminate if the window is deselected. #IfWinActive MAME: Compact Computer 40 [cc40] { Insert:: lines:=[] prev:=0 Loop, parse, clipboard,`n,`r ; split on LF, omit CR if present { content:=StrSplit(A_LoopField,A_Space,,2) num:=content[1] if (num="") { continue } else if num is not digit ; if no valid line number { mess:="No valid line number for line " A_Index ". in text. Line reads `n`n" Trim(A_Loopfield) "`n`nEnter anyway?" MsgBox, 4, , %mess% IfMsgBox No { return } continue } else if (lines[num]) ; if line number duplicated { mess:="Line number " num " used here:`n`n" num A_Space lines[num] "`n`nAlso found here:`n`n " num A_Space content[2] "`n`nEnter anyway?" MsgBox, 4, , %mess% ifMsgBox No { return } } else if (num<prev) { mess:="Line number " prev " precedes line number " num " as follows:`n`n" prev A_Space lines[prev] "`n" num A_Space content[2] "`n`nEnter anyway?" MsgBox, 4, , %mess% ifMsgBox No { return } } lines[num]:=content[2] prev:=num } SetKeyDelay, 40,50 ; pre-press delay and press duration in ms Sleep, 300 Loop, parse, clipboard,,`r { IfWinNotActive, ahk_exe Mame64.exe { return } switch A_LoopField { case Chr(34): Send +2 case "!": Send +1 case "(": Send +8 case ")": Send +9 case "'": Send +0 case "+": Send {NumpadAdd} case "?": Send +{=} case "*": Send {NumpadMult} case "/": Send {NumpadDiv} case Chr(10): { Send {Enter} Sleep, 750 ; newline delay in ms } default: Send %A_Loopfield% } } Send {Enter} ; optionally, always enter final line even when newline absent return } 4 Quote Link to comment Share on other sites More sharing options...
