+Retrospect Posted March 15 Author Share Posted March 15 2 minutes ago, TheBF said: we are handling 1/2 the numbers and so less math When I was trying to do a "screen scan" in my game , Cattle Battle, to check how many cows were alive, I found having to scan using X and Y (incrementing Y until 32 then Y=1 and increment X by 1) was far far too slow. I pondered how John Plaster had done this , for Tombstone, to check for adjacent cacti in his case, and it dawned on me then, that Assembly was using just one number for the address and it was doing it very fast. So I had to have an array for the cow's "alive" status instead VPEEK() and VPOKE() will be looked into though, for sure. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 9 minutes ago, Retrospect said: When I was trying to do a "screen scan" in my game , Cattle Battle, to check how many cows were alive, I found having to scan using X and Y (incrementing Y until 32 then Y=1 and increment X by 1) was far far too slow. I pondered how John Plaster had done this , for Tombstone, to check for adjacent cacti in his case, and it dawned on me then, that Assembly was using just one number for the address and it was doing it very fast. So I had to have an array for the cow's "alive" status instead VPEEK() and VPOKE() will be looked into though, for sure. Bringing it back home to Forth. Forth does everything involving single memory elements with PEEK and POKE equivalents called @ (fetch) and ! (store) And for TI99 the Forth authors have added the equivalent for Video memory. V@ V! in FbForth and TurboForth. In Camel99 I used VC@ VC! because they are for characters. (bytes) Camel99 also has V@ and V! for integers which means you can store numbers in VDP RAM if you want to. When you declare variables in Forth they are not like BASIC. The give you an address, Not the number they are holding. VARIABLE X VARIABLE Y 99 X ! ( Put 99 into X) X @ ( get the number held in X and print with .) It can get "wordy" so there are some other ways to do this but learn about variables first. 1 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 9 minutes ago, TheBF said: but learn about variables first Classic99 QI399.063 2023-03-15 04-28-30.mp4 3 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 I set X to 1000 and Y to 100, then attempted a loop to supposedly count down from X to Y. I'm taking it, that it didn't lock up, or loop forever, that this succeeded. Classic99 QI399.063 2023-03-15 04-35-05.mp4 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 Yo 3 minutes ago, Retrospect said: I set X to 1000 and Y to 100, then attempted a loop to supposedly count down from X to Y. I'm taking it, that it didn't lock up, or loop forever, that this succeeded. Classic99 QI399.063 2023-03-15 04-35-05.mp4 19.22 MB · 0 downloads You forgot to "fetch" X and Y to get their numbers on the stack. so : TEST X @ Y @ DO .... ; 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 Oh and easy test to see what's going on is put I . in the loop and print the index. 1 1 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 1 minute ago, TheBF said: : TEST X @ Y @ DO .... ; That made a remarkable difference. 1 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 The text format is like this because it is a number? shifts it once space over? Edit: No! I needed a CR first! Classic99 QI399.063 2023-03-15 04-45-32.mp4 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 The code makes dot work processes the number on the stack into a string, then types the string starting wherever the cursor is. It assumes you know where you want the output to go. You are getting pretty handy with this Forth thing. I can hear the wheels turning all the way over 'ere. Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 15 minutes ago, TheBF said: You are getting pretty handy with this Forth thing. I can hear the wheels turning all the way over 'ere. 😄 I will be eventually thank you though! So to ask a noob question ( i can't believe I'm asking this ) Say I've declared variable X , and then I do 0 X ! to declare it nill afterwards ... what is the way to do x=x+1 within a loop? Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 Or should I say, I'm attempting to do a simple program, that has X declared as null to begin with, and a delay loop. once the delay loop has hit maximum number, X is incremented (only until 15) Then we can do X SCREEN ? to make the screen color change? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 18 minutes ago, Retrospect said: 😄 I will be eventually thank you though! So to ask a noob question ( i can't believe I'm asking this ) Say I've declared variable X , and then I do 0 X ! to declare it nill afterwards ... what is the way to do x=x+1 within a loop? You can do it the long way. X @ 1+ X ! Or with the +! operator that adds a number to the contents of a variable 1 X +! -4 X +! \ add a negative number is legal. Or in Camel99 I used the native 9900 machine instructions called INC and DEC like this. X 1+! X 1-! These are the fastest. You also have X OFF \ set to zero X ON \ set to true. All bits on. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 20 minutes ago, Retrospect said: Or should I say, I'm attempting to do a simple program, that has X declared as null to begin with, and a delay loop. once the delay loop has hit maximum number, X is incremented (only until 15) Then we can do X SCREEN ? to make the screen color change? Break it into small pieces that are too small to get wrong. That's Chuck's thinking. VARIABLE X : DELAY 500 MS ; : TEST X OFF BEGIN DELAY X @ SCREEN 1 X +! ?TERMINAL UNTIL ; But we would never use a variable for something so trivial in Forth. Variables are for things you want the program to remember. Hang onto to your shorts now. : TEST2 0 \ number of the stack BEGIN DELAY DUP SCREEN 1+ ?TERMINAL UNTIL DROP ; \ throw it way now. We're done. Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 6 minutes ago, TheBF said: Or in Camel99 I used the native 9900 machine instructions called INC and DEC like this. X 1+! X 1-! These are the fastest. I used this. Makes sense. Classic99 QI399.063 2023-03-15 05-48-16.mp4 2 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 5 minutes ago, TheBF said: UNTIL DROP ; \ throw it way now. We're done. When I put "DROP ; " it said ? Unfinished Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 Or : SCREENS 15 0 DO I SCREEN 250 MS LOOP ; : RUN BEGIN SCREENS ?TERMINAL UNTIL ; I is NOT a variable. It is also a subroutine that knows how to get the loop counter in a DO LOOP onto the DATA stack. Nesting loops is almost never done. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 Just now, Retrospect said: When I put "DROP ; " it said ? Unfinished If between : and ; anything was left on the data stack during the compiling, you get that message. Look over you loop or break out pieces into separate words and try them line by line. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 I am not at my normal machine so I can't test anything. Maybe you didn't have DELAY defined? Just change it to 200 MS or whatever. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 I gotta pack it in for now. Cheers Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted March 15 Author Share Posted March 15 When I said " I " i mean me, not I Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 15 Share Posted March 15 I was actually trying the starfield by generating pixels at random instead of a constant moving direction. Then if I needed to set a "direction" I could run something like this??? I also suck at programming Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 1 hour ago, GDMike said: I was actually trying the starfield by generating pixels at random instead of a constant moving direction. Then if I needed to set a "direction" I could run something like this??? I also suck at programming Not sure I completely understand what you are trying to get but maybe the existing words can do this. The RND-STAR word gives you one of the chars that makes a star. The NEW-STARS re-loads RND vdp addresses into the ]LOCATION array. .STARS puts a random star at every location that is in the ]LOCATION array. So if you run .STARS over and over the stars are going to change all the time. Let's try it. This gives a very crazy effect. : TEST2 PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN SHIFT-STARS .STARS ?TERMINAL UNTIL 8 SCREEN ; This sits on the random stars for a bit longer and changes are delayed. : ?BREAK ?TERMINAL IF 8 SCREEN TRUE ABORT" *BREAK*" THEN ; : TEST3 PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN 100 0 DO .STARS 100 MS ?BREAK LOOP 100 0 DO SHIFT-STARS ?BREAK LOOP AGAIN ; Here is the whole thing. Spoiler INCLUDE DSK1.TOOLS INCLUDE DSK1.GRAFIX INCLUDE DSK1.RANDOM INCLUDE DSK1.ARRAYS \ define our stars DECIMAL S" 0000000100000000" 40 CALLCHAR S" 0000000200000000" 41 CALLCHAR S" 0000000400000000" 42 CALLCHAR S" 0000000800000000" 43 CALLCHAR S" 0000001000000000" 44 CALLCHAR S" 0000002000000000" 45 CALLCHAR S" 0000004000000000" 46 CALLCHAR S" 0000000000000000" 47 CALLCHAR : NEXT-STAR ( char -- char') 1+ 7 AND 40 + ; \ : TESTNEXT 40 BEGIN NEXT-STAR SWAP . UNTIL ; : RND-STAR ( -- char) 8 RND 40 + ; : RND-VADDR ( -- Vaddr) C/SCR @ RND \ get random address from zero to size of screen VPG @ + ; \ get the video page, add to the random number 32 CONSTANT #STARS \ lock this down as a constant \ array that holds the VDP address of every star #STARS ARRAY ]LOCATION : NEW-STARS ( n --) #STARS 0 DO RND-VADDR I ]LOCATION ! LOOP ; NEW-STARS \ initialize the array now \ This array FETCHES the star's VDP screen address from ]location : ]VDPLOC ( n -- Vaddr) ]LOCATION @ ; \ Put the stars on the screen at the random LOCATION in our LOCATIONS array : .STARS #STARS 0 DO RND-STAR I ]VDPLOC VC! \ write star to video memory LOOP ; \ Given a screen address, test if we hit the left edge of the screen : LEFT-EDGE? ( n -- ?) C/L @ MOD 0= ; \ modulo divide by "chars per line" \ Take the address of a cell in ]LOCATION array. \ get the screen location of a star \ move it 1 one left, but address can't go below zero so stop that. \ If we hit the left edge add 31 to the Vaddr and store it back in Address : MOVELEFT ( addr -- ) \ decrement a variable to 0 but not below DUP @ ( -- addr Vaddr) BL OVER VC! \ erase char in old screen location 1- 0 MAX ( -- addr Va) \ subtract 1 but don't go below 0 DUP LEFT-EDGE? \ test if we are at the edge of the screen IF 31 + \ yes. Add 31 to go back to right side of screen THEN SWAP ! ; \ store this new location in the addr of ]LOCATION array ; : SHIFT-STARS #STARS 0 DO I ]VDPLOC VC@ \ read star character from screen location NEXT-STAR \ advance to the next bit character DUP 47 = ( -- Va c ?) IF I ]LOCATION MOVELEFT THEN I ]VDPLOC VC! \ store the new star at the VDP location LOOP ; : TEST PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN SHIFT-STARS ?TERMINAL UNTIL 8 SCREEN ; : TEST2 PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN SHIFT-STARS .STARS ?TERMINAL UNTIL 8 SCREEN ; : ?BREAK ?TERMINAL IF 8 SCREEN TRUE ABORT" *BREAK*" THEN ; : TEST3 PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN 100 0 DO .STARS 100 MS ?BREAK LOOP 100 0 DO SHIFT-STARS ?BREAK LOOP AGAIN ; 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 This one is always changing the star field and then shifts 8 times. : TEST4 PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN PAGE NEW-STARS .STARS 8 0 DO SHIFT-STARS LOOP ?TERMINAL UNTIL 8 SCREEN ; 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 15 Share Posted March 15 I cleaned up this code and removed all the noisy comments. Also factored out the word WRAP which makes MOVE-LEFT clearer to read. Spoiler INCLUDE DSK1.TOOLS INCLUDE DSK1.GRAFIX INCLUDE DSK1.RANDOM INCLUDE DSK1.ARRAYS DECIMAL 32 CONSTANT #STARS #STARS ARRAY ]LOCATION : ]VDPLOC ( n -- Vaddr) ]LOCATION @ ; S" 0000000100000000" 40 CALLCHAR S" 0000000200000000" 41 CALLCHAR S" 0000000400000000" 42 CALLCHAR S" 0000000800000000" 43 CALLCHAR S" 0000001000000000" 44 CALLCHAR S" 0000002000000000" 45 CALLCHAR S" 0000004000000000" 46 CALLCHAR S" 0000000000000000" 47 CALLCHAR : NEXT-STAR ( char -- char') 1+ 7 AND 40 + ; : RND-STAR ( -- char) 8 RND 40 + ; : RND-VADDR ( -- Vaddr) C/SCR @ RND VPG @ + ; : NEW-STARS ( n --) #STARS 0 DO RND-VADDR I ]LOCATION ! LOOP ; : .STARS ( -- ) #STARS 0 DO RND-STAR I ]VDPLOC VC! LOOP ; : LEFT-EDGE? ( n -- ?) C/L @ MOD 0= ; : WRAP ( Vaddr -- Vaddr') DUP LEFT-EDGE? IF 31 + THEN ; : MOVELEFT ( addr -- ) DUP @ ( -- addr Vaddr) BL OVER VC! 1- 0 MAX WRAP SWAP ! ; : SHIFT-STARS #STARS 0 DO I ]VDPLOC VC@ NEXT-STAR DUP 47 = ( -- Vaddr c ?) IF I ]LOCATION MOVELEFT THEN I ]VDPLOC VC! LOOP ; NEW-STARS ( Init locations) : TEST PAGE 40 SET# 16 1 COLOR 2 SCREEN .STARS BEGIN SHIFT-STARS ?TERMINAL UNTIL 8 SCREEN ; 4 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 15 Share Posted March 15 Right. I like it better. That's me tho. Quote Link to comment Share on other sites More sharing options...
