STNICCC2000 port for Lynx
42bs
26 minutes ago, Heaven/TQA said:
here is the file. that does not have "indexed" frames and the end frame byte and end of file byte are different to V2. just 1 palette for all. so no palette information inside the data. it is straight forward when you already got a "v2" parser. you can look at "displayFrame" label in the source code and "nPolyDraw". and you need the ST palette setup converted to Lynx but that is easy.
I like such:
		move.l	d0,a6
		rept	533
		movem.l	d0-a6,-(sp)
		endr
Here a first shot. Only one direction yet. Little stuttering while depacking.
nostalgia.lnx
looks cool. I cached the frame start adresses so actually when going backwards I went back that cache table...
not sure how to do it on Lynx as the file is "streamed" from cart...
btw. not sure if the palette conversion is correct? as there are purple colors...
here you see how the blitter does not struggle to draw... but the 6502 is hard fighting to feed the blitter... ;)
that's why I think that the Lynx has the best (except display AND the sound) hardware/cpu combo of retro consoles I have touched...
Edited by Heaven/TQA
I have now a version with separate frames non-packed. This will allow to load a single frame. Only need to "remember" the stream position (or pre-calc it).
I will surely try.
I will surely try.
i did the easy way out... I just stored each frame start the adress into a lo/hi table in first run through and then later backwards I just loaded that adresses to the parser...
but when doing Elements demo on Lynx... I remember that the cart is like a SD card.... so you have files... but can you not "seek"? so you simply store that adresses when running first time the animation?
You don't have to have a file abstraction. It has 256 blocks. The problem is that selecting a block needs bit banging. And it has not random access. You cannot "just" select a byte. You need first select the block and then read dummy bytes until the wanted byte.
So for the frames, there would be an option to use 220 blocks and each containing two frames to have a rather quick access.
So no large table needed, just a selectBlock(frame/2) + seek(frame & 1).
can not remember how I loaded the parts of Elements demo... long time :D
Felix is slightly faster. Real Suzy must obviously take some more time to draw a sprite. In current implementation I assume that its speed is capped only by required bus access. I'm planing to make a test that will interrupt sprite drawing after n cycles and examine how much of a sprite have been drawn to that point.
Sound is not so bad if you'll use a good tool to compose for it.
Posted (edited)
I think the card reading in Felix is a bit quicker compared to the Lynx.
BTW: Video is taken (of course) from a real Lynx II.
Edited by 42bs
Hm.. I was trying make it match by adding some artificial wait states, but it's hard match for a long run. It's a matter of a good test program that would read a bunch of blocks and print the timing.
Disable drawing the poly in the Nostalgia demo should give a good bench. First run is linear read, all further runs use seek to the respective frame.
Any idea, if Vision by Oxygene uses the same technique like Nostalgia or STNICCC2000. Would be cool to have the Wipeout part also for the Lynx/Jaguar.
23 hours ago, 42bs said:
For the impatient or w/o hardware or Felix:
btw. did anybody ever did a better poly routine than the we use "since back of those days" esp. for the jittering right edges of the sprite? Some did some experiements with feeding some "subpix" value into the sprite hardware to adress that (he found such a possibility in the Handy source code).
I think the quickest is the stretched/tilted sprite approach.
And this has its draw-backs.
I tried the approach calculating left/right points and draw only horizontal line, but it does not seem to be quicker. At least if you have lots off tiny polygons.
The STNICCC2000 or Nostalgic-O-Demo data set is also a bit "unfair" as likely contains a lot of 3pixel polygons due to the down-sizing.
no, this wont work. unless you split the triangle in left and right. the problem is the slope on left and right side depend on each other, and are quantized
Why can Sega Saturn do it with sprites better?
Hmm, serious? Because Sega Saturn came out 5 years later and has a real polygon engine. Where as the triangles of the Lynx are just a "oh we can do this" of the tilting/stretching. It is _not_ a polygon engine!
nope. Saturn works with Quad sprites... similar to 3do (need to double check again)... but Saturn is 2x Mega Drive with some Risc side kick ;)
