320 mode colours question
11 hours ago, PacManPlus said:
I actually ended up using 320B for Scramble, both with and without Kangaroo mode depending on the area of the screen.
(I *still* don't see the usefulness of 320C or 320D mode...  Do any homebrew games use them?  I don't think any retail games do...)
Not that I've seen, though you can use 320C to get extra colors, without worrying about the kangaroo 00/01 glitch.  But I think the color pixel limitations are a tradeoff.  I had planned to try some interlace experiments with it though.
Edited by Synthpopalooza
  • 2 months later...
10 hours ago, Eagle said:
Today I did converter for 320C mode. @Defender_2600 you may like it results ;)
Great work, thanks. And you can convince more people if you show all 8 colors on the same scanline with two sprites, and each sprites with 4 colors ( you can use my 320C Mario sprites as an example ).:)
Your editor can be helpful in getting people to practice 320C graphics and understand the advantage of having 8 colors from two palettes over 320B which has 6 colors from two palettes. 320C and 320B have different restrictions regarding pixel placement but in many cases you can get better results with 320C and you can still use 320C + 320A (for example you can use 320A - 1 bpp for a starry background, consuming less cycles).
For example, 320C would be perfect for Galaga sprites, we have more colors than 320B and the same number of cycles are required (2 bpp).
1184258942_1917605019_7800MarioBrosin320Cmodeb.PNG.70099c305c107085a1917585af19ef34(1).png.409f6a439e58156d2da4c75c15591381.thumb.png.b3e7a599c95f08c23053d92311ac3417.png
Edited by Defender_2600
One-on-One Basketball is made completely in 320C mode, it has bad graphics but it's just bad pixel art.
And there is another game in the works, it will be a big surprise so I won't say more.
Editor it's not finished. No point, to many problems with changing sprites, colours, saving etc.
Like I said this is just converter for 320c mode only.
I'm looking for different solution. Editor is just viewer for now.
Bin attached (PAL no signature)
320cViewer.a78
Edited by Eagle
Your editor can be helpful in getting people to practice 320C graphics and understand the advantage of having 8 colors from two palettes over 320B which has 6 colors from two palettes. 320C and 320B have different restrictions regarding pixel placement but in many cases you can get better results with 320C and you can still use 320C + 320A (for example you can use 320A for a starry background, consuming less cycles).
For example, 320C would be perfect for Galaga sprites, we have more colors than 320B and the same number of cycles are required.
For people who want to try drawing graphics in 320C mode, I just want to add that each pair of pixels must include the same color or one color + the background color. It requires patience because you need to manually check each pair of pixels but (in some circumstances) it can be more versatile and colorful than the 320B mode. Of course, a sprite editor would be very useful, so that when you draw sprites it is not possible (as error) to place two different colors within the same pair of pixels.
Here are my previous Galaga sprites with a grid dividing the pairs of pixels, to better understand how to get around the limitations of pixel placement in 320C mode.
1913967034_7800Galagasprites320Cmodev.2.thumb.PNG.5ac6927a1412c5b3d10558efb2180bdd.PNG
I'm using Grafx2 by setting grid for 2x1
Shift+G - grid menu
G - grid on/off (must be off)
Shift+Alt+G - grid view
Also now I have LUA script for checking bad cells
To run script right click on red marked FX button and open CellColorCheck.lua
Script will mark bad cells, press undo to unmark them
CellColorCheck.lua
Edited by Eagle
  • Like 5
Waouh, thank you for the explanation. I had been reading and rereading the 7800 software guide and the Maria chip reference, and now it suddenly seems clear to me. Very clever color coding indeed. I had never figured out why this mode actually existed...
Cool - but I don't understand how you can get 4-color sprites? Pixel values are either 00, 01, 10, or 11 with 00 being background color or transparent, right?
