RXB and Integer Variables
  From the "COMBAT XB COMPETITION":
On 3/20/2023 at 12:20 AM, RXB said:
Cool looking at the PDF documents do you have to update it when I release a new version of RXB?
Down the road I am looking at adding Integer math to be used instead of Floating Point math in RXB, maybe a modified version of XB 110 also calling it XB 111.
Adding a token to XB so like you can currently do A$= a string.
But a new token A%= a word value (2 bytes) instead of like currently A= a floating point value (8 bytes).
Thus instead of 9 x 8 bytes for say A(9) being 72 bytes for those numbers, A#(9) would be 9 x 2 bytes would be only 18 bytes and faster too.
You see Floating Point really slows down XB especially when dealing with Graphics as row and column values never need to be Floating Points.
Currently if you say ROW=7 (>40 >07, >00, >00 >00 >00 >00 >00) it is stored in 8 bytes floating point stored variable ROW.
But in RXB or XB 111 it would be ROW$=7 (>00 >07)  it is stored in 2 bytes variable ROW#.
So over all savings of memory is 3 bytes vs 8 bytes.
Ah but speed difference will really add up very fast as no Floating-Point conversion is needed.
This will also be done in Assembly of the ROMs. (I am rewriting the XB ROMs for this new feature.)
So this will benefit everyone using XB or RXB. And TIcodEd can also benefit.
Hi Rich,
I think this topic deserves an own thread to discuss, this is an amazing project! Would you like to share your approach in more detail?
When I look at any XB, I can't remember a single CALL that expects a floatingpoint number. HCHAR, SOUND, COLOR, SPRITE ... all integer parameters. Only the arithmetic functions require floats. Avoiding those
       BLWP @XMLLNK
       DATA CFI
would really save a lot of time. I mean, in the program they are unquoted strings, will be converted to Radix-100, transfered to the FAC, then converted by XMLLNK/CFI to integer, where it could be just a 16bit MOV in the first place....
When I look at the way TI stores a program in tokens I see
1. Numeric Variables and numeric literals as "unquoted strings":
X=123 ->  58 BE[=] C8[Unquotedstring] 03[length] 31 32 33
2. String variables and string literals as "quoted strings":
A$="Hello." ->  41 24 BE[=] C7[Quotedstring] 06[length] 48 65 6C 6C 6F 2E
The introduction of integer-variables would require a third pair, i.e.
N%=165 -> 4E 25 BE[=] C6[SignedInteger] 00 A5
>C6 is not used by XB, but I am not sure which additional token are already taken by ABASIC, I couldn't find a token-list including them ( @9640News ?)
I would be happy to include something like this in TiCodEd. I am rooting hard for your project!
Steve
Thanks I know very little about ABASIC other then I downloaded the Manual to see the features used.
And how RXB % token integers would work is:
N%=165 ->4E 25 BE[=] >C6 >00 >A5
There is no sign used ranges are >00 to >7FFF same as in CALL LOAD or CALL PEEK for positive numbers or >8000 to >FFFF for negative numbers.
i.e. CALL LOAD(8192,165) 8192 is >2000 or CALL LOAD(-20480,165) -20480 is >B000
This is exactly how many RXB commands work like
CALL MOVES("RR",5,8192,-20480) this would move from RAM to RAM the 5 bytes from >2000 TO >B000
But in future it would not be using FLOATING POINT to do this thus speeding up XB quite a bit.
Thank you again. Expecting some help from Lee Stewart on this project.
1 hour ago, 9640News said:
If one sorta knows what they are searching for, you can look at BeeryMiller/ABasic: ABasic for MDOS (github.com) and do a search for a string/word that might lead to the tokens list.
Beery
Look for file 160.EQUTOKEN.   There are a few other files, and there is also an extended "NUD" token handler. Don't put complete trust in the list as some things are hard-coded elsewhere, but this is a good starting point for the curious.  I bumped into this while tracking down an issue with the token handler in ABASIC.  Much of the assembly code will match XB's code as ABASIC is derived from much of the same source.
Do you mean this literally?
Or do you mean the way it was used for example in the Swedish computer ABC-80, where A was a floating point numeric variable but A% was an integer one, both possibilities existing at the same time?
That would of course make it much more convenient.
Yea I have been making modified versions of XB ROMs and GPL for 30 years now.
And yes A=11 would be like normal XB a Floating Point number in memory, but A%=11 would be a word value of 2 bytes only in memory.
In total memory usage A=11 takes up 18 bytes of memory, while A%=11 takes up only 8 bytes of memory total.
i.e. A % = >C6 1 1 this is 6 bytes for name in program, 2 bytes for the number 11 to be stored as >000A in memory.
Yes, I've read about what you've been doing, and I'm of course aware of the concept of integer vs. real data. My question was not about the benefit of it, just about if what you were quoted to have written was false or true. It would have been limiting if it was true, so I'm glad it was a mistake.
I presume the issue is not so much the pure math (+, -, * and div), but rather all places where a numeric variable can be used. Does the system have a common routine that's called to evaluate the four different types of values in a statement like FOR I%=12 TO B*3 STEP X%+2 ? So that you only have to modify that number handler in one place?
If you look for NFOR you will find the FOR routine in ROM 1 and below that is the NEXT routine in ROM 1.
As you can see even in Floating point format is converted to integer for Assembly to complete the math and same for the increment values.
Spoiler
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0001
  0001            ************************************************************
  0003
  0004      7016  CNS    EQU  >7016             * GROM ADDRESS'S
  0005      7492  PWRZZ  EQU  >7492             *
  0006      76C2  LOGZZ  EQU  >76C2             *
  0007      75CA  EXPZZ  EQU  >75CA             *
  0008      783A  SQRZZ  EQU  >783A             *
  0009      78B2  COSZZ  EQU  >78B2             *
  0010      78C0  SINZZ  EQU  >78C0             *
  0011      7940  TANZZ  EQU  >7940             *
  0012      797C  ATNZZ  EQU  >797C             *
  0013      79EC  GRINT  EQU  >79EC             *
  0014      7A90  ROLOUT EQU  >7A90             *
  0015      7AC4  ROLIN  EQU  >7AC4             *
  0016      7B88  CRUNCH EQU  >7B88             *
  0017      7F6E  PUTCHR EQU  >7F6E             *
  0018            *
  0019            * NOTE RXB CHANGE: All lables with $ changed to Z
  0020            *      LPAR$ is now LPARZ or WARN$$ is now WARNZZ
  0021            *      this was to use same names as GPL source
  0022            *
  0023            ************************************************************
  0025
  0026            *
  0027      6000  LWCNS  EQU  >6000
  0028            *
  0029      4000  WRVDP  EQU  >4000             Write enable for VDP
  0030      8800  XVDPRD EQU  >8800             Read VDP data
  0031      8C00  XVDPWD EQU  >8C00             Write VDP data
  0032      9800  XGRMRD EQU  >9800             Read GROM data
  0033      0402  GRMWAX EQU  >9C02->9800       Write GROM address
  0034      0002  GRMRAX EQU  >9802->9800       Read GROM address
  0035      0400  GRMWDX EQU  >9C00->9800       GROM write data
  0036            *
  0037      CB00  KEYTAB EQU  >CB00             ADDRESS OF KEYWORD TABLE
  0038            *
  0039      7D00  NEGPAD EQU  >7D00
  0040      8300  PAD0   EQU  >8300
  0041      8301  PAD1   EQU  >8301
  0042      835F  PAD5F  EQU  >835F
  0043      83C2  PADC2  EQU  >83C2
  0044            *
  0045      8300  VAR0   EQU  >8300
  0046      8302  MNUM   EQU  >8302
  0047      8303  MNUM1  EQU  >8303
  0048      8304  PABPTR EQU  >8304
  0049      8306  CCPPTR EQU  >8306
  0050      8308  CCPADR EQU  >8308
  0051      830A  RAMPTR EQU  >830A
  0052      830A  CALIST EQU  RAMPTR
  0053      830C  BYTE   EQU  >830C
  0054      8310  PROAZ  EQU  >8310
  0055      8310  VAR5   EQU  PROAZ
  0056      8312  PZ     EQU  >8312
  0057      8312  LINUM  EQU  PZ
  0058      8314  OEZ    EQU  >8314
  0059      8316  QZ     EQU  >8316
  0060      8316  XFLAG  EQU  QZ
  0061      8316  VAR9   EQU  QZ
 99/4 ASSEMBLER
EQUATES                                                      PAGE 0002
  0062      8317  DSRFLG EQU  >8317
  0063      8317  FORNET EQU  DSRFLG
  0064      8318  STRSP  EQU  >8318
  0065      831A  CZ     EQU  >831A
  0066      831A  STREND EQU  CZ
  0067      831A  WSM    EQU  CZ
  0068      831C  SREF   EQU  >831C * Temporary string pointer
  0069      831C  WSM2   EQU  SREF  * Temporary string pointer
  0070      831E  WSM4   EQU  >831E * Start of current statement
  0071      831E  SMTSRT EQU  WSM4  * Start of current statement
  0072      8320  WSM6   EQU  >8320 * Screen address
  0073      8320  VARW   EQU  WSM6  * Screen address
  0074      8321  VARW1  EQU  >8321
  0075      8322  ERRCOD EQU  >8322 * Return error code from ALC
  0076      8322  WSM8   EQU  ERRCOD * Return error code from ALC
  0077      8323  ERRCO1 EQU  >8323
  0078      8324  STVSPT EQU  >8324 * Value-stack base
  0079      8326  RTNADD EQU  >8326
  0080      8328  NUDTAB EQU  >8328
  0081      832A  VARA   EQU  >832A * Ending display location
  0082      832C  PGMPTR EQU  >832C * Program text pointer
  0083      832D  PGMPT1 EQU  >832D
  0084      832E  EXTRAM EQU  >832E * Line number table pointer
  0085      832F  EXTRM1 EQU  >832F
  0086      8330  STLN   EQU  >8330 * Start of line number table
  0087      8332  ENLN   EQU  >8332 * End of line number table
  0088      8334  DATA   EQU  >8334 * Data pointer for READ
  0089      8336  LNBUF  EQU  >8336 * Line table pointer for READ
  0090      8338  INTRIN EQU  >8338 * Add of intrinsic poly constant
  0091      833A  SUBTAB EQU  >833A * Subprogram symbol table
  0092      833E  SYMTAB EQU  >833E * Symbol table pointer
  0093      833F  SYMTA1 EQU  >833F
  0094      8340  FREPTR EQU  >8340 * Free space pointer
  0095      8342  CHAT   EQU  >8342 * Current charater/token
  0096      8343  BASE   EQU  >8343 * OPTION BASE value
  0097      8344  PRGFLG EQU  >8344 * Program/imperative flag
  0098      8345  FLAG   EQU  >8345 * General 8-bit flag
  0099      8346  BUFLEV EQU  >8346 * Crunch-buffer destruction level
  0100      8348  LSUBP  EQU  >8348 * Last subprogram block on stack
  0101      834A  FAC    EQU  >834A * Floating-point ACcurmulator
  0102      834B  FAC1   EQU  >834B
  0103      834C  FAC2   EQU  >834C
  0104      834E  FAC4   EQU  >834E
  0105      834F  FAC5   EQU  >834F
  0106      8350  FAC6   EQU  >8350
  0107      8351  FAC7   EQU  >8351
  0108      8352  FAC8   EQU  >8352
  0109      8353  FAC9   EQU  >8353
  0110      8354  FAC10  EQU  >8354
  0111      8354  FLTNDX EQU  FAC10
  0112      8354  FDVSR  EQU  FAC10
  0113      8355  FAC11  EQU  >8355
  0114      8355  SCLEN  EQU  FAC11
  0115      8355  FDVSR1 EQU  FAC11
  0116      8356  FAC12  EQU  >8356
  0117      8356  FDVSR2 EQU  FAC12
  0118      8357  FAC13  EQU  >8357
  0119      8358  FAC14  EQU  >8358
  0120      8359  FAC15  EQU  >8359
 99/4 ASSEMBLER
EQUATES                                                      PAGE 0003
  0121      835A  FAC16  EQU  >835A
  0122      835C  FDVSR8 EQU  >835C * Floating-point ARGument
  0123      835C  ARG    EQU  FDVSR8 * Floating-point ARGument
  0124      835D  ARG1   EQU  >835D
  0125      835E  ARG2   EQU  >835E
  0126      835F  ARG3   EQU  >835F
  0127      8360  ARG4   EQU  >8360
  0128      8364  ARG8   EQU  >8364
  0129      8365  ARG9   EQU  >8365
  0130      8366  ARG10  EQU  >8366
  0131      836B  FAC33  EQU  >836B
  0132      836C  TEMP2  EQU  >836C
  0133      836C  FLTERR EQU  TEMP2
  0134      836D  TYPE   EQU  >836D
  0135      836E  VSPTR  EQU  >836E * Value stack pointer
  0136      836F  VSPTR1 EQU  >836F
  0137      8372  STKDAT EQU  >8372
  0138      8373  STKADD EQU  >8373
  0139      8373  STACK  EQU  >8373
  0140      8374  PLAYER EQU  >8374
  0141      8375  KEYBRD EQU  >8375
  0142      8375  SIGN   EQU  KEYBRD
  0143      8376  JOYY   EQU  >8376 * Exponent in floating-point
  0144      8376  EXP    EQU  JOYY
  0145      8377  JOYX   EQU  >8377
  0146      8378  RANDOM EQU  >8378
  0147      8379  TIME   EQU  >8379
  0148      837A  MOTION EQU  >837A
  0149      837B  VDPSTS EQU  >837B
  0150      837C  STATUS EQU  >837C
  0151      837D  CHRBUF EQU  >837D
  0152      837E  YPT    EQU  >837E
  0153      837F  XPT    EQU  >837F
  0154      8389  RAMFLG EQU  >8389 * ERAM flag
  0155      83BA  STKEND EQU  >83BA
  0156      83AE  STND12 EQU  STKEND-12
  0157      83C0  CRULST EQU  >83C0
  0158      83CB  SAVEG  EQU  >83CB
  0159      83D2  SADDR  EQU  >83D2
  0160      83D4  RAND16 EQU  >83D4
  0161            *
  0162      83E0  WS     EQU  >83E0
  0163      83E1  R0LB   EQU  >83E1
  0164      83E3  R1LB   EQU  >83E3
  0165      83E5  R2LB   EQU  >83E5
  0166      83E7  R3LB   EQU  >83E7
  0167      83E9  R4LB   EQU  >83E9
  0168      83EB  R5LB   EQU  >83EB
  0169      83ED  R6LB   EQU  >83ED
  0170      83EF  R7LB   EQU  >83EF
  0171      83F1  R8LB   EQU  >83F1
  0172      83F3  R9LB   EQU  >83F3
  0173      83F5  R10LB  EQU  >83F5
  0174      83F7  R11LB  EQU  >83F7
  0175      83F9  R12LB  EQU  >83F9
  0176      83FB  R13LB  EQU  >83FB
  0177      83FD  R14LB  EQU  >83FD
  0178      83FF  R15LB  EQU  >83FF
  0179            *
 99/4 ASSEMBLER
EQUATES                                                      PAGE 0004
  0180      8302  GDST   EQU  >8302
  0181      8303  AAA11  EQU  >8303
  0182      8303  GDST1  EQU  >8303
  0183      8304  VARY   EQU  >8304
  0184      8306  VARY2  EQU  >8306
  0185      8308  BCNT2  EQU  >8308
  0186      830C  CSRC   EQU  >830C
  0187      834C  ADDR1  EQU  >834C
  0188      834D  ADDR11 EQU  >834D
  0189      834E  BCNT1  EQU  >834E
  0190      8350  ADDR2  EQU  >8350
  0191      8351  ADDR21 EQU  >8351
  0192      8354  GSRC   EQU  >8354
  0193      8355  DDD11  EQU  >8355
  0194      8355  GSRC1  EQU  >8355
  0195      8356  BCNT3  EQU  >8356
  0196      8358  DEST   EQU  >8358
  0197      8359  DEST1  EQU  >8359
  0198      8384  RAMTOP EQU  >8384
  0199            * VDP variables
  0200      0376  SYMBOL EQU  >0376 * Saved symbol table pointer
  0201      038A  ERRLN  EQU  >038A * On-error line pointer
  0202      0392  TABSAV EQU  >0392 * Saved main symbol table ponter
  0203      03C0  VROAZ  EQU  >03C0 * Temporary VDP Roll Out Area
  0204      03DC  FPSIGN EQU  >03DC
  0205      0820  CRNBUF EQU  >0820 * CRuNch BUFfer address
  0206      08BE  CRNEND EQU  >08BE * CRuNch buffer END
  0207            ************************************************************
  0208 6000              AORG >6000
  0210
  0211            * PAGE SELECTOR FOR PAGE 1
  0212      6000  PAGE1  EQU  $                 >6000
  0213 6000 0002  C2     DATA 2                 0
  0214            * PAGE SELECTOR FOR PAGE 2
  0215      6002  PAGE2  EQU  $                 >6002
  0216 6002   00  C7     BYTE >00
  0217 6003   07  CBH7   BYTE >07               2
  0218 6004   0A  CBHA   BYTE >0A
  0219 6005   94  CBH94  BYTE >94               4
  0220 6006 0028  C40    DATA 40                6
  0221 6008 0064  C100   DATA 100               8
  0222 600A 1000  C1000  DATA >1000             A
  0223 600C 0000         DATA 0                 C
  0224 600E 4001  FLTONE DATA >4001             E
  0225            ************************************************************
  0226            * XML table number 7 for Extended Basic - must have
  0227            *     it's origin at >6010
  0228            ************************************************************
  0229            *           0      1      2      3      4      5     6
  0230 6010 619C         DATA COMPCG,GETSTG,MEMCHG,CNSSEL,PARSEG,CONTG,EXECG
       6012 61A2
       6014 72CE
       6016 6070
       6018 6470
       601A 64C4
       601C 6500
  0231            *           7      8    9     A    B    C      D
  0232 601E 61BA         DATA VPUSHG,VPOP,PGMCH,SYMB,SMBB,ASSGNV,FBSYMB
       6020 6C2A
 99/4 ASSEMBLER
XML359                                                       PAGE 0005
       6022 6410
       6024 61B4
       6026 61A8
       6028 61AE
       602A 618C
  0233            *             E     F
  0234 602C 6EE2         DATA SPEED,CRNSEL
       602E 6076
  0235            ************************************************************
  0236            * XML table number 8 for Extended Basic - must have
  0237            *     it's origin at >6030
  0238            ************************************************************
  0239            *           0   1      2    3      4  5     6      7
  0240 6030 74AA         DATA CIF,CONTIN,RTNG,SCROLL,IO,GREAD,GWRITE,DELREP
       6032 65CC
       6034 6630
       6036 7ADA
       6038 7B48
       603A 7EB4
       603C 7ED8
       603E 7EF4
  0241            *           8    9    A      B      C      D      E
  0242 6040 7F7E         DATA MVDN,MVUP,VGWITE,GVWITE,GREAD1,GWITE1,GDTECT
       6042 6F98
       6044 7FC0
       6046 7FDA
       6048 7EA6
       604A 7ECA
       604C 6050
  0243            *           F
  0244 604E 7C56         DATA PSCAN
  0245
  0246            * Determine if and how much ERAM is present
  0247 6050 D80B  GDTECT MOVB R11,@PAGE1        First enable page 1 ROM
       6052 6000
  0248            *-----------------------------------------------------------
  0249            * Replace following line      6/16/81
  0250            * (Extended Basic must be made to leave enough space at
  0251            * top of RAM expansion for the "hooks" left by the 99/4A
  0252            * for TIBUG.)
  0253            *      SETO R0                Start at >FFFF
  0254            * with
  0255            *      LI   R0,>FFE7          Start at >FFE7
  0256            ************************************************************
  0257            * RXB 2020 change for PRAM command
  0258 6054 C020         MOV  @RAMTOP,R0        PRAM sets RAMTOP value
       6056 8384
  0259            *-----------------------------------------------------------
  0260 6058 D40B         MOVB R11,*R0           Write a byte of data
  0261 605A 940B         CB   R11,*R0           Read and compare the data
  0262 605C 1306         JEQ  DTECT2            If matches-found ERAM top
  0263            *-----------------------------------------------------------
  0264            * Change the following line   6/16/81
  0265            *      AI   R0,->2000         Else drop down 8K
  0266 605E 0200         LI   R0,>DFFF          Else drop down 8K
       6060 DFFF
  0267            *-----------------------------------------------------------
  0268 6062 D40B         MOVB R11,*R0           Write a byte of data
  0269 6064 940B         CB   R11,*R0           Read and compare the data
 99/4 ASSEMBLER
XML359                                                       PAGE 0006
  0270 6066 1301         JEQ  DTECT2            If matches-found ERAM top
  0271 6068 04C0         CLR  R0                No match so no ERAM
  0272 606A C800  DTECT2 MOV  R0,@RAMTOP        Set the ERAM top
       606C 8384
  0273 606E 045B         RT                     And return to GPL
  0274 6070 0202  CNSSEL LI   R2,CNS
       6072 7016
  0275 6074 1002         JMP  PAGSEL
  0276 6076 0202  CRNSEL LI   R2,CRUNCH
       6078 7B88
  0277            * Select page 2 for CRUNCH and CNS
  0278 607A 05E0  PAGSEL INCT @STKADD           Get space on subroutine stack
       607C 8373
  0279 607E D1E0         MOVB @STKADD,R7        Get stack pointer
       6080 8373
  0280 6082 0987         SRL  R7,8              Shift to use as offset
  0281 6084 D9CB         MOVB R11,@PAD0(R7)     Save return addr to GPL interp
       6086 8300
  0282 6088 D9E0         MOVB @R11LB,@PAD1(R7)
       608A 83F7
       608C 8301
  0283 608E D80B         MOVB R11,@PAGE2        Select page 2
       6090 6002
  0284 6092 0692         BL   *R2               Do the conversion
  0285 6094 D80B         MOVB R11,@PAGE1        Reselect page 1
       6096 6000
  0286 6098 D1E0         MOVB @STKADD,R7        Get subroutine stack pointer
       609A 8373
  0287 609C 0660         DECT @STKADD           Decrement pointer
       609E 8373
  0288 60A0 0987         SRL  R7,8              Shift to use as offset
  0289 60A2 D2E7         MOVB @PAD0(R7),R11     Restore return address
       60A4 8300
  0290 60A6 D827         MOVB @PAD1(R7),@R11LB
       60A8 8301
       60AA 83F7
  0291 60AC 045B         RT                     Return to GPL interpeter
  0292 60AE D7E0  GETCH  MOVB @R6LB,*R15
       60B0 83ED
  0293 60B2 1000         NOP
  0294 60B4 D7C6         MOVB R6,*R15
  0295 60B6 0586         INC  R6
  0296 60B8 D220         MOVB @XVDPRD,R8
       60BA 8800
  0297 60BC 0988  GETCH1 SRL  R8,8
  0298 60BE 045B         RT
  0299 60C0 DB46  GETCHG MOVB R6,@GRMWAX(R13)
       60C2 0402
  0300 60C4 DB60         MOVB @R6LB,@GRMWAX(R13)
       60C6 83ED
       60C8 0402
  0301 60CA 0586         INC  R6
  0302 60CC D21D         MOVB *R13,R8
  0303 60CE 10F6         JMP  GETCH1
  0304 60D0 D236  GETCGR MOVB *R6+,R8
  0305 60D2 10F4         JMP  GETCH1
  0306            *
  0307      60D6  CBHFF  EQU  $+2
  0308 60D4 0205  POPSTK LI   R5,-8
 99/4 ASSEMBLER
XML359                                                       PAGE 0007
       60D6 FFF8
  0309 60D8 D7E0         MOVB @VSPTR1,*R15
       60DA 836F
  0310 60DC 0206         LI   R6,ARG
       60DE 835C
  0311 60E0 D7E0         MOVB @VSPTR,*R15
       60E2 836E
  0312 60E4 A805         A    R5,@VSPTR
       60E6 836E
  0313 60E8 DDA0  STKMOV MOVB @XVDPRD,*R6+
       60EA 8800
  0314 60EC 0585         INC  R5
  0315 60EE 16FC         JNE  STKMOV
  0316 60F0 045B         RT
  0317            *
  0318 60F2 05E0  PUTSTK INCT @STKADD
       60F4 8373
  0319 60F6 D120         MOVB @STKADD,R4
       60F8 8373
  0320 60FA 0984         SRL  R4,8
  0321 60FC D92D         MOVB @GRMRAX(13),@PAD0(R4)
       60FE 0002
       6100 8300
  0322 6102 D92D         MOVB @GRMRAX(13),@PAD1(R4)
       6104 0002
       6106 8301
  0323 6108 0624         DEC  @PAD0(R4)
       610A 8300
  0324 610C 045B         RT
  0325            *
  0326 610E D120  GETSTK MOVB @STKADD,R4
       6110 8373
  0327 6112 0984         SRL  R4,8
  0328 6114 0660         DECT @STKADD
       6116 8373
  0329 6118 DB64         MOVB @PAD0(R4),@GRMWAX(R13)
       611A 8300
       611C 0402
  0330 611E DB64         MOVB @PAD1(R4),@GRMWAX(R13)
       6120 8301
       6122 0402
  0331 6124 045B         RT
  0332            ************************************************************
  0333 6126              AORG >6126
  0335
  0336      0F64  ROUNUP EQU  >0F64   Uses XML >01 Rounding of floating point
  0337      0D42  SCOMPB EQU  >0D42   Set SCOMP with direct return without GPL
  0338      12B8  CFI    EQU  >12B8   CFI (XML >12)
  0339      0E8C  SMULT  EQU  >0E8C   SMUL (XML >0D)
  0340      0FF4  FDIV   EQU  >0FF4   FDIV (XML >09)
  0341      0FC2  OVEXP  EQU  >0FC2   Overflow (XML >04)
  0342      0E88  FMULT  EQU  >0E88   FMUL (XML >08)
  0343      0D74  SSUB   EQU  >0D74   SSUB (XML >0C)
  0344      0D80  FADD   EQU  >0D80   FADD (XML >06)
  0345      0FF8  SDIV   EQU  >0FF8   SDIV (XML >0E)
  0346      0D7C  FSUB   EQU  >0D7C   FSUB (XML (>07)
  0347      0D84  SADD   EQU  >0D84   SADD (XML >0B)
  0348      0FB2  ROUNU  EQU  >0FB2   Rounding with digit number in >8354 (XML
  0349      006A  RESET  EQU  >006A   Clear condition bit in GPL status (GPL i
 99/4 ASSEMBLER
REFS359                                                      PAGE 0008
  0350      0070  NEXT   EQU  >0070   GPL interpreter
  0351      11B2  CSN01  EQU  >11B2   CSN (XML >10) (Without R3 loaded with >1
  0352      0D3A  FCOMP  EQU  >0D3A   FCOMP (XML >0A)
  0353 6126 C0CB  FCOMPB MOV  R11,R3
  0354 6128 0460         B    @FCOMP+22
       612A 0D50
  0355      187C  GETV   EQU  >187C   Read 1 byte from VDP, Entry over data ad
  0356      1880  GETV1  EQU  >1880   Same >187C but does not fetch address, i
  0357      1E8C  SAVREG EQU  >1E8C   Set substack pointer and Basic byte
  0358      1E90  SAVRE2 EQU  >1E90   Same >1E8C but does not set R8 into >834
  0359      1E7A  SETREG EQU  >1E7A   Substack pointer in R9 and actual Basic
  0360      18AA  STVDP3 EQU  >18AA   Write R6 in VDP (R1=Address+3),
  0361            *                   used for variable table and string point
  0362      18AE  STVDP  EQU  >18AE   Write R6 in VDP (R1=Address+3),
  0363            *                   used for variable table and string point
  0364      15E0  FBS    EQU  >15E0   Pointer fetch var list
  0365      15E6  FBS001 EQU  >15E6   Fetch length byte
  0366            ************************************************************
  0367
  0368 612C              AORG >612C
  0370
  0371            *
  0372            * The CHARACTER PROPERTY TABLE
  0373            * There is a one-byte entry for every character code
  0374            * in the range LLC(lowest legal character) to
  0375            * HLC(highest legal character), inclusive.
  0376      0020  LLC    EQU  >20
  0377      0000  CPNIL  EQU  >00               " $ % ' ?
  0378      0002  CPDIG  EQU  >02               digit (0-9)
  0379      0004  CPNUM  EQU  >04               digit, period, E
  0380      0008  CPOP   EQU  >08               1 char operators(!#*+-/<=>^ )
  0381      0010  CPMO   EQU  >10               multiple operator ( : )
  0382      0020  CPALPH EQU  >20               A-Z, @, _
  0383      0040  CPBRK  EQU  >40               ( ) , ;
  0384      0080  CPSEP  EQU  >80               space
  0385      0022  CPALNM EQU  CPALPH+CPDIG      alpha-digit
  0386            *-----------------------------------------------------------
  0387            * Following lines are for adding lowercase character set in
  0388            * 99/4A,                      5/12/81
  0389      0001  CPLOW  EQU  >01               a-z
  0390      0023  CPULNM EQU  CPALNM+CPLOW      Alpha(both upper and lower)+
  0391            *                             digit-legal variable character
  0392      0021  CPUL   EQU  CPALPH+CPLOW      Alpha(both upper and lower)
  0393            *-----------------------------------------------------------
  0394      610C  CPTBL  EQU  $-LLC
  0395 612C   80         BYTE CPSEP               SPACE
  0396 612D   08         BYTE CPOP              ! EXCLAMATION POINT
  0397 612E   00         BYTE CPNIL             " QUOTATION MARKS
  0398 612F   08         BYTE CPOP              # NUMBER SIGN
  0399 6130   00         BYTE CPNIL             $ DOLLAR SIGN
  0400 6131   00         BYTE CPNIL             % PERCENT
  0401 6132   08         BYTE CPOP              & AMPERSAND
  0402 6133   00         BYTE CPNIL             ' APOSTROPHE
  0403 6134   40         BYTE CPBRK             ( LEFT PARENTHESIS
  0404 6135   40         BYTE CPBRK             ) RIGHT PARENTHESIS
  0405 6136   08         BYTE CPOP              * ASTERISK
  0406 6137   0C         BYTE CPOP+CPNUM        + PLUS
  0407 6138   40         BYTE CPBRK             , COMMA
  0408 6139   0C         BYTE CPOP+CPNUM        - MINUS
 99/4 ASSEMBLER
CPT                                                          PAGE 0009
  0409 613A   04         BYTE CPNUM             . PERIOD
  0410 613B   08         BYTE CPOP              / SLANT
  0411 613C   06         BYTE CPNUM+CPDIG       0 ZERRO
  0412 613D   06         BYTE CPNUM+CPDIG       1 ONE
  0413 613E   06         BYTE CPNUM+CPDIG       2 TWO
  0414 613F   06         BYTE CPNUM+CPDIG       3 THREE
  0415 6140   06         BYTE CPNUM+CPDIG       4 FOUR
  0416 6141   06         BYTE CPNUM+CPDIG       5 FIVE
  0417 6142   06         BYTE CPNUM+CPDIG       6 SIX
  0418 6143   06         BYTE CPNUM+CPDIG       7 SEVEN
  0419 6144   06         BYTE CPNUM+CPDIG       8 EIGHT
  0420 6145   06         BYTE CPNUM+CPDIG       9 NINE
  0421 6146   10  LBCPMO BYTE CPMO              : COLON
  0422 6147   40         BYTE CPBRK             : SEMICOLON
  0423 6148   08         BYTE CPOP              < LESS THAN
  0424 6149   08         BYTE CPOP              = EQUALS
  0425 614A   08         BYTE CPOP              > GREATER THAN
  0426 614B   00         BYTE CPNIL             ? QUESTION MARK
  0427 614C   20         BYTE CPALPH            @ COMMERCIAL AT
  0428 614D   20         BYTE CPALPH            A UPPERCASE A
  0429 614E   20         BYTE CPALPH            B UPPERCASE B
  0430 614F   20         BYTE CPALPH            C UPPERCASE C
  0431 6150   20         BYTE CPALPH            D UPPERCASE D
  0432 6151   24         BYTE CPALPH+CPNUM      E UPPERCASE E
  0433 6152   20         BYTE CPALPH            F UPPERCASE F
  0434 6153   20         BYTE CPALPH            G UPPERCASE G
  0435 6154   20         BYTE CPALPH            H UPPERCASE H
  0436 6155   20         BYTE CPALPH            I UPPERCASE I
  0437 6156   20         BYTE CPALPH            J UPPERCASE J
  0438 6157   20         BYTE CPALPH            K UPPERCASE K
  0439 6158   20         BYTE CPALPH            L UPPERCASE L
  0440 6159   20         BYTE CPALPH            M UPPERCASE M
  0441 615A   20         BYTE CPALPH            N UPPERCASE N
  0442 615B   20         BYTE CPALPH            O UPPERCASE O
  0443 615C   20         BYTE CPALPH            P UPPERCASE P
  0444 615D   20         BYTE CPALPH            Q UPPERCASE Q
  0445 615E   20         BYTE CPALPH            R UPPERCASE R
  0446 615F   20         BYTE CPALPH            S UPPERCASE S
  0447 6160   20         BYTE CPALPH            T UPPERCASE T
  0448 6161   20         BYTE CPALPH            U UPPERCASE U
  0449 6162   20         BYTE CPALPH            V UPPERCASE V
  0450 6163   20         BYTE CPALPH            W UPPERCASE W
  0451 6164   20         BYTE CPALPH            X UPPERCASE X
  0452 6165   20         BYTE CPALPH            Y UPPERCASE Y
  0453 6166   20         BYTE CPALPH            Z UPPERCASE Z
  0454 6167   20         BYTE CPALPH            [ LEFT SQUARE BRACKET
  0455 6168   20         BYTE CPALPH            \ REVERSE SLANT
  0456 6169   20         BYTE CPALPH            ] RIGHT SQUARE BRACKET
  0457 616A   08         BYTE CPOP              ^ CIRCUMFLEX
  0458 616B   20         BYTE CPALPH            _ UNDERLINE
  0459            *-----------------------------------------------------------
  0460            * Following "`" and lowercase characters are for
  0461            * adding lowercase character set in 99/4A, 5/12/81
  0462            *-----------------------------------------------------------
  0463 616C   00         BYTE CPNIL             ` GRAVE ACCENT
  0464 616D   21         BYTE CPALPH+CPLOW      a LOWERCASE a
  0465 616E   21         BYTE CPALPH+CPLOW      b LOWERCASE b
  0466 616F   21         BYTE CPALPH+CPLOW      c LOWERCASE c
  0467 6170   21         BYTE CPALPH+CPLOW      d LOWERCASE d
 99/4 ASSEMBLER
CPT                                                          PAGE 0010
  0468 6171   21         BYTE CPALPH+CPLOW      e LOWERCASE e
  0469 6172   21         BYTE CPALPH+CPLOW      f LOWERCASE f
  0470 6173   21         BYTE CPALPH+CPLOW      g LOWERCASE g
  0471 6174   21         BYTE CPALPH+CPLOW      h LOWERCASE h
  0472 6175   21         BYTE CPALPH+CPLOW      i LOWERCASE i
  0473 6176   21         BYTE CPALPH+CPLOW      j LOWERCASE j
  0474 6177   21         BYTE CPALPH+CPLOW      k LOWERCASE k
  0475 6178   21         BYTE CPALPH+CPLOW      l LOWERCASE l
  0476 6179   21         BYTE CPALPH+CPLOW      m LOWERCASE m
  0477 617A   21         BYTE CPALPH+CPLOW      n LOWERCASE n
  0478 617B   21         BYTE CPALPH+CPLOW      o LOWERCASE o
  0479 617C   21         BYTE CPALPH+CPLOW      p LOWERCASE p
  0480 617D   21         BYTE CPALPH+CPLOW      q LOWERCASE q
  0481 617E   21         BYTE CPALPH+CPLOW      r LOWERCASE r
  0482 617F   21         BYTE CPALPH+CPLOW      s LOWERCASE s
  0483 6180   21         BYTE CPALPH+CPLOW      t LOWERCASE t
  0484 6181   21         BYTE CPALPH+CPLOW      u LOWERCASE u
  0485 6182   21         BYTE CPALPH+CPLOW      v LOWERCASE v
  0486 6183   21         BYTE CPALPH+CPLOW      w LOWERCASE w
  0487 6184   21         BYTE CPALPH+CPLOW      x LOWERCASE x
  0488 6185   21         BYTE CPALPH+CPLOW      y LOWERCASE y
  0489 6186   21         BYTE CPALPH+CPLOW      z LOWERCASE z
  0490
  0491                   EVEN
  0492            ************************************************************
  0493 6188              AORG >6188
  0495
  0496            * General Basic support routines (not includeing PARSE)
  0497
  0498            *
  0499      0503  ERRBS  EQU  >0503             BAD SUBSCRIPT ERROR CODE
  0500      0603  ERRTM  EQU  >0603             ERROR STRING/NUMBER MISMATCH
  0501            *
  0502 6188 6500  STCODE DATA >6500
  0503 618A 0006  C6     DATA >0006
  0504            *
  0505            * Entry to find Basic symbol table entry for GPL
  0506            *
  0507 618C 06A0  FBSYMB BL   @FBS              Search the symbol table
       618E 15E0
  0508 6190 006A         DATA RESET             If not found - condition reset
  0509 6192 F820  SET    SOCB @BIT2,@STATUS     Set GPL condition
       6194 62AB
       6196 837C
  0510 6198 0460         B    @NEXT             If found - condition set
       619A 0070
  0511            * GPL entry for COMPCT to take advantage of common code
  0512 619C 0206  COMPCG  LI   R6,COMPCT        Address of COMPCT
       619E 73D8
  0513 61A0 100E         JMP  SMBB10            Jump to set up
  0514            * GPL entry for GETSTR to take advantage of common code
  0515 61A2 0206  GETSTG LI   R6,GETSTR         Address of MEMCHK
       61A4 736C
  0516 61A6 100B         JMP  SMBB10            Jump to set up
  0517            * GPL entry for SMB to take advantage of common code
  0518 61A8 0206  SMBB   LI   R6,SMB            Address of SMB routine
       61AA 61DC
  0519 61AC 1008         JMP  SMBB10            Jump to set up
  0520            * GPL entry for ASSGNV to take advantage of common code
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0011
  0521 61AE 0206  ASSGNV LI   R6,ASSG           Address of ASSGNV routine
       61B0 6334
  0522 61B2 1005         JMP  SMBB10            Jump to set up
  0523            * GPL entry for SMB to take advantage of common code
  0524 61B4 0206  SYMB   LI   R6,SYM            Address of SYM routine
       61B6 6312
  0525 61B8 1002         JMP  SMBB10            Jump to set up
  0526            * GPL entry for SMB to take advantage of common code
  0527 61BA 0206  VPUSHG LI   R6,VPUSH          Address of VPUSH routine
       61BC 6BAA
  0528 61BE C1CB  SMBB10 MOV  R11,R7            Save return address
  0529 61C0 06A0         BL   @PUTSTK           Save current GROM address
       61C2 60F2
  0530 61C4 06A0         BL   @SETREG           Set up Basic registers
       61C6 1E7A
  0531 61C8 05C9         INCT R9                Get space on subroutine stack
  0532 61CA C647         MOV  R7,*R9            Save the return address
  0533 61CC 0696         BL   *R6               Branch and link to the routine
  0534 61CE C1D9         MOV  *R9,R7            Get return address
  0535 61D0 0649         DECT R9                Restore subroutine stack
  0536 61D2 06A0         BL   @SAVREG           Save registers for GPL
       61D4 1E8C
  0537 61D6 06A0         BL   @GETSTK           Restore GROM address
       61D8 610E
  0538 61DA 0457         B    *R7               Return to GPL
  0539            ************************************************************
  0540            * Subroutine to find the pointer to variable space of each
  0541            * element of symbol table entry. Decides whether symbol
  0542            * table entry pointed to by FAC, FAC+1 is a simple variable
  0543            * and returns proper 8-byte block in FAC through FAC7
  0544            ************************************************************
  0545 61DC 05C9  SMB    INCT R9                Get space on subroutine stack
  0546 61DE C64B         MOV  R11,*R9           Save return address
  0547 61E0 C820         MOV  @FAC,@FAC4        Copy pointer to table entry
       61E2 834A
       61E4 834E
  0548 61E6 A820         A    @C6,@FAC4         Add 6 so point a value space
       61E8 618A
       61EA 834E
  0549 61EC 06A0         BL   @GETV             Get 1st byte of table entry
       61EE 187C
  0550 61F0 834A         DATA FAC               Pointer is in FAC
  0551            *
  0552 61F2 C101         MOV  R1,R4             Copy for later use.
  0553 61F4 C081         MOV  R1,R2             Copy for later use.
  0554 61F6 0A21         SLA  R1,2              Check for UDF entry
  0555 61F8 1821         JOC  BERMUV            If UDF - then error
  0556 61FA C104         MOV  R4,R4             Check for string.
  0557 61FC 1102         JLT  SMB02             Skip if it is string.
  0558 61FE 04E0         CLR  @FAC2             Clear for numeric case.
       6200 834C
  0559            *
  0560            * In case of subprogram call check if parameter is shared by
  0561            * it's  calling program.
  0562            *
  0563 6202 0A11  SMB02  SLA  R1,1              Check for the shared bit.
  0564 6204 1705         JNC  SMB04             If it is not shared skip.
  0565 6206 06A0         BL   @GET              Get the value space pointer
       6208 6C9A
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0012
  0566 620A 834E         DATA FAC4                in the symbol table.
  0567 620C C801         MOV  R1,@FAC4          Store the value space address.
       620E 834E
  0568            *
  0569            * Branches to take care of string and array cases.
  0570            * Only the numeric variable case stays on.
  0571            *
  0572 6210 D104  SMB04  MOVB R4,R4             R4 has header byte information
  0573 6212 1116         JLT  SMBO50            Take care of string.
  0574 6214 0A54  SMB05  SLA  R4,5              Get only the dimension number.
  0575 6216 09D4         SRL  R4,13
  0576 6218 162A         JNE  SMBO20             go to array case.
  0577            *
  0578            * Numeric ERAM cases are special.
  0579            * If it is shared get the actual v.s. address from ERAM.
  0580            * Otherwise get it from VDP RAM.
  0581            *
  0582 621A D120         MOVB @RAMTOP,R4        Check for ERAM.
       621C 8384
  0583 621E 130B         JEQ  SMBO10            Yes ERAM case.
  0584 6220 0A32         SLA  R2,3              R2 has a header byte.
  0585 6222 1704         JNC  SMB06             Shared bit is not ON.
  0586 6224 06A0         BL   @GETG             Get v.s. pointer from ERAM
       6226 6CCA
  0587 6228 834E         DATA FAC4
  0588 622A 1003         JMP  SMB08
  0589 622C 06A0  SMB06  BL   @GET              Not shared.
       622E 6C9A
  0590 6230 834E         DATA FAC4              Get v.s. address from VDP RAM.
  0591            *
  0592 6232 C801  SMB08  MOV  R1,@FAC4          Store it in FAC4 area.
       6234 834E
  0593            *
  0594            * Return from the SMB routine.
  0595            *
  0596 6236 C2D9  SMBO10 MOV  *R9,R11           Restore return address
  0597 6238 0649         DECT R9                Restore stack
  0598 623A 045B         RT                     And return
  0599 623C 0460  BERMUV B    @ERRMUV           * INCORRECT NAME USAGE
       623E 6970
  0600            *
  0601            * Start looking for the real address of the symbol.
  0602            *
  0603 6240 0288  SMBO50 CI   R8,LPARZ*256      String - now string array?
       6242 B700
  0604 6244 13E7         JEQ  SMB05             Yes, process as an array
  0605 6246 C820  SMB51  MOV  @STCODE,@FAC2     String ID code in FAC2
       6248 6188
       624A 834C
  0606 624C C820         MOV  @FAC4,@FAC        Get string pointer address
       624E 834E
       6250 834A
  0607 6252 06A0         BL   @GET              Get exact pointer to string
       6254 6C9A
  0608 6256 834A         DATA FAC
  0609            *
  0610 6258 C801         MOV  R1,@FAC4          Save pointer to string
       625A 834E
  0611 625C C0C1         MOV  R1,R3             Was it a null?
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0013
  0612 625E 1304         JEQ  SMB57             Length is 0 - so is null
  0613 6260 0603         DEC  R3                Otherwise point at length byte
  0614 6262 06A0         BL   @GETV1            Get the string length
       6264 1880
  0615 6266 0981         SRL  R1,8              Shift for use as double
  0616 6268 C801  SMB57  MOV  R1,@FAC6          Put into FAC entry
       626A 8350
  0617 626C 10E4         JMP  SMBO10            And return
  0618            *
  0619            * Array cases are taken care of here.
  0620            *
  0621 626E C804  SMBO20  MOV R4,@FAC2          Now have a dimension counter
       6270 834C
  0622            *                              that is initilized to maximum
  0623            *  *FAC+4,FAC+5 already points to 1st dimension maximum in
  0624            *    in symbol table.
  0625 6272 04C2         CLR  R2                Clear index accumulator
  0626 6274 C802  SMBO25 MOV  R2,@FAC6          Save accumulator in FAC
       6276 8350
  0627 6278 06A0         BL   @PGMCHR           Get next character
       627A 6C74
  0628 627C 06A0         BL   @PSHPRS           PUSH and PARSE subscript
       627E 6B9C
  0629 6280   B7         BYTE LPARZ,0           Up to a left parenthesis or le
       6281   00
  0630            *
  0631 6282 9820         CB   @FAC2,@STCODE     Dimension can't be a string
       6284 834C
       6286 6188
  0632 6288 1441         JHE  ERRT              It is - so error
  0633            * Now do float to interger conversion of dimension
  0634 628A 04E0         CLR  @FAC10            Assume no error
       628C 8354
  0635 628E 06A0         BL   @CFI              Gets 2 byte integer in FAC,FAC
       6290 12B8
  0636 6292 D120         MOVB @FAC10,R4         Error on conversion?
       6294 8354
  0637 6296 1636         JNE  ERR3              Yes, error BAD SUBSCRIPT
  0638 6298 C160         MOV  @FAC,R5           Save index just read
       629A 834A
  0639 629C 06A0         BL   @VPOP             Restore FAC block
       629E 6C2A
  0640 62A0 06A0         BL   @GET              Get next dimension maximum
       62A2 6C9A
  0641 62A4 834E         DATA FAC4              FAC4 points into symbol table
  0642            *
  0643 62A6 8045         C    R5,R1             Subscript less-then maximum?
  0644 62A8 1B2D         JH   ERR3              No, index out of bounds
  0645      62AB  BIT2   EQU  $+1               Constant >20 (Opcode is >D120)
  0646 62AA D120         MOVB @BASE,R4          Fetch option base to check low
       62AC 8343
  0647 62AE 1303         JEQ  SMBO40            If BASE=0, INDEX=0 is ok
  0648 62B0 0605         DEC  R5                Adjust BASE 1 index
  0649 62B2 1128         JLT  ERR3              If subscript was =0 then error
  0650 62B4 1001         JMP  SMBO41            Accumulate the subscripts
  0651 62B6 0581  SMBO40 INC  R1                Adjust size if BASE=0
  0652 62B8 3860  SMBO41 MPY  @FAC6,R1          R1,R2 has ACCUM*MAX dimension
       62BA 8350
  0653 62BC A085         A    R5,R2             Add latest to accumulator
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0014
  0654 62BE 05E0         INCT @FAC4             Increment dimension max pointe
       62C0 834E
  0655 62C2 0620         DEC  @FAC2             Decrement remaining-dim count
       62C4 834C
  0656 62C6 1305         JEQ  SMBO70            All dimensions handled ->done
  0657 62C8 0288         CI   R8,COMMAZ*256     Otherwise, must be at a comma
       62CA B300
  0658 62CC 13D3         JEQ  SMBO25            We are, so loop for more
  0659 62CE 0460  ERR1   B    @ERRSYN           Not a comma, so SYNTAX ERROR
       62D0 664E
  0660            *
  0661            * At this point the required number of dimensions have been
  0662            *  scanned.
  0663            * R2 Contains the index
  0664            * R4 Points to the first array element or points to the
  0665            *  address in ERAM where the first array element is.
  0666 62D2 0288  SMBO70 CI   R8,RPARZ*256      Make sure at a right parenthes
       62D4 B600
  0667 62D6 16FB         JNE  ERR1              Not, so error
  0668 62D8 06A0         BL   @PGMCHR           Get nxt token
       62DA 6C74
  0669 62DC 06A0         BL   @GETV             Now check string or numeric
       62DE 187C
  0670 62E0 834A         DATA FAC                array by checking s.t.
  0671            *
  0672 62E2 110C         JLT  SMB71             If MSB set is a string array
  0673 62E4 0A32         SLA  R2,3              Numeric, multiply by 8
  0674 62E6 D0E0         MOVB @RAMTOP,R3        Does ERAM exist?
       62E8 8384
  0675 62EA 1305         JEQ  SMBO71            No
  0676 62EC 06A0         BL   @GET              Yes, get the content of value
       62EE 6C9A
  0677 62F0 834E         DATA FAC4               pointer
  0678            *
  0679 62F2 C801         MOV  R1,@FAC4          Put it in FAC4
       62F4 834E
  0680 62F6 A802  SMBO71 A    R2,@FAC4          Add into values pointer
       62F8 834E
  0681 62FA 109D         JMP  SMBO10            And return in the normal way
  0682 62FC 0A12  SMB71  SLA  R2,1              String, multiply by 2
  0683 62FE A802         A    R2,@FAC4          Add into values pointer
       6300 834E
  0684 6302 10A1         JMP  SMB51             And build the string FAC entry
  0685 6304 0200  ERR3   LI   R0,ERRBS          Bad subscript return vector
       6306 0503
  0686 6308 0460  ERRX   B    @ERR              Exit to GPL
       630A 6652
  0687 630C 0200  ERRT   LI   R0,ERRTM          String/number mismatch vector
       630E 0603
  0688 6310 10FB         JMP  ERRX              Use the long branch
  0689            ************************************************************
  0690            * Subroutine to put symbol name into FAC and to call FBS to
  0691            * find the symbol table for the symbol
  0692            ************************************************************
  0693 6312 04E0  SYM    CLR  @FAC15            Clear the character counter
       6314 8359
  0694 6316 0202         LI   R2,FAC            Copying string into FAC
       6318 834A
  0695 631A C04B         MOV  R11,R1            Save return address
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0015
  0696            *-----------------------------------------------------------
  0697            * Fix "A long constant in a variable field in INPUT,
  0698            *      ACCEPT, LINPUT, NEXT and READ etc. may crash the
  0699            *      sytem" bug,            5/22/81
  0700            * Insert the following 2 lines
  0701 631C D208         MOVB R8,R8
  0702 631E 11D7         JLT  ERR1              If token
  0703 6320 DC88  SYM1   MOVB R8,*R2+           Save the character
  0704 6322 05A0         INC  @FAC15            Count it
       6324 8359
  0705 6326 06A0         BL   @PGMCHR           Get next character
       6328 6C74
  0706 632A 15FA         JGT  SYM1              Still characters in the name
  0707 632C 06A0         BL   @FBS              Got name, now find s.t. entry
       632E 15E0
  0708 6330 62CE         DATA ERR1              Return vector if not found
  0709            *
  0710 6332 0451         B    *R1               Return to caller if found
  0711            ************************************************************
  0712            * ASSGNV, callable from GPL or 9900 code, to assign a value
  0713            * to a symbol (strings and numerics) . If numeric, the
  0714            * 8 byte descriptor is in the FAC. The descriptor block
  0715            * (8 bytes) for the destination variable is on the stack.
  0716            * There are two types of descriptor entries which are
  0717            * created by SMB in preparation for ASSGNV, one for
  0718            * numerics and one for strings.
  0719            *                     NUMERIC
  0720            * +-------------------------------------------------------+
  0721            * |S.T. ptr | 00 |       |Value ptr |                     |
  0722            * +-------------------------------------------------------+
  0723            *                     STRING
  0724            * +-------------------------------------------------------+
  0725            * |Value ptr| 65 |       |String ptr|String length        |
  0726            * +-------------------------------------------------------+
  0727            *
  0728            * CRITICAL NOTE: Becuase of the BL @POPSTK below, if a
  0729            * string entry is popped and a garbage collection has taken
  0730            * place while the entry was pushed on the stack, and the
  0731            * entry was a permanent string the pointer in FAC4 and FAC5
  0732            * will be messed up. A BL @VPOP would have taken care of
  0733            * the problem but would have taken a lot of extra code.
  0734            * Therefore, at ASSG50-ASSG54 it is assumed that the
  0735            * previous value assigned to the destination variable has
  0736            * been moved and the pointer must be reset by going back to
  0737            * the symbol table and getting the correct value pointer.
  0738            ************************************************************
  0739 6334 C28B  ASSG   MOV  R11,R10           Save the retun address
  0740 6336 06A0         BL   @ARGTST           Check arg and variable type
       6338 6B6E
  0741 633A 02CC         STST R12               Save status of type
  0742 633C 06A0         BL   @POPSTK           Pop destination descriptor
       633E 60D4
  0743            *                              into ARG
  0744 6340 0A3C         SLA  R12,3             Variable type numeric?
  0745 6342 1745         JNC  ASSG70            Yes, handle it as such
  0746            * Assign a string to a string variable
  0747 6344 C060         MOV  @ARG4,R1          Get destination pointer
       6346 8360
  0748            *                             Dest have non-null  value?
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0016
  0749 6348 130B         JEQ  ASSG54            No, null->never assigned
  0750            * Previously assigned - Must first free the old value
  0751 634A 06A0         BL   @GET              Correct for POPSTK above
       634C 6C9A
  0752 634E 835C         DATA ARG               Pointer is in ARG
  0753            *
  0754 6350 C801         MOV  R1,@ARG4          Correct ARG+4,5 too
       6352 8360
  0755            *-----------------------------------------------------------
  0756            * Fix "Assigning a string to itself when memory is full can
  0757            *      destroy the string" bug, 5/22/81
  0758            * Add the following 2 lines and the label ASSG80
  0759 6354 8801         C    R1,@FAC4          Do not do anything in assign-
       6356 834E
  0760            *                              ing a string to itself case
  0761 6358 1317         JEQ  ASSG80            Detect A$=A$ case, exit
  0762            *-----------------------------------------------------------
  0763 635A 04C6         CLR  R6                Clear for zeroing backpointer
  0764 635C 06A0         BL   @STVDP3           Free the string
       635E 18AA
  0765 6360 C120  ASSG54 MOV  @FAC6,R4          Is source string a null?
       6362 8350
  0766 6364 130C         JEQ  ASSG57            Yes, handle specially
  0767 6366 C0E0         MOV  @FAC,R3           Get address of source pointer
       6368 834A
  0768 636A 0283         CI   R3,>001C          Got a temporay string?
       636C 001C
  0769 636E 160D         JNE  ASSG56            No, more complicated
  0770 6370 C120         MOV  @FAC4,R4          Pick up direct ptr to string
       6372 834E
  0771            * Common string code to set forward and back pointers
  0772 6374 C1A0  ASSG55 MOV  @ARG,R6           Ptr to symbol table pointer
       6376 835C
  0773 6378 C044         MOV  R4,R1             Pointer to source string
  0774 637A 06A0         BL   @STVDP3           Set the backpointer
       637C 18AA
  0775 637E C060  ASSG57 MOV  @ARG,R1           Address of symbol table ptr
       6380 835C
  0776 6382 C184         MOV  R4,R6             Pointer to string
  0777 6384 06A0         BL   @STVDP            Set the forward pointer
       6386 18AE
  0778 6388 045A  ASSG80 B    *R10              Done, return
  0779            * Symbol-to-symbol assigments of strings
  0780            * Must create copy of string
  0781 638A C820  ASSG56 MOV  @FAC6,@BYTE       Fetch length for GETSTR
       638C 8350
       638E 830C
  0782            * NOTE: FAC through FAC+7 cannot be destroyed
  0783            *       address^of string length^of string
  0784 6390 06A0         BL   @VPUSH            So save it on the stack
       6392 6BAA
  0785 6394 C80A         MOV  R10,@FAC          Save return link in FAC since
       6396 834A
  0786            *                              GETSTR does not destroy FAC
  0787 6398 06A0         BL   @GETSTR           Call GPL to do the GETSTR
       639A 736C
  0788 639C C2A0         MOV  @FAC,R10          Restore return link
       639E 834A
  0789 63A0 06A0         BL   @VPOP             Pop the source info back
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0017
       63A2 6C2A
  0790            * Set up to copy the source string into destination
  0791 63A4 C0E0         MOV  @FAC4,R3          R3 is now copy-from
       63A6 834E
  0792 63A8 C160         MOV  @SREF,R5          R5 is now copy-to
       63AA 831C
  0793 63AC C105         MOV  R5,R4             Save for pointer setting
  0794            * Registers to be used in the copy
  0795            * R1 - Used for a buffer
  0796            * R3 - Copy-from address
  0797            * R2 - # of bytes to be moved
  0798            * R5 - copy-to address
  0799 63AE C0A0         MOV  @FAC6,R2          Fetch the length of the string
       63B0 8350
  0800 63B2 0265         ORI  R5,WRVDP          Enable the VDP write
       63B4 4000
  0801 63B6 06A0  ASSG59 BL   @GETV1            Get the character
       63B8 1880
  0802 63BA D7E0         MOVB @R5LB,*R15        Load out destination address
       63BC 83EB
  0803 63BE 0583         INC  R3                Increment the copy-from
  0804 63C0 D7C5         MOVB R5,*R15           1st byte of address to
  0805 63C2 0585         INC  R5                Increment for next character
  0806 63C4 D801         MOVB R1,@XVDPWD        Put the character out
       63C6 8C00
  0807 63C8 0602         DEC  R2                Decrement count, finished?
  0808 63CA 15F5         JGT  ASSG59            No, loop for more
  0809 63CC 10D3         JMP  ASSG55            Yes, now set pointers
  0810            * Code to copy a numeric value into the symbol table
  0811 63CE 0202  ASSG70 LI   R2,8              Need to assign 8 bytes
       63D0 0008
  0812 63D2 C160         MOV  @ARG4,R5          Destination pointer(R5)
       63D4 8360
  0813            *                              from buffer(R4), (R2)bytes
  0814 63D6 C0E0         MOV  @RAMTOP,R3        Does ERAM exist?
       63D8 8384
  0815 63DA 160C         JNE  ASSG77            Yes, write to ERAM
  0816            *                             No, write to VDP
  0817 63DC D7E0         MOVB @R5LB,*R15        Load out 2nd byte of address
       63DE 83EB
  0818 63E0 0265         ORI  R5,WRVDP          Enable the write to the VDP
       63E2 4000
  0819 63E4 D7C5         MOVB R5,*R15           Load out 1st byte of address
  0820 63E6 0204         LI   R4,FAC            Source is FAC
       63E8 834A
  0821 63EA D834  ASSG75 MOVB *R4+,@XVDPWD      Move a byte
       63EC 8C00
  0822 63EE 0602         DEC  R2                Decrement the counter, done?
  0823 63F0 15FC         JGT  ASSG75            No, loop for more
  0824 63F2 045A         B    *R10              Yes, return to the caller
  0825 63F4 0204  ASSG77 LI   R4,FAC            Source is in FAC
       63F6 834A
  0826 63F8 DD74  ASSG79 MOVB *R4+,*R5+         Move a byte
  0827 63FA 0602         DEC  R2                Decrement the counter, done?
  0828 63FC 15FD         JGT  ASSG79            No, loop for more
  0829 63FE 045A         B    *R10              Yes, return to caller
  0830            * Check for required token
  0831 6400 D01D  SYNCHK MOVB *R13,R0           Read required token
  0832            *
 99/4 ASSEMBLER
BASSUP                                                       PAGE 0018
  0833 6402 9800         CB   R0,@CHAT          Have the required token?
       6404 8342
  0834 6406 1304         JEQ  PGMCH             Yes, read next character
  0835 6408 06A0         BL   @SETREG           Error return requires R8/R9 se
       640A 1E7A
  0836 640C 0460         B    @ERRSYN           * SYNTAX ERROR
       640E 664E
  0837            *      PGMCH - GPL entry point for PGMCHR to set up register
  0838 6410 C30B  PGMCH  MOV  R11,R12           Save return address
  0839 6412 06A0         BL   @PGMCHR           Get the next character
       6414 6C74
  0840 6416 D808         MOVB R8,@CHAT          Put it in for GPL
       6418 8342
  0841 641A 045C         B    *R12              Return to GPL
  0842 641C 045B         RT                     And return to the caller
  0843 641E C13B  PUTV   MOV  *R11+,R4
  0844 6420 C114         MOV  *R4,R4
  0845 6422 D7E0  PUTV1  MOVB @R4LB,*R15
       6424 83E9
  0846 6426 0264         ORI  R4,WRVDP
       6428 4000
  0847 642A D7C4         MOVB R4,*R15
  0848 642C 1000         NOP
  0849 642E D801         MOVB R1,@XVDPWD
       6430 8C00
  0850 6432 045B         RT
  0851            * MOVFAC - copies 8 bytes from VDP(@FAC4) or ERAM(@FAC4)
  0852            *          to FAC
  0853 6434 C060  MOVFAC MOV @FAC4,R1           Get pointer to source
       6436 834E
  0854 6438 0202         LI  R2,8               8 byte values
       643A 0008
  0855 643C 0203         LI  R3,FAC             Destination is FAC
       643E 834A
  0856 6440 C020         MOV @RAMTOP,R0         Does ERAM exist?
       6442 8384
  0857 6444 160A         JNE MOVFA2             Yes, from ERAM
  0858            *                             No, from VDP RAM
  0859 6446 06C1         SWPB R1
  0860 6448 D7C1         MOVB R1,*R15           Load 2nd byte of address
  0861 644A 06C1         SWPB R1
  0862 644C D7C1         MOVB R1,*R15           Load 1st byte of address
  0863 644E 0205         LI   R5,XVDPRD
       6450 8800
  0864 6452 DCD5  MOVF1  MOVB *R5,*R3+          Move a byte
  0865 6454 0602         DEC  R2                Decrement counter, done?
  0866 6456 15FD         JGT  MOVF1             No, loop for more
  0867 6458 045B         RT                     Yes, return to caller
  0868 645A DCF1  MOVFA2 MOVB *R1+,*R3+
  0869 645C 0602         DEC  R2
  0870 645E 16FD         JNE  MOVFA2
  0871 6460 045B         RT
  0872 6462 045B         RT                     And return to caller
  0873            ************************************************************
  0874 6464              AORG >6464
  0876
  0877            *      BASIC PARSE CODE
  0878            * REGISTER USAGE
  0879            *    RESERVED FOR GPL INTERPRETER  R13, R14, R15
 99/4 ASSEMBLER
PARSES                                                       PAGE 0019
  0880            *          R13 contains the read address for GROM
  0881            *          R14 is used in BASSUP/10 for the VDPRAM pointer
  0882            *    RESERVED IN BASIC SUPPORT
  0883            *          R8 MSB current character (like CHAT in GPL)
  0884            *          R8 LSB zero
  0885            *          R10 read data port address for program data
  0886            *   ALL EXITS TO GPL MUST GO THROUGH "NUDG05"
  0887            *
  0888
  0889            *                         ~~~TOKENS~~~
  0890      0081  ELSEZ  EQU  >81               ELSE
  0891      0082  SSEPZ  EQU  >82               STATEMENT SEPERATOR
  0892      0083  TREMZ  EQU  >83               TAIL REMARK
  0893      0084  IFZ    EQU  >84               IF
  0894      0085  GOZ    EQU  >85               GO
  0895      0086  GOTOZ  EQU  >86               GOTO
  0896      0087  GOSUBZ EQU  >87               GOSUB
  0897      008E  BREAKZ EQU  >8E               BREAK
  0898      0096  NEXTZ  EQU  >96               NEXT
  0899      00A1  SUBZ   EQU  >A1               SUB
  0900      00A5  ERRORZ EQU  >A5               ERROR
  0901      00A6  WARNZ  EQU  >A6               WARNING
  0902      00B0  THENZ  EQU  >B0               THEN
  0903      00B1  TOZ    EQU  >B1               TO
  0904      00B3  COMMAZ EQU  >B3               COMMA
  0905      00B6  RPARZ  EQU  >B6               RIGHT PARENTHESIS )
  0906      00B7  LPARZ  EQU  >B7               LEFT PARENTHESIS (
  0907      00BA  ORZ    EQU  >BA               OR
  0908      00BB  ANDZ   EQU  >BB               AND
  0909      00BC  XORZ   EQU  >BC               XOR
  0910      00BD  NOTZ   EQU  >BD               NOT
  0911      00BE  EQZ    EQU  >BE               EQUAL (=)
  0912      00C0  GTZ    EQU  >C0               GREATER THEN (>)
  0913      00C1  PLUSZ  EQU  >C1               PLUS (+)
  0914      00C2  MINUSZ EQU  >C2               MINUS (-)
  0915      00C4  DIVIZ  EQU  >C4               DIVIDE (/)
  0916      00C5  EXPONZ EQU  >C5               EXPONENT
  0917      00C7  STRINZ EQU  >C7               STRING
  0918      00C9  LNZ    EQU  >C9               LINE NUMBER
  0919      00CB  ABSZ   EQU  >CB               ABSOLUTE
  0920      00D1  SGNZ   EQU  >D1               SIGN
  0921            *
  0922 6464 0018  C24    DATA 24                CONSTANT 24
  0923 6466 65A6  EXRTNA DATA EXRTN             RETURN FOR EXEC
  0924            *
  0925 6468 0200  ERRSO  LI   R0,>0703          Issue STACK OVERFLOW message
       646A 0703
  0926 646C 0460         B    @ERR
       646E 6652
  0927            *
  0928            * GRAPHICS LANGUAGE ENTRY TO PARSE
  0929            *
  0930 6470 06A0  PARSEG BL   @SETREG           Set up registers for Basic
       6472 1E7A
  0931 6474 D2ED         MOVB @GRMRAX(R13),R11   Get GROM address
       6476 0002
  0932 6478 D82D         MOVB @GRMRAX(R13),@R11LB
       647A 0002
       647C 83F7
 99/4 ASSEMBLER
PARSES                                                       PAGE 0020
  0933 647E 060B         DEC  R11
  0934            *
  0935            * 9900 ENTRY TO PARSE
  0936            *
  0937 6480 05C9  PARSE  INCT R9                Get room for return address
  0938 6482 0289         CI   R9,STKEND         Stack full?
       6484 83BA
  0939 6486 1BF0         JH   ERRSO             Yes, too many levels deep
  0940 6488 C64B         MOV  R11,*R9           Save the return address
  0941 648A D1C8  P05    MOVB R8,R7             Test for token beginning
  0942 648C 1102         JLT  P10               If token, then look it up
  0943 648E 0460         B    @PSYM             If not token is a symbol
       6490 6884
  0944 6492 06A0  P10    BL   @PGMCHR           Get next character
       6494 6C74
  0945 6496 0977         SRL  R7,7              Change last character to offse
  0946 6498 0227         AI   R7,->B7*2         Check for legal NUD
       649A FE92
  0947 649C 0287         CI   R7,NTABLN         Within the legal NUD address?
       649E 0056
  0948 64A0 1B22         JH   CONT15            No, check for legal LED
  0949 64A2 C1E7         MOV  @NTAB(R7),R7      Get NUD address
       64A4 69FE
  0950 64A6 1525         JGT  B9900             If 9900 code
  0951      64A8  P17    EQU  $                 R7 contains offset into nudtab
  0952 64A8 0247         ANDI R7,>7FFF          If GPL code, get rid of MSB
       64AA 7FFF
  0953 64AC A1E0         A    @NUDTAB,R7        Add in table address
       64AE 8328
  0954 64B0 06A0  NUDG05 BL   @SAVREG           Restore GPL pointers
       64B2 1E8C
  0955 64B4 DB47         MOVB R7,@GRMWAX(R13)    Write out new GROM address
       64B6 0402
  0956 64B8 06C7         SWPB R7                Bare the LSB
  0957 64BA DB47         MOVB R7,@GRMWAX(R13)    Put it out too
       64BC 0402
  0958 64BE 0460         B    @RESET            Go back to GPL interpreter
       64C0 006A
  0959 64C2 10F2  P17L   JMP  P17
  0960            *
  0961            * CONTINUE ROUTINE FOR PARSE
  0962            *
  0963 64C4 06A0  CONTG  BL   @SETREG           GPL entry-set Basic registers
       64C6 1E7A
  0964 64C8 C199  CONT   MOV  *R9,R6            Get last address from stack
  0965 64CA 1506         JGT  CONT10            9900 code if not negative
  0966 64CC DB46         MOVB R6,@GRMWAX(R13)    Write out new GROM address
       64CE 0402
  0967 64D0 06C6         SWPB R6                Bare the second byte
  0968 64D2 DB46         MOVB R6,@GRMWAX(R13)    Put it out too
       64D4 0402
  0969 64D6 C18D         MOV  R13,R6            Set up to test precedence
  0970 64D8 9216  CONT10 CB   *R6,R8            Test precedence
  0971 64DA 1411         JHE  NUDNDL            Have parsed far enough->return
  0972 64DC 0978         SRL  R8,7              Make into table offset
  0973 64DE 0228         AI   R8,->B8*2         Minimum token for a LED (*2)
       64E0 FE90
  0974 64E2 0288         CI   R8,LTBLEN         Maximum token for a LED (*2)
       64E4 001C
 99/4 ASSEMBLER
PARSES                                                       PAGE 0021
  0975 64E6 1B09  CONT15 JH   NOLEDL            If outside legal LED range-err
  0976 64E8 C1E8         MOV  @LTAB(R8),R7      Pick up address of LED handler
       64EA 6A54
  0977 64EC 04C8         CLR  R8                Clear 'CHAT' for getting new
  0978 64EE 06A0         BL   @PGMCHR           Get next character
       64F0 6C74
  0979 64F2 0457  B9900  B    *R7               Go to the LED handler
  0980 64F4 0649  NUDE10 DECT R9                Back up subroutine stack
  0981 64F6 0587         INC  R7                Skip over precedence
  0982 64F8 10DB         JMP  NUDG05            Goto code to return to GPL
  0983 64FA 0460  NOLEDL B    @NOLED
       64FC 664E
  0984 64FE 1073  NUDNDL JMP  NUDND1
  0985            * Execute one or more lines of Basic
  0986      6500  EXECG  EQU  $                 GPL entry point for execution
  0987 6500 06A0         BL   @SETREG           Set up registers
       6502 1E7A
  0988 6504 04E0         CLR  @ERRCOD           Clear the return code
       6506 8322
  0989 6508 D020         MOVB @PRGFLG,R0        Imperative statement?
       650A 8344
  0990 650C 131A         JEQ  EXEC15            Yes, handle it as such
  0991            * Loop for each statement in the program
  0992      650E  EXEC10 EQU  $
  0993 650E D020         MOVB @FLAG,R0          Now test for trace mode
       6510 8345
  0994 6512 0A30         SLA  R0,3              Check the trace bit in FLAG
  0995 6514 115F         JLT  TRACL             If set->display line number
  0996 6516 C820  EXEC11 MOV  @EXTRAM,@PGMPTR   Get text pointer
       6518 832E
       651A 832C
  0997 651C 0660         DECT @PGMPTR           Back to the line # to check
       651E 832C
  0998            *                              break point
  0999 6520 06A0         BL   @PGMCHR           Get the first byte of line #
       6522 6C74
  1000 6524 02C0         STST R0                Save status for breakpnt check
  1001 6526 05A0         INC  @PGMPTR           Get text pointer again
       6528 832C
  1002 652A 06A0         BL   @PGMCHR           Go get the text pointer
       652C 6C74
  1003 652E 06C8         SWPB R8                Save 1st byte of text pointer
  1004 6530 06A0         BL   @PGMCHR           Get 2nd byte of text pointer
       6532 6C74
  1005 6534 06C8         SWPB R8                Put text pointer in order
  1006 6536 C808         MOV  R8,@PGMPTR        Set new text pointer
       6538 832C
  1007 653A 04C8         CLR  R8                Clean up the mess
  1008 653C 0A20         SLA  R0,2              Check breakpoint status
  1009 653E 1101         JLT  EXEC15            If no breakpoint set - count
  1010 6540 177A         JNC  BRKPNT            If breakpoint set-handle it
  1011      6542  EXEC15 EQU  $
  1012      6544  C3     EQU  $+2               Constant data 3
  1013      6545  CB3    EQU  $+3               Constant byte 3
  1014 6542 0300         LIMI 3                 Let interrupts loose
       6544 0003
  1015      6548  C0     EQU  $+2               Constant data 0
  1016 6546 0300         LIMI 0                 Shut down interrupts
       6548 0000
 99/4 ASSEMBLER
PARSES                                                       PAGE 0022
  1017 654A 04E0         CLR  @>83D6            Reset VDP timeout
       654C 83D6
  1018 654E 020C         LI   R12,>24           Load console KBD address in CR
       6550 0024
  1019 6552 30E0         LDCR @C0,3             Select keyboard section
       6554 6548
  1020 6556 020C         LI   R12,6             Read address
       6558 0006
  1021 655A 3600         STCR R0,8              SCAN the keyboard
  1022 655C 2420         CZC  @C1000,R0         Shift-key depressed?
       655E 600A
  1023 6560 160A         JNE  EXEC16            No, execute the Basic statemen
  1024 6562 020C         LI   R12,>24           Test column 3 of keyboard
       6564 0024
  1025 6566 30E0         LDCR @CB3,3            Select keyboard section
       6568 6545
  1026 656A 020C         LI   R12,6             Read address
       656C 0006
  1027 656E 3600         STCR R0,8              SCAN the keyboard
  1028 6570 2420         CZC  @C1000,R0         Shift-C depressed?
       6572 600A
  1029 6574 132E         JEQ  BRKP1L            Yes, so take Basic breakpoint
  1030 6576 C820  EXEC16 MOV  @PGMPTR,@SMTSRT   Save start of statement
       6578 832C
       657A 831E
  1031 657C 05C9         INCT R9                Get subroutine stack space
  1032 657E C660         MOV  @EXRTNA,*R9       Save the GPL return address
       6580 6466
  1033 6582 06A0         BL   @PGMCHR           Now get 1st character of stmt
       6584 6C74
  1034 6586 1320         JEQ  EXRTN3            If EOL after EOS
  1035 6588 1102  EXEC17 JLT  EXEC20            If top bit set->keyword
  1036 658A 0460         B    @NLET             If not->fake a 'LET' stmt
       658C 6948
  1037 658E C1C8  EXEC20 MOV  R8,R7             Save 1st token so can get 2nd
  1038 6590 05A0         INC  @PGMPTR           Increment the perm pointer
       6592 832C
  1039 6594 D21A         MOVB *R10,R8           Read the character
  1040 6596 0977         SRL  R7,7              Convert 1st to table offset
  1041 6598 0227         AI   R7,->AA*2         Check for legal stmt token
       659A FEAC
  1042 659C 1558         JGT  ERRONE            Not in range -> error
  1043 659E C1E7         MOV  @STMTTB(R7),R7    Get address of stmt handler
       65A0 69FC
  1044 65A2 118F         JLT  P17L              If top bit set -> GROM code
  1045 65A4 0457         B    *R7               If 9900 code, goto it!
  1046 65A6   83  EXRTN  BYTE >83               Unused bytes for data constant
  1047 65A7   65  CBH65  BYTE >65                since NUDEND skips precedence
  1048 65A8 0288         CI   R8,SSEPZ*256      EOS only?
       65AA 8200
  1049 65AC 13CA         JEQ  EXEC15            Yes, continue on this line
  1050 65AE D020  EXRTN2 MOVB @PRGFLG,R0        Did we execute an imperative
       65B0 8344
  1051 65B2 1351         JEQ  EXEC50            Yes, so return to top-level
  1052 65B4 6820         S    @C4,@EXTRAM       No, so goto the next line
       65B6 6A80
       65B8 832E
  1053 65BA 8820         C    @EXTRAM,@STLN     Check to see if end of program
       65BC 832E
 99/4 ASSEMBLER
PARSES                                                       PAGE 0023
       65BE 8330
  1054 65C0 14A6         JHE  EXEC10            No, so loop for the next line
  1055 65C2 1049         JMP  EXEC50            Yes, so return to top-level
  1056            *
  1057            * STMT handler for ::
  1058            *
  1059 65C4 D208  SMTSEP MOVB R8,R8             EOL?
  1060 65C6 16E0         JNE  EXEC17            NO, there is another stmt
  1061 65C8 0649  EXRTN3 DECT R9                YES
  1062 65CA 10F1         JMP  EXRTN2            Jump back into it
  1063            * Continue after a breakpoint
  1064 65CC 06A0  CONTIN BL   @SETREG           Set up Basic registers
       65CE 1E7A
  1065 65D0 10B8  EXC15L JMP  EXEC15            Continue execution
  1066 65D2 1038  BRKP1L JMP  BRKPN1
  1067 65D4 104E  TRACL  JMP  TRACE
  1068            * Test for required End-Of-Statement
  1069 65D6 D208  EOL    MOVB R8,R8             EOL reached?
  1070 65D8 1306         JEQ  NUDND1            Yes
  1071 65DA 0288         CI   R8,TREMZ*256      Higher then tail remark token?
       65DC 8300
  1072 65DE 1B37         JH   ERRONE            Yes, its an error
  1073 65E0 0288         CI   R8,ELSEZ*256      Tail, ssep or else?
       65E2 8100
  1074 65E4 1A34         JL   ERRONE            No, error
  1075            *
  1076            * Return from call to PARSE
  1077            * (entered from CONT)
  1078            *
  1079 65E6 C1D9  NUDND1 MOV  *R9,R7            Get the return address
  1080 65E8 1185         JLT  NUDE10            If negative - return to GPL
  1081 65EA 0649         DECT R9                Back up the subroutine stack
  1082 65EC 0467         B    @2(R7)            And return to caller
       65EE 0002
  1083            *      (Skip the precedence word)
  1084 65F0 D208  NUDEND MOVB R8,R8             Check for EOL
  1085 65F2 13F9         JEQ  NUDND1            If EOL
  1086 65F4 0288  NUDND2 CI   R8,STRINZ*256     Lower than a string?
       65F6 C700
  1087 65F8 1A08         JL   NUDND4            Yes
  1088 65FA 0288         CI   R8,LNZ*256        Higher than a line #?
       65FC C900
  1089 65FE 1315         JEQ  SKPLN             Skip line numbers
  1090 6600 1A0B         JL   SKPSTR            Skip string or numeric
  1091 6602 06A0  NUDND3 BL   @PGMCHR           Read next character
       6604 6C74
  1092 6606 13EF         JEQ  NUDND1            If EOL
  1093 6608 10F5         JMP  NUDND2            Continue scan of line
  1094 660A 0288  NUDND4 CI   R8,TREMZ*256      Higher than a tail remark?
       660C 8300
  1095 660E 1BF9         JH   NUDND3            Yes
  1096 6610 0288         CI   R8,SSEPZ*256      Lower then stmt sep(else)?
       6612 8200
  1097 6614 1AF6         JL   NUDND3            Yes
  1098 6616 10E7         JMP  NUDND1            TREM or SSEP
  1099 6618 06A0  SKPSTR BL   @PGMCHR
       661A 6C74
  1100 661C 06C8         SWPB R8                Prepare to add
  1101 661E A808         A    R8,@PGMPTR        Skip it
 99/4 ASSEMBLER
PARSES                                                       PAGE 0024
       6620 832C
  1102 6622 04C8         CLR  R8                Clear lower byte
  1103 6624 06A0  SKPS01 BL   @PGMCHR           Get next token
       6626 6C74
  1104 6628 10E3         JMP  NUDEND            Go on
  1105 662A 05E0  SKPLN  INCT @PGMPTR           Skip line number
       662C 832C
  1106 662E 10FA         JMP  SKPS01            Go on
  1107            *
  1108            * Return from "CALL" to GPL
  1109 6630 06A0  RTNG   BL   @SETREG           Set up registers again
       6632 1E7A
  1110 6634 10D8         JMP  NUDND1            And jump back into it!
  1111            ************************************************************
  1112            * Handle Breakpoints
  1113 6636 D020  BRKPNT MOVB @FLAG,R0          Check flag bits
       6638 8345
  1114 663A 0A10         SLA  R0,1              Check bit 6 for breakpoint
  1115 663C 11C9         JLT  EXC15L            If set then ignore breakpoint
  1116 663E 0200  BRKPN2 LI   R0,BRKFL
       6640 0001
  1117 6642 1007         JMP  EXIT              Return to top-level
  1118 6644 D020  BRKPN1 MOVB @FLAG,R0          Move flag bits
       6646 8345
  1119 6648 0A10         SLA  R0,1              Check bit 6 for breakpoint
  1120 664A 1195         JLT  EXEC16            If set then ignore breakpoint
  1121 664C 10F8         JMP  BRKPN2            Bit not set
  1122            *
  1123            * Error handling from 9900 code
  1124            *
  1125      664E  ERRSYN EQU  $                 These all issue same message
  1126      664E  ERRONE EQU  $
  1127      664E  NONUD  EQU  $
  1128      664E  NOLED  EQU  $
  1129 664E 0200         LI   R0,ERRSN          *SYNTAX ERROR return code
       6650 0003
  1130      6652  EXIT   EQU  $
  1131 6652 C800  ERR    MOV  R0,@ERRCOD        Load up return code for GPL
       6654 8322
  1132            * General return to GPL portion of Basic
  1133 6656 C1E0  EXEC50 MOV  @RTNADD,R7        Get return address
       6658 8326
  1134 665A 0460         B    @NUDG05           Use commond code to link back
       665C 64B0
  1135            * Handle STOP and END statements
  1136            STOP
  1137 665E 0649  END    DECT R9                Pop last call to PARSE
  1138 6660 10FA         JMP  EXEC50            Jump to return to top-level
  1139            * Error codes for return to GPL
  1140      0003  ERRSN  EQU  >0003             ERROR SYNTAX
  1141      0103  ERROM  EQU  >0103             ERROR OUT OF MEMORY
  1142      0203  ERRIOR EQU  >0203             ERROR INDEX OUT OF RANGE
  1143      0303  ERRLNF EQU  >0303             ERROR LINE NOT FOUND
  1144      0403  ERREX  EQU  >0403             ERROR EXECUTION
  1145            * >0004 WARNING NUMERIC OVERFLOW
  1146      0001  BRKFL  EQU  >0001             BREAKPOINT RETURN VECTOR
  1147      0005  ERROR  EQU  >0005             ON ERROR
  1148      0006  UDF    EQU  >0006             FUNCTION REFERENCE
  1149      0007  BREAK  EQU  >0007             ON BREAK
 99/4 ASSEMBLER
PARSES                                                       PAGE 0025
  1150      0008  CONCAT EQU  >0008             CONCATENATE (&) STRINGS
  1151      0009  WARN   EQU  >0009             ON WARNING
  1152            * Warning routine (only OVERFLOW)
  1153 6662 C820  WARNZZ MOV  @C4,@ERRCOD       Load warning code for GPL
       6664 6A80
       6666 8322
  1154 6668 020B         LI   R11,CONT-2        To optimize for return
       666A 64C6
  1155            * Return to GPL as a CALL
  1156 666C 05C9  CALGPL INCT R9                Get space on subroutine stack
  1157 666E C64B         MOV  R11,*R9           Save return address
  1158 6670 10F2         JMP  EXEC50            And go to GPL
  1159            * Trace a line (Call GPL routine)
  1160 6672 C820  TRACE  MOV  @C2,@ERRCOD       Load return vector
       6674 6000
       6676 8322
  1161 6678 020B         LI   R11,EXEC11-2      Set up for return to execute
       667A 6514
  1162 667C 10F7         JMP  CALGPL            Call GPL to display line #
  1163            * Special code to handle concatenate (&)
  1164 667E 0200  CONC   LI   R0,CONCAT         Go to GPL to handle it
       6680 0008
  1165 6682 10E7         JMP  EXIT              Exit to GPL interpeter
  1166            ************************************************************
  1167            *              NUD routine for a numeric constant
  1168            * NUMCON first puts pointer to the numeric string into
  1169            * FAC12 for CSN, clears the error byte (FAC10) and then
  1170            * converts from a string to a floating point number. Issues
  1171            * warning if necessary. Leaves value in FAC
  1172            ************************************************************
  1173 6684 C820  NUMCON MOV  @PGMPTR,@FAC12    Set pointer for CSN
       6686 832C
       6688 8356
  1174 668A 06C8         SWPB R8                Swap to get length into LSB
  1175 668C A808         A    R8,@PGMPTR        Add to pointer to check end
       668E 832C
  1176 6690 04E0         CLR  @FAC10            Assume no error
       6692 8354
  1177 6694 06A0         BL   @SAVRE2           Save registers
       6696 1E90
  1178 6698 0203         LI   R3,GETCH          Adjustment for ERAM in order
       669A 60AE
  1179 669C D120         MOVB @RAMFLG,R4         to call CSN
       669E 8389
  1180 66A0 1302         JEQ  NUMC49
  1181 66A2 0203         LI   R3,GETCGR
       66A4 60D0
  1182 66A6 06A0  NUMC49 BL   @CSN01            Convert String to Number
       66A8 11B2
  1183 66AA 06A0         BL   @SETREG           Restore registers
       66AC 1E7A
  1184 66AE 8820         C    @FAC12,@PGMPTR    Check to see if all converted
       66B0 8356
       66B2 832C
  1185 66B4 16CC         JNE  ERRONE            If not - error
  1186 66B6 06A0         BL   @PGMCHR           Now get next char from program
       66B8 6C74
  1187 66BA D020         MOVB @FAC10,R0         Get an overflow on conversion?
       66BC 8354
 99/4 ASSEMBLER
PARSES                                                       PAGE 0026
  1188 66BE 16D1         JNE  WARNZZ            Yes, have GPL issue warning
  1189 66C0 0460         B    @CONT             Continue the PARSE
       66C2 64C8
  1190            *
  1191            * ON ERROR, ON WARNING and ON BREAK
  1192 66C4 0200  ONERR  LI   R0,ERROR          ON ERROR code
       66C6 0005
  1193 66C8 10C4         JMP  EXIT              Return to GPL code
  1194 66CA 0200  ONWARN LI   R0,WARN           ON WARNING code
       66CC 0009
  1195 66CE 10C1         JMP  EXIT              Return to GPL code
  1196 66D0 0200  ONBRK  LI   R0,BREAK          ON BREAK code
       66D2 0007
  1197 66D4 10BE         JMP  EXIT              Return to GPL code
  1198            *
  1199            * NUD routine for "GO"
  1200            *
  1201 66D6 04C3  GO     CLR  R3                Dummy "ON" index for common
  1202 66D8 1020         JMP  ON30              Merge into "ON" code
  1203            *
  1204            * NUD ROUTINE FOR "ON"
  1205            *
  1206 66DA 0288  ON     CI   R8,WARNZ*256      On warning?
       66DC A600
  1207 66DE 13F5         JEQ  ONWARN            Yes, goto ONWARN
  1208 66E0 0288         CI   R8,ERRORZ*256     On error?
       66E2 A500
  1209 66E4 13EF         JEQ  ONERR             Yes, got ONERR
  1210 66E6 0288         CI   R8,BREAKZ*256     On break?
       66E8 8E00
  1211 66EA 13F2         JEQ  ONBRK             Yes, goto ONBRK
  1212            *
  1213            * Normal "ON" statement
  1214            *
  1215 66EC 06A0         BL   @PARSE            PARSE the index value
       66EE 6480
  1216 66F0   B3         BYTE COMMAZ            Stop on a comma or less
  1217 66F1   66  CBH66  BYTE >66               Unused byte for constant
  1218 66F2 06A0         BL   @NUMCHK           Ensure index is a number
       66F4 6B92
  1219 66F6 04E0         CLR  @FAC10            Assume no error in CFI
       66F8 8354
  1220 66FA 06A0         BL   @CFI              Convert Floating to Integer
       66FC 12B8
  1221 66FE D020         MOVB @FAC10,R0         Test error code
       6700 8354
  1222 6702 1603         JNE  GOTO90            If overflow, BAD VALUE
  1223 6704 C0E0         MOV  @FAC,R3           Get the index
       6706 834A
  1224 6708 1503         JGT  ON20              Must be positive
  1225 670A 0200  GOTO90 LI   R0,ERRIOR         Negative, BAD VALUE
       670C 0203
  1226 670E 10A1  GOTO95 JMP  ERR               Jump to error handler
  1227      6710  ON20   EQU  $                 Now check GO TO/SUB
  1228 6710 0288         CI   R8,GOZ*256        Bare "GO" token?
       6712 8500
  1229 6714 1608         JNE  ON40              No, check other possibilities
  1230 6716 06A0         BL   @PGMCHR           Yes, get next token
       6718 6C74
 99/4 ASSEMBLER
PARSES                                                       PAGE 0027
  1231 671A 0288  ON30   CI   R8,TOZ*256        "GO TO" ?
       671C B100
  1232 671E 1365         JEQ  GOTO50            Yes, handle GO TO like GOTO
  1233 6720 0288         CI   R8,SUBZ*256       "GO SUB" ?
       6722 A100
  1234 6724 1005         JMP  ON50              Merge to common code to test
  1235 6726 0288  ON40   CI   R8,GOTOZ*256      "GOTO" ?
       6728 8600
  1236 672A 135F         JEQ  GOTO50            Yes, go handle it
  1237 672C 0288         CI   R8,GOSUBZ*256     "GOSUB" ?
       672E 8700
  1238 6730 168E  ON50   JNE  ERRONE            No, so is an error
  1239 6732 06A0         BL   @PGMCHR           Get next token
       6734 6C74
  1240 6736 1002         JMP  GOSUB2            Goto gosub code
  1241 6738 108A  ERR1B  JMP  ERRONE            Issue error message
  1242            * NUD routine for "GOSUB"
  1243 673A 04C3  GOSUB  CLR  R3                Dummy index for "ON" code
  1244            * Common GOSUB code
  1245      673C  GOSUB2 EQU  $                 Now build a FAC entry
  1246 673C 0201         LI   R1,FAC            Optimize to save bytes
       673E 834A
  1247 6740 CC43         MOV  R3,*R1+           Save the "ON" index
  1248            *                              in case of garbage collection
  1249 6742 DC60         MOVB @CBH66,*R1+       Indicate GOSUB entry on stack
       6744 66F1
  1250 6746 0581         INC  R1                Skip FAC3
  1251 6748 C460         MOV  @PGMPTR,*R1       Save current ptr w/in line
       674A 832C
  1252 674C 05F1         INCT *R1+              Skip line # to correct place
  1253 674E C460         MOV  @EXTRAM,*R1       Save current line # pointer
       6750 832E
  1254 6752 06A0         BL   @VPUSH            Save the stack entry
       6754 6BAA
  1255 6756 C0E0         MOV  @FAC,R3           Restore the "ON" index
       6758 834A
  1256 675A 1001         JMP  GOTO20            Jump to code to find the line
  1257            * NUD routine for "GOTO"
  1258 675C 04C3  GOTO   CLR  R3                Dummy index for "ON" code
  1259            * Common (ON) GOTO/GOSUB THEN/ELSE code to fine line
  1260            *
  1261            * Get line number from program
  1262 675E 0288  GOTO20 CI   R8,LNZ*256        Must have line number token
       6760 C900
  1263 6762 16EA         JNE  ERR1B             Don't, so error
  1264 6764 06A0  GETL10 BL   @PGMCHR           Get MSB of the line number
       6766 6C74
  1265 6768 D008         MOVB R8,R0             Save it
  1266 676A 06A0         BL   @PGMCHR           Read the character
       676C 6C74
  1267 676E 0603         DEC  R3                Decrement the "ON" index
  1268 6770 1534         JGT  GOTO40            Loop if not there yet
  1269            *
  1270            * Find the program line
  1271            *
  1272 6772 C060         MOV  @STLN,R1          Get into line # table
       6774 8330
  1273 6776 D0A0         MOVB @RAMFLG,R2        Check ERAM flag to see where?
       6778 8389
 99/4 ASSEMBLER
PARSES                                                       PAGE 0028
  1274 677A 1310         JEQ  GOTO31            From VDP, go handle it
  1275 677C C081         MOV  R1,R2             Copy address
  1276 677E 8801  GOT32  C    R1,@ENLN          Finished w/line # table?
       6780 8332
  1277 6782 1422         JHE  GOTO34            Yes, so line doesn't exist
  1278 6784 D0F2         MOVB *R2+,R3           2nd byte match?
  1279 6786 0243         ANDI R3,>7FFF          Reset possible breakpoint
       6788 7FFF
  1280 678A 9003         CB   R3,R0             Compare 1st byte of #, Match?
  1281 678C 1605         JNE  GOT35             Not a match, so move on
  1282 678E 9232         CB   *R2+,R8           2nd byte match?
  1283 6790 131E         JEQ  GOTO36            Yes, line is found!
  1284 6792 05C2  GOT33  INCT R2                Skip line pointer
  1285 6794 C042         MOV  R2,R1             Advance to next line in table
  1286 6796 10F3         JMP  GOT32             Go back for more
  1287 6798 D0F2  GOT35  MOVB *R2+,R3           Skip 2nd byte of line #
  1288 679A 10FB         JMP  GOT33             And jump back in
  1289 679C D7E0  GOTO31 MOVB @R1LB,*R15        Get the data from the VDP
       679E 83E3
  1290 67A0 0202         LI   R2,XVDPRD         Load up to read data
       67A2 8800
  1291 67A4 D7C1         MOVB R1,*R15           Write out MSB of address
  1292 67A6 8801  GOTO32 C    R1,@ENLN          Finished w/line # table
       67A8 8332
  1293 67AA 140E         JHE  GOTO34            Yes, so line doesn't exist
  1294 67AC D0D2         MOVB *R2,R3            Save in temporary place for
  1295            *                              breakpoint checking
  1296 67AE 0243         ANDI R3,>7FFF          Reset possible breakpoint
       67B0 7FFF
  1297 67B2 9003         CB   R3,R0             Compare 1st byte of #, Match?
  1298 67B4 1607         JNE  GOTO35            Not a match, so move on
  1299 67B6 9212         CB   *R2,R8            2nd byte match?
  1300 67B8 130A         JEQ  GOTO36            Yes, line is found!
  1301 67BA D0D2  GOTO33 MOVB *R2,R3            Skip 1st byte of line pointer
  1302 67BC 0221         AI   R1,4              Advance to next line in table
       67BE 0004
  1303 67C0 D0D2         MOVB *R2,R3            Skip 1nd byte of line pointer
  1304 67C2 10F1         JMP  GOTO32            Go back for more
  1305 67C4 D0D2  GOTO35 MOVB *R2,R3            Skip 2nd byte of line #
  1306 67C6 10F9         JMP  GOTO33            And jump back in
  1307 67C8 0200  GOTO34 LI   R0,ERRLNF         LINE NOT FOUND error vector
       67CA 0303
  1308 67CC 10A0         JMP  GOTO95            Jump for error exit
  1309 67CE 05C1  GOTO36 INCT R1                Adjust to line pointer
  1310 67D0 C801         MOV  R1,@EXTRAM        Save for execution of the line
       67D2 832E
  1311 67D4 0649         DECT R9                Pop saved link to goto
  1312 67D6 0460         B    @EXEC10           Reenter EXEC code directly
       67D8 650E
  1313 67DA 06A0  GOTO40 BL   @PGMCHR           Get next token
       67DC 6C74
  1314 67DE 06A0         BL   @EOSTMT           Premature end of statement?
       67E0 6862
  1315 67E2 1393         JEQ  GOTO90            Yes =>BAD VALUE for index
  1316 67E4 0288         CI   R8,COMMAZ*256     Comma next ?
       67E6 B300
  1317 67E8 1603         JNE  ERR1C             No, error
  1318 67EA 06A0  GOTO50 BL   @PGMCHR           Yes, get next character
       67EC 6C74
 99/4 ASSEMBLER
PARSES                                                       PAGE 0029
  1319 67EE 10B7         JMP  GOTO20            And check this index value
  1320 67F0 10A3  ERR1C  JMP  ERR1B             Linking becuase long-distance
  1321 67F2 0200  ERR51  LI   R0,>0903          RETURN WITHOUT GOSUB
       67F4 0903
  1322 67F6 108B         JMP  GOTO95            Exit to GPL
  1323            * NUD entry for "RETURN"
  1324 67F8 8820  RETURN C    @VSPTR,@STVSPT    Check bottom of stack
       67FA 836E
       67FC 8324
  1325 67FE 12F9         JLE  ERR51             Error -> RETURN WITHOUT GOSUB
  1326 6800 06A0         BL   @VPOP             Pop entry
       6802 6C2A
  1327 6804 9820         CB   @CBH66,@FAC2      Check ID for a GOSUB entry
       6806 66F1
       6808 834C
  1328 680A 160B         JNE  RETU30            Check for ERROR ENTRY
  1329            *
  1330            * Have a GOSUB entry
  1331            *
  1332 680C 06A0         BL   @EOSTMT           Must have EOS after return
       680E 6862
  1333 6810 16F3         JNE  RETURN            Not EOS, then error return?
  1334 6812 C820         MOV  @FAC4,@PGMPTR     Get return ptr w/in line
       6814 834E
       6816 832C
  1335 6818 C820         MOV  @FAC6,@EXTRAM     Get return line pointer
       681A 8350
       681C 832E
  1336 681E 0460         B    @SKPS01           Go adjust it and get back
       6820 6624
  1337            * Check ERROR entry
  1338 6822 9820  RETU30 CB   @CBH69,@FAC2      ERROR ENTRY?
       6824 6A9B
       6826 834C
  1339 6828 1307         JEQ  RETU40            Yes, take care of error entry
  1340 682A 9820         CB   @CBH6A,@FAC2      Subprogram entry?
       682C 6860
       682E 834C
  1341 6830 16E3         JNE  RETURN            No, look some more
  1342 6832 06A0         BL   @VPUSH            Push it back. Keep information
       6834 6BAA
  1343 6836 10DD         JMP  ERR51             RETURN WITHOUT GOSUB error
  1344            *
  1345            * Have an ERROR entry
  1346            * RETURN, RETURN line #, RETURN or RETURN NEXT follows.
  1347            *
  1348 6838 04C3  RETU40 CLR  R3                In case of a line number
  1349 683A 0288         CI   R8,LNZ*256        Check for a line number
       683C C900
  1350 683E 1392         JEQ  GETL10            Yes, treat like GOTO
  1351 6840 C820         MOV  @FAC4,@PGMPTR     Get return ptr w/in line
       6842 834E
       6844 832C
  1352 6846 C820         MOV  @FAC6,@EXTRAM     Get return line pointer
       6848 8350
       684A 832E
  1353 684C 06A0         BL   @EOSTMT           EOL now?
       684E 6862
  1354 6850 1305         JEQ  BEXC15            Yes, treat like GOSUB rtn.
 99/4 ASSEMBLER
PARSES                                                       PAGE 0030
  1355 6852 0288         CI   R8,NEXTZ*256      NEXT now?
       6854 9600
  1356 6856 16CC         JNE  ERR1C             No, so its an error
  1357 6858 0460         B    @SKPS01           Yes, so execute next statement
       685A 6624
  1358 685C 0460  BEXC15 B    @EXEC15           Execute next line
       685E 6542
  1359 6860   6A  CBH6A  BYTE >6A               Subprogram call stack ID
  1360                   EVEN
  1361            ************************************************************
  1362            *         EOSTMT - Check for End-Of-STateMenT
  1363            *         Returns with condition '=' if EOS
  1364            *           else condition '<>' if not EOS
  1365            ************************************************************
  1366 6862 D208  EOSTMT MOVB R8,R8             EOL or non-token?
  1367 6864 1305         JEQ  EOSTM1            EOL-return condition '='
  1368 6866 1504         JGT  EOSTM1            Non-token return condition '<>
  1369 6868 0288         CI   R8,TREMZ*256      In the EOS range (>81 to >83)?
       686A 8300
  1370 686C 1B01         JH   EOSTM1            No, return condition '<>'
  1371 686E 8208         C    R8,R8             Yes, force condition to '='
  1372 6870 045B  EOSTM1 RT
  1373            ************************************************************
  1374            *         EOLINE - Tests for End-Of-LINE; either a >00 or a
  1375            *                  '!'
  1376            *         Returns with condition '=' if EOL else condition
  1377            *                  '<>' if not EOL
  1378            ************************************************************
  1379 6872 D208  EOLINE MOVB R8,R8             EOL?
  1380 6874 1302         JEQ  EOLNE1            Yes, return with '=' set
  1381 6876 0288         CI   R8,TREMZ*256      Set condition on a tall remark
       6878 8300
  1382 687A 045B  EOLNE1 RT                     And return
  1383 687C 0200  SYMB20 LI   R0,UDF            Long distance
       687E 0006
  1384 6880 0460         B    @GOTO95
       6882 670E
  1385            * NUD for a symbol (variable)
  1386 6884 06A0  PSYM   BL   @SYM              Get symbol table entry
       6886 6312
  1387 6888 06A0         BL   @GETV             Get 1st byte of entry
       688A 187C
  1388 688C 834A         DATA FAC               SYM left pointer in FAC
  1389            *
  1390 688E 0A11         SLA  R1,1              UDF reference?
  1391 6890 11F5         JLT  SYMB20            Yes, special code for it
  1392 6892 06A0         BL   @SMB              No, get value space pointer
       6894 61DC
  1393 6896 9820         CB   @FAC2,@CBH65      String reference?
       6898 834C
       689A 65A7
  1394 689C 1302         JEQ  SYMB10            Yes, special code for it
  1395 689E 06A0         BL   @MOVFAC           No, numeric ->copy into FAC
       68A0 6434
  1396 68A2 0460  SYMB10 B    @CONT             And continue the PARSE
       68A4 64C8
  1397            * Statement entry for IF statement
  1398 68A6 06A0  IF     BL   @PARSE            Evaluate the expression
       68A8 6480
 99/4 ASSEMBLER
PARSES                                                       PAGE 0031
  1399 68AA   B3         BYTE COMMAZ            Stop on a comma
  1400 68AB   67  CBH67  BYTE >67               Unused byte for a constant
  1401 68AC 06A0         BL   @NUMCHK           Ensure the value is a number
       68AE 6B92
  1402 68B0 04C3         CLR  R3                Create a dummy "ON" index
  1403 68B2 0288         CI   R8,THENZ*256      Have a "THEN" token
       68B4 B000
  1404 68B6 169C         JNE  ERR1C             No, error
  1405 68B8 0520         NEG  @FAC              Test if condition true i.e. <>
       68BA 834A
  1406 68BC 1610         JNE  IFZ10             True - branch to the special #
  1407 68BE 06A0         BL   @PGMCHR           Advance to line number token
       68C0 6C74
  1408 68C2 0288         CI   R8,LNZ*256        Have the line # token?
       68C4 C900
  1409 68C6 1619         JNE  IFZ20             No, must look harder for ELSE
  1410 68C8 05E0         INCT @PGMPTR           Skip the line number
       68CA 832C
  1411 68CC 06A0         BL   @PGMCHR           Get next token
       68CE 6C74
  1412 68D0 0288  IFZ5   CI   R8,ELSEZ*256      Test if token is ELSE
       68D2 8100
  1413 68D4 1304         JEQ  IFZ10             We do! So branch to the line #
  1414 68D6 0460         B    @EOL              We don't, so better be EOL
       68D8 65D6
  1415 68DA 0460  GETL1Z B    @GETL10           Get 1st token of clause
       68DC 6764
  1416 68DE 06A0  IFZ10  BL   @PGMCHR           Get 1st token of clause
       68E0 6C74
  1417 68E2 0288         CI   R8,LNZ*256        Line # token?
       68E4 C900
  1418 68E6 13F9         JEQ  GETL1Z            Yes, go there
  1419 68E8 06A0         BL   @EOSTMT           EOS?
       68EA 6862
  1420 68EC 1381  JEQ1C  JEQ  ERR1C             Yes, its an error
  1421 68EE 0208         LI   R8,SSEPZ*256      Cheat to do a continue
       68F0 8200
  1422 68F2 0620         DEC  @PGMPTR           Back up to get 1st character
       68F4 832C
  1423 68F6 0460         B    @CONT             Continue on
       68F8 64C8
  1424            *
  1425            * LOOK FOR AN ELSE CLAUSE SINCE THE CONDITION WAS FALSE
  1426            *
  1427 68FA 0203  IFZ20  LI   R3,1              IF/ELSE pair counter
       68FC 0001
  1428 68FE 06A0         BL   @EOLINE           Trap out EOS following THEN/EL
       6900 6872
  1429 6902 13F4         JEQ  JEQ1C             error
  1430 6904 0288  IFZ25  CI   R8,ELSEZ*256      ELSE?
       6906 8100
  1431 6908 1603         JNE  IFZ27             If not
  1432 690A 0603         DEC  R3                Matching ELSE?
  1433 690C 13E8         JEQ  IFZ10             Yes, do it
  1434 690E 100F         JMP  IFZ35             No, go on
  1435 6910 0288  IFZ27  CI   R8,IFZ*256        Check for it
       6912 8400
  1436 6914 1602         JNE  IFZ28             Not an IF
  1437 6916 0583         INC  R3                Increment nesting level
 99/4 ASSEMBLER
PARSES                                                       PAGE 0032
  1438 6918 100A         JMP  IFZ35              And go on
  1439 691A 0288  IFZ28  CI   R8,STRINZ*256     Lower than string?
       691C C700
  1440 691E 1A04         JL   IFZ30             Yes
  1441 6920 0288         CI   R8,LNZ*256        Higher or = to a line #
       6922 C900
  1442 6924 1307         JEQ  IFZ40             = line #
  1443 6926 1A09         JL   IFZ50             Skip strings and numerics
  1444 6928 06A0  IFZ30  BL   @EOLINE           EOL?
       692A 6872
  1445 692C 13D1         JEQ  IFZ5              Yes, done scanning
  1446 692E 06A0  IFZ35  BL   @PGMCHR           Get next character
       6930 6C74
  1447 6932 10E8         JMP  IFZ25               And go on
  1448            *
  1449            * SKIP LINE #'s
  1450            *
  1451 6934 05E0  IFZ40  INCT @PGMPTR           Skip the line #
       6936 832C
  1452 6938 10FA         JMP  IFZ35             Go on
  1453            *
  1454            * SKIP STRINGS AND NUMERICS
  1455            *
  1456 693A 06A0  IFZ50  BL   @PGMCHR           Get # of bytes to skip
       693C 6C74
  1457 693E 06C8         SWPB R8                Swap for add
  1458 6940 A808         A    R8,@PGMPTR        Skip it
       6942 832C
  1459 6944 04C8         CLR  R8                Clear LSB of R8
  1460 6946 10F3         JMP  IFZ35
  1461            ************************************************************
  1462
  1464
  1465            ************************************************************
  1466            *                   'LET' statement handler
  1467            * Assignments are done bye putting an entry on the stack
  1468            * for the destination variable and getting the source value
  1469            * into the FAC. Multiple assignments are handled by the
  1470            * stacking the variable entrys and then looping for the
  1471            * assignments. Numeric assignments pose no problems,
  1472            * strings are more complicated. String assignments are done
  1473            * by assigning the source string to the last variable
  1474            * specified in the list and changing the FAC entry so that
  1475            * the string assigned to the next-to-the-last variable
  1476            * comes from the permanent string belonging to the variable
  1477            * just assigned.
  1478            * e.g.    A$,B$,C$="HELLO"
  1479            *
  1480            *         C$-------"HELLO" (source string)
  1481            *
  1482            *         B$-------"HELLO" (copy from CZ's string)
  1483            *
  1484            *         A$-------"HELLO" (copy from BZ's string)
  1485            ************************************************************
  1486 6948 04E0  NLET   CLR  @PAD0             Counter for multiple assign's
       694A 8300
  1487 694C 06A0  NLET05 BL   @SYM              Get symbol table address
       694E 6312
  1488            *-----------------------------------------------------------
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0033
  1489            * The following code has been taken out for checking is
  1490            * inserted in SMB             5/22/81
  1491            *      BL   @GETV             Get first byte of entry
  1492            *      DATA FAC               SYM left pointer in FAC
  1493            *      SLA  R1,1              Test if a UDF
  1494            *      JLT  ERRMUV            Is a UDF - so error
  1495            *-----------------------------------------------------------
  1496 6950 06A0         BL   @SMB              Get value space pointer
       6952 61DC
  1497 6954 06A0         BL   @VPUSH            Push s.t. pointer on stack
       6956 6BAA
  1498 6958 05A0         INC  @PAD0             Count the variable
       695A 8300
  1499 695C 0288         CI   R8,EQZ*256        Is the token an '='?
       695E BE00
  1500 6960 130B         JEQ  NLET10            Yes, go into assignment loop
  1501 6962 0288         CI   R8,COMMAZ*256     Must have a comma now
       6964 B300
  1502 6966 161E         JNE  ERR1CZ            Didn't - so error
  1503 6968 06A0         BL   @PGMCHR           Get next token
       696A 6C74
  1504 696C 15EF         JGT  NLET05            If legal symbol character
  1505 696E 101A         JMP  ERR1CZ            If not - error
  1506 6970 0200  ERRMUV LI   R0,>0D03          MULTIPLY USED VARIABLE
       6972 0D03
  1507 6974 0460         B    @ERR
       6976 6652
  1508 6978 06A0  NLET10 BL   @PGMCHR           Get next token
       697A 6C74
  1509 697C 06A0         BL   @PARSE            PARSE the value to assign
       697E 6480
  1510 6980   83         BYTE TREMZ             Parse to the end of statement
  1511 6981   65  STCOD2 BYTE >65               Wasted byte (STCODE copy)
  1512            * Loop for assignments
  1513 6982 06A0  NLET15 BL   @ASSG             Assign the value to the symbol
       6984 6334
  1514 6986 0620         DEC  @PAD0             One less to assign, done?
       6988 8300
  1515 698A 130A         JEQ  LETCON            Yes, branch out
  1516 698C 9820         CB   @FAC2,@STCOD2     String or numeric?
       698E 834C
       6990 6981
  1517 6992 16F7         JNE  NLET15            Numeric, just loop for more
  1518 6994 C806         MOV  R6,@FAC4          Get pointer to new string
       6996 834E
  1519 6998 C820         MOV  @ARG,@FAC         Get pointer to last s.t. entry
       699A 835C
       699C 834A
  1520 699E 10F1         JMP  NLET15            Now loop to assign more
  1521 69A0 0460  LETCON B    @EOL              Yes, continue the PARSE
       69A2 65D6
  1522 69A4 0460  ERR1CZ B    @ERR1C            For long distance jump
       69A6 67F0
  1523 69A8 664E         DATA NONUD             (SPARE)             >80
  1524 69AA 664E         DATA NONUD             ELSE                >81
  1525 69AC 65C4         DATA SMTSEP            ::                  >82
  1526 69AE 65E6         DATA NUDND1            !                   >83
  1527 69B0 68A6         DATA IF                IF                  >84
  1528 69B2 66D6         DATA GO                GO                  >85
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0034
  1529 69B4 675C         DATA GOTO              GOTO                >86
  1530 69B6 673A         DATA GOSUB             GOSUB               >87
  1531 69B8 67F8         DATA RETURN            RETURN              >88
  1532 69BA 65F0         DATA NUDEND            DEF                 >89
  1533 69BC 65F0         DATA NUDEND            DIM                 >8A
  1534 69BE 665E         DATA END               END                 >8B
  1535 69C0 7000         DATA NFOR              FOR                 >8C
  1536 69C2 6948         DATA NLET              LET                 >8D
  1537 69C4 8002         DATA >8002             BREAK               >8E
  1538 69C6 8004         DATA >8004             UNBREAK             >8F
  1539 69C8 8006         DATA >8006             TRACE               >90
  1540 69CA 8008         DATA >8008             UNTRACE             >91
  1541 69CC 8016         DATA >8016             INPUT               >92
  1542 69CE 65E6         DATA NUDND1            DATA                >93
  1543 69D0 8012         DATA >8012             RESTORE             >94
  1544 69D2 8014         DATA >8014             RANDOMIZE           >95
  1545 69D4 7230         DATA NNEXT             NEXT                >96
  1546 69D6 800A         DATA >800A             READ                >97
  1547 69D8 665E         DATA STOP              STOP                >98
  1548 69DA 8032         DATA >8032             DELETE              >99
  1549 69DC 65E6         DATA NUDND1            REM                 >9A
  1550 69DE 66DA         DATA ON                ON                  >9B
  1551 69E0 800C         DATA >800C             PRINT               >9C
  1552 69E2 750A         DATA CALL              CALL                >9D
  1553 69E4 65F0         DATA NUDEND            OPTION              >9E
  1554 69E6 8018         DATA >8018             OPEN                >9F
  1555 69E8 801A         DATA >801A             CLOSE               >A0
  1556 69EA 665E         DATA STOP              SUB                 >A1
  1557 69EC 8034         DATA >8034             DISPLAY             >A2
  1558 69EE 65E6         DATA NUDND1            IMAGE               >A3
  1559 69F0 8024         DATA >8024             ACCEPT              >A4
  1560 69F2 664E         DATA NONUD             ERROR               >A5
  1561 69F4 664E         DATA NONUD             WARNING             >A6
  1562 69F6 78D2         DATA SUBXIT            SUBEXIT             >A7
  1563 69F8 78D2         DATA SUBXIT            SUBEND              >A8
  1564 69FA 800E         DATA >800E             RUN                 >A9
  1565 69FC 8010  STMTTB DATA >8010             LINPUT              >AA
  1566 69FE 6E68  NTAB   DATA NLPR              LEFT PARENTHISIS    >B7
  1567 6A00 664E         DATA NONUD             CONCATENATE         >B8
  1568 6A02 664E         DATA NONUD             SPARE               >B9
  1569 6A04 664E         DATA NONUD             AND                 >BA
  1570 6A06 664E         DATA NONUD             OR                  >BB
  1571 6A08 664E         DATA NONUD             XOR                 >BC
  1572 6A0A 6E2E         DATA O0NOT             NOT                 >BD
  1573 6A0C 664E         DATA NONUD             =                   >BE
  1574 6A0E 664E         DATA NONUD             <                   >BF
  1575 6A10 664E         DATA NONUD             >                   >C0
  1576 6A12 6E96         DATA NPLUS             +                   >C1
  1577 6A14 6E82         DATA NMINUS            -                   >C2
  1578 6A16 664E         DATA NONUD             *                   >C3
  1579 6A18 664E         DATA NONUD             /                   >C4
  1580 6A1A 664E         DATA NONUD             ^                   >C5
  1581 6A1C 664E         DATA NONUD             SPARE               >C6
  1582 6A1E 7442         DATA NSTRCN            QUOTED STRING       >C7
  1583 6A20 6684         DATA NUMCON        UNQUOTED STRING/NUMERIC >C8
  1584 6A22 664E         DATA NONUD             LINE NUMBER         >C9
  1585 6A24 8026         DATA >8026             EOF                 >CA
  1586 6A26 6CFA         DATA NABS              ABS                 >CB
  1587 6A28 6D16         DATA NATN              ATN                 >CC
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0035
  1588 6A2A 6D1C         DATA NCOS              COS                 >CD
  1589 6A2C 6D22         DATA NEXP              EXP                 >CE
  1590 6A2E 6D28         DATA NINT              INT                 >CF
  1591 6A30 6D2E         DATA NLOG              LOG                 >D0
  1592 6A32 6D34         DATA NSGN              SGN                 >D1
  1593 6A34 6D64         DATA NSIN              SIN                 >D2
  1594 6A36 6D6A         DATA NSQR              SQR                 >D3
  1595 6A38 6D70         DATA NTAN              TAN                 >D4
  1596 6A3A 8036         DATA >8036             LEN                 >D5
  1597 6A3C 8038         DATA >8038             CHRZ                >D6
  1598 6A3E 803A         DATA >803A             RND                 >D7
  1599 6A40 8030         DATA >8030             SEGZ                >D8
  1600 6A42 802A         DATA >802A             POS                 >D9
  1601 6A44 802C         DATA >802C             VAL                 >DA
  1602 6A46 802E         DATA >802E             STR                 >DB
  1603 6A48 8028         DATA >8028             ASC                 >DC
  1604 6A4A 801C         DATA >801C             PI                  >DD
  1605 6A4C 8000         DATA >8000             REC                 >DE
  1606 6A4E 801E         DATA >801E             MAX                 >DF
  1607 6A50 8020         DATA >8020             MIN                 >E0
  1608 6A52 8022         DATA >8022             RPTZ                >E1
  1609      0056  NTABLN EQU  $-NTAB
  1610 6A54 667E  LTAB   DATA CONC              &                   >B8
  1611 6A56 664E         DATA NOLED             SPARE               >B9
  1612 6A58 6E1C         DATA O0OR              OR                  >BA
  1613 6A5A 6DFA         DATA O0AND             AND                 >BB
  1614 6A5C 6E50         DATA O0XOR             XOR                 >BC
  1615 6A5E 664E         DATA NOLED             NOT                 >BD
  1616 6A60 6A8E         DATA EQUALS            =                   >BE
  1617 6A62 6A70         DATA LESS              <                   >BF
  1618 6A64 6A7E         DATA GREATR            >                   >C0
  1619 6A66 6B1E         DATA PLUS              +                   >C1
  1620 6A68 6B4A         DATA MINUS             -                   >C2
  1621 6A6A 6B56         DATA TIMES             *                   >C3
  1622 6A6C 6B62         DATA DIVIDE            /                   >C4
  1623 6A6E 6CE2         DATA LEXP              ^                   >C5
  1624      001C  LTBLEN EQU  $-LTAB
  1625            ************************************************************
  1626            *                     Relational operators
  1627            * Logical conparisons encode the type of comparison and use
  1628            * common code to PARSE the expression and set the status
  1629            * bits.
  1630            *
  1631            * The types of legal comparisons are:
  1632            *                             0 EQUAL
  1633            *                             1 NOT EQUAL
  1634            *                             2 LESS THAN
  1635            *                             3 LESS OR EQUAL
  1636            *                             4 GREATER THAN
  1637            *                             5 GREATER THAN OR EQUAL
  1638            *
  1639            * This code is saved on the subroutine stack
  1640            ************************************************************
  1641 6A70 0202  LESS   LI   R2,2              LESS-THAN code for common rtn
       6A72 0002
  1642 6A74 0288         CI   R8,GTZ*256        Test for '>' token
       6A76 C000
  1643 6A78 1604         JNE  LT10              Jump if not
  1644 6A7A 0642         DECT R2                Therefore, NOT-EQUAL code
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0036
  1645 6A7C 1005         JMP  LT15              Jump to common
  1646      6A80  C4     EQU  $+2               Constant 4
  1647 6A7E 0202  GREATR LI   R2,4              GREATER-THEN code for common
       6A80 0004
  1648 6A82 0288  LT10   CI   R8,EQZ*256        Test for '=' token
       6A84 BE00
  1649 6A86 1605         JNE  LTST01            Jump if '>='
  1650 6A88 06A0  LT15   BL   @PGMCHR           Must be plain old '>' or '<'
       6A8A 6C74
  1651 6A8C 1001         JMP  LEDLE             Jump to test
  1652 6A8E 0702  EQUALS SETO R2                Equal bit for common routine
  1653 6A90 0582  LEDLE  INC  R2                Sets to zero
  1654 6A92 05C9  LTST01 INCT R9                Get room on stack for code
  1655 6A94 C642         MOV  R2,*R9            Save status matching code
  1656 6A96 06A0         BL   @PSHPRS           Push 1st arg and PARSE the 2nd
       6A98 6B9C
  1657 6A9A   C0         BYTE GTZ               Parse to a '>'
  1658 6A9B   69  CBH69  BYTE >69               Used in RETURN routine
  1659 6A9C C119         MOV  *R9,R4            Get the type code from stack
  1660 6A9E 0649         DECT R9                Reset subroutine stack pointer
  1661 6AA0 D324         MOVB @LTSTAB(R4),R12   Get address bias to baranch to
       6AA2 6ADA
  1662 6AA4 088C         SRA  R12,8             Right justify
  1663 6AA6 06A0         BL   @ARGTST           Test for matching arguments
       6AA8 6B6E
  1664 6AAA 131A         JEQ  LTST20            Handle strings specially
  1665 6AAC 06A0         BL   @SCOMPB           Floating point comparison
       6AAE 0D42
  1666 6AB0 046C  LTST15 B    @LTSTXX(R12)      Interpret the status by code
       6AB2 6AB4
  1667      6AB4  LTSTXX EQU  $
  1668 6AB4 1504  LTSTGE JGT  LTRUE             Test if GREATER or EQUAL
  1669 6AB6 1303  LTSTEQ JEQ  LTRUE             Test if EQUAL
  1670 6AB8 04C4  LFALSE CLR  R4                FALSE is a ZERO
  1671 6ABA 1003         JMP  LTST90            Put it into FAC
  1672 6ABC 13FD  LTSTNE JEQ  LFALSE            Test if NOT-EQUAL
  1673 6ABE 0204  LTRUE  LI   R4,>BFFF          TRUE is a minus-one
       6AC0 BFFF
  1674 6AC2 0203  LTST90 LI   R3,FAC            Store result in FAC
       6AC4 834A
  1675 6AC6 CCC4         MOV  R4,*R3+           Exp & 1st byte of manitissa
  1676 6AC8 04F3         CLR  *R3+              ZERO the remaining digits
  1677 6ACA 04F3         CLR  *R3+              ZERO the remaining digits
  1678 6ACC 04F3         CLR  *R3+              ZERO the remaining digits
  1679 6ACE 1039         JMP  LEDEND            Jump to end of LED routine
  1680 6AD0 13F6  LTSTLE JEQ  LTRUE             Test LESS-THAN or EQUAL
  1681 6AD2 11F5  LTSTLT JLT  LTRUE             Test LESS-THEN
  1682 6AD4 10F1         JMP  LFALSE            Jump to false
  1683 6AD6 15F3  LTSTGT JGT  LTRUE             Test GREATER-THAN
  1684 6AD8 10EF         JMP  LFALSE            Jump to false
  1685            * Data table for offsets for types
  1686 6ADA   02  LTSTAB BYTE LTSTEQ-LTSTXX     EQUAL               (0)
  1687 6ADB   08         BYTE LTSTNE-LTSTXX     NOT EQUAL           (1)
  1688 6ADC   1E         BYTE LTSTLT-LTSTXX     LESS THEN           (2)
  1689 6ADD   1C         BYTE LTSTLE-LTSTXX     LESS or EQUAL       (3)
  1690 6ADE   22         BYTE LTSTGT-LTSTXX     GREATER THEN        (4)
  1691 6ADF   00         BYTE LTSTGE-LTSTXX     GREATER or EQUAL    (5)
  1692 6AE0 C2A0  LTST20 MOV  @FAC4,R10         Pointer to string1
       6AE2 834E
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0037
  1693 6AE4 D1E0         MOVB @FAC7,R7          R7 = string2 length
       6AE6 8351
  1694 6AE8 06A0         BL   @VPOP             Get LH arg back
       6AEA 6C2A
  1695 6AEC C120         MOV  @FAC4,R4          Pointer to string2
       6AEE 834E
  1696 6AF0 D1A0         MOVB @FAC7,R6          R6 = string2 length
       6AF2 8351
  1697 6AF4 D146         MOVB R6,R5             R5 will contain shorter length
  1698 6AF6 91C6         CB   R6,R7             Compare the 2 lengths
  1699 6AF8 1101         JLT  CSTR05            Jump if length2 < length1
  1700 6AFA D147         MOVB R7,R5             Swap if length1 > length2
  1701 6AFC 0985  CSTR05 SRL  R5,8              Shift for speed and test zero
  1702 6AFE 130D         JEQ  CSTR20            If ZERO-set status with length
  1703 6B00 C0CA  CSTR10 MOV  R10,R3            Current character location
  1704 6B02 058A         INC  R10               Increment pointer
  1705 6B04 06A0         BL   @GETV1            Get from VDP
       6B06 1880
  1706 6B08 D001         MOVB R1,R0             And save for comparison
  1707 6B0A C0C4         MOV  R4,R3             Current char location in ARG
  1708 6B0C 0584         INC  R4                Increment pointer
  1709 6B0E 06A0         BL   @GETV1            Get from VDP
       6B10 1880
  1710 6B12 9001         CB   R1,R0             Compare the characters
  1711 6B14 16CD         JNE  LTST15            Return with status if <>
  1712 6B16 0605         DEC  R5                Otherwise, decrement counter
  1713 6B18 15F3         JGT  CSTR10            And loop for each character
  1714 6B1A 91C6  CSTR20 CB   R6,R7             Status set by length compare
  1715 6B1C 10C9         JMP  LTST15            Return to do test of status
  1716            * ARITHMETIC FUNCTIONS
  1717 6B1E 06A0  PLUS   BL   @PSHPRS           Push left arg and PARSE right
       6B20 6B9C
  1718 6B22   C2         BYTE MINUSZ,0          Stop on a minus!!!!!!!!!!!!!!!
       6B23   00
  1719 6B24 0202         LI   R2,SADD           Address of add routine
       6B26 0D84
  1720 6B28 04E0  LEDEX  CLR  @FAC10            Clear error code
       6B2A 8354
  1721 6B2C 06A0         BL   @ARGTST           Make sure both numerics
       6B2E 6B6E
  1722 6B30 132E         JEQ  ARGT05            If strings, error
  1723 6B32 06A0         BL   @SAVREG           Save registers
       6B34 1E8C
  1724 6B36 0692         BL   *R2               Do the operation
  1725 6B38 06A0         BL   @SETREG           Restore registers
       6B3A 1E7A
  1726 6B3C D0A0         MOVB @FAC10,R2         Test for overflow
       6B3E 8354
  1727 6B40 1602         JNE  LEDERR            If overflow ->error
  1728 6B42 0460  LEDEND B    @CONT             Continue the PARSE
       6B44 64C8
  1729 6B46 0460  LEDERR B    @WARNZZ           Overflow - issue warning
       6B48 6662
  1730 6B4A 06A0  MINUS  BL   @PSHPRS           Push left arg and PARSE right
       6B4C 6B9C
  1731 6B4E   C2         BYTE MINUSZ,0          Parse to a minus
       6B4F   00
  1732 6B50 0202         LI   R2,SSUB           Address of subtract routine
       6B52 0D74
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0038
  1733 6B54 10E9         JMP  LEDEX             Common code for the operation
  1734 6B56 06A0  TIMES  BL   @PSHPRS           Push left arg and PARSE right
       6B58 6B9C
  1735 6B5A   C4         BYTE DIVIZ,0           Parse to a divide!!!!!!!!!!!!!
       6B5B   00
  1736 6B5C 0202         LI   R2,SMULT          Address of multiply routine
       6B5E 0E8C
  1737 6B60 10E3         JMP  LEDEX             Common code for the operation
  1738 6B62 06A0  DIVIDE BL   @PSHPRS           Push left arg and PARSE right
       6B64 6B9C
  1739 6B66   C4         BYTE DIVIZ,0           Parse to a divide
       6B67   00
  1740 6B68 0202         LI   R2,SDIV           Address of divide routine
       6B6A 0FF8
  1741 6B6C 10DD         JMP  LEDEX             Common code for the operation
  1742            ************************************************************
  1743            * Test arguments on both the stack and in the FAC
  1744            *      Both must be of the same type
  1745            *  CALL:
  1746            *      BL   @ARGTST
  1747            *      JEQ                    If string
  1748            *      JNE                    If numeric
  1749            ************************************************************
  1750 6B6E C1A0  ARGTST MOV  @VSPTR,R6         Get stack pointer
       6B70 836E
  1751 6B72 05C6         INCT R6
  1752 6B74 D7E0         MOVB @R6LB,*R15        Load 2nd byte of stack address
       6B76 83ED
  1753 6B78 1000         NOP                    Kill some time
  1754 6B7A D7C6         MOVB R6,*R15           Load 1st byte of stack address
  1755 6B7C 1000         NOP                    Kill some time
  1756 6B7E 9820         CB   @XVDPRD,@CBH65    String in operand 1?
       6B80 8800
       6B82 65A7
  1757 6B84 1606         JNE  ARGT10            No, numeric
  1758 6B86 9820         CB   @FAC2,@CBH65      Yes, is other the same?
       6B88 834C
       6B8A 65A7
  1759 6B8C 1306         JEQ  ARGT20            Yes, do string comparison
  1760 6B8E 0460  ARGT05 B    @ERRT             Data types don't match
       6B90 630C
  1761            NUMCHK
  1762 6B92 9820  ARGT10 CB   @FAC2,@CBH65      2nd operand can't be string
       6B94 834C
       6B96 65A7
  1763 6B98 13FA         JEQ  ARGT05            If so, error
  1764 6B9A 045B  ARGT20 RT                     Ok, so return with status
  1765            * VPUSH followed by a PARSE
  1766 6B9C 05C9  PSHPRS INCT R9                Get room on stack
  1767 6B9E 0289         CI   R9,STKEND         Stack full?
       6BA0 83BA
  1768 6BA2 1B41         JH   VPSH27            Yes, error
  1769 6BA4 C64B         MOV  R11,*R9           Save return on stack
  1770 6BA6 020B         LI   R11,P05           Optimize for the parse
       6BA8 648A
  1771            * Stack VPUSH routine
  1772 6BAA 0200  VPUSH  LI   R0,8              Pushing 8 byte entries
       6BAC 0008
  1773 6BAE A800         A    R0,@VSPTR         Update the pointer
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0039
       6BB0 836E
  1774 6BB2 C060         MOV  @VSPTR,R1         Now get the new pointer
       6BB4 836E
  1775 6BB6 D7E0         MOVB @R1LB,*R15        Write new address to VDP chip
       6BB8 83E3
  1776 6BBA 0261         ORI  R1,WRVDP          Enable the write
       6BBC 4000
  1777 6BBE D7C1         MOVB R1,*R15           Write 1st byte of address
  1778 6BC0 0201         LI   R1,FAC            Source is FAC
       6BC2 834A
  1779 6BC4 D831  VPSH15 MOVB *R1+,@XVDPWD      Move a byte
       6BC6 8C00
  1780 6BC8 0600         DEC  R0                Decrement the count, done?
  1781 6BCA 15FC         JGT  VPSH15            No, more to move
  1782 6BCC C00B         MOV  R11,R0            Save the return address
  1783 6BCE 9820         CB   @FAC2,@CBH65      Pushing a string entry?
       6BD0 834C
       6BD2 65A7
  1784 6BD4 160E         JNE  VPSH20            No, so done
  1785 6BD6 C1A0         MOV  @VSPTR,R6         Entry on stack
       6BD8 836E
  1786 6BDA 0226         AI   R6,4              Pointer to the string is here
       6BDC 0004
  1787 6BDE C060         MOV  @FAC,R1           Get the string's owner
       6BE0 834A
  1788 6BE2 0281         CI   R1,>001C          Is it a tempory string?
       6BE4 001C
  1789 6BE6 1605         JNE  VPSH20            No, so done
  1790 6BE8 C060  VPSH19 MOV  @FAC4,R1          Get the address of the string
       6BEA 834E
  1791 6BEC 1302         JEQ  VPSH20            If null string, nothing to do
  1792 6BEE 06A0         BL   @STVDP3           Set the backpointer
       6BF0 18AA
  1793 6BF2 C060  VPSH20 MOV  @VSPTR,R1         Check for buffer-zone
       6BF4 836E
  1794      6BF8  C16    EQU  $+2
  1795 6BF6 0221         AI   R1,16             Correct by 16
       6BF8 0010
  1796 6BFA 8801         C    R1,@STREND        At least 16 bytes between stac
       6BFC 831A
  1797            *                              and string space?
  1798 6BFE 1236         JLE  VPOP18            Yes, so ok
  1799 6C00 05C9         INCT R9                No, save return address
  1800 6C02 C640         MOV  R0,*R9             on stack
  1801 6C04 06A0         BL   @COMPCT           Do the garbage collection
       6C06 73D8
  1802 6C08 C019         MOV  *R9,R0            Restore return address
  1803 6C0A 0649         DECT R9                Fix subroutine stack pointer
  1804 6C0C C060         MOV  @VSPTR,R1         Get value stack pointer
       6C0E 836E
  1805 6C10 0221         AI   R1,16             Buffer zone
       6C12 0010
  1806 6C14 8801         C    R1,@STREND        At least 16 bytes now?
       6C16 831A
  1807 6C18 1229         JLE  VPOP18            Yes, so ok
  1808 6C1A 0200  VPSH23 LI   R0,ERROM          No, so MEMORY FULL error
       6C1C 0103
  1809 6C1E 06A0  VPSH25 BL   @SETREG           In case of GPL call
       6C20 1E7A
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0040
  1810 6C22 0460         B    @ERR
       6C24 6652
  1811 6C26 0460  VPSH27 B    @ERRSO            STACK OVERFLOW
       6C28 6468
  1812            * Stack VPOP routine
  1813 6C2A 0202  VPOP   LI   R2,FAC            Destination in FAC
       6C2C 834A
  1814 6C2E C060         MOV  @VSPTR,R1         Get stack pointer
       6C30 836E
  1815 6C32 8801         C    R1,@STVSPT        Check for stack underflow
       6C34 8324
  1816 6C36 121B         JLE  VPOP20            Yes, error
  1817 6C38 D7E0         MOVB @R1LB,*R15        Write 2nd byte of address
       6C3A 83E3
  1818 6C3C 0200         LI   R0,8              Popping 8 bytes
       6C3E 0008
  1819 6C40 D7C1         MOVB R1,*R15           Write 1st byte of address
  1820 6C42 6800         S    R0,@VSPTR         Adjust stack pointer
       6C44 836E
  1821 6C46 DCA0  VPOP10 MOVB @XVDPRD,*R2+      Move a byte
       6C48 8800
  1822 6C4A 0600         DEC  R0                Decrement the counter, done?
  1823 6C4C 15FC         JGT  VPOP10            No, finish the work
  1824 6C4E C00B         MOV  R11,R0            Save return address
  1825 6C50 9820         CB   @FAC2,@CBH65      Pop a string?
       6C52 834C
       6C54 65A7
  1826 6C56 160A         JNE  VPOP18            No, so done
  1827 6C58 04C6         CLR  R6                For backpointer clear
  1828 6C5A C0E0         MOV  @FAC,R3           Get string owner
       6C5C 834A
  1829 6C5E 0283         CI   R3,>001C          Pop a temporary?
       6C60 001C
  1830 6C62 13C2         JEQ  VPSH19            Yes, must free it
  1831 6C64 06A0         BL   @GET1             No, get new pointer from s.t.
       6C66 6C9E
  1832 6C68 C801         MOV  R1,@FAC4          Set new pointer to string
       6C6A 834E
  1833 6C6C 0450  VPOP18 B    *R0               And return
  1834 6C6E 0200  VPOP20 LI   R0,ERREX          * SYNTAX ERROR
       6C70 0403
  1835 6C72 10D5         JMP  VPSH25
  1836            * The returned status reflects the character
  1837            * RAMFLG = >00   | No ERAM or imperative statements
  1838            *          >FF   | With ERAM and a program is being run
  1839 6C74 D220  PGMCHR MOVB @RAMFLG,R8        Test ERAM flag
       6C76 8389
  1840 6C78 160A         JNE  PGMC10            ERAM and a program is being ru
  1841            * Next label is for entry from SUBPROG.
  1842 6C7A D7E0  PGMSUB MOVB @PGMPT1,*R15      Write 2nd byte of address
       6C7C 832D
  1843 6C7E 020A         LI   R10,XVDPRD        Read data address
       6C80 8800
  1844 6C82 D7E0         MOVB @PGMPTR,*R15      Write 1st byte of address
       6C84 832C
  1845 6C86 05A0         INC  @PGMPTR           Increment the perm pointer
       6C88 832C
  1846 6C8A D21A         MOVB *R10,R8           Read the character
  1847 6C8C 045B         RT                     And return
 99/4 ASSEMBLER
PARSES2                                                      PAGE 0041
  1848 6C8E C2A0  PGMC10 MOV  @PGMPTR,R10
       6C90 832C
  1849 6C92 05A0         INC  @PGMPTR
       6C94 832C
  1850 6C96 D23A         MOVB *R10+,R8          Write 2nd byte of a address
  1851 6C98 045B         RT
  1852            ************************************************************
  1853 6C9A              AORG >6C9A
  1855
  1856            * (VDP to VDP) or (RAM to RAM)
  1857            * GET,GET1          : Get two bytes of data from VDP
  1858            *                   : R3 : address in VDP
  1859            *                   : R1 : where the one byte data stored
  1860            * PUT1              : Put two bytes of data into VDP
  1861            *                   : R4 : address on VDP
  1862            *                   : R1 : data
  1863            * GETG,GETG2        : Get two bytes of data from ERAM
  1864            *                   : R3 : address on ERAM
  1865            *                   : R1 : where the two byte data stored
  1866            * PUTG2             : Put two bytes of data into ERAM
  1867            *                   : R4 : address on ERAM
  1868            *                   : R1 : data
  1869            * PUTVG1            : Put one byte of data into ERAM
  1870            *                   : R4 : address in ERAM
  1871            *                   : R1 : data
  1872
  1873            * Get two bytes from RAM(R3) into R1
  1874 6C9A C0FB  GET    MOV  *R11+,R3
  1875 6C9C C0D3         MOV  *R3,R3
  1876 6C9E D7E0  GET1   MOVB @R3LB,*R15
       6CA0 83E7
  1877 6CA2 D7C3         MOVB R3,*R15
  1878 6CA4 1000         NOP
  1879 6CA6 D060         MOVB @XVDPRD,R1
       6CA8 8800
  1880 6CAA D820         MOVB @XVDPRD,@R1LB
       6CAC 8800
       6CAE 83E3
  1881 6CB0 045B         RT
  1882            * Put two bytes from R1 to RAM(R4)
  1883 6CB2 D7E0  PUT1   MOVB @R4LB,*R15
       6CB4 83E9
  1884 6CB6 0264         ORI  R4,WRVDP
       6CB8 4000
  1885 6CBA D7C4         MOVB R4,*R15
  1886 6CBC 1000         NOP
  1887 6CBE D801         MOVB R1,@XVDPWD
       6CC0 8C00
  1888 6CC2 D820         MOVB @R1LB,@XVDPWD
       6CC4 83E3
       6CC6 8C00
  1889 6CC8 045B         RT
  1890            * Get two bytes from ERAM(R3) to R1
  1891 6CCA C0FB  GETG   MOV  *R11+,R3
  1892 6CCC C0D3         MOV  *R3,R3
  1893      6CCE  GETG2  EQU  $
  1894 6CCE D073         MOVB *R3+,R1
  1895 6CD0 D813         MOVB *R3,@R1LB
       6CD2 83E3
 99/4 ASSEMBLER
GETPUTS                                                      PAGE 0042
  1896 6CD4 0603         DEC  R3
  1897 6CD6 045B         RT
  1898            * Put two bytes from R1 to ERAM(R4)
  1899      6CD8  PUTG2  EQU  $
  1900 6CD8 DD01         MOVB R1,*R4+
  1901 6CDA D520         MOVB @R1LB,*R4
       6CDC 83E3
  1902 6CDE 0604         DEC  R4                Preserve R4
  1903 6CE0 045B         RT
  1904            ************************************************************
  1905
  1906 6CE2              AORG >6CE2
  1908
  1909 6CE2 9820  LEXP   CB   @FAC2,@CBH63      Must have a numeric
       6CE4 834C
       6CE6 6D05
  1910 6CE8 1B39         JH   ERRSNM            Don't, so error
  1911 6CEA 06A0         BL   @PSHPRS           Push 1st and parse 2nd
       6CEC 6B9C
  1912 6CEE   C5         BYTE EXPONZ,0          Up to another wxpon or less
       6CEF   00
  1913 6CF0 06A0         BL   @STKCHK           Make sure room on stack
       6CF2 6DC0
  1914 6CF4 0202         LI   R2,PWRZZ          Address of power routine
       6CF6 7492
  1915 6CF8 1049         JMP  COMM05            Jump into common routine
  1916            * ABS
  1917 6CFA 0288  NABS   CI   R8,LPARZ*256      Must have a left parenthesis
       6CFC B700
  1918 6CFE 1630         JNE  SYNERR            If not, error
  1919 6D00 06A0         BL   @PARSE            Parse the argument
       6D02 6480
  1920 6D04   CB         BYTE ABSZ              Up to another ABS
  1921 6D05   63  CBH63  BYTE >63               Use the wasted byte
  1922 6D06 9820         CB   @FAC2,@CBH63      Must have numeric arg
       6D08 834C
       6D0A 6D05
  1923 6D0C 1B27         JH   ERRSNM            If not, error
  1924 6D0E 0760         ABS  @FAC              Take the absolute value
       6D10 834A
  1925 6D12 0460  BCONT  B    @CONT             And continue
       6D14 64C8
  1926            * ATN
  1927 6D16 0202  NATN   LI   R2,ATNZZ          Load up arctan address
       6D18 797C
  1928 6D1A 102C         JMP  COMMON            Jump into common rountine
  1929            * COS
  1930 6D1C 0202  NCOS   LI   R2,COSZZ          Load up cosine address
       6D1E 78B2
  1931 6D20 1029         JMP  COMMON            Jump into common routine
  1932            * EXP
  1933 6D22 0202  NEXP   LI   R2,EXPZZ          Load up exponential address
       6D24 75CA
  1934 6D26 1026         JMP  COMMON            Jump into common routine
  1935            * INT
  1936 6D28 0202  NINT   LI   R2,GRINT          Load up greatest integer addre
       6D2A 79EC
  1937 6D2C 1023         JMP  COMMON            Jump into common routine
  1938            * LOG
 99/4 ASSEMBLER
NUD359                                                       PAGE 0043
  1939 6D2E 0202  NLOG   LI   R2,LOGZZ          Load up logarithm code
       6D30 76C2
  1940 6D32 1020         JMP  COMMON            Jump to common routine
  1941            * SGN
  1942 6D34 0288  NSGN   CI   R8,LPARZ*256      Must have left parenthesis
       6D36 B700
  1943 6D38 1613         JNE  SYNERR            If not, error
  1944 6D3A 06A0         BL   @PARSE            Parse the argument
       6D3C 6480
  1945 6D3E   D1         BYTE SGNZ,0            Up to another SGN
       6D3F   00
  1946 6D40 9820         CB   @FAC2,@CBH63      Must have a numeric arg
       6D42 834C
       6D44 6D05
  1947 6D46 1B0A         JH   ERRSNM            If not, error
  1948 6D48 0204         LI   R4,>4001          Floating point one
       6D4A 4001
  1949 6D4C C020         MOV  @FAC,R0           Check status
       6D4E 834A
  1950 6D50 13E0         JEQ  BCONT             If 0, return 0
  1951 6D52 1502         JGT  BLTST9            If positive, return +1
  1952 6D54 0460         B    @LTRUE            If negative, return -1
       6D56 6ABE
  1953 6D58 0460  BLTST9 B    @LTST90           Sets up the FAC w/R4 and 0s
       6D5A 6AC2
  1954 6D5C 0460  ERRSNM B    @ERRT             STRING-NUMBER MISMATCH
       6D5E 630C
  1955 6D60 0460  SYNERR B    @ERRONE           SYNTAX ERROR
       6D62 664E
  1956            * SIN
  1957 6D64 0202  NSIN   LI   R2,SINZZ          Load up sine address
       6D66 78C0
  1958 6D68 1005         JMP  COMMON            Jump into common routine
  1959            * SQR
  1960 6D6A 0202  NSQR   LI   R2,SQRZZ          Load up square-root address
       6D6C 783A
  1961 6D6E 1002         JMP  COMMON            Jump into common routine
  1962            * TAN
  1963 6D70 0202  NTAN   LI   R2,TANZZ          Load up tangent address
       6D72 7940
  1964 6D74 06A0  COMMON BL   @STKCHK           Make sure room on stacks
       6D76 6DC0
  1965 6D78 0288         CI   R8,LPARZ*256      Must have left parenthesis
       6D7A B700
  1966 6D7C 16F1         JNE  SYNERR            If not, error
  1967 6D7E 05C9         INCT R9                Get space on subroutine stack
  1968 6D80 C642         MOV  R2,*R9            Put address of routine on stac
  1969 6D82 06A0         BL   @PARSE            Parse the argument
       6D84 6480
  1970 6D86   FF         BYTE >FF,0             To end of the arg
       6D87   00
  1971 6D88 C099         MOV  *R9,R2            Get address of function back
  1972 6D8A 0649         DECT  R9               Decrement subroutine stack
  1973 6D8C 9820  COMM05 CB   @FAC2,@CBH63      Must have a numeric arg
       6D8E 834C
       6D90 6D05
  1974 6D92 1BE4         JH   ERRSNM            If not, error
  1975 6D94 04E0         CLR  @FAC10            Assume no error or warning
       6D96 8354
 99/4 ASSEMBLER
NUD359                                                       PAGE 0044
  1976 6D98 06A0         BL   @SAVREG           Save Basic registers
       6D9A 1E8C
  1977 6D9C C802         MOV  R2,@PAGE2         Select page 2
       6D9E 6002
  1978 6DA0 0692         BL   *R2               Evaluate the function
  1979 6DA2 C802         MOV  R2,@PAGE1         Reselect Page 1
       6DA4 6000
  1980 6DA6 06A0         BL   @SETREG           Set registers up again
       6DA8 1E7A
  1981 6DAA D020         MOVB @FAC10,R0         Check for error or warning
       6DAC 8354
  1982 6DAE 13B1         JEQ  BCONT             If not error, continue
  1983 6DB0 0990         SRL  R0,9              Check for warning
  1984 6DB2 1304         JEQ  PWARN             Warning, issue it
  1985 6DB4 0200         LI   R0,>0803          BAD ARGUMENT code
       6DB6 0803
  1986 6DB8 0460         B    @ERR
       6DBA 6652
  1987 6DBC 0460  PWARN  B    @WARNZZ           Issue the warning message
       6DBE 6662
  1988 6DC0 0289  STKCHK CI   R9,STND12         Enough room on the subr stack?
       6DC2 83AE
  1989 6DC4 1B18         JH   BSO               No, memory full error
  1990 6DC6 C020         MOV  @VSPTR,R0         Get the value stack pointer
       6DC8 836E
  1991 6DCA 0220         AI   R0,48             Buffer-zone of 48 bytes
       6DCC 0030
  1992 6DCE 8800         C    R0,@STREND        Room between stack & strings
       6DD0 831A
  1993 6DD2 1A0E         JL   STKRTN            Yes, return
  1994 6DD4 05C9         INCT R9                Get space on subr stack
  1995 6DD6 CE4B         MOV  R11,*R9+          Save return address
  1996 6DD8 CE42         MOV  R2,*R9+           Save COMMON function code
  1997 6DDA C640         MOV  R0,*R9            Save v-stack pointer+48
  1998 6DDC 06A0         BL   @COMPCT           Do a garbage collection
       6DDE 73D8
  1999 6DE0 8819         C    *R9,@STREND       Enough space now?
       6DE2 831A
  2000 6DE4 1406         JHE  BMF               No, MEMORY FULL error
  2001 6DE6 0649         DECT R9                Decrement stack pointer
  2002 6DE8 C099         MOV  *R9,R2            Restore COMMON function code
  2003 6DEA 0649         DECT R9                Decrement stack pointer
  2004 6DEC C2D9  RETRN  MOV *R9,R11            Restore return address
  2005 6DEE 0649         DECT R9                Decrement stack pointer
  2006 6DF0 045B  STKRTN RT
  2007 6DF2 0460  BMF    B    @VPSH23           * MEMORY FULL
       6DF4 6C1A
  2008 6DF6 0460  BSO    B    @ERRSO            * STACK OVERFLOW
       6DF8 6468
  2009            ************************************************************
  2010            * LED routine for AND, OR, NOT, and XOR
  2011            ************************************************************
  2012 6DFA 06A0  O0AND  BL   @PSHPRS           Push L.H. and PARSE R.H.
       6DFC 6B9C
  2013 6DFE   BB         BYTE ANDZ,0            Stop on AND or less
       6DFF   00
  2014 6E00 06A0         BL   @CONVRT           Convert both to integers
       6E02 6E9E
  2015 6E04 0560         INV  @FAC              Complement L.H.
 99/4 ASSEMBLER
NUD359                                                       PAGE 0045
       6E06 834A
  2016 6E08 4820         SZC  @FAC,@ARG         Perform the AND
       6E0A 834A
       6E0C 835C
  2017 6E0E C820  O0AND1 MOV  @ARG,@FAC         Put back in FAC
       6E10 835C
       6E12 834A
  2018 6E14 06A0  O0AND2 BL   @CIF              Convert back to floating
       6E16 74AA
  2019 6E18 0460         B    @CONT             Continue
       6E1A 64C8
  2020 6E1C 06A0  O0OR   BL   @PSHPRS           Push L.H. and PARSE R.H.
       6E1E 6B9C
  2021 6E20   BA         BYTE ORZ,0             Stop on OR or less
       6E21   00
  2022 6E22 06A0         BL   @CONVRT           Convert both to integers
       6E24 6E9E
  2023 6E26 E820         SOC  @FAC,@ARG         Perform the OR
       6E28 834A
       6E2A 835C
  2024 6E2C 10F0         JMP  O0AND1            Convert to floating and done
  2025 6E2E 06A0  O0NOT  BL   @PARSE            Parse the arg
       6E30 6480
  2026 6E32   BD         BYTE NOTZ,0            Stop on NOT or less
       6E33   00
  2027 6E34 9820         CB   @FAC2,@CBH63      Get a numeric back?
       6E36 834C
       6E38 6D05
  2028 6E3A 1B49         JH   ERRSN1            No, error
  2029 6E3C 04E0         CLR  @FAC10            Clear for CFI
       6E3E 8354
  2030 6E40 06A0         BL   @CFI              Convert to Integer
       6E42 12B8
  2031 6E44 D020         MOVB @FAC10,R0         Check for an error
       6E46 8354
  2032 6E48 168B         JNE  SYNERR            Error
  2033 6E4A 0560         INV  @FAC              Perform the NOT
       6E4C 834A
  2034 6E4E 10E2         JMP  O0AND2            Convert to floating and done
  2035 6E50 06A0  O0XOR  BL   @PSHPRS           Push L.H. and PARSE R.H.
       6E52 6B9C
  2036 6E54   BC         BYTE XORZ,0            Stop on XOR or less
       6E55   00
  2037 6E56 06A0         BL   @CONVRT           Convert both to integer
       6E58 6E9E
  2038 6E5A C020         MOV  @ARG,R0           Get R.H. into register
       6E5C 835C
  2039 6E5E 2820         XOR  @FAC,R0           Do the XOR
       6E60 834A
  2040 6E62 C800         MOV  R0,@FAC           Put result back in FAC
       6E64 834A
  2041 6E66 10D6         JMP  O0AND2            Convert and continue
  2042            ************************************************************
  2043            * NUD for left parenthesis
  2044            ************************************************************
  2045 6E68 0288  NLPR   CI   R8,RPARZ*256      Have a right paren already?
       6E6A B600
  2046 6E6C 1332         JEQ  ERRSY1            If so, syntax error
  2047 6E6E 06A0         BL   @PARSE            Parse inside the parenthesises
 99/4 ASSEMBLER
NUD359                                                       PAGE 0046
       6E70 6480
  2048 6E72   B7         BYTE LPARZ,0           Up to left parenthesis or less
       6E73   00
  2049 6E74 0288         CI   R8,RPARZ*256      Have a right parenthesis now?
       6E76 B600
  2050 6E78 162C         JNE  ERRSY1            No, so error
  2051 6E7A 06A0         BL   @PGMCHR           Get next token
       6E7C 6C74
  2052 6E7E 0460  BCON1  B    @CONT             And continue
       6E80 64C8
  2053            ************************************************************
  2054            * NUD for unary minus
  2055            ************************************************************
  2056 6E82 06A0  NMINUS BL   @PARSE            Parse the expression
       6E84 6480
  2057 6E86   C2         BYTE MINUSZ,0          Up to another minus
       6E87   00
  2058 6E88 0520         NEG  @FAC              Make it negative
       6E8A 834A
  2059 6E8C 9820  NMIN10 CB   @FAC2,@CBH63      Must have a numeric
       6E8E 834C
       6E90 6D05
  2060 6E92 1B1D         JH   ERRSN1            If not, error
  2061 6E94 10F4         JMP  BCON1             Continue
  2062            ************************************************************
  2063            * NUD for unary plus
  2064            ************************************************************
  2065 6E96 06A0  NPLUS  BL   @PARSE            Parse the expression
       6E98 6480
  2066 6E9A   C1         BYTE PLUSZ,0
       6E9B   00
  2067 6E9C 10F7         JMP  NMIN10            Use common code
  2068            ************************************************************
  2069            * CONVRT - Takes two arguments, 1 form FAC and 1 from the
  2070            *          top of the stack and converts them to integer
  2071            *          from floating point, issuing appropriate errors
  2072            ************************************************************
  2073 6E9E 05C9  CONVRT INCT R9
  2074 6EA0 C64B         MOV  R11,*R9           SAVE RTN ADDRESS
  2075 6EA2 06A0         BL   @ARGTST           ARGS MUST BE SAME TYPE
       6EA4 6B6E
  2076 6EA6 1313         JEQ  ERRSN1            AND NON-STRING
  2077 6EA8 04E0         CLR  @FAC10            FOR CFI ERROR CODE
       6EAA 8354
  2078 6EAC 06A0         BL   @CFI              CONVERT R.H. ARG
       6EAE 12B8
  2079 6EB0 D020         MOVB @FAC10,R0         ANY ERROR OR WARNING?
       6EB2 8354
  2080 6EB4 160A         JNE  ERRBV             YES
  2081 6EB6 C820         MOV  @FAC,@ARG         MOVE TO GET L.H. ARG
       6EB8 834A
       6EBA 835C
  2082 6EBC 06A0         BL   @VPOP             GET L.H. BACK
       6EBE 6C2A
  2083 6EC0 06A0         BL   @CFI              CONVERT L.H.
       6EC2 12B8
  2084 6EC4 D020         MOVB @FAC10,R0         ANY ERROR OR WARNING?
       6EC6 8354
  2085 6EC8 1391         JEQ  RETRN             No, get rtn off stack and rtn
 99/4 ASSEMBLER
NUD359                                                       PAGE 0047
  2086            *                             Yes, issue error
  2087 6ECA 0460  ERRBV  B    @GOTO90           BAD VALUE
       6ECC 670A
  2088 6ECE 0460  ERRSN1 B    @ERRT             STRING NUMBER MISMATCH
       6ED0 630C
  2089 6ED2 0460  ERRSY1 B    @ERRONE           SYNTAX ERROR
       6ED4 664E
  2090            ************************************************************
  2091 6ED6              AORG >6ED6
  2093
  2094
  2095 6ED6 0460  BSYNCH B    @SYNCHK
       6ED8 6400
  2096 6EDA 0460  BERSYN B    @ERRSYN
       6EDC 664E
  2097 6EDE 0460  BERSNM B    @ERRT
       6EE0 630C
  2098 6EE2 D01D  SPEED  MOVB *R13,R0           Read XML code
  2099 6EE4 0980         SRL  R0,8              Shift for word value
  2100 6EE6 13F7         JEQ  BSYNCH            0 is index for SYNCHK
  2101 6EE8 0600         DEC  R0                Not SYNCHK, check further
  2102 6EEA 1344         JEQ  PARCOM            1 is index for PARCOM
  2103 6EEC 0600         DEC  R0                Not PARCOM, check further
  2104 6EEE 1320         JEQ  RANGE             2 is index for RANGE
  2105            * All otheres assumed to be SEETWO
  2106            ************************************************************
  2107            * Find the line specified by the number in FAC
  2108            * Searches the table from low address (high number) to
  2109            *  high address (low number).
  2110            ************************************************************
  2111 6EF0 020A  SEETWO LI   R10,SET           Assume number will be found
       6EF2 6192
  2112 6EF4 0207         LI   R7,GET1           Assume reading from the VDP
       6EF6 6C9E
  2113 6EF8 D020         MOVB @RAMTOP,R0        But correct
       6EFA 8384
  2114 6EFC 1302         JEQ  SEETW2               If
  2115 6EFE 0207         LI   R7,GETG2              ERAM is present
       6F00 6CCE
  2116 6F02 C0E0  SEETW2 MOV  @ENLN,R3          Get point to start from
       6F04 8332
  2117 6F06 0223         AI   R3,-3             Get into table
       6F08 FFFD
  2118 6F0A 0697  SEETW4 BL   *R7               Read the number from table
  2119 6F0C 0241         ANDI R1,>7FFF          Throw away possible breakpoint
       6F0E 7FFF
  2120 6F10 8801         C    R1,@FAC           Match the number needed?
       6F12 834A
  2121 6F14 130A         JEQ  SEETW8            Yes, return with condition set
  2122 6F16 1B07         JH   SEETW6            No, and also passed it =>retur
  2123 6F18 0223         AI   R3,-4             No, but sitll might be there
       6F1A FFFC
  2124 6F1C 8803         C    R3,@STLN          Reached end of table?
       6F1E 8330
  2125 6F20 14F4         JHE  SEETW4            No, so check further
  2126 6F22 C0E0         MOV  @STLN,R3          End of table, default to last
       6F24 8330
  2127 6F26 020A  SEETW6 LI   R10,RESET         Indicate not found
       6F28 006A
 99/4 ASSEMBLER
SPEEDS                                                       PAGE 0048
  2128 6F2A C803  SEETW8 MOV  R3,@EXTRAM        Put pointer in for GPL
       6F2C 832E
  2129 6F2E 045A         B    *R10              Return with condition
  2130 6F30 C30B  RANGE  MOV  R11,R12           Save return address
  2131 6F32 9820         CB   @FAC2,@CBH63      Have a numeric
       6F34 834C
       6F36 6D05
  2132 6F38 1BD2         JH   BERSNM            Otherwise string number mismat
  2133 6F3A 04E0         CLR  @FAC10            Assume no conversion error
       6F3C 8354
  2134 6F3E 06A0         BL   @CFI              Convert from float to integer
       6F40 12B8
  2135 6F42 D020         MOVB @FAC10,R0         Get an error?
       6F44 8354
  2136 6F46 160E         JNE  RANERR            Yes, indicate it
  2137 6F48 D01D         MOVB *R13,R0           Read lower limit
  2138 6F4A 0980         SRL  R0,8              Shift for word compare
  2139 6F4C D05D         MOVB *R13,R1           Read 1st byte of upper limit
  2140 6F4E 06C1         SWPB R1                Kill time
  2141 6F50 D05D         MOVB *R13,R1           Read 2nd byte of upper limit
  2142 6F52 06C1         SWPB R1                Restore upper limit
  2143 6F54 C0A0         MOV  @FAC,R2           Get the value
       6F56 834A
  2144 6F58 1105         JLT  RANERR            If negative, error
  2145 6F5A 8002         C    R2,R0             Less then low limit?
  2146 6F5C 1103         JLT  RANERR            Yes, error
  2147 6F5E 8042         C    R2,R1             Greater then limit?
  2148 6F60 1B01         JH   RANERR            Yes, error
  2149 6F62 045C         B    *R12              All ok, so return
  2150 6F64 06A0  RANERR BL   @SETREG           Set up registers for error
       6F66 1E7A
  2151 6F68 0460         B    @GOTO90           * BAD VALUE
       6F6A 670A
  2152            * Make sure at a left parenthesis
  2153 6F6C 9820  LPAR   CB   @CHAT,@LBLPZ      At a left parenthesis
       6F6E 8342
       6F70 6F81
  2154 6F72 16B3         JNE  BERSYN            No, syntax error
  2155            * Parse up to a comma and insure at a comma
  2156 6F74 06A0  PARCOM BL   @PUTSTK           Save GROM address
       6F76 60F2
  2157 6F78 06A0         BL   @SETREG           Set up R8/R9
       6F7A 1E7A
  2158 6F7C 06A0         BL   @PARSE            Parse the next item
       6F7E 6480
  2159 6F80   B3         BYTE COMMAZ            Up to a comma
  2160 6F81   B7  LBLPZ  BYTE LPARZ
  2161 6F82 0288         CI   R8,COMMAZ*256     End on a comma?
       6F84 B300
  2162 6F86 16A9         JNE  BERSYN            No, syntax error
  2163 6F88 06A0         BL   @PGMCHR           Yes, get character after it
       6F8A 6C74
  2164 6F8C 06A0         BL   @SAVREG           Save R8/R9 for GPL
       6F8E 1E8C
  2165 6F90 06A0         BL   @GETSTK           Restore GROM address
       6F92 610E
  2166 6F94 0460         B    @RESET            Return to GPL reset
       6F96 006A
  2167            ************************************************************
 99/4 ASSEMBLER
SPEEDS                                                       PAGE 0049
  2168 6F98              AORG >6F98
  2170
  2171            * (RAM to RAM)
  2172            * WITH ERAM    : Move the contents in ERAM FROM a higher
  2173            *                 address to a lower address
  2174            *                ARG    : byte count
  2175            *                VAR9   : source address
  2176            *                VAR0   : destination address
  2177
  2178 6F98 C060  MVUP   MOV  @ARG,R1           Get byte count
       6F9A 835C
  2179 6F9C C0E0         MOV  @VAR9,R3          Get source
       6F9E 8316
  2180 6FA0 C160         MOV  @VAR0,R5          Get destination
       6FA2 8300
  2181 6FA4 DD73  MVUP05 MOVB *R3+,*R5+         Move a byte
  2182 6FA6 0601         DEC  R1                Decrement the counter
  2183 6FA8 16FD         JNE  MVUP05            Loop if more to move
  2184 6FAA 045B         RT
  2185            ************************************************************
  2186
  2187 6FAC              AORG >6FAC
  2189
  2190            * Get a non-space character
  2191 6FAC C00B  GETNB  MOV  R11,R0            Save return address
  2192 6FAE 06A0  GETNB1 BL   @GETCHR           Get next character
       6FB0 6FBA
  2193 6FB2 0281         CI   R1,' '*256        Space character?
       6FB4 2000
  2194 6FB6 13FB         JEQ  GETNB1            Yes, get next character
  2195 6FB8 0450         B    *R0               No, return character condition
  2196            * Get the next character
  2197 6FBA 8820  GETCHR C    @VARW,@VARA       End of line?
       6FBC 8320
       6FBE 832A
  2198 6FC0 1B0E         JH   GETCH2            Yes, return condition
  2199 6FC2 D7E0         MOVB @VARW1,*R15       No, write LSB of VDP address
       6FC4 8321
  2200 6FC6 0201         LI   R1,>A000          Negative screen offset (->60)
       6FC8 A000
  2201 6FCA D7E0         MOVB @VARW,*R15        Write MSB of VDP address
       6FCC 8320
  2202 6FCE 05A0         INC  @VARW             Increment read-from pointer
       6FD0 8320
  2203 6FD2 B060         AB   @XVDPRD,R1        Read and remove screen offset
       6FD4 8800
  2204 6FD6 0281         CI   R1,>1F00          Read an edge character?
       6FD8 1F00
  2205 6FDA 13EF         JEQ  GETCHR            Yes, skip it
  2206 6FDC 045B         RT                     Return
  2207 6FDE 04C1  GETCH2 CLR  R1                Indicate end of line
  2208 6FE0 045B         RT                     Return
  2209            *-----------------------------------------------------------
  2210            * Remove this routine from CRUNCH because CRUNCH is running
  2211            * out of space                5/11/81
  2212            *-----------------------------------------------------------
  2213            *      Calculate and put length of string/number into
  2214            *      length byte
  2215 6FE2 C0CB  LENGTH MOV  R11,R3            Save retun address
 99/4 ASSEMBLER
GETNBS                                                       PAGE 0050
  2216 6FE4 C020         MOV  @RAMPTR,R0        Save current crunch pointer
       6FE6 830A
  2217 6FE8 C200         MOV  R0,R8             Put into r8 for PUTCHR below
  2218 6FEA 6205         S    R5,R8             Calculate length of string
  2219 6FEC 0608         DEC  R8                RAMPTR is post-incremented
  2220 6FEE C805         MOV  R5,@RAMPTR        Address of length byte
       6FF0 830A
  2221 6FF2 06A0         BL   @PUTCHR           Put the length in
       6FF4 7F6E
  2222 6FF6 C800         MOV  R0,@RAMPTR        Restore crunch pointer
       6FF8 830A
  2223 6FFA 0453         B    *R3               And return
  2224            * FILL IN BYTES OF MODULE WITH COPY OF ORIGINAL?
  2225 6FFC 0000         DATA >0000
  2226 6FFE EF71         DATA >EF71             ?????
  2227            ************************************************************
  2228 7000              AORG >7000
  2230
  2231            ************************************************************
  2232            * FOR statement
  2233            * Builds up a stack entry for the FOR statement. Checks the
  2234            * syntax of a FOR statement and also checks to see if the
  2235            * loop is executed at all. The loop is not executed if the
  2236            * limit of the FOR is > then initial value and the step is
  2237            * positive of the limit of the FOR is < then initial value
  2238            * and the step is negative.
  2239            *
  2240            * A stack entry for a 'FOR' statement looks like:
  2241            *
  2242            * +-------------------------------------------------------+
  2243            * | PTR TO S.T. | >67 |     | Value Space  | BUFLEV       |
  2244            * |   ENTRY     |     |     |  Pointer     |              |
  2245            * | ------------------------------------------------------|
  2246            * | FOR line #  | FOR line  |                             |
  2247            * | table ptr   |  pointer  |                             |
  2248            * |-------------------------------------------------------|
  2249            * |                    Increment Value                    |
  2250            * |-------------------------------------------------------|
  2251            * |                        Limit                          |
  2252            * +-------------------------------------------------------+
  2253            ************************************************************
  2254 7000 D208  NFOR   MOVB R8,R8             EOL?
  2255 7002 1501         JGT  NFOR1             If symbol name, ok
  2256 7004 107C         JMP  ERRCDT            If EOL or Token, error
  2257 7006 06A0  NFOR1  BL   @SYM              Get pointer to s.t. entry
       7008 6312
  2258 700A 06A0         BL   @GETV             Get 1st byte of symbol
       700C 187C
  2259 700E 834A         DATA FAC                 entry
  2260            *
  2261 7010 0241         ANDI R1,>C700          Check string, function & array
       7012 C700
  2262 7014 1670         JNE  BERMUW            If andy of the above, error
  2263 7016 0288         CI   R8,EQZ*256        Must have '='
       7018 BE00
  2264 701A 1671         JNE  ERRCDT            If not, error
  2265 701C 06A0         BL   @SMB              Get index's value space
       701E 61DC
  2266 7020 04E0         CLR  @FAC2             Dummy entry ID on the stack
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0051
       7022 834C
  2267 7024 C820         MOV  @BUFLEV,@FAC6     Save buffer level
       7026 8346
       7028 8350
  2268            *
  2269            * Search stack for another FOR entry with the same loop
  2270            *  variable. If one is found, remove it.
  2271            *
  2272 702A C0E0         MOV  @VSPTR,R3         Copy stack pointer
       702C 836E
  2273            *
  2274            * See if end of stack
  2275 702E 8803  NFOR1A C    R3,@STVSPT        Check stack underflow
       7030 8324
  2276 7032 1228         JLE  NFOR1E            Finished with stack scan
  2277            * See if FOR entry
  2278 7034 06A0         BL   @GET1             Get pointer to s.t. entry
       7036 6C9E
  2279 7038 C001         MOV  R1,R0             Move it to use later
  2280 703A D060         MOVB @XVDPRD,R1        Read stack ID
       703C 8800
  2281 703E 9801         CB   R1,@CBH67         Is stack entry a FOR?
       7040 68AB
  2282 7042 1606         JNE  NFOR1B            No, 8 byte regular entry
  2283            * Compare loop variables
  2284 7044 8800         C    R0,@FAC           Loop variables match?
       7046 834A
  2285 7048 1309         JEQ  NFOR1C            Yes
  2286 704A 0223         AI   R3,-32            Skip this FOR entry
       704C FFE0
  2287 704E 10EF         JMP  NFOR1A            Loop
  2288 7050 9801  NFOR1B CB   R1,@CCBH6A        Hit a subprogram entry?
       7052 70AF
  2289 7054 1317         JEQ  NFOR1E            Yes, don't scan anymore
  2290 7056 0223         AI   R3,-8             Skip 8 byte stack entry
       7058 FFF8
  2291 705A 10E9         JMP  NFOR1A            Loop
  2292            * Found matching loop variable, move stack down 32 bytes
  2293 705C C0A0  NFOR1C MOV  @VSPTR,R2         Copy stack pointer
       705E 836E
  2294 7060 6083         S    R3,R2             Calculate # of bytes to move
  2295 7062 130D         JEQ  NFOR1D            0 bytes, skip move
  2296 7064 C103         MOV  R3,R4             Destination pointer
  2297 7066 0224         AI   R4,-24            Place to move to
       7068 FFE8
  2298      706C  C8     EQU  $+2
  2299 706A 0223         AI   R3,8              Point at entry above FOR entry
       706C 0008
  2300 706E 06A0  NFOR1F BL   @GETV1            Get the byte
       7070 1880
  2301 7072 06A0         BL   @PUTV1            Put the byte
       7074 6422
  2302 7076 0583         INC  R3                Inc From pointer
  2303 7078 0584         INC  R4                Inc To pointer
  2304 707A 0602         DEC  R2                Decrement counter
  2305 707C 16F8         JNE  NFOR1F            Loop if not done
  2306 707E 6820  NFOR1D S    @C32,@VSPTR       Adjust top of stack
       7080 7196
       7082 836E
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0052
  2307            * Now put new FOR entry on stack
  2308 7084 06A0  NFOR1E BL   @VPUSH            Reserve space for limit
       7086 6BAA
  2309 7088 06A0         BL   @VPUSH               increment,
       708A 6BAA
  2310 708C 06A0         BL   @VPUSH                and 2nd info entry
       708E 6BAA
  2311 7090 D820         MOVB @CBH67,@FAC2      FOR ID on stack
       7092 68AB
       7094 834C
  2312 7096 06A0         BL   @PGMCHR           Get next character
       7098 6C74
  2313 709A 06A0         BL   @PSHPRS           Push symbol I.D. entry
       709C 6B9C
  2314 709E   B1         BYTE TOZ               Parse the initial value
  2315 709F   63  CCBH63 BYTE >63               Wasted byte (CBH63)
  2316 70A0 0288         CI   R8,TOZ*256        TO?
       70A2 B100
  2317 70A4 162C         JNE  ERRCDT            No, error
  2318 70A6 06A0         BL   @PGMCHR
       70A8 6C74
  2319 70AA 06A0         BL   @PSHPRS           Push initial and get limit
       70AC 6B9C
  2320 70AE   B2         BYTE STEPZ
  2321 70AF   6A  CCBH6A BYTE >6A               Wasted byte (CBA6A)
  2322 70B0 9820         CB   @CCBH63,@FAC2     If a string value
       70B2 709F
       70B4 834C
  2323 70B6 1A1D         JL   BERR6             Its an error
  2324 70B8 6820         S    @C40,@VSPTR
       70BA 6006
       70BC 836E
  2325 70BE 06A0         BL   @VPUSH            Push the limit
       70C0 6BAA
  2326 70C2 06A0         BL   @EOSTMT           At the end of statement?
       70C4 6862
  2327 70C6 131D         JEQ  NFOR2             Yes, default incr to 1
  2328 70C8 0288         CI   R8,STEPZ*256      STEP?
       70CA B200
  2329 70CC 1618         JNE  ERRCDT            No, Its an error
  2330 70CE A820         A    @C32,@VSPTR       Corrrect stack pointer
       70D0 7196
       70D2 836E
  2331 70D4 06A0         BL   @PGMCHR
       70D6 6C74
  2332 70D8 06A0         BL   @PARSE            Get the increment
       70DA 6480
  2333 70DC   83         BYTE TREMZ,0
       70DD   00
  2334 70DE 6820         S    @C32,@VSPTR       Get stack to needed place
       70E0 7196
       70E2 836E
  2335 70E4 C020         MOV  @FAC,R0           Can't have zero increment
       70E6 834A
  2336 70E8 1308         JEQ  ERRBV2            If 0, its an error
  2337 70EA 9820         CB   @CCBH63,@FAC2     Can't have zero increment
       70EC 709F
       70EE 834C
  2338 70F0 140F         JHE  NFOR3             If numeric, ok
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0053
  2339 70F2 0460  BERR6  B    @ERRT             * STRING NUMBER MISMATCH
       70F4 630C
  2340 70F6 0460  BERMUW B    @ERRMUV           * MULTIPLY USED VARIABLE
       70F8 6970
  2341 70FA 0460  ERRBV2 B    @GOTO90
       70FC 670A
  2342 70FE 0460  ERRCDT B    @ERRSYN
       7100 664E
  2343 7102 0200  NFOR2  LI   R0,FAC
       7104 834A
  2344 7106 CC20         MOV  @FLTONE,*R0+      Put a floating one in
       7108 600E
  2345 710A 04F0         CLR  *R0+
  2346 710C 04F0         CLR  *R0+
  2347 710E 04D0         CLR  *R0
  2348 7110 06A0  NFOR3  BL   @VPUSH            Push the step
       7112 6BAA
  2349 7114 0201         LI   R1,FAC            Optimize to save bytes
       7116 834A
  2350 7118 CC60         MOV  @EXTRAM,*R1+      Save line # pointer
       711A 832E
  2351 711C C460         MOV  @PGMPTR,*R1       Save ptr w/in the line
       711E 832C
  2352 7120 0611         DEC  *R1               Back up so get last character
  2353 7122 06A0         BL   @VPUSH            Push it too!
       7124 6BAA
  2354 7126 A820         A    @H16,@VSPTR       Point to initial value
       7128 7156
       712A 836E
  2355 712C 06A0         BL   @VPOP             Get initial value
       712E 6C2A
  2356 7130 06A0         BL   @ASSG             Assign it
       7132 6334
  2357 7134 A820         A    @C8,@VSPTR        Restore to top of entry
       7136 706C
       7138 836E
  2358            * Check to see if execute loop at all
  2359 713A 06A0         BL   @VPOP             Get ptr to value
       713C 6C2A
  2360 713E 06A0         BL   @MOVFAC           Get value
       7140 6434
  2361 7142 6820         S    @H16,@VSPTR       Point at limit
       7144 7156
       7146 836E
  2362 7148 06A0         BL   @SCOMPB           Compare them
       714A 0D42
  2363            * VSPTR is now below the FOR entry
  2364 714C 02C4         STST R4                Save the status
  2365 714E 1309         JEQ  NFOR03            IF =
  2366 7150 C0E0         MOV  @VSPTR,R3
       7152 836E
  2367      7156  H16    EQU  $+2
  2368 7154 0223         AI   R3,16
       7156 0010
  2369 7158 06A0         BL   @GETV1            Check negative step
       715A 1880
  2370 715C 1107         JLT  NFOR05            If a decrement
  2371 715E 0A14         SLA  R4,1              Check out of limit
  2372 7160 1507         JGT  NFOR07            Out of limit
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0054
  2373 7162 A820  NFOR03 A    @C32,@VSPTR       Leave the entry on
       7164 7196
       7166 836E
  2374 7168 0460         B    @CONT     <<<<<<< Result is w/in limit
       716A 64C8
  2375 716C 0A14  NFOR05 SLA  R4,1              Check out of limit
  2376 716E 15F9         JGT  NFOR03            Result is w/in limit
  2377            * Initial value is not within the limit. Therefore, the loop
  2378            * is not executed at all. Must skip the code in the body of
  2379            * the loop
  2380 7170 0203  NFOR07 LI   R3,1              FOR/NEXT pair counter
       7172 0001
  2381 7174 06A0  NFOR09 BL   @EOLINE           Check end of line
       7176 6872
  2382 7178 1338         JEQ  NFOR13            Is end of line
  2383 717A 06A0         BL   @PGMCHR           Get 1st token on line
       717C 6C74
  2384 717E 0288  NFOR10 CI   R8,NEXTZ*256      If NEXT
       7180 9600
  2385 7182 1618         JNE  NFOR11            If not
  2386 7184 0603         DEC  R3                Decrement counter
  2387 7186 162B         JNE  NFOR12            If NOT matching next
  2388 7188 06A0         BL   @PGMCHR           Get 1st char of loop variable
       718A 6C74
  2389            * Check is added in SYM       5/26/81
  2390            *      JLT  ERRCDT            If token
  2391 718C 06A0         BL   @SYM              Get s.t. pointer to check matc
       718E 6312
  2392 7190 C0E0         MOV  @VSPTR,R3         Correct to top of entry
       7192 836E
  2393      7196  C32    EQU  $+2
  2394 7194 0223         AI   R3,32
       7196 0020
  2395 7198 06A0         BL   @GET1             Get pointer
       719A 6C9E
  2396 719C 8801         C    R1,@FAC           Match?
       719E 834A
  2397 71A0 1605         JNE  ERRFNN            No match
  2398 71A2 0460         B    @CONT             Continue  <<<<<<<< THE WAY
       71A4 64C8
  2399 71A6 A820  ERRFN  A    @C4,@EXTRAM
       71A8 6A80
       71AA 832E
  2400 71AC 0200  ERRFNN LI   R0,>0B03          FOR NEXT NESTING
       71AE 0B03
  2401 71B0 0460         B    @ERR
       71B2 6652
  2402 71B4 0288  NFOR11 CI   R8,SUBZ*256       Hit a SUB?
       71B6 A100
  2403 71B8 13F9         JEQ  ERRFNN            Yes, can't find matching next
  2404 71BA 0288         CI   R8,FORZ*256       FOR?
       71BC 8C00
  2405 71BE 1601         JNE  NFOR20            No, Check some more
  2406 71C0 0583         INC  R3                Increment depth
  2407 71C2 0288  NFOR20 CI   R8,LNZ*256        Line number token?
       71C4 C900
  2408 71C6 1602         JNE  NFOR30            No, Check some more
  2409 71C8 05E0         INCT @PGMPTR           Skip the line number
       71CA 832C
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0055
  2410 71CC 0288  NFOR30 CI   R8,STRINZ*256     String?
       71CE C700
  2411 71D0 1606         JNE  NFOR12            No, Check end of statement
  2412 71D2 06A0         BL   @PGMCHR           Yes, get string length
       71D4 6C74
  2413 71D6 06C8         SWPB R8                Put the length in R8
  2414 71D8 A808         A    R8,@PGMPTR        Skip that many length
       71DA 832C
  2415 71DC 04C8         CLR  R8                Clear next crunched code
  2416 71DE 06A0  NFOR12 BL   @PGMCHR           Read next crunched code
       71E0 6C74
  2417 71E2 06A0         BL   @EOSTMT           Check EOS (includes EOL)
       71E4 6862
  2418 71E6 16ED         JNE  NFOR20            Check for line # or string
  2419 71E8 10C5         JMP  NFOR09            Is EOS or EOL
  2420 71EA D020  NFOR13 MOVB @PRGFLG,R0        If imperative w/out match
       71EC 8344
  2421 71EE 13DE         JEQ  ERRFNN            Its an error
  2422 71F0 6820         S    @C4,@EXTRAM       Goto next line
       71F2 6A80
       71F4 832E
  2423 71F6 8820         C    @EXTRAM,@STLN     Hit end of program?
       71F8 832E
       71FA 8330
  2424 71FC 1AD4         JL   ERRFN             Yes, can't match the next
  2425 71FE C820         MOV  @EXTRAM,@PGMPTR   Set PGMPTR to get new PGMPTR
       7200 832E
       7202 832C
  2426 7204 06A0         BL   @PGMCHR           Get
       7206 6C74
  2427 7208 D808         MOVB R8,@PGMPTR         new
       720A 832C
  2428 720C D81A         MOVB *R10,@PGMPT1        PGMPTR
       720E 832D
  2429 7210 06A0         BL   @PGMCHR           Get next line
       7212 6C74
  2430 7214 06A0         BL   @EOSTMT           Check EOS or EOL
       7216 6862
  2431 7218 13AD         JEQ  NFOR09            Is EOS or EOL
  2432 721A 10B1         JMP  NFOR10            Keep looping
  2433            * NEXT4 and NEXT2A were moved from in-line to here in an
  2434            * effort to make the "normal" path through the NEXT code as
  2435            * straight-line as possible.
  2436 721C 6820  NEXT4  S    @C24,@VSPTR       LOOP VARIABLES DON'T MATCH
       721E 6464
       7220 836E
  2437 7222 1008         JMP  NEXT2
  2438 7224 06A0  NEXT2B BL   @VPUSH            Keep stack information
       7226 6BAA
  2439 7228 0200  NEXT2A LI   R0,>0C03            NEXT WITHOUT FOR
       722A 0C03
  2440 722C 0460         B    @ERR
       722E 6652
  2441            ************************************************************
  2442            * NEXT statement handler - find the matching FOR statement
  2443            * on the stack, add the increment to the current value of
  2444            * the index variable and check to see if execute the loop
  2445            * again. If loop-variable's value is still within bounds,
  2446            * goto the top of the loop, otherwise, flush the FOR entry
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0056
  2447            * off the stack and continue with the statement following
  2448            * the NEXT statement.
  2449            ************************************************************
  2450 7230 06A0  NNEXT  BL   @SYM              GET S.T.   I.D.
       7232 6312
  2451            *      MOV  @FAC,R4           SYM/FBSYMB leaves value in R4
  2452 7234 8820  NEXT2  C    @VSPTR,@STVSPT    CHECK FOR BOTTOM OF STACK
       7236 836E
       7238 8324
  2453 723A 12F6         JLE  NEXT2A            IF AT BOTTOM -> NEXT W/OUT FOR
  2454 723C 06A0         BL   @VPOP             GET 'FOR' ENTRY OFF STACK
       723E 6C2A
  2455 7240 9820         CB   @FAC2,@CBH67      CHECK FOR 'FOR' ENTRY
       7242 834C
       7244 68AB
  2456 7246 16EE         JNE  NEXT2B            Is not a 'FOR' entry, error
  2457 7248 8804         C    R4,@FAC           CHECK IF MATCHING 'FOR' ENTRY
       724A 834A
  2458 724C 16E7         JNE  NEXT4             Is not a match, so check more
  2459 724E C0E0         MOV  @VSPTR,R3         Check BUFLEV for match
       7250 836E
  2460 7252 0223         AI   R3,14             Point at the BUFLEV in stack
       7254 000E
  2461 7256 06A0         BL   @GET1             Read it
       7258 6C9E
  2462 725A 8801         C    R1,@BUFLEV        SAME LEVEL?
       725C 8346
  2463 725E 16A6         JNE  ERRFNN            NO, ITS AN ERROR
  2464 7260 6820         S    @C8,@VSPTR
       7262 706C
       7264 836E
  2465 7266 06A0         BL   @MOVFAC           GET INDEX VALUE
       7268 6434
  2466 726A 06A0         BL   @SAVREG           SAVE BASIC REGISTERS
       726C 1E8C
  2467 726E 06A0         BL   @SADD             ADD IN THE INCREMENT
       7270 0D84
  2468 7272 06A0         BL   @SETREG           RESTORE BASIC REGS
       7274 1E7A
  2469 7276 A820         A    @C24,@VSPTR
       7278 6464
       727A 836E
  2470 727C 06A0         BL   @ASSG             SAVE NEW INDEX VALUE
       727E 6334
  2471 7280 6820         S    @H16,@VSPTR       POINT TO THE LIMIT
       7282 7156
       7284 836E
  2472 7286 06A0         BL   @SCOMPB           TEST W/IN LIMIT
       7288 0D42
  2473 728A 02C4         STST R4                SAVE RESULT OF COMPARE
  2474 728C 1309         JEQ  NEXT5             IF = DO LAST LOOP
  2475 728E C0E0         MOV  @VSPTR,R3         CHECK FOR A DECREMENT
       7290 836E
  2476 7292 0223         AI   R3,16             Point at increment/decrement
       7294 0010
  2477 7296 06A0         BL   @GETV1            Get 1st byte and set condition
       7298 1880
  2478 729A 1116         JLT  NEXT6             If was a decrement
  2479 729C 0A14         SLA  R4,1              Check if out of limit
 99/4 ASSEMBLER
FORNEXTS                                                     PAGE 0057
  2480 729E 1512         JGT  NEXT8             Out of limit
  2481 72A0 A820  NEXT5  A    @C32,@VSPTR       Point to 'FOR' I.D. entry
       72A2 7196
       72A4 836E
  2482 72A6 C0E0         MOV  @VSPTR,R3         GOTO TOP OF 'FOR' LOOP
       72A8 836E
  2483 72AA 0223         AI   R3,-8             Point to old EXTRAM
       72AC FFF8
  2484 72AE 06A0         BL   @GET1             Get new EXTRAM
       72B0 6C9E
  2485 72B2 C801         MOV  R1,@EXTRAM        Put it in
       72B4 832E
  2486 72B6 05C3         INCT R3                POINT AT OLD PGMPTR
  2487 72B8 06A0         BL   @GET1             Get old PGMPTR
       72BA 6C9E
  2488 72BC C801         MOV  R1,@PGMPTR        Put it in
       72BE 832C
  2489 72C0 06A0         BL   @PGMCHR           Get 1st token in line
       72C2 6C74
  2490 72C4 0460  NEXT8  B    @CONT             Continue on
       72C6 64C8
  2491            * TEST LIMIT FOR DECREMENT
  2492 72C8 0A14  NEXT6  SLA  R4,1              Check if out of limit
  2493 72CA 15EA         JGT  NEXT5             If within limit, continue
  2494 72CC 10FB         JMP  NEXT8             Continue PARSE
  2495            ************************************************************
  2496 72CE              AORG >72CE
  2498
  2499            ************************************************************
  2500            *                 MEMORY CHECK ROUTINE
  2501            * It checks to see if there is enough room to insert a
  2502            * symbol table entry or a P.A.B. into the VDP between the
  2503            * static symbol table/PAB area and the dymamic string area.
  2504            * If there is not it attempts to move the string space down
  2505            * (to  lower address) and then insert the needed area
  2506            * between the two. NOTE: it may invoke COMPCT to do a
  2507            * garbage collection. If there is not enough space after
  2508            * COMPCT then issues *MEMORY FULL* message.
  2509            *
  2510            * INPUT:  # of bytes needed in FAC, FAC+1
  2511            * USES:   R0, R12 as temporaries as well as R0 - R6 when
  2512            *         invoking COMPCT
  2513            ************************************************************
  2514 72CE 06A0  MEMCHG BL   @MEMCHK           GPL entry point
       72D0 72D8
  2515 72D2 6192         DATA SET               If NOT enough memory
  2516 72D4 0460         B    @RESET            If enough memory
       72D6 006A
  2517 72D8 C30B  MEMCHK MOV  R11,R12           Save return address
  2518 72DA C020         MOV  @FREPTR,R0        GET BEGINNING OF S.T. FREE SPA
       72DC 8340
  2519 72DE 6020         S    @STRSP,R0         CALCULATE SIZE OF GAP
       72E0 8318
  2520 72E2 8020         C    @FAC,R0           ENOUGH SPACE ALREADY?
       72E4 834A
  2521 72E6 1A3C         JL   MEMC08            YES - DONE - RTN
  2522 72E8 06A0         BL   @COMPCT           NO - COMPACITFY STRING SPACE
       72EA 73D8
  2523 72EC C020         MOV  @STREND,R0        GET STRING FREE SPACE
 99/4 ASSEMBLER
STRINGS                                                      PAGE 0058
       72EE 831A
  2524 72F0 6020         S    @VSPTR,R0         CALCULATE SIZE OF GAP
       72F2 836E
  2525 72F4 0220         AI   R0,-64            VSPTR OFFSET TOO
       72F6 FFC0
  2526 72F8 C2A0         MOV  @FAC,R10          GET TOTAL # NEEDED BACK
       72FA 834A
  2527 72FC 8280         C    R0,R10            ENOUGH ROOM NOW?
  2528 72FE 1A32         JL   MEMERR            NO - *MEMORY FULL*
  2529            *
  2530            * Now move the DYNAMIC STRING AREA DOWN IN MEMORY
  2531            *
  2532 7300 C020         MOV  @STRSP,R0         CALCULATE # OF BYTES
       7302 8318
  2533 7304 C0A0         MOV  @STREND,R2        Beginning of move address
       7306 831A
  2534 7308 6002         S    R2,R0              in the total string space
  2535 730A 680A         S    R10,@STREND       SET FREE PTR(COPY-TO ADDRESS)
       730C 831A
  2536 730E C000         MOV  R0,R0             NO BYTES TO MOVE?
  2537 7310 130D         JEQ  MEMC04            RIGHT
  2538 7312 C0C2         MOV  R2,R3             ADDRESS FOR GETV
  2539 7314 0583         INC  R3
  2540 7316 C120         MOV  @STREND,R4        ADDRESS FOR PUTV
       7318 831A
  2541 731A 0584         INC  R4
  2542 731C 06A0  MEMC03 BL   @GETV1            GET THE BYTE
       731E 1880
  2543 7320 06A0         BL   @PUTV1            PUT THE BYTE
       7322 6422
  2544 7324 0583         INC  R3                INC THE FROM
  2545 7326 0584         INC  R4                INC THE TO
  2546 7328 0600         DEC  R0                DEC THE COUNT
  2547 732A 15F8         JGT  MEMC03            IF NOT DONE
  2548            *                             MOVE IT
  2549 732C 680A  MEMC04 S    R10,@STRSP        SET NEW STRIG SPACE PTR
       732E 8318
  2550            *
  2551            * NOW FIX UP STRING PTRS
  2552            *
  2553 7330 C020         MOV  @STRSP,R0         GET BEGINNING OF STRING SPACE
       7332 8318
  2554 7334 8020  MEMC05 C    @STREND,R0        FINISHED?
       7336 831A
  2555 7338 1413         JHE  MEMC08            YES
  2556 733A 04C1         CLR  R1                CLEAR LOWER BYTE
  2557 733C C0C0         MOV  R0,R3             FOR GETV
  2558 733E 06A0         BL   @GETV1            GET LENGTH BYTE
       7340 1880
  2559 7342 06C1         SWPB R1                SWAP FOR ADD
  2560 7344 6001         S    R1,R0             POINT AT BEGINNING OF STRING
  2561 7346 C0C0         MOV  R0,R3             FOR THE GETV1 BELOW
  2562 7348 0223         AI   R3,-3             POINT AT THE BACKPOITER
       734A FFFD
  2563 734C 06A0         BL   @GET1             GET THE BACK POINTER
       734E 6C9E
  2564            *                             BOTH BYTES
  2565 7350 C041         MOV  R1,R1             FREE STRING?
  2566 7352 1303         JEQ  MEMC06            YES
 99/4 ASSEMBLER
STRINGS                                                      PAGE 0059
  2567 7354 C180         MOV  R0,R6             PTR TO STRING FOR STVDP
  2568 7356 06A0         BL   @STVDP            SET FORWARD PTR
       7358 18AE
  2569 735A 0220  MEMC06 AI   R0,-4             NOW POINT AT NEXT LENGTH
       735C FFFC
  2570 735E 10EA         JMP  MEMC05            CONTINUE ON
  2571 7360 046C  MEMC08 B    @2(R12)           Return with space allocated
       7362 0002
  2572 7364 C31C  MEMERR MOV  *R12,R12          Pick up error return address
  2573 7366 045C         B    *R12              * MEMORY FULL(prescan time)
  2574 7368 0460  ERRMEM B    @VPSH23           * MEMORY FULL(execution tiem)
       736A 6C1A
  2575            ************************************************************
  2576            * GETSTR - Checks to see if there is enough space in the
  2577            *          string area to allocate a string, if there is it
  2578            *          allocates it. If there is not it does a garbage
  2579            *          collection and once again checks to see if there
  2580            *          is enough room. If so it allocates it, if not it
  2581            *          issues a *MEMORY FULL* message.
  2582            *
  2583            * INPUT :  # of bytes needed in @BYTE
  2584            * OUTPUT:  Pointer to new string in @SREF
  2585            *          Both length bytes in place & zeroed Breakpointer
  2586            *          @STREND points 1st free byte(new)
  2587            *
  2588            * USES  :  R0 - R6 Temporaries
  2589            *
  2590            * Note  :  COMPCT allows a buffer zone of 8 stack entries
  2591            *          above what is there when COMPCT is called. This
  2592            *          should allow enough space to avoid a collision
  2593            *          between the string space and the stack. If
  2594            *          garbage begins to appear in the string space
  2595            *          that can't be accounted for, the buffer zone
  2596            *          will be increased.
  2597            ************************************************************
  2598 736C C020  GETSTR MOV  @BYTE,R0          GET # OF BYTES NEEDED
       736E 830C
  2599 7370 C30B         MOV  R11,R12           SAVE RTN ADDRESS
  2600 7372 8C30         C    *R0+,*R0+         ADJUST FOR BACKPTR & 2 LENGTHS
  2601            *                              (INCREMENT BY 4)
  2602 7374 C060         MOV  @STREND,R1        CHECK IF ENOUGH ROOM
       7376 831A
  2603 7378 6040         S    R0,R1             BY ADVANCING THE FREE PTR
  2604 737A C0A0         MOV  @VSPTR,R2         GET VALUE STACK PTR
       737C 836E
  2605 737E 0222         AI   R2,64             ALLOW BUFFER ZONE
       7380 0040
  2606 7382 8081         C    R1,R2             ENOUGH SPACE?
  2607 7384 1B0E         JH   GETS10            YES, ALL IS WELL
  2608 7386 06A0         BL   @COMPCT           NO, COMPACTIFY
       7388 73D8
  2609 738A C0A0         MOV  @VSPTR,R2         GET VALUE STACK POINTER
       738C 836E
  2610 738E 0222         AI   R2,64             ALLOW BUFFER ZONE
       7390 0040
  2611 7392 C020         MOV  @BYTE,R0          GET # OF BYTES BACK
       7394 830C
  2612 7396 8C30         C    *R0+,*R0+         INCREMENT BY 4
  2613 7398 C060         MOV  @STREND,R1        GET NEW END OF STRING SPACE
 99/4 ASSEMBLER
STRINGS                                                      PAGE 0060
       739A 831A
  2614 739C 6040         S    R0,R1             ADVANCE IT
  2615 739E 8081         C    R1,R2             ENOUGH SPACE NOW?
  2616 73A0 12E3         JLE  ERRMEM            NO, *MEMORY FULL*
  2617 73A2 0220  GETS10 AI   R0,-4             GET EXACT LENGTH BACK
       73A4 FFFC
  2618 73A6 D060         MOVB @R0LB,R1          STORE ENTRY LENGTH
       73A8 83E1
  2619 73AA 06A0         BL   @PUTV             PUT THE ENDING LENGTH
       73AC 641E
  2620 73AE 831A         DATA STREND             BYTE IN THE STRING
  2621 73B0 6800         S    R0,@STREND        PT AT FIRST BYTE OF STRING
       73B2 831A
  2622 73B4 C820         MOV  @STREND,@SREF     POINT SREF AT THE STRING
       73B6 831A
       73B8 831C
  2623 73BA 0620         DEC  @STREND           POINT AT LEADING LENGTH BYTE
       73BC 831A
  2624 73BE 06A0         BL   @PUTV             PUT THE LEADING LENGTH BYTE IN
       73C0 641E
  2625 73C2 831A         DATA STREND            THE STRING
  2626 73C4 0660         DECT @STREND           POINT AT BACKPOINTER
       73C6 831A
  2627 73C8 04C6         CLR  R6                ZERO FOR THE BACKPOINTER
  2628 73CA C060         MOV  @STREND,R1        ADDR OR THE BACKPOINTER
       73CC 831A
  2629 73CE 06A0         BL   @STVDP            CLEAR THE BACKPOINTER
       73D0 18AE
  2630 73D2 0620         DEC  @STREND           POINT AT 1ST FREE BYTE
       73D4 831A
  2631 73D6 045C         B    *R12              ALL DONE
  2632            ************************************************************
  2633            * COMPCT - Is the string garbage collection routine. It can
  2634            *          be invoked by GETSTR or MEMCHK. It copies all
  2635            *          used strings to the top of the string space
  2636            *          suppressing out all of the unused strings
  2637            *    INPUT : None
  2638            *    OUTPUT: UPDATED @STRSP AND @STREND
  2639            *    USES  : R0-R6 AS TEMPORARIES
  2640            ************************************************************
  2641 73D8 C1CB  COMPCT MOV  R11,R7            Save rtn address
  2642 73DA C020         MOV  @FREPTR,R0        Get pointer to free space
       73DC 8340
  2643 73DE C160         MOV  @STRSP,R5         Get pointer to string space
       73E0 8318
  2644 73E2 C800         MOV  R0,@STRSP         Set new string space pointer
       73E4 8318
  2645 73E6 0585         INC  R5                Compensate for decrement
  2646 73E8 0605  COMP03 DEC  R5                Point at length of string
  2647 73EA 8160         C    @STREND,R5        At end of string space?
       73EC 831A
  2648 73EE 1A03         JL   COMP05            No, check this string for copy
  2649 73F0 C800         MOV  R0,@STREND        Yes, set end of free space
       73F2 831A
  2650 73F4 0457         B    *R7               Return to caller
  2651 73F6 C085  COMP05 MOV  R5,R2             Copy ptr to end in case moved
  2652 73F8 C0C5         MOV  R5,R3             Copy ptr to end in read length
  2653 73FA 06A0         BL   @GETV1            Read the length byte
       73FC 1880
 99/4 ASSEMBLER
STRINGS                                                      PAGE 0061
  2654 73FE D181         MOVB R1,R6             Put it in R6 for address
  2655 7400 0986         SRL  R6,8              Need in LSB for word
  2656 7402 6146         S    R6,R5             Point at the string start
  2657 7404 0225         AI   R5,-3             Point at the back pointer
       7406 FFFD
  2658 7408 C0C5         MOV  R5,R3             Set up for GETV
  2659 740A 06A0         BL   @GET1             Get the backpointer
       740C 6C9E
  2660 740E C041         MOV  R1,R1             Is this string garbage?
  2661 7410 13EB         JEQ  COMP03            Yes, just ignore it
  2662            * PERTINENT REGISTERS AT THIS POINT
  2663            *        R0 - is where the sting will end
  2664            *        R6 - # of bytes to be moved(does not)
  2665            *             include lengths and backpointer
  2666            *        R2 - points at trailing length byte of string
  2667            *             to be moved
  2668            * IN GENERAL : MOVE (R6) BYTES FROM VDP(R2-R6) TO VDP(R0-R6)
  2669            *              VDP(R0-R6) moving backwards i.e. the last
  2670            *              byte of the entry is moved first, then the
  2671            *              next to the last byte...
  2672 7412 8DB6         C    *R6+,*R6+         INCR by 4 to include overhead
  2673 7414 C0C2         MOV  R2,R3             Restore ptr to end of string
  2674 7416 C100         MOV  R0,R4             Get ptr to end of string space
  2675 7418 06A0  COMP10 BL   @GETV1            Read a byte
       741A 1880
  2676 741C 06A0         BL   @PUTV1            Write a byte
       741E 6422
  2677 7420 0603         DEC  R3                Decrement source pointer
  2678 7422 0604         DEC  R4                Decrement destination pointer
  2679 7424 0606         DEC  R6                Decrement the counter
  2680 7426 15F8         JGT  COMP10            Loop if not finished
  2681 7428 0244         ANDI R4,>3FFF          Delete VDP write-enable & reg
       742A 3FFF
  2682 742C C004         MOV  R4,R0             Set new free space pointer
  2683 742E 0584         INC  R4                Point at backpointer just move
  2684 7430 C0C4         MOV  R4,R3             Copy pointer to read it
  2685 7432 06A0         BL   @GET1             Get the backpointer
       7434 6C9E
  2686            * R1 now contains the address of the forward pointer
  2687 7436 C183         MOV  R3,R6             Address of the string entry
  2688 7438 0226         AI   R6,3              Point at the string itself
       743A 0003
  2689            * R6 now contains the address of the string
  2690 743C 06A0         BL   @STVDP            Reset the forward pointer
       743E 18AE
  2691 7440 10D3         JMP  COMP03            Loop for next string
  2692            ************************************************************
  2693            * NSTRCN - Nud for string constants
  2694            *          Copies the string into the string space and sets
  2695            *          up the FAC with a string entry of the following
  2696            *          form:
  2697            *
  2698            * +-------+-----+----+------------+-----------+
  2699            * | >001C | >65 | XX | Pointer    | Length of |
  2700            * |       |     |    | to string  | string    |
  2701            * +-------+-----+----+------------+-----------+
  2702            * FAC     +2    +3   +4           +6
  2703            ************************************************************
  2704 7442 06C8  NSTRCN SWPB R8
 99/4 ASSEMBLER
STRINGS                                                      PAGE 0062
  2705 7444 C808         MOV  R8,@FAC6          Save length
       7446 8350
  2706 7448 C808         MOV  R8,@BYTE          For GETSTR
       744A 830C
  2707 744C 06C8         SWPB R8
  2708 744E 06A0         BL   @GETSTR           Get result string
       7450 736C
  2709 7452 0200         LI   R0,>001C          Get address of SREF
       7454 001C
  2710 7456 0201         LI   R1,FAC            Optimize to save bytes
       7458 834A
  2711 745A CC40         MOV  R0,*R1+           Indicate temporary string
  2712 745C DC60         MOVB @CBH65,*R1+       Indicate a string
       745E 65A7
  2713 7460 DC40         MOVB R0,*R1+           Byte is not used
  2714 7462 C460         MOV  @SREF,*R1         Save pointer to string
       7464 831C
  2715 7466 C0A0         MOV  @BYTE,R2          Get number of bytes to copy in
       7468 830C
  2716 746A 1318         JEQ  NSTR20            If none to copy
  2717 746C C111         MOV  *R1,R4            Get pointer to destination
  2718 746E C0E0         MOV  @PGMPTR,R3        Get pointer to source
       7470 832C
  2719 7472 D020         MOVB @RAMFLG,R0        ERAM or VDP?
       7474 8389
  2720 7476 1609         JNE  NSTR10            ERAM
  2721            * Get the string from VDP
  2722 7478 06A0  NSTR05 BL   @GETV1            Get a byte
       747A 1880
  2723 747C 06A0         BL   @PUTV1            Put a byte
       747E 6422
  2724 7480 0583         INC  R3                Next in source
  2725 7482 0584         INC  R4                Next in destination
  2726 7484 0602         DEC  R2                1 less to move
  2727 7486 16F8         JNE  NSTR05            If more to move, do it
  2728 7488 1009         JMP  NSTR20            Else if done, exit
  2729 748A D7E0  NSTR10 MOVB @R4LB,*R15        Write 2nd byte of VDP address
       748C 83E9
  2730 748E 0264         ORI  R4,WRVDP          Enable VDP write
       7490 4000
  2731 7492 D7C4         MOVB R4,*R15           Write 1st byte of VDP address
  2732 7494 D833  NSTR15 MOVB *R3+,@XVDPWD      Move byte from ERAM to VDP
       7496 8C00
  2733 7498 0602         DEC  R2                1 less to move
  2734 749A 16FC         JNE  NSTR15            If ont done, loop for more
  2735 749C A820  NSTR20 A    @FAC6,@PGMPTR     Skip the string
       749E 8350
       74A0 832C
  2736 74A2 06A0         BL   @PGMCHR           Get character following string
       74A4 6C74
  2737 74A6 0460         B    @CONT             And continue on
       74A8 64C8
  2738            ************************************************************
  2739 74AA              AORG >74AA
  2741
  2742            ************************************************************
  2743            * CIF     - Convert integer to floating
  2744            *           Assume that the value in the FAC is an integer
  2745            *            and converts it into an 8 byte floating point
 99/4 ASSEMBLER
CIFS                                                         PAGE 0063
  2746            *            value
  2747            ************************************************************
  2748 74AA 0204  CIF    LI   R4,FAC            Will convert into the FAC
       74AC 834A
  2749 74AE C014         MOV  *R4,R0            Get integer into register
  2750 74B0 C184         MOV  R4,R6             Copy pointer to FAC to clear i
  2751 74B2 04F6         CLR  *R6+              Clear FAC & FAC+1
  2752 74B4 04F6         CLR  *R6+              In case had a string in FAC
  2753 74B6 C140         MOV  R0,R5             Is integer equal to zero?
  2754 74B8 1323         JEQ  CIFRT             Yes, zero result and return
  2755 74BA 0740         ABS  R0                Get ABS value of ARG
  2756 74BC 0203         LI   R3,>40            Get exponent bias
       74BE 0040
  2757 74C0 04F6         CLR  *R6+              Clear words in result that
  2758 74C2 04D6         CLR  *R6                might not get a value
  2759 74C4 0280         CI   R0,100            Is integer less than 100?
       74C6 0064
  2760 74C8 1A13         JL   CIF02             Yes, just put in 1st fraction
  2761            *                              part
  2762 74CA 0280         CI   R0,10000          No, is ARG less then 100^2?
       74CC 2710
  2763 74CE 1A08         JL   CIF01             Yes, just 1 division necessary
  2764            *                             No, 2 divisions are necessary
  2765 74D0 0583         INC  R3                Add 1 to exponent for 1st
  2766 74D2 C040         MOV  R0,R1             Put # in low order word for th
  2767            *                              divide
  2768 74D4 04C0         CLR  R0                Clear high order word for the
  2769            *                              divide
  2770 74D6 3C20         DIV  @C100,R0          Divide by the radix
       74D8 6008
  2771 74DA D920         MOVB @R1LB,@3(R4)  ~@  Move the radix digit in
       74DC 83E3
       74DE 0003
  2772 74E0 0583  CIF01  INC  R3                Add 1 to exponent for divide
  2773 74E2 C040         MOV  R0,R1             Put in low order for divide
  2774 74E4 04C0         CLR  R0                Clear high order for divide
  2775 74E6 3C20         DIV  @C100,R0          Divide by the radix
       74E8 6008
  2776 74EA D920         MOVB @R1LB,@2(R4)  ~@  Put next radix digit in
       74EC 83E3
       74EE 0002
  2777 74F0 D920  CIF02  MOVB @R0LB,@1(R4)  ~@  Put highest order radix digit
       74F2 83E1
       74F4 0001
  2778 74F6 D520         MOVB @R3LB,*R4         Put exponent in
       74F8 83E7
  2779 74FA 0545         INV  R5                Is result positive?
  2780 74FC 1101         JLT  CIFRT             Yes, sign is correct
  2781 74FE 0514         NEG  *R4               No, make it negative
  2782 7500 045B  CIFRT  RT
  2783            ************************************************************
  2784
  2785 7502              AORG >7502
  2787
  2788 7502 A000  CONTAD DATA >A000             Address of a continue stmt
  2789      A026  GPLIST EQU  >A026             GPL subprogram linked list
  2790
  2791      00C8  UNQSTZ EQU  >C8               Unquoted string token
  2792
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0064
  2793 7504 8000  INUSE  DATA >8000             In-use flag
  2794 7506 4000  FNCFLG DATA >4000             User-defined function flag
  2795 7508 2000  SHRFLG DATA >2000             Shared-value flag
  2796            *
  2797            * ERROR CODES
  2798            *
  2799      1203  ERRSND EQU  >1203             * SUBEND NOT IN SUBPROGRAM
  2800      0F03  ERRREC EQU  >0F03             * RECURSIVE SUBPROGRAM CALL
  2801      0E03  ERRIAL EQU  >0E03             * INCORRECT ARGUMENT LIST
  2802      1103  ERROLP EQU  >1103             * ONLY LEGAL IN A PROGRAM
  2803
  2804            ************************************************************
  2805            * CALL - STATEMENT EXECUTION
  2806            * Finds the subprogram specified in the subprogram table,
  2807            * evaluates and assigns any arguments to the formal
  2808            * parameters, builds the stack block, and transfers control
  2809            * into the subprogram.
  2810            *  General register usage:
  2811            *     R0 - R6 Temporaries
  2812            *     R7      Pointer into formals in subprogram name entry
  2813            *     R8      Character returned by PGMCHR
  2814            *     R9      Subroutine stack
  2815            *     R10     Temporary
  2816            *     R11     Return link
  2817            *     R12     Temporary
  2818            *     R13     GROM read-data address
  2819            *     R14     Interpreter flags
  2820            *     R15     VDP write-address address
  2821            ************************************************************
  2822 750A 06A0  CALL   BL   @PGMCHR           Skip UNQSTZ & get name length
       750C 6C74
  2823 750E D808         MOVB R8,@FAC15         Save lengthfor FBS
       7510 8359
  2824 7512 D108         MOVB R8,R4             For the copies to be made
  2825 7514 0984         SRL  R4,8               below
  2826 7516 C020         MOV  @PGMPTR,R0        Get pointer to name
       7518 832C
  2827 751A D060         MOVB @RAMFLG,R1        ERAM or VDP?
       751C 8389
  2828 751E 130D         JEQ  CALL04            VDP
  2829            * ERAM, must copy into VDP
  2830 7520 C140         MOV  R0,R5             Pointer to string in ERAM
  2831 7522 0200         LI   R0,CRNBUF         Destination in VDP
       7524 0820
  2832 7526 C0C4         MOV  R4,R3             Length for this move
  2833 7528 D7E0         MOVB @R0LB,*R15        Load out the VDP write address
       752A 83E1
  2834 752C 0260         ORI  R0,WRVDP          Enable the VDP write
       752E 4000
  2835 7530 D7C0         MOVB R0,*R15           Second byte of VDP write
  2836 7532 D835  CALL02 MOVB *R5+,@XVDPWD      Move a byte
       7534 8C00
  2837 7536 0603         DEC  R3                One less byte to move
  2838 7538 16FC         JNE  CALL02            Loop if not done
  2839 753A A804  CALL04 A    R4,@PGMPTR        Skip over the name
       753C 832C
  2840 753E 0201         LI   R1,FAC            Destination in CPU
       7540 834A
  2841 7542 D7E0         MOVB @R0LB,*R15        Load out VDP read address
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0065
       7544 83E1
  2842 7546 0240         ANDI R0,>3FFF          Kill VDP write-enable
       7548 3FFF
  2843 754A D7C0         MOVB R0,*R15           Both bytes
  2844 754C 1000         NOP                    Don't go to fast for it
  2845 754E DC60  CALL06 MOVB @XVDPRD,*R1+      Move a byte
       7550 8800
  2846 7552 0604         DEC  R4                One less bye to move
  2847 7554 16FC         JNE  CALL06            Loop if not done
  2848 7556 C120         MOV  @SUBTAB,R4        Get beginning of subpgm table
       7558 833A
  2849 755A 133C         JEQ  SCAL89            If table empty, search in GPL
  2850 755C 06A0         BL   @FBS001           Search subprogram table
       755E 15E6
  2851 7560 75D4         DATA SCAL89            If not found, search in GPL
  2852            * Pointer to table entry returned in both R4 and FAC
  2853 7562 06A0         BL   @PGMCHR           Get next token
       7564 6C74
  2854 7566 C0C4         MOV  R4,R3             Duplicate pointer for GETV
  2855 7568 06A0         BL   @GETV1            Get flag byte
       756A 1880
  2856 756C 1130         JLT  SCAL90            If attempted recursive call
  2857 756E 0A11         SLA  R1,1              Check for BASIC/GPL program
  2858 7570 1106         JLT  GPLSU             GPL subprogram
  2859 7572 D2E0         MOVB @PRGFLG,R11       Imperative call to BASIC sub?
       7574 8344
  2860 7576 1614         JNE  SCAL01            No, OK-handle BASIC subprogram
  2861 7578 0200         LI   R0,ERROLP         Can't call a BASIC sub
       757A 1103
  2862 757C 102D         JMP  SCAL91              imperatively
  2863            *
  2864            * Handle a GPL subprogram
  2865            *
  2866 757E 05C9  GPLSU  INCT R9
  2867 7580 CE60         MOV  @CONTAD,*R9+      Put address of a cont on stack
       7582 7502
  2868 7584 C64D         MOV  R13,*R9           Save address for real BASIC
  2869 7586 0223         AI   R3,6              Now set up new environment
       7588 0006
  2870 758A 06A0         BL   @GET1             Get access address of GPL subp
       758C 6C9E
  2871 758E DB41         MOVB R1,@GRMWAX(R13)    Load out the address into GRO
       7590 0402
  2872 7592 06C1         SWPB R1                Need to kill time here
  2873 7594 DB41         MOVB R1,@GRMWAX(R13)    Next byte also
       7596 0402
  2874 7598 06A0         BL   @SAVREG           Restore registers to GPL
       759A 1E8C
  2875 759C 0460         B    @RESET            And enter the routine
       759E 006A
  2876            *
  2877            * Execute BASIC subprogram
  2878            *
  2879      75A0  SCAL01 EQU  $
  2880            *-----------------------------------------------------------
  2881            * Fix "An error happened in a CALL statement keeps its
  2882            *      in-use flag set" bug.  5/12/81
  2883            *  Move the following 3 lines after finishing processing
  2884            *  the parameter list, before entering the subprogram.
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0066
  2885            *        SRL  R1,1             Restore mode to original form
  2886            *        SOCB @INUSE,R1        Set the in-use flag bit
  2887            *        BL   @PUTV1           Put the byte back
  2888            * Save the pointer to table entry for setting in-use flag
  2889            * later.
  2890            * $$$$$$$ USE VDP(0374) 2 BYTES AS TEMPRORARY HERE
  2891 75A0 0204         LI   R4,>0374          R4: address register for PUT1
       75A2 0374
  2892 75A4 C043         MOV  R3,R1             R1: data register for PUT1
  2893 75A6 06A0         BL   @PUT1             Save the pointer to table
       75A8 6CB2
  2894            *                              entry in VDP temporary
  2895            *-----------------------------------------------------------
  2896 75AA C303         MOV  R3,R12            Save subtable address
  2897 75AC 04E0         CLR  @FAC2             Indicate non-special entry
       75AE 834C
  2898 75B0 06A0         BL   @VPUSH            Push subprogram entry on stack
       75B2 6BAA
  2899 75B4 C10C         MOV  R12,R4            Restore sub table address
  2900 75B6 C1C4         MOV  R4,R7
  2901 75B8 0227         AI   R7,6              Point to 1st argument in list
       75BA 0006
  2902 75BC C0C7         MOV  R7,R3             Formals' pointer
  2903 75BE 06A0         BL   @GET1             Check to see if any
       75C0 6C9E
  2904 75C2 C041         MOV  R1,R1             Any args?
  2905 75C4 133F         JEQ  SCAL32            None, jump forward
  2906 75C6 0288         CI   R8,LPARZ*256      Must see a left parenthesis
       75C8 B700
  2907 75CA 1640         JNE  SCAL34            If not, error
  2908 75CC 1013         JMP  SCAL08            Jump into argument loop
  2909 75CE 0200  SCAL90 LI   R0,ERRREC         * RECURSIVE SUBPROGRAM CALL
       75D0 0F03
  2910 75D2 1002         JMP  SCAL91
  2911 75D4 0200  SCAL89 LI   R0,>000A          GPL check for DSR subprogram
       75D6 000A
  2912 75D8 0460  SCAL91 B    @ERR
       75DA 6652
  2913 75DC 1031  SCAL93 JMP  SCAL12            Going down!
  2914 75DE 06A0  SCAL05 BL   @POPSTK           Short stack pop routine
       75E0 60D4
  2915 75E2 C1E0         MOV  @ARG4,R7          To quickly restore R7
       75E4 8360
  2916 75E6 05C7         INCT R7                To account for SCAL80
  2917 75E8 0288  SCAL06 CI   R8,RPARZ*256      Actual list ended?
       75EA B600
  2918 75EC 132D         JEQ  SCAL30            Actuals all scanned
  2919 75EE 0288         CI   R8,COMMAZ*256     Must see a comma then
       75F0 B300
  2920 75F2 1626         JNE  SCAL12            Didn't, so error
  2921            * Scan next actual. Check if it is just a name
  2922 75F4 C820  SCAL08 MOV  @PGMPTR,@ERRCOD   Save text ptr in case of expr
       75F6 832C
       75F8 8322
  2923 75FA 06A0         BL   @PGMCHR           Get next character
       75FC 6C74
  2924 75FE 1179         JLT  SCAL40            No, so must be an expression
  2925 7600 C307         MOV  R7,R12            Save formals pointer
  2926 7602 06A0         BL   @SYM              Read name & see if recognized
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0067
       7604 6312
  2927 7606 06A0         BL   @GETV             Check function flag
       7608 187C
  2928 760A 834A         DATA FAC
  2929 760C C1CC         MOV  R12,R7            Restore formals pointer first
  2930 760E 2460         CZC  @FNCFLG,R1        User-defined function?
       7610 7506
  2931 7612 166F         JNE  SCAL40            Yes, pass by value
  2932 7614 0288         CI   R8,LPARZ*256      Complex type?
       7616 B700
  2933 7618 1620         JNE  SCAL15            No
  2934 761A 06A0         BL   @PGMCHR           Check if formal entry
       761C 6C74
  2935 761E 0288         CI   R8,RPARZ*256      FOO() ?
       7620 B600
  2936 7622 1319         JEQ  SCAL14            Yes, handle it as such
  2937 7624 0288         CI   R8,COMMAZ*256     or FOO(,...) ?
       7626 B300
  2938 7628 1613         JNE  SCAL35            No, an array element FOO(I...
  2939 762A 06A0  SCAL10 BL   @PGMCHR           Formal array, scan to end
       762C 6C74
  2940 762E 06A0         BL   @EOSTMT           Check if end-of-statement
       7630 6862
  2941 7632 1306         JEQ  SCAL12            Premature end of statement
  2942 7634 0288         CI   R8,COMMAZ*256     Another comma?
       7636 B300
  2943 7638 13F8         JEQ  SCAL10            Yes, continue on to end
  2944 763A 0288         CI   R8,RPARZ*256      End yet?
       763C B600
  2945 763E 130B         JEQ  SCAL14            Yes, merge in below
  2946 7640 0460  SCAL12 B    @ERRONE           * SYNTAX ERROR
       7642 664E
  2947 7644 0460  SCAL32 B    @SCAL62           Going down!
       7646 77B8
  2948 7648 0460  SCAL30 B    @SCAL60
       764A 77B4
  2949 764C 0460  SCAL34 B    @SCAL88
       764E 7878
  2950 7650 0460  SCAL35 B    @SCAL50
       7652 7744
  2951 7654 10C9  SCAL37 JMP  SCAL06
  2952            *
  2953            * Here for Scalers/Arrays by Reference
  2954 7656 06A0  SCAL14 BL   @PGMCHR           Pass the right parenthesis
       7658 6C74
  2955 765A 0288  SCAL15 CI   R8,COMMAZ*256     Just a name?
       765C B300
  2956 765E 1303         JEQ  SCAL16            Yes
  2957 7660 0288         CI   R8,RPARZ*256      Start an expression?
       7662 B600
  2958 7664 1646         JNE  SCAL40            Yes, name starts an expression
  2959 7666 06A0  SCAL16 BL   @GETV             Get mode of name
       7668 187C
  2960 766A 834A         DATA FAC               Ptr to s.t. entry left by SYM
  2961 766C D081         MOVB R1,R2             Save for check below
  2962 766E 06A0         BL   @SCAL80           And fetch next formal info
       7670 787E
  2963 7672 D042         MOVB R2,R1             Copy for this check
  2964 7674 0241         ANDI R1,>C700            for the comparison
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0068
       7676 C700
  2965 7678 C006         MOV  R6,R0             Use a temporary rgister
  2966 767A 0240         ANDI R0,>C700            for the comparison
       767C C700
  2967 767E 8001         C    R1,R0             Must be exact match
  2968 7680 16E5         JNE  SCAL34            Else can't pass by reference
  2969 7682 E1A0         SOC  @SHRFLG,R6        Set the shared symbol flag
       7684 7508
  2970 7686 D046         MOVB R6,R1             Load up for PUTV
  2971 7688 C105         MOV  R5,R4             Address to put the flag
  2972 768A 06A0         BL   @PUTV1            Set the flag in the s.t. entry
       768C 6422
  2973 768E 0244         ANDI R4,>3FFF          Kill VDP write-enable bit
       7690 3FFF
  2974            *
  2975            * The following section finds actual's value space address
  2976            *  and puts it in R1.
  2977            *  FAC contains the symbol table's address.
  2978            * If actual is NOT shared.......................
  2979            *  Symbol table's address+6 will point to the value space
  2980            *   except for numeric ERAM cae. In a numeric ERAM case
  2981            *   GET1 to get pointer to the ERAM value space.
  2982            * If actual is SHARED........................
  2983            *  GET1 to get the pointer in symbol table's address+6
  2984            *  In a numeric ERAM case, GETG to get the indirect point
  2985            *   to the actual's vlaue space pointer after GET1 is call
  2986            *
  2987 7692 C060         MOV  @FAC,R1           Ptr to actual s.t. entry
       7694 834A
  2988 7696 0221         AI   R1,6              Ptr to actuals value space
       7698 0006
  2989 769A 0246         ANDI R6,>8700          Keep info on string or array
       769C 8700
  2990 769E 0242         ANDI R2,>2000          Is actual shared?
       76A0 2000
  2991 76A2 130C         JEQ  SCAL23            No, use it
  2992 76A4 C0C1         MOV  R1,R3             Else look further
  2993 76A6 06A0         BL   @GET1             Get the true pointer
       76A8 6C9E
  2994 76AA D186         MOVB R6,R6             Array or string?
  2995 76AC 160F         JNE  SCAL24            Yes, both are special cases
  2996 76AE D0A0         MOVB @RAMTOP,R2        ERAM present?
       76B0 8384
  2997 76B2 130C         JEQ  SCAL24            No ERAM, so skip
  2998            * Numeric variable, shared, ERAM.
  2999 76B4 C0C1         MOV  R1,R3             Get ptr to original from ERAM
  3000 76B6 06A0         BL   @GETG2            Get indirect pointer
       76B8 6CCE
  3001 76BA 1008         JMP  SCAL24
  3002            * Shared bit is NOT on.
  3003 76BC D186  SCAL23 MOVB R6,R6             Check for array or string
  3004 76BE 1606         JNE  SCAL24            Yes, take what's in there
  3005 76C0 D0A0         MOVB @RAMTOP,R2        ERAM exists?
       76C2 8384
  3006 76C4 1303         JEQ  SCAL24            No
  3007 76C6 C0C1         MOV  R1,R3             Numeric and ERAM case
  3008 76C8 06A0         BL   @GET1             Get ERAM value space address
       76CA 6C9E
  3009            *                             R4 pointing to value space of
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0069
  3010 76CC 0224  SCAL24 AI   R4,6               subprogram's symbol table
       76CE 0006
  3011 76D0 D186         MOVB R6,R6             Array or string case?
  3012 76D2 160C         JNE  SCAL26            Yes, so just put ptr in VDP
  3013            * Here check for ERAM program and if ERAM then copy the
  3014            * address of shared value space into corresponding value
  3015            * space in ERAM
  3016 76D4 D1A0         MOVB @RAMTOP,R6        Get the ERAM flag
       76D6 8384
  3017 76D8 1309         JEQ  SCAL26            If no ERAM, simple case
  3018 76DA C181         MOV  R1,R6             Keep shared value space addres
  3019 76DC C0C4         MOV  R4,R3             Put ptr in value space in ERAM
  3020 76DE 06A0         BL   @GET1             Get value space address in ERA
       76E0 6C9E
  3021 76E2 C101         MOV  R1,R4             Copy address into R4 for PUTG2
  3022 76E4 C046         MOV  R6,R1             Get the value to put in ERAM
  3023 76E6 06A0         BL   @PUTG2            Write it into ERAM
       76E8 6CD8
  3024 76EA 10B4         JMP  SCAL37            Loop for next argument
  3025 76EC 06A0  SCAL26 BL   @PUT1             Set symbol indirect link
       76EE 6CB2
  3026 76F0 10B1         JMP  SCAL37            And loop for next arg
  3027            *
  3028            * Here to pass an expression by value
  3029            *
  3030 76F2 C820  SCAL40 MOV  @ERRCOD,@PGMPTR   Restore text pointer
       76F4 8322
       76F6 832C
  3031 76F8 C807         MOV  R7,@FAC4          Save formals pointer
       76FA 834E
  3032 76FC 04E0         CLR  @FAC2             Don't let VPUSH mess up
       76FE 834C
  3033 7700 06A0  SCAL42 BL   @PGMCHR           Set up for the parse
       7702 6C74
  3034            * Save formals ptr & SUBTAB ptr and evaluate the expression
  3035 7704 06A0         BL   @PSHPRS
       7706 6B9C
  3036 7708   B6         BYTE RPARZ             Stop on an rpar or comma
  3037 7709   6A  DCBH6A BYTE >6A               (CBH6A copy)
  3038 770A 06A0         BL   @POPSTK           Restore formals pointer
       770C 60D4
  3039 770E A820         A    @C16,@VSPTR       But keep it on stack
       7710 6BF8
       7712 836E
  3040 7714 06A0         BL   @VPUSH            Save parse result
       7716 6BAA
  3041 7718 C1E0         MOV  @ARG4,R7          Restore formals pointer
       771A 8360
  3042 771C 06A0         BL   @SCAL80           And fetch next formal's info
       771E 787E
  3043 7720 C805         MOV  R5,@FAC           Set up for assignment
       7722 834A
  3044 7724 06A0         BL   @SMB              Get value space
       7726 61DC
  3045 7728 6820         S    @C16,@VSPTR       Get to s.t. info
       772A 6BF8
       772C 836E
  3046 772E 06A0         BL   @VPUSH            Set up for ASSG
       7730 6BAA
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0070
  3047 7732 A820         A    @C8,@VSPTR        Get back to parse result
       7734 706C
       7736 836E
  3048 7738 06A0         BL   @VPOP             Get parse result back
       773A 6C2A
  3049 773C 06A0         BL   @ASSG             Assign the value to the formal
       773E 6334
  3050 7740 0460         B    @SCAL05           And go back for more
       7742 75DE
  3051            *
  3052            * Here for array elements
  3053            *
  3054 7744 0620  SCAL50 DEC  @PGMPTR           Restore text pointer to lpar
       7746 832C
  3055 7748 020B         LI   R11,FAC2          Optimize to save
       774A 834C
  3056 774C 04FB         CLR  *R11+             Don't let VPUSH mess up (FAC2)
  3057 774E CEC7         MOV  R7,*R11+          Save formals pointer    (FAC4)
  3058 7750 C6E0         MOV  @ERRCOD,*R11      For save on stack       (FAC6)
       7752 8322
  3059 7754 06A0         BL   @VPUSH            Save the info
       7756 6BAA
  3060 7758 0208         LI   R8,LPARZ*256      Load up R8 with the lpar again
       775A B700
  3061 775C C820         MOV  @FAC,@PAD0        Save ptr to s.t. entry
       775E 834A
       7760 8300
  3062 7762 06A0         BL   @SMB              Check if name or expression
       7764 61DC
  3063 7766 0288         CI   R8,COMMAZ*256
       7768 B300
  3064 776A 1309         JEQ  SCAL54            Name if ended on a comma
  3065 776C 0288         CI   R8,RPARZ*256
       776E B600
  3066 7770 1306         JEQ  SCAL54             or rpar
  3067 7772 06A0         BL   @VPOP             Get saved info back
       7774 6C2A
  3068 7776 C820         MOV  @FAC6,@PGMPTR     Else expr, Restore test pointe
       7778 8350
       777A 832C
  3069 777C 10C1         JMP  SCAL42            And handle like an expression
  3070            *
  3071            * Passing array elements by reference
  3072 777E 06A0  SCAL54 BL   @POPSTK           Restore symbol pointer
       7780 60D4
  3073 7782 C1E0         MOV  @ARG4,R7
       7784 8360
  3074 7786 06A0         BL   @SCAL80           Get next formal's info
       7788 787E
  3075 778A 06A0         BL   @GETV             Check actualOs mode
       778C 187C
  3076 778E 8300         DATA PAD0              Get back header information
  3077 7790 0241         ANDI R1,>C000          Throw away all but string & fu
       7792 C000
  3078 7794 9046         CB   R6,R1             Check mode match (string/num)
  3079 7796 1612         JNE  JNE88             Don't, so error
  3080            * Can set bit in R1 since MSB (R1)=MSB (R6)
  3081 7798 F060         SOCB @SHRFLG,R1        Set the share flag
       779A 7508
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0071
  3082 779C C105         MOV  R5,R4             Address for PUTV
  3083 779E 06A0         BL   @PUTV1            Put it in the s.t. entry
       77A0 6422
  3084 77A2 0244         ANDI R4,>3FFF          Kill VDP write, enable bit
       77A4 3FFF
  3085 77A6 C060         MOV  @FAC,R1           Assuming string, ref link=@FAC
       77A8 834A
  3086 77AA D186         MOVB R6,R6             Check if it is a string
  3087 77AC 118F         JLT  SCAL24            If so, go set ref. link
  3088 77AE C060         MOV  @FAC4,R1          Numeric, ref. link=@FAC4(v.s.)
       77B0 834E
  3089 77B2 108C         JMP  SCAL24            Now set the link and go on
  3090            *
  3091            * Here when done parsing actuals
  3092            *
  3093 77B4 06A0  SCAL60 BL   @PGMCHR           Pass the right parenthesis
       77B6 6C74
  3094 77B8 06A0  SCAL62 BL   @EOSTMT           Must be at end of statement
       77BA 6862
  3095 77BC 165D  JNE88  JNE  SCAL88            If not, error
  3096 77BE C0C7         MOV  R7,R3             Formals must also have ended
  3097 77C0 05C7         INCT R7
  3098 77C2 C807         MOV  R7,@FAC           Keep R7, POPSTK destorys R7
       77C4 834A
  3099 77C6 06A0         BL   @GET1             Get the last arg address
       77C8 6C9E
  3100 77CA C041         MOV  R1,R1             Formals end?
  3101 77CC 1655         JNE  SCAL88            Didn't, so error
  3102            *
  3103            * Now set up the stack entry
  3104            *
  3105 77CE 06A0         BL   @VPUSH            Check if enough room for push
       77D0 6BAA
  3106 77D2 6820         S    @C8,@VSPTR        Get back right pointer
       77D4 706C
       77D6 836E
  3107 77D8 06A0         BL   @POPSTK           Retrieve ptr to subprog s.t.
       77DA 60D4
  3108 77DC 020C         LI   R12,FAC           For code optimization
       77DE 834A
  3109 77E0 C04C         MOV  R12,R1            Store following data in FAC
  3110 77E2 C81C         MOV  *R12,@ARG2        Save new environment pointer
       77E4 835E
  3111            *
  3112            * First push entry. PGMCHR, EXTRAM, SYMTAB and RAM(SYNBOL)
  3113            *
  3114 77E6 0200         LI   R0,PGMPTR         Optimize
       77E8 832C
  3115 77EA CC70         MOV  *R0+,*R1+         Text pointer         PGMPTR
  3116 77EC CC70         MOV  *R0+,*R1+         Line table pointer   EXTRAM
  3117 77EE CC60         MOV  @SYMTAB,*R1+      Symbol table pointer
       77F0 833E
  3118 77F2 0203         LI   R3,SYMBOL         Put address of SYMBOL
       77F4 0376
  3119 77F6 06A0         BL   @GET1             Get RAM(SYMBOL) in REG1
       77F8 6C9E
  3120 77FA C801         MOV  R1,@FAC6          Move to FAC area
       77FC 8350
  3121 77FE 06A0         BL   @VPUSH            Save first entry
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0072
       7800 6BAA
  3122            *
  3123            * Push second entry. Subprogram table pointer, >6A on warnin
  3124            *  bits and @LSUBP in the second stack.
  3125 7802 C10C         MOV  R12,R4            Going to build entry in FAC
  3126 7804 CD20         MOV  @ARG,*R4+         Subprogram table entry pointer
       7806 835C
  3127 7808 DD20         MOVB @DCBH6A,*R4+      >6A = Stack ID
       780A 7709
  3128 780C D0A0         MOVB @FLAG,R2          Warning/break bits
       780E 8345
  3129 7810 0242         ANDI R2,>0600          Mask off other bits
       7812 0600
  3130 7814 DD02         MOVB R2,*R4+           Put bits in stack entry
  3131 7816 C820         MOV  @LSUBP,@FAC6      Last subprogram block on stack
       7818 8348
       781A 8350
  3132 781C 06A0         BL   @VPUSH            Push final entry
       781E 6BAA
  3133 7820 C820         MOV  @VSPTR,@LSUBP     Set bottom of stack for the su
       7822 836E
       7824 8348
  3134            *
  3135            * Now build the new environment by modifying PGMCHR,
  3136            * EXTRAM and pointer to sub's symbol table.
  3137 7826 0200         LI   R0,PGMPTR         Optimization
       7828 832C
  3138 782A D7E0         MOVB @ARG3,*R15        2nd byte of address
       782C 835F
  3139 782E 0201         LI   R1,XVDPRD         Optimize to save bytes
       7830 8800
  3140 7832 D7E0         MOVB @ARG2,*R15        1st byte of address
       7834 835E
  3141 7836 0204         LI   R4,4              Need 4 bytes
       7838 0004
  3142 783A DC11  SCAL70 MOVB *R1,*R0+          Read EXTRAM and PGMPTR
  3143 783C 0604         DEC  R4
  3144 783E 16FD         JNE  SCAL70
  3145 7840 D811         MOVB *R1,@SYMTAB       New SYMTAB
       7842 833E
  3146 7844 0204         LI   R4,SYMBOL
       7846 0376
  3147 7848 D811         MOVB *R1,@SYMTA1
       784A 833F
  3148 784C C060         MOV  @SYMTAB,R1
       784E 833E
  3149 7850 06A0         BL   @PUT1             New RAM(SYMBOL)
       7852 6CB2
  3150 7854 04E0         CLR  @ERRCOD           Clean up our mess
       7856 8322
  3151 7858 06A0         BL   @PGMCHR           Get the next token into R8
       785A 6C74
  3152            *-----------------------------------------------------------
  3153            * Fix "A error happened in a CALL statement keeps it
  3154            *   "in-use flag set" bug,    5/23/81
  3155            * Insert following lines:
  3156 785C 0203         LI   R3,>0374          Restore the pointer to table
       785E 0374
  3157            *  entry from VDP temporary, R3: address reg. for GET1
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0073
  3158 7860 06A0         BL   @GET1
       7862 6C9E
  3159 7864 C0C1         MOV  R1,R3             Get flag byte
  3160 7866 06A0         BL   @GETV1
       7868 1880
  3161 786A F060         SOCB @INUSE,R1         Set the in-use flag bit
       786C 7504
  3162 786E C103         MOV  R3,R4             ??????????????????????????????
  3163 7870 06A0         BL   @PUTV1            Put the byte back
       7872 6422
  3164            *-----------------------------------------------------------
  3165 7874 0460         B    @NUDEND           Enter the subprogram
       7876 65F0
  3166 7878 0200  SCAL88 LI   R0,ERRIAL         * INCORRECT ARGUMENT LIST
       787A 0E03
  3167 787C 1062         JMP  $+>C6             Jump to  B @ERR
  3168            ************************************************************
  3169            * Fetch next formal and prop for adjustment
  3170            * Register modification
  3171            *    R5  Address of s.t. entry (formal's entry)
  3172            *    R6  Header byte of formal's entry
  3173            *    R7  Updated formal's pointer
  3174            * Destroys: R1, R2, R3, R4, R11, R12
  3175            ************************************************************
  3176 787E C30B  SCAL80 MOV  R11,R12           Save return address
  3177 7880 C0C7         MOV  R7,R3             Fetch symbol pointer
  3178 7882 05C7         INCT R7                Point to next formal
  3179 7884 06A0         BL   @GET1             Fetch s.t. pointer
       7886 6C9E
  3180 7888 C0C1         MOV  R1,R3             Set condition & put in place
  3181 788A 13F6         JEQ  SCAL88            If to many actuals
  3182 788C C101         MOV  R1,R4             Save for below
  3183 788E C141         MOV  R1,R5             Save for return
  3184 7890 06A0         BL   @GET1             Get header bytes
       7892 6C9E
  3185 7894 2060         COC  @SHRFLG,R1        Shared?
       7896 7508
  3186 7898 1313         JEQ  SCAL82            Yes, reset flag and old value
  3187 789A C181         MOV  R1,R6             Save for return & test string
  3188 789C 1101         JLT  SCAL81            If it is a string, then SCAL81
  3189 789E 045C         B    *R12              Return
  3190 78A0 0223  SCAL81 AI   R3,6              Is string, point at value ptr
       78A2 0006
  3191 78A4 06A0         BL   @GET1             Get the value pointer
       78A6 6C9E
  3192 78A8 C101         MOV  R1,R4             Null value?
  3193 78AA 1312         JEQ  SCAL86            Yes
  3194 78AC 04C1         CLR  R1                No, must free current string
  3195 78AE 0224         AI   R4,-3             Point at the backpointer
       78B0 FFFD
  3196 78B2 06A0         BL   @PUT1             Clear the backpointer
       78B4 6CB2
  3197 78B6 C103         MOV  R3,R4
  3198 78B8 04C1  SCAL84 CLR  R1                Needed for entry from below
  3199 78BA 06A0         BL   @PUT1             Clear the forward pointer
       78BC 6CB2
  3200 78BE 045C         B    *R12              Just return
  3201 78C0 0241  SCAL82 ANDI R1,>DFFF          Reset the share flag
       78C2 DFFF
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0074
  3202 78C4 06A0         BL   @PUTV1            Put it there
       78C6 6422
  3203 78C8 0224         AI   R4,6              Point at ref pointer
       78CA 0006
  3204 78CC C181         MOV  R1,R6             Set for return
  3205 78CE 11F4         JLT  SCAL84            If string clear ref pointer
  3206 78D0 045C  SCAL86 B    *R12              Return
  3207            ************************************************************
  3208            * Execute a SUBEXIT or SUBEND
  3209            ************************************************************
  3210 78D2 C160  SUBXIT MOV  @LSUBP,R5         Check for subprogram on stack
       78D4 8348
  3211 78D6 1333         JEQ  SCAL98            Not one, so error
  3212 78D8 8805         C    R5,@VSPTR         Extra check on stack pointer
       78DA 836E
  3213 78DC 1B30         JH   SCAL98            Pointers are messed up, error
  3214 78DE 06A0  SBXT05 BL   @VPOP             Get stack entry
       78E0 6C2A
  3215 78E2 9820         CB   @FAC2,@DCBH6A     Reached the subprogram entry?
       78E4 834C
       78E6 7709
  3216 78E8 16FA         JNE  SBXT05            Not yet
  3217            *
  3218            * Reached the subprogram stack entry. Get information FAC
  3219            *  area has subprograms table pointer, >6A, on warning bits
  3220            *  and LSUBP
  3221 78EA 020C         LI   R12,FAC           Optimize for the copies
       78EC 834A
  3222 78EE C00C         MOV  R12,R0            For this copy
  3223 78F0 C0F0         MOV  *R0+,R3           Subprogram pointer
  3224 78F2 06A0         BL   @GETV1            Get header byte in subprogram
       78F4 1880
  3225 78F6 5060         SZCB @INUSE,R1         Reset the in-use bit
       78F8 7504
  3226 78FA C103         MOV  R3,R4
  3227 78FC 06A0         BL   @PUTV1            Put it back
       78FE 6422
  3228 7900 C070         MOV  *R0+,R1           On warning bits
  3229 7902 D120         MOVB @FLAG,R4          Get the current flag
       7904 8345
  3230 7906 0244         ANDI R4,>F900          Trash current warning bits
       7908 F900
  3231 790A F120         SOCB @R1LB,R4          OR the old ones back in
       790C 83E3
  3232 790E D804         MOVB R4,@FLAG          And put flag back
       7910 8345
  3233 7912 05C0         INCT R0                There is one word empty
  3234 7914 C830         MOV  *R0+,@LSUBP       Last subprogram block on stack
       7916 8348
  3235            *
  3236            * Second subprogram stack entry. Restore pointers. FAC area
  3237            *  has PGMPTR, EXTRAM, SYMTAB, RAM(SYMBOL)
  3238 7918 06A0         BL   @VPOP             Get second entry
       791A 6C2A
  3239 791C C00C         MOV  R12,R0            Put FAC in R0. (optimization)
  3240 791E 0201         LI   R1,PGMPTR         For optimization
       7920 832C
  3241 7922 C470         MOV  *R0+,*R1          Restore text pointer    PGMPTR
  3242 7924 0631         DEC  *R1+              Save code to decrement it
 99/4 ASSEMBLER
SUBPROGS                                                     PAGE 0075
  3243 7926 CC70         MOV  *R0+,*R1+         Line table pointer EXTRAM
  3244 7928 C830         MOV  *R0+,@SYMTAB      Restore symbol table pointer
       792A 833E
  3245 792C C070         MOV  *R0+,R1           Restore permanent s.t. pointer
  3246 792E 0204         LI   R4,SYMBOL         Place in VDP
       7930 0376
  3247 7932 06A0         BL   @PUT1             Put it out there
       7934 6CB2
  3248 7936 06A0         BL   @PGMCHR           Load R8 with EOS/EOL & go on
       7938 6C74
  3249 793A 0460         B    @EOL
       793C 65D6
  3250 793E 0200  SCAL98 LI   R0,ERRSND         * SUBEND NOT IN SUBPROGRAM
       7940 1203
  3251 7942 0460         B    @ERR
       7944 6652
  3252            ************************************************************
  3253
  3254
  3256
  3257            ************************************************************
  3258            * RESOLV - Attempt to resolve all subprograms referenced in
  3259            * call statements by first searching the internal subprogram
  3260            * table (SUBTAB), then by searching GROMs for GPL
  3261            * subprograms. In RESGPL, it builds a subprogram table.
  3262            * If, after searching all of the subprogram areas, there
  3263            * are any subprograms whose location cannot be determined,
  3264            * an error occurs.
  3265            ************************************************************
  3266 7946 05C9  RESOLV INCT R9                Save return address
  3267 7948 C64B         MOV  R11,*R9
  3268 794A C160         MOV  @CALIST,R5        Pick up call list pointer
       794C 830A
  3269 794E 1337         JEQ  RES50             If no subprogram references
  3270 7950 C1A0  RES03  MOV  @SUBTAB,R6        Pick up subprogram table ptr
       7952 833A
  3271 7954 1327  RES05  JEQ  RES15             Try to resolve by checking
  3272            *
  3273            * Compares two names for a match when trying to resolve all
  3274            *  references to subprograms.
  3275            * Register usage is generally as follows:
  3276            *         R5  - Pointer to CALIST entry to be compared
  3277            *         R7  - Pointer to entry to be compared to SUBTAB
  3278            *               Returns as pointer to name if found or zero
  3279            *                if not found
  3280            *         R10 - Returned as length of name
  3281 7956 C0C6         MOV  R6,R3             Put in place for GETV
  3282 7958 0583         INC  R3                Point at the name length
  3283 795A 06A0         BL   @GETV1            Get the name length
       795C 1880
  3284 795E 0981         SRL  R1,8              Put in LSB and clear MSB
  3285 7960 C101         MOV  R1,R4             Save it for the move
  3286 7962 0223         AI   R3,3              Point at name pointer
       7964 0003
  3287 7966 06A0         BL   @GET1             Get the name pointer
       7968 6C9E
  3288 796A C1C1         MOV  R1,R7             Save in permanent
  3289 796C C801         MOV  R1,@PGMPTR        Save for compare
       796E 832C
 99/4 ASSEMBLER
SUBPROGS2                                                    PAGE 0076
  3290 7970 C0C5         MOV  R5,R3             To get the CALIST entry
  3291 7972 0583         INC  R3                Point at the name length
  3292 7974 06A0         BL   @GETV1            Get the name length
       7976 1880
  3293 7978 9801         CB   R1,@R4LB          Name length match?
       797A 83E9
  3294 797C 161A         JNE  RES20             No, no match possible
  3295 797E C004         MOV  R4,R0             Save name length for compare
  3296 7980 0223         AI   R3,3              Point at the name pointer
       7982 0003
  3297 7984 06A0         BL   @GET1             Get the pointer to the name
       7986 6C9E
  3298 7988 C0C1         MOV  R1,R3             Set up to get the name
  3299 798A 06A0  COMPTN BL   @GETV1            Get a char of CALIST name
       798C 1880
  3300            * Next PGMSUB call is the same as PGMCHR except in skipping
  3301            *  ERAM check
  3302 798E 06A0         BL   @PGMSUB           Get a char of found name
       7990 6C7A
  3303 7992 9201         CB   R1,R8             Chars match?
  3304 7994 160E         JNE  RES20             No, not same name
  3305 7996 0583         INC  R3                Next character
  3306 7998 0600         DEC  R0                Done with compare?
  3307 799A 16F7         JNE  COMPTN            No, check the rest
  3308            * Found the subprogram in GROM and built the table.
  3309            * Set resolved flag and get back.
  3310 799C C105         MOV  R5,R4             Set resolved flag now
  3311 799E 0701         SETO R1                Set up a resolved flag
  3312 79A0 06A0         BL   @PUTV1            And put the byte in
       79A2 6422
  3313 79A4 C0C5  RES15  MOV  R5,R3             Get call list pointer
  3314 79A6 05C3         INCT R3                Point at link
  3315 79A8 06A0         BL   @GET1             Get the name link
       79AA 6C9E
  3316 79AC C141         MOV  R1,R5             Save and set condition
  3317 79AE 130E         JEQ  RESGPL            End of call list? Yes
  3318 79B0 16CF         JNE  RES03             No, go check the next in list
  3319 79B2 C0C6  RES20  MOV  R6,R3             Get next entry in subpgm table
  3320 79B4 05C3         INCT R3                Point at the link
  3321 79B6 06A0         BL   @GET1             Get the link
       79B8 6C9E
  3322 79BA C181         MOV  R1,R6             Update subprogram table pointe
  3323 79BC 10CB         JMP  RES05             And try next entry
  3324 79BE 04C3  RES50  CLR  R3                Indicate no error return
  3325 79C0 C2D9  RES51  MOV  *R9,R11           Restore return address
  3326 79C2 0649         DECT R9                Restore stack
  3327 79C4 045B         RT                     All resolved and ok
  3328 79C6 0203  RES52  LI   R3,>001C
       79C8 001C
  3329 79CA 10FA         JMP  RES51
  3330            ************************************************************
  3331            *                   RESGPL routine
  3332            * Resolves as a GPL subprogram by comparing names in CALL
  3333            * list and GROM link list in EXEC. If name found in GROM
  3334            * then turn the resolved flag on and if not found an error
  3335            * occurs. Fetch subprogram access address from the link
  3336            * list and builds a subprogram table for that call.
  3337            ************************************************************
  3338 79CC C160  RESGPL MOV  @CALIST,R5        Get the call list pointer
 99/4 ASSEMBLER
SUBPROGS2                                                    PAGE 0077
       79CE 830A
  3339            * Get the next subprogram in the call list that has not been
  3340            *  resolved.
  3341 79D0 C0C5  GET01  MOV  R5,R3             Get pointer in call list
  3342 79D2 13F5         JEQ  RES50             If end of list
  3343 79D4 06A0         BL   @GETV1            Get the resolved flag
       79D6 1880
  3344 79D8 1306         JEQ  GPL00             If not resolved
  3345 79DA 05C3  GET03  INCT R3                Point at link
  3346 79DC 06A0         BL   @GET1             Get the link
       79DE 6C9E
  3347 79E0 C141         MOV  R1,R5             Save it and set condition
  3348 79E2 16F6         JNE  GET01             If not end of list, go on
  3349 79E4 10EC         JMP  RES50             Return
  3350            * Start looking at GROM subprogram link list.
  3351 79E6 0207  GPL00  LI   R7,GPLIST         Load address of link list
       79E8 A026
  3352 79EA C0C5         MOV  R5,R3             Copy CALIST address
  3353 79EC 0583         INC  R3                Point to name length
  3354 79EE 06A0         BL   @GETV1            Get the name length
       79F0 1880
  3355 79F2 0981         SRL  R1,8              Adjust to the right byte
  3356 79F4 C001         MOV  R1,R0             Copy for later use
  3357 79F6 04CA         CLR  R10               Clear for name length
  3358 79F8 0223         AI   R3,3              Point to name ptr in call list
       79FA 0003
  3359 79FC DB47  GPL10  MOVB R7,@GRMWAX(R13)    Specify address in link list
       79FE 0402
  3360 7A00 06C7         SWPB R7                Need to kill time here
  3361 7A02 DB47         MOVB R7,@GRMWAX(R13)    Move next byte
       7A04 0402
  3362 7A06 06C7         SWPB R7                Get R7 in right order
  3363 7A08 D21D         MOVB *R13,R8           Read next link address from
  3364 7A0A D81D         MOVB *R13,@R8LB         linked list
       7A0C 83F1
  3365 7A0E 05C7         INCT R7                Point to name length in GROM
  3366 7A10 DB47         MOVB R7,@GRMWAX(R13)    Specify name length address
       7A12 0402
  3367 7A14 06C7         SWPB R7                Need to kill time here
  3368 7A16 DB47         MOVB R7,@GRMWAX(R13)    Move next byte
       7A18 0402
  3369 7A1A 06C7         SWPB R7                Get R7 in right order
  3370 7A1C D81D         MOVB *R13,@R10LB       Get the name length in GROM
       7A1E 83F5
  3371 7A20 8280         C    R0,R10            Compare name length
  3372 7A22 1304         JEQ  GPL25             If matches, compare names
  3373 7A24 C1C8  GPLNXT MOV  R8,R7             Didn't match, get link to next
  3374 7A26 16EA         JNE  GPL10             Loop if not end of list
  3375 7A28 C0C5         MOV  R5,R3             If end of GPL list, ignore thi
  3376 7A2A 10D7         JMP  GET03              entry in CALIST
  3377            * Start comparing the names
  3378 7A2C 06A0  GPL25  BL   @GET1             Get name ptr form call list
       7A2E 6C9E
  3379            *                             R1 contains address of name
  3380 7A30 D7E0         MOVB @R1LB,*R15        Get one character from VDP
       7A32 83E3
  3381 7A34 1000         NOP
  3382 7A36 D7C1         MOVB R1,*R15           Then compare with the one in
  3383 7A38 981D  GPL30  CB   *R13,@XVDPRD       GROM - R13 points to GROM
 99/4 ASSEMBLER
SUBPROGS2                                                    PAGE 0078
       7A3A 8800
  3384 7A3C 16F3         JNE  GPLNXT            If no match get next in GROM
  3385 7A3E 060A         DEC  R10               All matched?
  3386 7A40 16FB         JNE  GPL30             No, loop for next characters
  3387            * Found the GPL subprogram. Now start building GPL's
  3388            *  subprogram table.
  3389            * First put all information in FAC since they might get
  3390            *  destroyed in MEMCHK.
  3391            * @FAC2  = Set program bit and name length
  3392            * @FAC4  = Subprogram table link address
  3393            * @FAC6  = Pointer to name
  3394            * @FAC8  = Access address in GROM
  3395            * @FAC10 = Current call list address
  3396 7A42 020C         LI   R12,FAC2          Optimize for speed and space
       7A44 834C
  3397 7A46 C700         MOV  R0,*R12           Keep length in FAC2
  3398 7A48 EF20         SOC  @FNCFLG,*R12+     Set program bit
       7A4A 7506
  3399 7A4C CF20         MOV  @SUBTAB,*R12+     Set up subtable link address
       7A4E 833A
  3400 7A50 06A0         BL   @GET1             Get pointer to name
       7A52 6C9E
  3401 7A54 CF01         MOV  R1,*R12+          Move it to FAC6
  3402 7A56 DF1D         MOVB *R13,*R12+        Get access address from GROM
  3403 7A58 1000         NOP
  3404 7A5A DF1D         MOVB *R13,*R12+         and put it in FAC8
  3405 7A5C C705         MOV  R5,*R12           Save current call list address
  3406            * Check if ERAM exists or imperative statement. If so then
  3407            * copy name into appropriate VDP area.
  3408 7A5E D1A0         MOVB @RAMFLG,R6        ERAM present?
       7A60 8389
  3409 7A62 1603         JNE  GPL40             Yes, then save name in table
  3410 7A64 D1A0         MOVB @PRGFLG,R6        Imperative call
       7A66 8344
  3411 7A68 1619         JNE  GPL60             No, handle normally
  3412            * Copy name into table area
  3413 7A6A C800  GPL40  MOV  R0,@FAC           Copy name length
       7A6C 834A
  3414 7A6E 06A0         BL   @MEMCHK           Get the space. FAC = name leng
       7A70 72D8
  3415 7A72 79C6         DATA RES52             Error return address
  3416 7A74 C0E0         MOV  @FAC6,R3          Get pointer to name
       7A76 8350
  3417 7A78 6820         S    @FAC,@FREPTR      New free pointer
       7A7A 834A
       7A7C 8340
  3418 7A7E C120         MOV  @FREPTR,R4        New place of name
       7A80 8340
  3419 7A82 0584         INC  R4
  3420 7A84 C804         MOV  R4,@FAC6          New pointer to name
       7A86 8350
  3421 7A88 C0A0         MOV  @FAC,R2           Counter for the move
       7A8A 834A
  3422            * Now copy the name, character by character
  3423 7A8C 06A0  GPL50  BL   @GETV1            Get a byte
       7A8E 1880
  3424 7A90 06A0         BL   @PUTV1            Put a byte
       7A92 6422
  3425 7A94 0583         INC  R3
 99/4 ASSEMBLER
SUBPROGS2                                                    PAGE 0079
  3426 7A96 0584         INC  R4
  3427 7A98 0602         DEC  R2                Done?
  3428 7A9A 16F8         JNE  GPL50             No, move the rest
  3429            * Restore all the information from FAC area and build
  3430            *  subprograms symbol table.
  3431 7A9C C820  GPL60  MOV  @C8,@FAC          Need 8 bytes
       7A9E 706C
       7AA0 834A
  3432 7AA2 06A0         BL   @MEMCHK           Get the bytes. Check the space
       7AA4 72D8
  3433 7AA6 79C6         DATA RES52             Error return address
  3434 7AA8 6820         S    @C8,@FREPTR       Updata the free pointer
       7AAA 706C
       7AAC 8340
  3435 7AAE C020         MOV  @FREPTR,R0        Get location to move to
       7AB0 8340
  3436 7AB2 0580         INC  R0                True pointer
  3437 7AB4 C800         MOV  R0,@SUBTAB        Update subprogram table ptr
       7AB6 833A
  3438 7AB8 0201         LI   R1,FAC2           Subprograms info starts FAC2
       7ABA 834C
  3439 7ABC D7E0         MOVB @R0LB,*R15        Load out address
       7ABE 83E1
  3440 7AC0 0260         ORI  R0,WRVDP          Enable VDP write
       7AC2 4000
  3441 7AC4 D7C0         MOVB R0,*R15
  3442 7AC6 0200         LI   R0,XVDPWD         Optimize to save bytes
       7AC8 8C00
  3443 7ACA 0203         LI   R3,8              Going to move 8 bytes
       7ACC 0008
  3444 7ACE D431  GPL70  MOVB *R1+,*R0          Copy mode, name length, link,
  3445 7AD0 0603         DEC  R3                 ptr to name, ptr to subprogra
  3446 7AD2 16FD         JNE  GPL70
  3447 7AD4 C0D1         MOV  *R1,R3            Restore ptr into call list
  3448 7AD6 0460         B    @GET03            Check next entry in call list
       7AD8 79DA
  3449            ************************************************************
  3450 7ADA              AORG >7ADA
  3452
  3453      0005  FLG    EQU  5
  3454
  3455            * R12  total number of bytes to move
  3456            * R10  move from
  3457            * R9   move to
  3458            * R8   minor counter (buffer counter)
  3459            * R7   buffer pointer
  3460
  3461 7ADA 020C  SCROLL LI   R12,736           Going to move 736 bytes
       7ADC 02E0
  3462 7ADE 020A         LI   R10,32            Address to move from
       7AE0 0020
  3463 7AE2 04C9         CLR  R9                Address to move to
  3464 7AE4 C18B         MOV  R11,R6            Save return address
  3465 7AE6 06A0         BL   @SCRO1            Scroll the screen
       7AE8 7B10
  3466 7AEA 0205         LI   R5,XVDPWD         Optimize for speed later
       7AEC 8C00
  3467 7AEE 0204         LI   R4,>02E0          Addr of bottom line on screen
       7AF0 02E0
 99/4 ASSEMBLER
SCROLLS                                                      PAGE 0080
  3468 7AF2 0201         LI   R1,>7F80          Edge character and space char
       7AF4 7F80
  3469 7AF6 0202         LI   R2,28             28 characters on bottom line
       7AF8 001C
  3470 7AFA 06A0         BL   @PUTV1            Init VDP & put out 1st edge ch
       7AFC 6422
  3471 7AFE D541         MOVB R1,*R5            Put out 2nd edge character
  3472 7B00 06C1         SWPB R1                Bare the space character
  3473 7B02 D541  SCRBOT MOVB R1,*R5            Write out space character
  3474 7B04 0602         DEC  R2                One less to move
  3475 7B06 16FD         JNE  SCRBOT            Loop if more
  3476 7B08 06C1         SWPB R1                Bare the edge character again
  3477 7B0A D541         MOVB R1,*R5            Output edge character
  3478 7B0C D541         MOVB R1,*R5            Output edge character
  3479 7B0E 0456         B    *R6               And return go GPL
  3480            * Generalized move routine
  3481 7B10 04C8  SCRO1  CLR  R8                Clear minor counter
  3482 7B12 D7E0         MOVB @R10LB,*R15       Write out LSB of read-address
       7B14 83F5
  3483 7B16 02A7         STWP R7                Get the WorkSpace pointer
  3484 7B18 D7CA         MOVB R10,*R15          Write out MSB of read-address
  3485 7B1A DDE0  SCRO2  MOVB @XVDPRD,*R7+      Read a byte
       7B1C 8800
  3486 7B1E 058A         INC  R10               Inc read-from address
  3487 7B20 0588         INC  R8                Inc minor counter
  3488 7B22 060C         DEC  R12               Dec total counter
  3489 7B24 1303         JEQ  SCRO4             If all bytes read-write them
  3490 7B26 0288         CI   R8,12             Filled WorkSpace buffer area?
       7B28 000C
  3491 7B2A 11F7         JLT  SCRO2             No, read more
  3492 7B2C D7E0  SCRO4  MOVB @R9LB,*R15        Write LSB of write-address
       7B2E 83F3
  3493 7B30 0269         ORI  R9,WRVDP          Enable the VDP write
       7B32 4000
  3494 7B34 D7C9         MOVB R9,*R15           Write MSB of write-address
  3495 7B36 02A7         STWP R7                Get WorkSpace buffer pointer
  3496 7B38 D837  SCRO6  MOVB *R7+,@XVDPWD      Write a byte
       7B3A 8C00
  3497 7B3C 0589         INC  R9                Increment write-address
  3498 7B3E 0608         DEC  R8                Decrement counter
  3499 7B40 16FB         JNE  SCRO6             Move more if not done
  3500 7B42 C30C         MOV  R12,R12           More on major counter?
  3501 7B44 16E5         JNE  SCRO1             No, go do another read
  3502 7B46 045B         RT                     Yes, done
  3503            ************************************************************
  3504            * Decode which I/O utility is being called
  3505            * Tag field following the XML IO has the following
  3506            * meaning:
  3507            *     0 - Line list - utility to search keyword table to
  3508            *         restore keyword from token
  3509            *     1 - Fill space - utility to fill record with space
  3510            *         when outputting imcomplete records
  3511            *     2 - Copy string - utility to copy a string, adding
  3512            *         the screen offset to each character for display
  3513            *         purposes
  3514            *     3 - Clear ERAM - utility to clear ERAM at the address
  3515            *         specified by the data word following the IO tag
  3516            *         and the # of bytes specified by the length
  3517            *         following the address word. Note that each data
 99/4 ASSEMBLER
SCROLLS                                                      PAGE 0081
  3518            *         word is the address of a CPU memory location.
  3519            ************************************************************
  3520 7B48 D01D  IO     MOVB *R13,R0           Read selector from GROM
  3521 7B4A 0980         SRL  R0,8              Shift for decoding
  3522 7B4C 1358         JEQ  LLIST             0 is tag for Line list
  3523 7B4E 0600         DEC  R0
  3524 7B50 132C         JEQ  FILSPC            1 is tag for Fill space
  3525 7B52 0600         DEC  R0
  3526 7B54 130E         JEQ  CSTRIN            2 is tag for Copy string
  3527            *                             3 is tag for CLRGRM string
  3528            *                                fall into it
  3529            * CALGRM
  3530            * R1 - address of clearing start
  3531            * R2 - number of bytes to clear
  3532 7B56 0201  CLRGRM LI   R1,PAD0           Get CPU RAM offset
       7B58 8300
  3533 7B5A C081         MOV  R1,R2             Need for next read too
  3534 7B5C B81D         AB   *R13,@R1LB        Add address of ERAM pointer
       7B5E 83E3
  3535 7B60 C051         MOV  *R1,R1            Read the ERAM address
  3536 7B62 B81D         AB   *R13,@R2LB        Read address of byte count
       7B64 83E5
  3537 7B66 C092         MOV  *R2,R2            Read the byte count
  3538 7B68 04C0         CLR  R0                Clear of clearing ERAM
  3539 7B6A DC40  CLRGR1 MOVB R0,*R1+           Clear a byte
  3540 7B6C 0602         DEC  R2                One less to clear, done?
  3541 7B6E 16FD         JNE  CLRGR1            No, loop for rest
  3542 7B70 045B         RT                     Yes, return
  3543            * CSTRIN
  3544            * R0 - MNUM
  3545            * R1 - GETV/PUTV buffer
  3546            * R3 - FAC4/GETV address
  3547            * R5 - return address
  3548 7B72 C14B  CSTRIN MOV  R11,R5            Save return address
  3549 7B74 D020         MOVB @MNUM,R0          Get MNUM
       7B76 8302
  3550 7B78 1317         JEQ  CSTR1O            If no bytes to copy
  3551 7B7A 0980         SRL  R0,8              Shift to use as counter
  3552 7B7C C120         MOV  @CCPADR,R4        Get copy-to address
       7B7E 8308
  3553 7B80 C0E0         MOV  @FAC4,R3          Get copy-from address
       7B82 834E
  3554 7B84 06A0  CSTRO5 BL   @GETV1            Get byte
       7B86 1880
  3555 7B88 B060         AB   @DSRFLG,R1        Add screen offset
       7B8A 8317
  3556 7B8C 06A0         BL   @PUTV1            Put the offset byte out
       7B8E 6422
  3557 7B90 0583         INC  R3                Increment from address
  3558 7B92 0584         INC  R4                Increment to address
  3559 7B94 0600         DEC  R0                One less to move
  3560 7B96 16F6         JNE  CSTRO5            Loop if not done
  3561 7B98 C803         MOV  R3,@FAC4          Restore for GPL
       7B9A 834E
  3562 7B9C D800  CSTR07 MOVB R0,@MNUM          Clear for GPL
       7B9E 8302
  3563      7BA3  CCBHFF EQU  $+3
  3564 7BA0 0244         ANDI R4,>BFFF          Throw away VDP write enable
       7BA2 BFFF
 99/4 ASSEMBLER
SCROLLS                                                      PAGE 0082
  3565 7BA4 C804         MOV  R4,@CCPADR        Restore for GPL
       7BA6 8308
  3566      7BA8  FILSZ6 EQU  $
  3567 7BA8 0455  CSTR1O B    *R5               Return
  3568            * FILSPC
  3569            * R0 - MNUM
  3570            * R1 - Buffer for GETV/PUTV
  3571            * R2 - MNUM1
  3572            * R3 - Pointer for GETV
  3573            * R4 - CCPADR, pointer for PUTV
  3574            * R5 - return address
  3575 7BAA C14B  FILSPC MOV  R11,R5            Save return address
  3576 7BAC D0A0         MOVB @MNUM1,R2         Get pointer to end of record
       7BAE 8303
  3577 7BB0 1604         JNE  FILSZ1            If space to fill for sure
  3578 7BB2 9802         CB   R2,@CCPPTR        Any filling to do?
       7BB4 8306
  3579 7BB6 1604         JNE  FILSZ2            Yes, do it normalling
  3580 7BB8 0455         B    *R5               No, 255 record already full
  3581 7BBA 9802  FILSZ1 CB   R2,@CCPPTR        Any filling to do?
       7BBC 8306
  3582 7BBE 12F4         JLE  FILSZ6            No, record is complete
  3583 7BC0 70A0  FILSZ2 SB   @CCPPTR,R2        Compute # of bytes to change
       7BC2 8306
  3584 7BC4 B802         AB   R2,@CCPPTR        Point to end
       7BC6 8306
  3585 7BC8 D020         MOVB @DSRFLG,R0        Filling with zeroes?
       7BCA 8317
  3586 7BCC 160A         JNE  FILSZ3            No, fill with spaces
  3587 7BCE C0E0         MOV  @PABPTR,R3        Check if internal files
       7BD0 8304
  3588 7BD2 0223         AI   R3,FLG            5 byte offset into PAB
       7BD4 0005
  3589 7BD6 04C1         CLR  R1                Initialize to test below
  3590 7BD8 06A0         BL   @GETV1            Get byte from PAB
       7BDA 1880
  3591 7BDC 0241         ANDI R1,>0800          Internal?
       7BDE 0800
  3592 7BE0 1602         JNE  FILSZ4            Yes, zero fill
  3593 7BE2 0220  FILSZ3 AI   R0,>2000          Add space character for filler
       7BE4 2000
  3594 7BE6 0982  FILSZ4 SRL  R2,8              Shift count for looping
  3595 7BE8 C120         MOV  @CCPADR,R4        Get start address to fill
       7BEA 8308
  3596 7BEC D040         MOVB R0,R1             Put filler in place for PUTV
  3597 7BEE 06A0  FILSZ5 BL   @PUTV1            Put out a filler
       7BF0 6422
  3598 7BF2 0584         INC  R4                Increment filler position
  3599 7BF4 0602         DEC  R2                One less to fill
  3600 7BF6 16FB         JNE  FILSZ5            Loop if move
  3601 7BF8 D802         MOVB R2,@MNUM1         Restore for GPL
       7BFA 8303
  3602 7BFC 10CF         JMP  CSTR07
  3603            * LLIST
  3604            * R0 - FAC - address of keytab in GROM
  3605            * R1 - keyword length
  3606 7BFE C30B  LLIST  MOV  R11,R12           Save return address
  3607 7C00 06A0         BL   @PUTSTK           Save GROM address
       7C02 60F2
 99/4 ASSEMBLER
SCROLLS                                                      PAGE 0083
  3608 7C04 C020         MOV  @FAC,R0           Get address of keytab
       7C06 834A
  3609 7C08 D220         MOVB @CHAT,R8          Get token to search for
       7C0A 8342
  3610 7C0C 0201         LI   R1,1              Assume one character keyword
       7C0E 0001
  3611 7C10 DB40  LLISZ4 MOVB R0,@GRMWAX(R13)   Load GROM address of table
       7C12 0402
  3612 7C14 DB60         MOVB @R0LB,@GRMWAX(R13) Both bytes
       7C16 83E1
       7C18 0402
  3613 7C1A D0DD         MOVB *R13,R3           Read address of x-char table
  3614 7C1C D81D         MOVB *R13,@R3LB        Both bytes
       7C1E 83E7
  3615 7C20 A0C1  LLISZ5 A    R1,R3             Add length of keyword to point
  3616            *                              at token
  3617 7C22 DB43         MOVB R3,@GRMWAX(R13)   Write out new GROM address
       7C24 0402
  3618 7C26 DB60         MOVB @R3LB,@GRMWAX(R13) Which points to token
       7C28 83E7
       7C2A 0402
  3619 7C2C D11D         MOVB *R13,R4           Read token value
  3620 7C2E D15D         MOVB *R13,R5           Read possible end of x-char
  3621            *                              table
  3622 7C30 9204         CB   R4,R8             Token value match?
  3623 7C32 1307         JEQ  LLISZ6            Yes!!! Found the keyword
  3624 7C34 0583         INC  R3                No, so skip token value
  3625 7C36 9805         CB   R5,@CCBHFF        Reach end of x-char table?
       7C38 7BA3
  3626 7C3A 16F2         JNE  LLISZ5            No, so check more in the table
  3627 7C3C 05C0         INCT R0                Point into x+1 char table
  3628 7C3E 0581         INC  R1                Try x+1 char table
  3629 7C40 10E7         JMP  LLISZ4            Loop to check it
  3630            * Come here when found keyword
  3631 7C42 60C1  LLISZ6 S    R1,R3             Subtract length to pnt at K.W.
  3632 7C44 C803         MOV  R3,@FAC8          Save ptr to KeyWord for GPL
       7C46 8352
  3633 7C48 C801         MOV  R1,@FAC4          Save KeyWord length for GPL
       7C4A 834E
  3634 7C4C D808         MOVB R8,@FAC           Save CHAT for GPL
       7C4E 834A
  3635 7C50 06A0         BL   @GETSTK           Restore GROM addres
       7C52 610E
  3636 7C54 045C         B    *R12              And return to GPL
  3637            ************************************************************
  3638 7C56              AORG >7C56
  3640
  3641      0088  RETURZ EQU  >88
  3642      0089  DEFZ   EQU  >89
  3643      008A  DIMZ   EQU  >8A
  3644      008B  ENDZ   EQU  >8B
  3645      008C  FORZ   EQU  >8C
  3646      0092  INPUTZ EQU  >92
  3647      0093  DATAZ  EQU  >93
  3648      009A  REMZ   EQU  >9A
  3649      009B  ONZ    EQU  >9B
  3650      009D  CALLZ  EQU  >9D
  3651      009E  OPTIOZ EQU  >9E
  3652      00A3  IMAGEZ EQU  >A3
 99/4 ASSEMBLER
SCANS                                                        PAGE 0084
  3653      00A7  SUBXTZ EQU  >A7
  3654      00A8  SUBNDZ EQU  >A8
  3655      00AA  LINPUZ EQU  >AA
  3656      00B2  STEPZ  EQU  >B2
  3657      00C7  NUMZ   EQU  >C7
  3658            *-----------------------------------------------------------
  3659            * Added for "NOPSCAN" feature 6/8/81
  3660      0040  P1     EQU  >40               @
  3661      0050  P2     EQU  >50               P
  3662      002B  P3     EQU  >2B               +
  3663      002D  P4     EQU  >2D               -
  3664      0070  P5     EQU  >70               p
  3665      03B7  PSCFG  EQU  >03B7             VDP temporary: PSCAN flag
  3666            *                                            >00 : no pscan
  3667            *                                            >FF : pscan
  3668            *-----------------------------------------------------------
  3669
  3670            *-----------------------------------------------------------
  3671            * SCAN routine is changed for implementing "NOPSCAN"
  3672            * feature,                    6/8/81
  3673            * "!@P+" or "!@p+"            is RESUME PSCAN
  3674            * "!@P-" or "!@p-"            is NO PSCAN
  3675            *-----------------------------------------------------------
  3676            *
  3677            ************************************************************
  3678            * SCAN is the main looping structure of the prescan routine.
  3679            * Takes care of scanning each statement in a line. Goes
  3680            * back to GPL to scan the special cases (DEF, OPTION, DIM,
  3681            * SUB, CALL, SUBEND, SUBEXIT) and also goes to GPL to enter
  3682            * variables into the symbol table. All statements which are
  3683            * not allowed to be imperative are checked directly without
  3684            * goting to GPL. The NOCARE label is where a non-special
  3685            * statement is scanned, looking for variables to enter them
  3686            * into the symbol table.
  3687            ************************************************************
  3688 7C56 D01D  PSCAN  MOVB *R13,R0           Read Scan code
  3689 7C58 06A0         BL   @PUTSTK           Save GROM address
       7C5A 60F2
  3690 7C5C 06A0         BL   @SETREG           Set up R8/R9 with CHAT/SUBSTK
       7C5E 1E7A
  3691            * First decode the type of XML being executed
  3692            * Types are: >00 - initial call with program
  3693            *            >01 - resume within a statement after call to
  3694            *                  GPL for some reason
  3695            *            >02 - initial call for imperative statement
  3696 7C60 0980         SRL  R0,8              Set condition
  3697 7C62 1305         JEQ  SCAN05            If calling scan routine w/pgm
  3698 7C64 0600         DEC  R0                Returning from call to GPL?
  3699 7C66 135D         JEQ  JNCARE            Yes, continue w/in line
  3700 7C68 C819         MOV  *R9,@RTNADD
       7C6A 8326
  3701 7C6C 1050         JMP  SCAN10
  3702 7C6E A660  SCAN05 A    @C3,*R9           Skip following XML and select
       7C70 6544
  3703 7C72 C819         MOV  *R9,@RTNADD       Set up rtn to common GPL loc
       7C74 8326
  3704 7C76 04E0         CLR  @DATA             Assume out of data
       7C78 8334
  3705 7C7A 8820  SCAN5A C    @LINUM,@EXTRAM    End of program yet?
 99/4 ASSEMBLER
SCANS                                                        PAGE 0085
       7C7C 8312
       7C7E 832E
  3706 7C80 161B         JNE  SCAN07            No, get next line
  3707 7C82 D020  SCAN5B MOVB @FORNET,R0        Check fornext counter
       7C84 8317
  3708 7C86 1655         JNE  FNERR             For/Next error
  3709 7C88 D020         MOVB @XFLAG,R0         Check subprogram bits
       7C8A 8316
  3710      7C8D  CBH40  EQU  $+1
  3711 7C8C 0A40         SLA  R0,4              Subprogram encountered?
  3712 7C8E 1108         JLT  SCAN6A            Yes, check subend
  3713 7C90 0200  SCAN06 LI   R0,>A000          Initialize data stack
       7C92 A000
  3714 7C94 D800         MOVB R0,@STACK
       7C96 8373
  3715 7C98 06A0         BL   @RESOLV           Resolve any subprogram refs
       7C9A 7946
  3716 7C9C 0460         B    @GPL05            Return
       7C9E 7E5E
  3717 7CA0 0A40  SCAN6A SLA  R0,4              Subend encountered?
  3718 7CA2 1707         JNC  ERRMS             No, text ended w/out subend
  3719 7CA4 0203         LI   R3,TABSAV         Get main symbol table's ptr
       7CA6 0392
  3720 7CA8 06A0         BL   @GET1             Get it
       7CAA 6C9E
  3721 7CAC C801         MOV  R1,@SYMTAB
       7CAE 833E
  3722 7CB0 10EF         JMP  SCAN06            Merge back in
  3723 7CB2 0203  ERRMS  LI   R3,>18            * MISSING SUBEND
       7CB4 0018
  3724 7CB6 1076         JMP  GPL05L
  3725 7CB8 6820  SCAN07 S    @C4,@EXTRAM       Go to next line in program
       7CBA 6A80
       7CBC 832E
  3726 7CBE D020         MOVB @RAMTOP,R0        ERAM program?
       7CC0 8384
  3727 7CC2 1604         JNE  SCAN08            Yes, handle  ERAM
  3728 7CC4 06A0         BL   @GET              No, het new line pointer in VD
       7CC6 6C9A
  3729 7CC8 832E         DATA EXTRAM
  3730 7CCA 1003         JMP  SCAN09
  3731 7CCC 06A0  SCAN08 BL   @GETG             Get new line pointer from GRAM
       7CCE 6CCA
  3732 7CD0 832E         DATA EXTRAM
  3733 7CD2 C801  SCAN09 MOV  R1,@PGMPTR        Put new line pointer into perm
       7CD4 832C
  3734 7CD6 5820         SZCB @CBH40,@XFLAG     Reset IFFLAG only on new line
       7CD8 7C8D
       7CDA 8316
  3735            *-----------------------------------------------------------
  3736            * Following is changed for adding "nopscan" feature
  3737            * SCAN9A @PGMCHR                Get 1st token on line
  3738 7CDC 06A0  SCAN9A BL   @PGMCHR           Get 1st token on line
       7CDE 6C74
  3739 7CE0 0203         LI   R3,PSCFG          Check the flag to see which
       7CE2 03B7
  3740            *                  mode is in: NOPSCAN (>00) or PSCAN (>FF)
  3741 7CE4 06A0         BL   @GETV1            Get the flag from VDP
       7CE6 1880
 99/4 ASSEMBLER
SCANS                                                        PAGE 0086
  3742 7CE8 1348         JEQ  NPSCAN            NOPSCAN mode
  3743            *-----------------------------------------------------------
  3744 7CEA 5820         SZCB @CBH94,@XFLAG     Reset ENTER, STRFLG, and FNCFL
       7CEC 6005
       7CEE 8316
  3745 7CF0 D020         MOVB @XFLAG,R0         Get flag bits
       7CF2 8316
  3746 7CF4 0A80         SLA  R0,8              Shift to check REMODE
  3747 7CF6 170B         JNC  SCAN10            If not in REMODE
  3748 7CF8 D208         MOVB R8,R8             Check if token
  3749 7CFA 1103         JLT  SCAN11            If token, look further
  3750 7CFC 0203  ERRIBS LI   R3,>1E            * ILLEGAL BETWEEN SUBPROGRAMS
       7CFE 001E
  3751 7D00 1051         JMP  GPL05L            Goto error return
  3752 7D02 0706  SCAN11 SETO R6                Set up index into table
  3753 7D04 0586  SCAN12 INC  R6                Increment to 1st/next element
  3754 7D06 9988         CB   R8,@IBSTAB(R6)    legal stmt between subprogdams
       7D08 7EA0
  3755 7D0A 1BFC         JH   SCAN12            Not able to tell, check furthe
  3756 7D0C 1AF7         JL   ERRIBS            Illegal statement here
  3757 7D0E 04C6  SCAN10 CLR  R6                Offset into special stmt table
  3758 7D10 C0E6  SCAN15 MOV  @SCNTAB(R6),R3    Read entry from special table
       7D12 7E70
  3759 7D14 9203         CB   R3,R8             Match this token?
  3760 7D16 1306         JEQ  SCAN20            Yes, handle special case
  3761 7D18 1B74         JH   NOCARE            Didn't match but passed in tab
  3762 7D1A 05C6         INCT R6                Increment offset into table
  3763 7D1C 0286         CI   R6,TABLEN         Reach end of table?
       7D1E 0030
  3764 7D20 16F7         JNE  SCAN15            No, check further
  3765 7D22 106F  JNCARE JMP  NOCARE            End of table, not special case
  3766 7D24 0A83  SCAN20 SLA  R3,8              Look at special case byte
  3767 7D26 1103         JLT  SCGPL1            If MSB set, goto GPL
  3768 7D28 06C3         SWPB R3                MSB reset, offset into 9900
  3769 7D2A 0463         B    @OFFSET(R3)       Branch to 9900 special handler
       7D2C 7D84
  3770 7D2E 0460  SCGPL1 B    @SCNGPL
       7D30 7E58
  3771 7D32 0460  FNERR  B    @FNNERR
       7D34 7E4C
  3772            *-----------------------------------------------------------
  3773            * These are added for "nopscan" feature 6/8/81
  3774 7D36 D020  SCAN26 MOVB @PRGFLG,R0        In program mode?
       7D38 8344
  3775 7D3A 13A3         JEQ  SCAN5B            No, check for/next subs&rtn
  3776 7D3C 06A0  SCAN28 BL   @PGMCHR           Yes, check "!@P+" or "!@P-"
       7D3E 6C74
  3777 7D40 0288         CI   R8,P1*256         "@" following "!"?
       7D42 4000
  3778 7D44 169A         JNE  SCAN5A            No, goto the next line
  3779 7D46 06A0         BL   @PGMCHR           Yes, check for "P"
       7D48 6C74
  3780 7D4A 0288         CI   R8,P2*256
       7D4C 5000
  3781 7D4E 1303         JEQ  SCAN40            Yes, check for "+" or "-"
  3782 7D50 0288         CI   R8,P5*256         No, try "p"
       7D52 7000
  3783 7D54 1692         JNE  SCAN5A            No, goto the next line
  3784 7D56 06A0  SCAN40 BL   @PGMCHR           Yes, check for "+" or "-"
 99/4 ASSEMBLER
SCANS                                                        PAGE 0087
       7D58 6C74
  3785 7D5A 0288         CI   R8,P3*256
       7D5C 2B00
  3786 7D5E 130A         JEQ  SCAN35            "!@P+" is found at the
  3787            *                               beginnning of the line
  3788 7D60 0288         CI   R8,P4*256
       7D62 2D00
  3789 7D64 168A         JNE  SCAN5A            Didn't file what we want,
  3790            *                              goto the next line
  3791 7D66 0201         LI   R1,0              "!@P-" is found, set flag to
       7D68 0000
  3792            *                              0 NO PSCAN
  3793 7D6A 0204  SCAN30 LI   R4,PSCFG          Address register for PUTV1
       7D6C 03B7
  3794 7D6E 06A0         BL   @PUTV1            Set the flag PSCFG in VDP tem.
       7D70 6422
  3795 7D72 1083         JMP  SCAN5A            Goto the next line
  3796 7D74 0201  SCAN35 LI   R1,>FF00          "!@P+", set flag to be >FF so
       7D76 FF00
  3797            *                              RESUME PSCAN
  3798 7D78 10F8         JMP  SCAN30            Use common code to set flag
  3799            *-----------------------------------------------------------
  3800            *-----------------------------------------------------------
  3801            * In NOPSCAN mode, only looking for "!@P+", "!@P-" at the
  3802            * beginning of each line      6/8/81
  3803 7D7A 0288  NPSCAN CI   R8,TREMZ*256      First token on line
       7D7C 8300
  3804            *                              is it "!"
  3805 7D7E 13DE         JEQ  SCAN28            Yes, check "!@P+" or "!@P-"
  3806 7D80 0460         B    @SCAN5A           No, ignore the whole line,
       7D82 7C7A
  3807            *                              just goto the next line
  3808            *-----------------------------------------------------------
  3809            OFFSET
  3810 7D84 10D8  SCN26A JMP  SCAN26
  3811 7D86 D020  SCAN25 MOVB @PRGFLG,R0        In imperative mode?
       7D88 8344
  3812 7D8A 1302         JEQ  SCAN5C            Yes, check for/next sub & rtn
  3813 7D8C 0460         B    @SCAN5A           No, check next line
       7D8E 7C7A
  3814 7D90 0460  SCAN5C B    @SCAN5B
       7D92 7C82
  3815            * 9900 code special handlers
  3816 7D94 F820  IFIF   SOCB @CBH40,@XFLAG     Indicate scan of "IF" stmt
       7D96 7C8D
       7D98 8316
  3817            * Special handler for program-only statements
  3818 7D9A D020  IMPER  MOVB @PRGFLG,R0        Executing in a program?
       7D9C 8344
  3819 7D9E 1649         JNE  NXTCHR            Yes, proceed in don't char mod
  3820 7DA0 0203  ERRIMP LI   R3,>12            Illegal imperative return code
       7DA2 0012
  3821 7DA4 105C  GPL05L JMP  GPL05             Return to GPL with error
  3822            * Special handler for data-statements
  3823 7DA6 D020  DATA1  MOVB @DATA,R0          Data already encountered?
       7DA8 8334
  3824 7DAA 1606         JNE  IMAGE             Yes, don't set pointer
  3825 7DAC C820         MOV  @EXTRAM,@LNBUF    Save line buffer pointer
       7DAE 832E
 99/4 ASSEMBLER
SCANS                                                        PAGE 0088
       7DB0 8336
  3826 7DB2 C820         MOV  @PGMPTR,@DATA     Set line buffer pointer
       7DB4 832C
       7DB6 8334
  3827            * Special handler for image-statements
  3828 7DB8 D020  IMAGE  MOVB @PRGFLG,R0        In program mode?
       7DBA 8344
  3829 7DBC 0460         B    @SCAN5A           Yes, no need to scan line
       7DBE 7C7A
  3830 7DC0 10EF         JMP  ERRIMP            No, illegal imperative
  3831            * Special handler for for-statements
  3832 7DC2 05A0  FOR    INC  @XFLAG            Increment the nesting counter
       7DC4 8316
  3833 7DC6 D020         MOVB @XFLAG,R0         Fetch the IFFLAG
       7DC8 8316
  3834 7DCA 0240         ANDI R0,>4000          Inside an if-statement?
       7DCC 4000
  3835 7DCE 1331         JEQ  NXTCHR            No, continue in don't care mod
  3836 7DD0 0203  SNTXER LI   R3,>1A            * SYNTAX ERROR
       7DD2 001A
  3837 7DD4 1044         JMP  GPL05
  3838            * Special handler for next-statements
  3839 7DD6 C020  SNEXT  MOV  @XFLAG,R0         Get flag and for-next counter
       7DD8 8316
  3840 7DDA 0240         ANDI R0,>40FF          Get rid of flag bits except IF
       7DDC 40FF
  3841 7DDE D000         MOVB R0,R0             IFFLAG set?
  3842 7DE0 16F7         JNE  SNTXER            Yes, syntax error
  3843 7DE2 0600         DEC  R0                Decrement counter by one
  3844 7DE4 D820         MOVB @R0LB,@FORNET     Move back to the real conter
       7DE6 83E1
       7DE8 8317
  3845 7DEA 1323         JEQ  NXTCHR            Returning to top level, ok
  3846 7DEC 1522         JGT  NXTCHR            Still at a secndary level, ok
  3847 7DEE 0203         LI   R3,>14            For/next nesting return code
       7DF0 0014
  3848 7DF2 1035         JMP  GPL05             Return to GPL with error
  3849 7DF4 D020  ELSE   MOVB @XFLAG,R0         Get flag byte
       7DF6 8316
  3850 7DF8 0240         ANDI R0,>4000          Inside an if?
       7DFA 4000
  3851 7DFC 13E9         JEQ  SNTXER            No, error
  3852            * Special handler for statement seperator
  3853 7DFE 0460  SEPSMT B    @SCAN9A           Skip the '::' and check next
       7E00 7CDC
  3854            * General don't care scan. Simply looks for variables to
  3855            *  enter into symbol table; stops on end of statement
  3856 7E02 0288  NOCARE CI   R8,SSEPZ*256      At a statement separator
       7E04 8200
  3857 7E06 13FB         JEQ  SEPSMT            Skip and scan next statement
  3858 7E08 0288         CI   R8,TREMZ*256      At a tail remark?
       7E0A 8300
  3859 7E0C 13BC         JEQ  SCAN25            Yes, check mode
  3860 7E0E D208         MOVB R8,R8             At an end-of-line or symbol?
  3861 7E10 13BA         JEQ  SCAN25            EOL, checK mode
  3862 7E12 151F         JGT  ENTER             Symbol, ENTER in symbol table
  3863 7E14 0288         CI   R8,LNZ*256        Special line number token?
       7E16 C900
  3864 7E18 130F         JEQ  SKIPLN            Yes, need to skip it
 99/4 ASSEMBLER
SCANS                                                        PAGE 0089
  3865 7E1A 0288         CI   R8,NUMZ*256       Special numeric token?
       7E1C C700
  3866 7E1E 130F         JEQ  STRSKP            Yes, need to skip it
  3867 7E20 0288         CI   R8,UNQSTZ*256     Special string token?
       7E22 C800
  3868 7E24 130C         JEQ  STRSKP            Yes, need to skip it
  3869 7E26 0288         CI   R8,THENZ*256      Hit a then-clause?
       7E28 B000
  3870 7E2A 13E4         JEQ  ELSE              Yes, treat like a stmt-sep
  3871 7E2C 0288         CI   R8,ELSEZ*256      Hit a else-clause?
       7E2E 8100
  3872 7E30 13E1         JEQ  ELSE              Yes, t[eat liek a stmt-sep
  3873 7E32 06A0  NXTCHR BL   @PGMCHR           Get next token
       7E34 6C74
  3874 7E36 10E5         JMP  NOCARE            And continue loop
  3875 7E38 05E0  SKIPLN INCT @PGMPTR           Skip line number
       7E3A 832C
  3876 7E3C 10FA         JMP  NXTCHR            And get next token
  3877 7E3E 06A0  STRSKP BL   @PGMCHR           Get length of string/number
       7E40 6C74
  3878 7E42 06C8         SWPB R8                Swap for add
  3879 7E44 A808         A    R8,@PGMPTR        Skip the string of number
       7E46 832C
  3880 7E48 04C8         CLR  R8                Clear LSB of character
  3881 7E4A 10F3         JMP  NXTCHR            And get next token
  3882            * Code to return to GPL to handle special case or an
  3883            *  end-of-line return
  3884 7E4C 0203  FNNERR LI   R3,>16            FOR/NEXT NESTING
       7E4E 0016
  3885 7E50 1006         JMP  GPL05
  3886 7E52 0203  ENTER  LI   R3,>10            Load return code for ENTER
       7E54 0010
  3887 7E56 1003         JMP  GPL05             Goto GPL
  3888 7E58 0243  SCNGPL ANDI R3,>7F00          Throw away GPL flag
       7E5A 7F00
  3889 7E5C 0983         SRL  R3,8              Shift to use as index for rtn
  3890 7E5E C660  GPL05  MOV  @RTNADD,*R9       Make sure right GROM address
       7E60 8326
  3891 7E62 A643         A    R3,*R9            Add offset to old GROM address
  3892 7E64 06A0         BL   @SAVREG           Save R8/R9 in CHAT/SUBSTK
       7E66 1E8C
  3893 7E68 06A0         BL   @GETSTK           Restore old GROM address
       7E6A 610E
  3894 7E6C 0460         B    @RESET            Goto GPL w/condition reset
       7E6E 006A
  3895            ************************************************************
  3896            * Table of specially scanned statements
  3897            * 2 bytes / special token
  3898            * Byte 1 - token value
  3899            * Byte 2 - "address" of special handler
  3900            *        If MSB set then GPL and rest is offset from
  3901            *         the XML that got us here
  3902            *        If MSB reset then 9900 code and is offset from
  3903            *         label OFFSET in this assembly of the special
  3904            *         case handler
  3905            ************************************************************
  3906 7E70   81  SCNTAB BYTE ELSEZ,ELSE-OFFSET
       7E71   70
  3907 7E72   82         BYTE SSEPZ,SEPSMT-OFFSET
 99/4 ASSEMBLER
SCANS                                                        PAGE 0090
       7E73   7A
  3908            *-----------------------------------------------------------
  3909            * Change the following line for searching for !@P- at the
  3910            *  beginning of line
  3911            *      BYTE TREMZ,SCAN25-OFFSET
  3912 7E74   83         BYTE TREMZ,SCN26A-OFFSET
       7E75   00
  3913            *-----------------------------------------------------------
  3914 7E76   84         BYTE IFZ,IFIF-OFFSET
       7E77   10
  3915 7E78   85         BYTE GOZ,IMPER-OFFSET
       7E79   16
  3916 7E7A   86         BYTE GOTOZ,IMPER-OFFSET
       7E7B   16
  3917 7E7C   87         BYTE GOSUBZ,IMPER-OFFSET
       7E7D   16
  3918 7E7E   88         BYTE RETURZ,IMPER-OFFSET
       7E7F   16
  3919 7E80   89         BYTE DEFZ,>82
       7E81   82
  3920 7E82   8A         BYTE DIMZ,>84
       7E83   84
  3921 7E84   8C         BYTE FORZ,FOR-OFFSET
       7E85   3E
  3922 7E86   92         BYTE INPUTZ,IMPER-OFFSET
       7E87   16
  3923 7E88   93         BYTE DATAZ,DATA1-OFFSET
       7E89   22
  3924 7E8A   96         BYTE NEXTZ,SNEXT-OFFSET
       7E8B   52
  3925 7E8C   9A         BYTE REMZ,SCAN25-OFFSET
       7E8D   02
  3926 7E8E   9B         BYTE ONZ,IMPER-OFFSET
       7E8F   16
  3927 7E90   9D         BYTE CALLZ,>86
       7E91   86
  3928 7E92   9E         BYTE OPTIOZ,>88
       7E93   88
  3929 7E94   A1         BYTE SUBZ,>8A
       7E95   8A
  3930 7E96   A3         BYTE IMAGEZ,IMAGE-OFFSET
       7E97   34
  3931 7E98   A7         BYTE SUBXTZ,>8C
       7E99   8C
  3932 7E9A   A8         BYTE SUBNDZ,>8E
       7E9B   8E
  3933 7E9C   AA         BYTE LINPUZ,IMPER-OFFSET
       7E9D   16
  3934 7E9E   B0         BYTE THENZ,ELSE-OFFSET
       7E9F   70
  3935      0030  TABLEN EQU  $-SCNTAB
  3936 7EA0   82  IBSTAB BYTE SSEPZ
  3937 7EA1   83         BYTE TREMZ
  3938 7EA2   8B         BYTE ENDZ
  3939 7EA3   9A         BYTE REMZ
  3940 7EA4   A1         BYTE SUBZ
  3941 7EA5   FF         BYTE >FF
  3942            ************************************************************
  3943 7EA6              AORG >7EA6
 99/4 ASSEMBLER
GREADS                                                       PAGE 0091
  3945
  3946            * (RAM to RAM)
  3947            * Read data from ERAM
  3948            * @GSRC  : Source address on ERAM
  3949            * @DEST  : Destination address in CPU
  3950            *           Where the data stored after read from ERAM
  3951            * @BCNT3 : byte count
  3952 7EA6 0203  GREAD1 LI   R3,BCNT3          # of bytes to move
       7EA8 8356
  3953 7EAA 0202         LI   R2,GSRC           Source in ERAM
       7EAC 8354
  3954 7EAE 0201         LI   R1,DEST           Destination in CPU
       7EB0 8358
  3955 7EB2 1006         JMP  GRZ1              Jump to common routine
  3956            * Read data from ERAM to CPU
  3957            * @ADDR1 : Source address on ERAM
  3958            * @ADDR2 : Destination address in CPU
  3959            *           Where the data stored after read from ERAM
  3960            * @BCNT1 : byte count
  3961 7EB4 0203  GREAD  LI   R3,BCNT1          # of bytes to move
       7EB6 834E
  3962 7EB8 0202         LI   R2,ADDR1          Source in ERAM
       7EBA 834C
  3963 7EBC 0201         LI   R1,ADDR2          Destination in CPU
       7EBE 8350
  3964            * Common ERAM to CPU transfer routine
  3965 7EC0 C112  GRZ1   MOV  *R2,R4
  3966 7EC2 DC74  GRZ2   MOVB *R4+,*R1+         Move byte from ERAM to CPU
  3967 7EC4 0613         DEC  *R3               One less to move, done?
  3968 7EC6 16FD         JNE  GRZ2              No, copy the rest
  3969 7EC8 045B         RT
  3970            ************************************************************
  3971
  3972 7ECA              AORG >7ECA
  3974
  3975            * (RAM to RAM)
  3976            * Write the data whcih is stored in CPU to ERAM
  3977            * @GDST  : Destination address on ERAM where data is going
  3978            *           to be stored
  3979            * @CSRC  : Soruce address on CPU where data stored
  3980            * @BCNT2 : byte count
  3981 7ECA 0203  GWITE1 LI   R3,BCNT2          Count
       7ECC 8308
  3982 7ECE 0202         LI   R2,GDST           Destination
       7ED0 8302
  3983 7ED2 0201         LI   R1,CSRC           Source
       7ED4 830C
  3984 7ED6 1006         JMP  GWZ1
  3985            * Write the data which is stored in CPU to ERAM
  3986            * @ADDR1 : Destination address on ERAM where data is going
  3987            *           to be stroed
  3988            * @ADDR2 : Source address on CPU where dta is stored
  3989            * @BCNT1 : byte count
  3990 7ED8 0203  GWRITE LI   R3,BCNT1          Count
       7EDA 834E
  3991 7EDC 0202         LI   R2,ADDR1          Destination
       7EDE 834C
  3992 7EE0 0201         LI   R1,ADDR2          Source
       7EE2 8350
 99/4 ASSEMBLER
GWRITES                                                      PAGE 0092
  3993            * Common routine to copy from CPU to ERAM
  3994      7EE4  GWZ1   EQU  $
  3995 7EE4 C112         MOV  *R2,R4            Get distination address
  3996 7EE6 C051         MOV  *R1,R1            Get CPU RAM address
  3997 7EE8 0221         AI   R1,PAD0           Add in CPU offset
       7EEA 8300
  3998 7EEC DD31  GWZ2   MOVB *R1+,*R4+         Move a byte
  3999 7EEE 0613         DEC  *R3               One less to move, done?
  4000 7EF0 16FD         JNE  GWZ2              No, more to move
  4001 7EF2 045B         RT
  4002            ************************************************************
  4003
  4004 7EF4              AORG >7EF4
  4006
  4007            * Delete the text in crunched program on VDP or ERAM
  4008            *  point to the line # (to be deleted) in the line # table
  4009            * RAMTOP  0 if no ERAM
  4010            * ENLN    Last location used by the line # table
  4011            * STLN    First location used by the line # table
  4012            *
  4013
  4014 7EF4 C20B  DELREP MOV  R11,R8            Save return
  4015 7EF6 05E0         INCT @EXTRAM           Point to line ptr in table
       7EF8 832E
  4016 7EFA C0E0         MOV  @EXTRAM,R3        Prepare to read it
       7EFC 832E
  4017 7EFE C1E0         MOV  @RAMTOP,R7        Check ERAM flag & get in reg
       7F00 8384
  4018 7F02 1603         JNE  DE01              ERAM, get from it
  4019 7F04 06A0         BL   @GET1             Get line ptr from VDP
       7F06 6C9E
  4020 7F08 1002         JMP  DE02
  4021 7F0A 06A0  DE01   BL   @GETG2            Get line ptr from ERAM
       7F0C 6CCE
  4022 7F0E 0601  DE02   DEC  R1                Point to line length
  4023 7F10 C0C1         MOV  R1,R3             Prepare to read length
  4024 7F12 C241         MOV  R1,R9             Save copy for use later
  4025 7F14 C1C7         MOV  R7,R7             Editing in ERAM?
  4026 7F16 1603         JNE  DE03              ERAM, get length from it
  4027 7F18 06A0         BL   @GETV1            Get line length from VDP
       7F1A 1880
  4028 7F1C 1001         JMP  DE04
  4029 7F1E D053  DE03   MOVB *R3,R1
  4030 7F20 D081  DE04   MOVB R1,R2             Move text length for use
  4031 7F22 0982         SRL  R2,8              Need as a word
  4032 7F24 0582         INC  R2                Text length = length + length
  4033            *                              byte
  4034 7F26 C0E0         MOV  @ENLN,R3          Get end of line # table
       7F28 8332
  4035 7F2A 0583         INC  R3                Adjust for inside loop
  4036            * UPDATE THE LINE # TABLE
  4037 7F2C 0643  DEREA  DECT R3                Point to line pointer
  4038 7F2E C1C7         MOV  R7,R7             Editing in ERAM?
  4039 7F30 1603         JNE  DE05              ERAM, read it as such
  4040 7F32 06A0         BL   @GET1             Get line pointer from VDP
       7F34 6C9E
  4041 7F36 1002         JMP  DE06
  4042 7F38 06A0  DE05   BL   @GETG2            Get line pointer from ERAM
       7F3A 6CCE
 99/4 ASSEMBLER
DELREPS                                                      PAGE 0093
  4043 7F3C C141  DE06   MOV  R1,R5             Move for use
  4044 7F3E 0605         DEC  R5                Point to length byte
  4045 7F40 8149         C    R9,R5             Compare location of delete
  4046            *                              line & this line
  4047 7F42 1209         JLE  DEREB             This line won't move ,
  4048            *                              don't fix pointer
  4049 7F44 A042         A    R2,R1             Add distance to move to pointe
  4050 7F46 C103         MOV  R3,R4             Write it to same place
  4051 7F48 C1C7         MOV  R7,R7             Editing in ERAM?
  4052 7F4A 1603         JNE  DE10              Yes
  4053 7F4C 06A0         BL   @PUT1             Put back into line # table
       7F4E 6CB2
  4054 7F50 1002         JMP  DEREB
  4055 7F52 06A0  DE10   BL   @PUTG2            Put back into line # table
       7F54 6CD8
  4056 7F56 0643  DEREB  DECT R3                Point at the line #
  4057 7F58 8803         C    R3,@STLN          At last line in table?
       7F5A 8330
  4058 7F5C 16E7         JNE  DEREA             No, loop for more
  4059            * UPDATA OF LINE # TABLE IS COMPLETE, NOW DELETE TEXT
  4060            * R9 still contains pointer to length byte of text to delete
  4061            * R2 still contains text length
  4062 7F5E 0609         DEC  R9
  4063 7F60 C0C9         MOV  R9,R3
  4064 7F62 C149         MOV  R9,R5
  4065 7F64 A142         A    R2,R5             Point to 1st token
  4066 7F66 C043         MOV  R3,R1             Save for later use
  4067 7F68 6060         S    @STLN,R1          VDP, calculate # of bytes to m
       7F6A 8330
  4068 7F6C 0581         INC  R1                Correct offset by one
  4069 7F6E 06A0         BL   @MVDN2            Delete the text
       7F70 7F8A
  4070            * NOW SET UP POINTERS TO LINE TABLE
  4071 7F72 0201  DE18   LI   R1,EXTRAM         Start with EXTRAM
       7F74 832E
  4072 7F76 AC42         A    R2,*R1+           Update EXTRAM
  4073 7F78 AC42         A    R2,*R1+           Update STLN
  4074 7F7A A442         A    R2,*R1            Update ENLN
  4075 7F7C 0458         B    *R8               And return
  4076            ************************************************************
  4077 7F7E              AORG >7F7E
  4079
  4080            * (VDP to VDP) or (RAM to RAM)
  4081            * WITHOUT ERAM : Move the contents in VDP RAM from a lower
  4082            *                address to a higher address avoiding a
  4083            *                possible over-write of data
  4084            * >835C          ARG    : byte count
  4085            * >8300          VAR0   : source address
  4086            * >8306          VARY2  : destination address
  4087            * WITH ERAM    Same as above except moves ERAM to ERAM
  4088
  4089 7F7E C060  MVDN   MOV  @ARG,R1           Get byte count
       7F80 835C
  4090 7F82 C160         MOV  @VARY2,R5         Get destination
       7F84 8306
  4091 7F86 C0E0         MOV  @VAR0,R3          Get source
       7F88 8300
  4092 7F8A C1E0  MVDN2  MOV  @RAMTOP,R7        ERAM or VDP?
       7F8C 8384
 99/4 ASSEMBLER
MVDNS                                                        PAGE 0094
  4093 7F8E 1612         JNE  MV01              ERAM, so handle it
  4094 7F90 1002         JMP  MV05              VDP, so jump into loop
  4095 7F92 0605  MVDN1  DEC  R5
  4096 7F94 0603         DEC  R3
  4097      7F96  MV05   EQU  $
  4098 7F96 D7E0         MOVB @R3LB,*R15        Write out read address
       7F98 83E7
  4099 7F9A D7C3         MOVB R3,*R15
  4100 7F9C D1E0         MOVB @XVDPRD,R7        Read a byte
       7F9E 8800
  4101 7FA0 D7E0         MOVB @R5LB,*R15        Write out write address
       7FA2 83EB
  4102 7FA4 0265         ORI  R5,WRVDP          Enable VDP write
       7FA6 4000
  4103 7FA8 D7C5         MOVB R5,*R15
  4104 7FAA D807         MOVB R7,@XVDPWD        Write the byte
       7FAC 8C00
  4105 7FAE 0601         DEC  R1                One less byte to move
  4106 7FB0 16F0         JNE  MVDN1             Loop if more to move
  4107 7FB2 045B         RT
  4108      7FB4  MV01   EQU  $
  4109 7FB4 D553  MVDNZ1 MOVB *R3,*R5           Move a byte
  4110 7FB6 0603         DEC  R3                Decrement destination
  4111 7FB8 0605         DEC  R5                Decrement source
  4112 7FBA 0601         DEC  R1                One less byte to move
  4113 7FBC 16FB         JNE  MVDNZ1            Loop if more to move
  4114 7FBE 045B         RT
  4115            ************************************************************
  4116
  4117 7FC0              AORG >7FC0
  4119
  4120            * (VDP to RAM) >834C=ADDR1,>8350=ADDR2,>834E=BCNT1
  4121            * Move data from VDP to ERAM
  4122            * @ADDR1 : Source address where the data stored on VDP
  4123            * @ADDR2 : Destination address on ERAM
  4124            * @BCNT1 : byte count
  4125
  4126      7FC0  VGWITE EQU  $
  4127 7FC0 D7E0         MOVB @ADDR11,*R15      LSB of VDP address
       7FC2 834D
  4128 7FC4 C0A0         MOV  @ADDR2,R2         Address in ERAM
       7FC6 8350
  4129 7FC8 D7E0         MOVB @ADDR1,*R15       MSB of VDP address
       7FCA 834C
  4130 7FCC 1000         NOP
  4131 7FCE DCA0  VGZ1   MOVB @XVDPRD,*R2+      Move a byte
       7FD0 8800
  4132 7FD2 0620         DEC  @BCNT1            One less to move
       7FD4 834E
  4133 7FD6 16FB         JNE  VGZ1              If not done, loop for more
  4134 7FD8 045B         RT                     Return
  4135            ************************************************************
  4136
  4137 7FDA              AORG >7FDA
  4139
  4140            * Move data from ERAM to VDP (RAM to VDP)
  4141            * @GSRC  : Source address where the data stored on ERAM
  4142            * @DEST  : Destination address on VDP
  4143            * @BCNT3 : byte count
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0095
  4144
  4145 7FDA C0A0  GVWITE MOV  @DEST,R2          VDP address
       7FDC 8358
  4146 7FDE D7E0         MOVB @R2LB,*R15        LSB of VDP address
       7FE0 83E5
  4147 7FE2 0262         ORI  R2,WRVDP          Enable VDP write
       7FE4 4000
  4148 7FE6 D7C2         MOVB R2,*R15           MSB of VDP address
  4149 7FE8 C0E0         MOV  @GSRC,R3          ERAM address
       7FEA 8354
  4150 7FEC D833  GVZ1   MOVB *R3+,@XVDPWD      Move a byte
       7FEE 8C00
  4151 7FF0 0620         DEC  @BCNT3            One less to move
       7FF2 8356
  4152 7FF4 16FB         JNE  GVZ1              If not done, loop for more
  4153 7FF6 045B         RT                     Return
  4154
  4155 7FFE              AORG >7FFE
  4156 7FFE 9226         DATA >9226
  4157
  4158            ************************************************************
  4159
  4160                   END
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0096
    AAA11   8303      ABSZ    00CB      ADDR1   834C      ADDR11  834D
    ADDR2   8350      ADDR21  8351      ANDZ    00BB      ARG     835C
    ARG1    835D      ARG10   8366      ARG2    835E      ARG3    835F
    ARG4    8360      ARG8    8364      ARG9    8365      ARGT05  6B8E
    ARGT10  6B92      ARGT20  6B9A      ARGTST  6B6E      ASSG    6334
    ASSG54  6360      ASSG55  6374      ASSG56  638A      ASSG57  637E
    ASSG59  63B6      ASSG70  63CE      ASSG75  63EA      ASSG77  63F4
    ASSG79  63F8      ASSG80  6388      ASSGNV  61AE      ATNZZ   797C
    B9900   64F2      BASE    8343      BCNT1   834E      BCNT2   8308
    BCNT3   8356      BCON1   6E7E      BCONT   6D12      BERMUV  623C
    BERMUW  70F6      BERR6   70F2      BERSNM  6EDE      BERSYN  6EDA
    BEXC15  685C      BIT2    62AB      BLTST9  6D58      BMF     6DF2
    BREAK   0007      BREAKZ  008E      BRKFL   0001      BRKP1L  65D2
    BRKPN1  6644      BRKPN2  663E      BRKPNT  6636      BSO     6DF6
    BSYNCH  6ED6      BUFLEV  8346      BYTE    830C      C0      6548
    C100    6008      C1000   600A      C16     6BF8      C2      6000
    C24     6464      C3      6544      C32     7196      C4      6A80
    C40     6006      C6      618A      C7      6002      C8      706C
    CALGPL  666C      CALIST  830A      CALL    750A      CALL02  7532
    CALL04  753A      CALL06  754E      CALLZ   009D      CB3     6545
    CBH40   7C8D      CBH63   6D05      CBH65   65A7      CBH66   66F1
    CBH67   68AB      CBH69   6A9B      CBH6A   6860      CBH7    6003
    CBH94   6005      CBHA    6004      CBHFF   60D6      CCBH63  709F
    CCBH6A  70AF      CCBHFF  7BA3      CCPADR  8308      CCPPTR  8306
    CFI     12B8      CHAT    8342      CHRBUF  837D      CIF     74AA
    CIF01   74E0      CIF02   74F0      CIFRT   7500      CLRGR1  7B6A
    CLRGRM  7B56      CNS     7016      CNSSEL  6070      COMM05  6D8C
    COMMAZ  00B3      COMMON  6D74      COMP03  73E8      COMP05  73F6
    COMP10  7418      COMPCG  619C      COMPCT  73D8      COMPTN  798A
    CONC    667E      CONCAT  0008      CONT    64C8      CONT10  64D8
    CONT15  64E6      CONTAD  7502      CONTG   64C4      CONTIN  65CC
    CONVRT  6E9E      COSZZ   78B2      CPALNM  0022      CPALPH  0020
    CPBRK   0040      CPDIG   0002      CPLOW   0001      CPMO    0010
    CPNIL   0000      CPNUM   0004      CPOP    0008      CPSEP   0080
    CPTBL   610C      CPUL    0021      CPULNM  0023      CRNBUF  0820
    CRNEND  08BE      CRNSEL  6076      CRULST  83C0      CRUNCH  7B88
    CSN01   11B2      CSRC    830C      CSTR05  6AFC      CSTR07  7B9C
    CSTR10  6B00      CSTR1O  7BA8      CSTR20  6B1A      CSTRIN  7B72
    CSTRO5  7B84      CZ      831A      DATA    8334      DATA1   7DA6
    DATAZ   0093      DCBH6A  7709      DDD11   8355      DE01    7F0A
    DE02    7F0E      DE03    7F1E      DE04    7F20      DE05    7F38
    DE06    7F3C      DE10    7F52      DE18    7F72      DEFZ    0089
    DELREP  7EF4      DEREA   7F2C      DEREB   7F56      DEST    8358
    DEST1   8359      DIMZ    008A      DIVIDE  6B62      DIVIZ   00C4
    DSRFLG  8317      DTECT2  606A      ELSE    7DF4      ELSEZ   0081
    END     665E      ENDZ    008B      ENLN    8332      ENTER   7E52
    EOL     65D6      EOLINE  6872      EOLNE1  687A      EOSTM1  6870
    EOSTMT  6862      EQUALS  6A8E      EQZ     00BE      ERR     6652
    ERR1    62CE      ERR1B   6738      ERR1C   67F0      ERR1CZ  69A4
    ERR3    6304      ERR51   67F2      ERRBS   0503      ERRBV   6ECA
    ERRBV2  70FA      ERRCDT  70FE      ERRCO1  8323      ERRCOD  8322
    ERREX   0403      ERRFN   71A6      ERRFNN  71AC      ERRIAL  0E03
    ERRIBS  7CFC      ERRIMP  7DA0      ERRIOR  0203      ERRLN   038A
    ERRLNF  0303      ERRMEM  7368      ERRMS   7CB2      ERRMUV  6970
    ERROLP  1103      ERROM   0103      ERRONE  664E      ERROR   0005
    ERRORZ  00A5      ERRREC  0F03      ERRSN   0003      ERRSN1  6ECE
    ERRSND  1203      ERRSNM  6D5C      ERRSO   6468      ERRSY1  6ED2
    ERRSYN  664E      ERRT    630C      ERRTM   0603      ERRX    6308
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0097
    EXC15L  65D0      EXEC10  650E      EXEC11  6516      EXEC15  6542
    EXEC16  6576      EXEC17  6588      EXEC20  658E      EXEC50  6656
    EXECG   6500      EXIT    6652      EXP     8376      EXPONZ  00C5
    EXPZZ   75CA      EXRTN   65A6      EXRTN2  65AE      EXRTN3  65C8
    EXRTNA  6466      EXTRAM  832E      EXTRM1  832F      FAC     834A
    FAC1    834B      FAC10   8354      FAC11   8355      FAC12   8356
    FAC13   8357      FAC14   8358      FAC15   8359      FAC16   835A
    FAC2    834C      FAC33   836B      FAC4    834E      FAC5    834F
    FAC6    8350      FAC7    8351      FAC8    8352      FAC9    8353
    FADD    0D80      FBS     15E0      FBS001  15E6      FBSYMB  618C
    FCOMP   0D3A      FCOMPB  6126      FDIV    0FF4      FDVSR   8354
    FDVSR1  8355      FDVSR2  8356      FDVSR8  835C      FILSPC  7BAA
    FILSZ1  7BBA      FILSZ2  7BC0      FILSZ3  7BE2      FILSZ4  7BE6
    FILSZ5  7BEE      FILSZ6  7BA8      FLAG    8345      FLG     0005
    FLTERR  836C      FLTNDX  8354      FLTONE  600E      FMULT   0E88
    FNCFLG  7506      FNERR   7D32      FNNERR  7E4C      FOR     7DC2
    FORNET  8317      FORZ    008C      FPSIGN  03DC      FREPTR  8340
    FSUB    0D7C      GDST    8302      GDST1   8303      GDTECT  6050
    GET     6C9A      GET01   79D0      GET03   79DA      GET1    6C9E
    GETCGR  60D0      GETCH   60AE      GETCH1  60BC      GETCH2  6FDE
    GETCHG  60C0      GETCHR  6FBA      GETG    6CCA      GETG2   6CCE
    GETL10  6764      GETL1Z  68DA      GETNB   6FAC      GETNB1  6FAE
    GETS10  73A2      GETSTG  61A2      GETSTK  610E      GETSTR  736C
    GETV    187C      GETV1   1880      GO      66D6      GOSUB   673A
    GOSUB2  673C      GOSUBZ  0087      GOT32   677E      GOT33   6792
    GOT35   6798      GOTO    675C      GOTO20  675E      GOTO31  679C
    GOTO32  67A6      GOTO33  67BA      GOTO34  67C8      GOTO35  67C4
    GOTO36  67CE      GOTO40  67DA      GOTO50  67EA      GOTO90  670A
    GOTO95  670E      GOTOZ   0086      GOZ     0085      GPL00   79E6
    GPL05   7E5E      GPL05L  7DA4      GPL10   79FC      GPL25   7A2C
    GPL30   7A38      GPL40   7A6A      GPL50   7A8C      GPL60   7A9C
    GPL70   7ACE      GPLIST  A026      GPLNXT  7A24      GPLSU   757E
    GREAD   7EB4      GREAD1  7EA6      GREATR  6A7E      GRINT   79EC
    GRMRAX  0002      GRMWAX  0402      GRMWDX  0400      GRZ1    7EC0
    GRZ2    7EC2      GSRC    8354      GSRC1   8355      GTZ     00C0
    GVWITE  7FDA      GVZ1    7FEC      GWITE1  7ECA      GWRITE  7ED8
    GWZ1    7EE4      GWZ2    7EEC      H16     7156      IBSTAB  7EA0
    IF      68A6      IFIF    7D94      IFZ     0084      IFZ10   68DE
    IFZ20   68FA      IFZ25   6904      IFZ27   6910      IFZ28   691A
    IFZ30   6928      IFZ35   692E      IFZ40   6934      IFZ5    68D0
    IFZ50   693A      IMAGE   7DB8      IMAGEZ  00A3      IMPER   7D9A
    INPUTZ  0092      INTRIN  8338      INUSE   7504      IO      7B48
    JEQ1C   68EC      JNCARE  7D22      JNE88   77BC      JOYX    8377
    JOYY    8376      KEYBRD  8375      KEYTAB  CB00      LBCPMO  6146
    LBLPZ   6F81      LEDEND  6B42      LEDERR  6B46      LEDEX   6B28
    LEDLE   6A90      LENGTH  6FE2      LESS    6A70      LETCON  69A0
    LEXP    6CE2      LFALSE  6AB8      LINPUZ  00AA      LINUM   8312
    LLC     0020      LLIST   7BFE      LLISZ4  7C10      LLISZ5  7C20
    LLISZ6  7C42      LNBUF   8336      LNZ     00C9      LOGZZ   76C2
    LPAR    6F6C      LPARZ   00B7      LSUBP   8348      LT10    6A82
    LT15    6A88      LTAB    6A54      LTBLEN  001C      LTRUE   6ABE
    LTST01  6A92      LTST15  6AB0      LTST20  6AE0      LTST90  6AC2
    LTSTAB  6ADA      LTSTEQ  6AB6      LTSTGE  6AB4      LTSTGT  6AD6
    LTSTLE  6AD0      LTSTLT  6AD2      LTSTNE  6ABC      LTSTXX  6AB4
    LWCNS   6000      MEMC03  731C      MEMC04  732C      MEMC05  7334
    MEMC06  735A      MEMC08  7360      MEMCHG  72CE      MEMCHK  72D8
    MEMERR  7364      MINUS   6B4A      MINUSZ  00C2      MNUM    8302
    MNUM1   8303      MOTION  837A      MOVF1   6452      MOVFA2  645A
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0098
    MOVFAC  6434      MV01    7FB4      MV05    7F96      MVDN    7F7E
    MVDN1   7F92      MVDN2   7F8A      MVDNZ1  7FB4      MVUP    6F98
    MVUP05  6FA4      NABS    6CFA      NATN    6D16      NCOS    6D1C
    NEGPAD  7D00      NEXP    6D22      NEXT    0070      NEXT2   7234
    NEXT2A  7228      NEXT2B  7224      NEXT4   721C      NEXT5   72A0
    NEXT6   72C8      NEXT8   72C4      NEXTZ   0096      NFOR    7000
    NFOR03  7162      NFOR05  716C      NFOR07  7170      NFOR09  7174
    NFOR1   7006      NFOR10  717E      NFOR11  71B4      NFOR12  71DE
    NFOR13  71EA      NFOR1A  702E      NFOR1B  7050      NFOR1C  705C
    NFOR1D  707E      NFOR1E  7084      NFOR1F  706E      NFOR2   7102
    NFOR20  71C2      NFOR3   7110      NFOR30  71CC      NINT    6D28
    NLET    6948      NLET05  694C      NLET10  6978      NLET15  6982
    NLOG    6D2E      NLPR    6E68      NMIN10  6E8C      NMINUS  6E82
    NNEXT   7230      NOCARE  7E02      NOLED   664E      NOLEDL  64FA
    NONUD   664E      NOTZ    00BD      NPLUS   6E96      NPSCAN  7D7A
    NSGN    6D34      NSIN    6D64      NSQR    6D6A      NSTR05  7478
    NSTR10  748A      NSTR15  7494      NSTR20  749C      NSTRCN  7442
    NTAB    69FE      NTABLN  0056      NTAN    6D70      NUDE10  64F4
    NUDEND  65F0      NUDG05  64B0      NUDND1  65E6      NUDND2  65F4
    NUDND3  6602      NUDND4  660A      NUDNDL  64FE      NUDTAB  8328
    NUMC49  66A6      NUMCHK  6B92      NUMCON  6684      NUMZ    00C7
    NXTCHR  7E32      O0AND   6DFA      O0AND1  6E0E      O0AND2  6E14
    O0NOT   6E2E      O0OR    6E1C      O0XOR   6E50      OEZ     8314
    OFFSET  7D84      ON      66DA      ON20    6710      ON30    671A
    ON40    6726      ON50    6730      ONBRK   66D0      ONERR   66C4
    ONWARN  66CA      ONZ     009B      OPTIOZ  009E      ORZ     00BA
    OVEXP   0FC2      P05     648A      P1      0040      P10     6492
    P17     64A8      P17L    64C2      P2      0050      P3      002B
    P4      002D      P5      0070      PABPTR  8304      PAD0    8300
    PAD1    8301      PAD5F   835F      PADC2   83C2      PAGE1   6000
    PAGE2   6002      PAGSEL  607A      PARCOM  6F74      PARSE   6480
    PARSEG  6470      PGMC10  6C8E      PGMCH   6410      PGMCHR  6C74
    PGMPT1  832D      PGMPTR  832C      PGMSUB  6C7A      PLAYER  8374
    PLUS    6B1E      PLUSZ   00C1      POPSTK  60D4      PRGFLG  8344
    PROAZ   8310      PSCAN   7C56      PSCFG   03B7      PSHPRS  6B9C
    PSYM    6884      PUT1    6CB2      PUTCHR  7F6E      PUTG2   6CD8
    PUTSTK  60F2      PUTV    641E      PUTV1   6422      PWARN   6DBC
    PWRZZ   7492      PZ      8312      QZ      8316      R0      0000
    R0LB    83E1      R1      0001      R10     000A      R10LB   83F5
    R11     000B      R11LB   83F7      R12     000C      R12LB   83F9
    R13     000D      R13LB   83FB      R14     000E      R14LB   83FD
    R15     000F      R15LB   83FF      R1LB    83E3      R2      0002
    R2LB    83E5      R3      0003      R3LB    83E7      R4      0004
    R4LB    83E9      R5      0005      R5LB    83EB      R6      0006
    R6LB    83ED      R7      0007      R7LB    83EF      R8      0008
    R8LB    83F1      R9      0009      R9LB    83F3      RAMFLG  8389
    RAMPTR  830A      RAMTOP  8384      RAND16  83D4      RANDOM  8378
    RANERR  6F64      RANGE   6F30      REMZ    009A      RES03   7950
    RES05   7954      RES15   79A4      RES20   79B2      RES50   79BE
    RES51   79C0      RES52   79C6      RESET   006A      RESGPL  79CC
    RESOLV  7946      RETRN   6DEC      RETU30  6822      RETU40  6838
    RETURN  67F8      RETURZ  0088      ROLIN   7AC4      ROLOUT  7A90
    ROUNU   0FB2      ROUNUP  0F64      RPARZ   00B6      RTNADD  8326
    RTNG    6630      SADD    0D84      SADDR   83D2      SAVEG   83CB
    SAVRE2  1E90      SAVREG  1E8C      SBXT05  78DE      SCAL01  75A0
    SCAL05  75DE      SCAL06  75E8      SCAL08  75F4      SCAL10  762A
    SCAL12  7640      SCAL14  7656      SCAL15  765A      SCAL16  7666
    SCAL23  76BC      SCAL24  76CC      SCAL26  76EC      SCAL30  7648
 99/4 ASSEMBLER
GVWITES                                                      PAGE 0099
    SCAL32  7644      SCAL34  764C      SCAL35  7650      SCAL37  7654
    SCAL40  76F2      SCAL42  7700      SCAL50  7744      SCAL54  777E
    SCAL60  77B4      SCAL62  77B8      SCAL70  783A      SCAL80  787E
    SCAL81  78A0      SCAL82  78C0      SCAL84  78B8      SCAL86  78D0
    SCAL88  7878      SCAL89  75D4      SCAL90  75CE      SCAL91  75D8
    SCAL93  75DC      SCAL98  793E      SCAN05  7C6E      SCAN06  7C90
    SCAN07  7CB8      SCAN08  7CCC      SCAN09  7CD2      SCAN10  7D0E
    SCAN11  7D02      SCAN12  7D04      SCAN15  7D10      SCAN20  7D24
    SCAN25  7D86      SCAN26  7D36      SCAN28  7D3C      SCAN30  7D6A
    SCAN35  7D74      SCAN40  7D56      SCAN5A  7C7A      SCAN5B  7C82
    SCAN5C  7D90      SCAN6A  7CA0      SCAN9A  7CDC      SCGPL1  7D2E
    SCLEN   8355      SCN26A  7D84      SCNGPL  7E58      SCNTAB  7E70
    SCOMPB  0D42      SCRBOT  7B02      SCRO1   7B10      SCRO2   7B1A
    SCRO4   7B2C      SCRO6   7B38      SCROLL  7ADA      SDIV    0FF8
    SEETW2  6F02      SEETW4  6F0A      SEETW6  6F26      SEETW8  6F2A
    SEETWO  6EF0      SEPSMT  7DFE      SET     6192      SETREG  1E7A
    SGNZ    00D1      SHRFLG  7508      SIGN    8375      SINZZ   78C0
    SKIPLN  7E38      SKPLN   662A      SKPS01  6624      SKPSTR  6618
    SMB     61DC      SMB02   6202      SMB04   6210      SMB05   6214
    SMB06   622C      SMB08   6232      SMB51   6246      SMB57   6268
    SMB71   62FC      SMBB    61A8      SMBB10  61BE      SMBO10  6236
    SMBO20  626E      SMBO25  6274      SMBO40  62B6      SMBO41  62B8
    SMBO50  6240      SMBO70  62D2      SMBO71  62F6      SMTSEP  65C4
    SMTSRT  831E      SMULT   0E8C      SNEXT   7DD6      SNTXER  7DD0
    SPEED   6EE2      SQRZZ   783A      SREF    831C      SSEPZ   0082
    SSUB    0D74      STACK   8373      STATUS  837C      STCOD2  6981
    STCODE  6188      STEPZ   00B2      STKADD  8373      STKCHK  6DC0
    STKDAT  8372      STKEND  83BA      STKMOV  60E8      STKRTN  6DF0
    STLN    8330      STMTTB  69FC      STND12  83AE      STOP    665E
    STREND  831A      STRINZ  00C7      STRSKP  7E3E      STRSP   8318
    STVDP   18AE      STVDP3  18AA      STVSPT  8324      SUBNDZ  00A8
    SUBTAB  833A      SUBXIT  78D2      SUBXTZ  00A7      SUBZ    00A1
    SYM     6312      SYM1    6320      SYMB    61B4      SYMB10  68A2
    SYMB20  687C      SYMBOL  0376      SYMTA1  833F      SYMTAB  833E
    SYNCHK  6400      SYNERR  6D60      TABLEN  0030      TABSAV  0392
    TANZZ   7940      TEMP2   836C      THENZ   00B0      TIME    8379
    TIMES   6B56      TOZ     00B1      TRACE   6672      TRACL   65D4
    TREMZ   0083      TYPE    836D      UDF     0006      UNQSTZ  00C8
    VAR0    8300      VAR5    8310      VAR9    8316      VARA    832A
    VARW    8320      VARW1   8321      VARY    8304      VARY2   8306
    VDPSTS  837B      VGWITE  7FC0      VGZ1    7FCE      VPOP    6C2A
    VPOP10  6C46      VPOP18  6C6C      VPOP20  6C6E      VPSH15  6BC4
    VPSH19  6BE8      VPSH20  6BF2      VPSH23  6C1A      VPSH25  6C1E
    VPSH27  6C26      VPUSH   6BAA      VPUSHG  61BA      VROAZ   03C0
    VSPTR   836E      VSPTR1  836F      WARN    0009      WARNZ   00A6
    WARNZZ  6662      WRVDP   4000      WS      83E0      WSM     831A
    WSM2    831C      WSM4    831E      WSM6    8320      WSM8    8322
    XFLAG   8316      XGRMRD  9800      XORZ    00BC      XPT     837F
    XVDPRD  8800      XVDPWD  8C00      YPT     837E
  0000 ERRORS
This makes it a little more easy to modify.
Thank you. I was more thinking along the line that evaluating the numeric value of an argument was done the same regardless of where it was done. Like it doesn't matter if you use variable B in the FOR statement above or if you calculate SIN(B) or SQR(B). If it's the same routine you don't need to change in too many places.
Why would you even consider using integer for SIN(B) or SQR(B) at all?
That is what INT(#) was for in first place.
Floating Point is for accuracy, integer is for rounded results using INT(#) or just for numbers like ROW and COLUMN for graphics.
My reason for % token for integers is mostly for Graphics like CALL HCHAR(row,column,character-number,repetition) as XB
treats all numbers a Floating Point even when it has to convert it to integer each time for all these in the command.
This is a true waste of time for the Interpreter when a better solution is using integer in first place instead.
FWIW,
ABASIC uses the "%" convention for integer constants (edit:and variables).   The numeric variables default to real (float) just like in XB however, there is additional functionality to convert a numberic variable from real to integer, or to declare a variable as an integer type. This also holds true for numeric arrays.
The interpreter leverages the variable stack and the token, as appropriate, to determine how to use the variable or constant.
SYMBOL TYPE OF VARIABLE
$      STRING VARIABLE
%     INTEGER CONSTANT
(no symbol) REAL FLOATING POINT
DEFINT - define as integers
DEFREAL- define as floating point (64 bit)
DEFSTR – define as string
The machine I moved onto after my TI was a Commodore 128.
It also had the standard convention for use of integer only variables vs float (and string).
From the system guide.....
The Commodore 128 uses three types of variables in BASIC. These are: normal numeric, integer numeric, string (alfanumeric).
Normal NUMERIC VARIABLES, also called floating point variables, can have any exponent value from -10 to +10, with up to nine digits of accuracy. When a number becomes larger than nine digits can show, the computer displays it in scientific notation form, with the number normalized to one digit and eight decimal places, followed by the letter E and the power of 10 by which the number is multiplied. For example, the number 12345678901 is displayed as 1.23456789E+10.
INTEGER VARIABLES can be used when the number is from +32767 to -32768 (inclusive), and with no fractional portion. An integer variable is a number like 5, 10 or -100. Integers take up less space than floating point variables, particularly when used in an array (see below).
STRING VARIABLES are those used for character data, which may contain numbers, letters and any other characters the Commodore 128 can display. An example of a string variable is "COMMODORE 128".
VARIABLE NAMES may consist of a single letter, a letter followed by a number, or two letters. Variable names may be longer than two characters, but only the first two are significant. An integer is specified by using the percent sign (%) after the variable name. String variables have a dollar sign ($) after their names.
EXAMPLES:
     Numeric Variable Names: A, A5, BZ
     Integer Variable Names: A%, A5%, BZ%
     String Variable Names: A$, A5$, BZ$
3 hours ago, apersson850 said:
Yes, I get where the integers are most useful. But since a user may still want to compute the square root of an integer, or maybe even the sine value, you need to handle it in some way. Unless you just issue an error, of course.
Well as INTEGER will only range from -32768 (>8001) to 0 (>0000) to 32767 (>7FFF) how would I do a SIN or SQR?
And yes, that would create a OUT OF RANGE ERROR or incorrect results overall with huge rounding errors.
Just like we have INT()  you could create FLOAT() to convert the other way. ??
Just spitballin' here.
Thanks, but we already have floating point built into XB so that is kind of superfluous.
We have INT(#) and that does a great job already.
So A%=INT(SIN(X+2)) would make A%=-1 if X=8
And that would same a many bytes of memory over Floating Point.
You could do the other way X=SQR(Y+A%) so X=8.87862602 if Y=76.83 and A%=2
This would be processed by the interpreter like X=SQR(Y+2)
I think adding more math would be mostly pointless unused features.
Actually, a routine like FLOAT() would only need to call CIF (Convert Integer to Float). Any expressions with mixed FLOATs and INTs should do the conversion implicitly, anyway, so maybe there would not be a need for FLOAT().
..lee
Edited by Lee Stewart
correction
You have floating point until somebody tries to feed an integer variable/expression to a transcendental function as was mentioned earlier.
It might be the easier way to cover your "assets" as they say.
And since as Lee points out there is already code to do it...
31 minutes ago, Lee Stewart said:
Actually, a routine like FLOAT() would only need to call CIF (Convert Float to Integer). Any expressions with mixed FLOATs and INTs should do the conversion implicitly, anyway, so maybe there would not be a need for FLOAT().
..lee
Lee is correct it is called INT(floating Point value) this routing just fetched the number in floating point and converts to integer.
Thus X%=INT(floating point value) is the integer.
Actually, I had the translation of CIF backwards. It should have been Convert Integer to Float.  I corrected it in my post. :dunce:
...lee
...lee
That is built-into all of XB as any number you entire is automatically converted to Floating Point.
Whether it's needed or not can be argued about. But there's no conceptual issue. The output of the functions would be a float, but the input could be an integer. So the interpreter would have to handle that the argument could be an integer too, not just the alternatives that exist today. This is perfectly legitimate:
A%=1
B%=127
PRINT SIN(A%)
PRINT SQR(B%)
The output would be 0.84147098 and 11.26942767, respectively. Nothing wrong with that. But the arguments need to implcitly be converted to float before fed into the math routines in question, which adds another alternative.
There is one standard math function that's a bit tricky, and that's division. If you compute B%=11::C%=3::PRINT B%/C%, then what should the result be? Normally / is a floating point operation, which would then return 3.66666667. But if you instead do B%=11::C%=3::A%=B%/C%::PRINT A%, then it's clear that the printout will be 3 instead, since it comes from an integer variable.
Pascal handles this by not only defining +, -, * and /, but for integer values also div and mod. Here div is integer division and mod is the reminder after integer division. So 11/3=3.66666667 but 11 div 3=3 and 11 mod 3=2.
In Pascal, the equivalent of A%=30000::B%=A%+A% will silently become -5536. No overflow alarms or anything else like that.
Edited by apersson850
A%=1
B%=127
PRINT SIN(A%)
PRINT SQR(B%)
Tell me how this would work in the Interpreter PRINT A%/B% as what is the point of even having INTEGER numbers if everything is Floating Point?
Unless specified all values will be in Floating Point as results.
Thus, how I plan on making it work in XB is the same as if you did this PRINT 11/3 the result will be a Floating Point result.
If you do a A%=11/3 than A%=3 the INTERPETER would use CIF automatically for A%, same if you did this A%=INT(PI) then A%=3
Doing any kind of math will always result in some floating point slowing down the results, I am not going to write a integer only ROM.
By the way RXB has CALL MOD(number,divisor,quotiant,remainder) example: CALL MOD(-32768,3,Q,R) would return Q=10922 and R=2
Well, that's what I'm asking you? The only point I see with integers, if the math still is with reals, is to save space to store them. Which may have a value by itself, but is a bit short handed.
Then it doesn't make sense, since A%+B% should definitely still be in integer. If you want to PRINT it, then perhaps converting it to a float before printing makes sense, since printing takes quite some time anyway.
You mean the opposite, right, CFI will be implied. Which makes sense, as you don't have integer literal values just like that.
Unfortunately my advice is then that you stop right there. Since if you aren't going to do integer math with integer variables, like in the A%=B%+C%, then the main benefit of higher speed is gone. The benefit of requiring less storagae space you can get already as it is, if you use CALL LOAD/CALL PEEK to store and retreive values somewhere in memory. Or you can use characters in a string and use their ASCII code as numeric values.
The good thing with integer math and the TMS 9900 is that it's simple. You have almost everything already in the CPU. Just need sign handling for DIV and MPY.
