Elia Spallanzani fdt Posted March 27, 2023 Share Posted March 27, 2023 https://jpking.itch.io/a1rl0ck From readme: TI99/4A: Insert the game disk Choose wheter you want to play with 40 or 80 columns When prompted to insert game disk 2, just press a key The game is compatible with the TI-99/4A and Geneve 9640 computers. The minimum requirements for TI-99/4A are: 32K, Disk controller, and Extended BASIC cartridge. 80 column mode requires either an F18A or V9938 hardware enhancement. For the Geneve 9640 you need TIMODE (GPL) and the Extended BASIC cartridge files. You may use either the 40 column or V9938/58 option. 8 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted March 28, 2023 Share Posted March 28, 2023 I tried the game tonight and played a few turns. I'll put this on my list to play. Thank you for sharing. An alternate option for Geneve users: GPL/XB are not required. The game may also be run from the OS command line via the EXEC program. "EXEC 80TERP-I" 4 Quote Link to comment Share on other sites More sharing options...
MikeV Posted March 30, 2023 Share Posted March 30, 2023 On 3/27/2023 at 10:14 AM, Elia Spallanzani fdt said: https://jpking.itch.io/a1rl0ck From readme: TI99/4A: Insert the game disk Choose whether you want to play with 40 or 80 columns When prompted to insert game disk 2, just press a key The game is compatible with the TI-99/4A and Geneve 9640 computers. The minimum requirements for TI-99/4A are: 32K, Disk controller, and Extended BASIC cartridge. 80 column mode requires either an F18A or V9938 hardware enhancement. For the Geneve 9640 you need TIMODE (GPL) and the Extended BASIC cartridge files. You may use either the 40 column or V9938/58 option. Works exactly as advertised! I did not realize you meant InfoCom format, neat! Thank you for supporting the TI world. MV Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 31, 2023 Share Posted March 31, 2023 Too bad there is no physical release... Quote Link to comment Share on other sites More sharing options...
MikeV Posted March 31, 2023 Share Posted March 31, 2023 3 hours ago, Vorticon said: Too bad there is no physical release... Actually it fully (seems to) supports the TI. If you download the full zip file bundle ~5mb, you will find the A1RLOCK_ti99.dsk in the bundle. It also has just about every other format one can think of off hand. Support for: 40 col., 80 col via F18A and 9938/9958 systems. 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted March 31, 2023 Share Posted March 31, 2023 5 hours ago, Vorticon said: Too bad there is no physical release... To Have and to Hold!🔑 ...the Pledged Property unto the Trustee and its successors and assigns forever; BUT IN TRUST, NEVERTHELESS, for the equal and proportionate benefit and security of the holders from time to time of all the Debentures issued hereunder and Outstanding, without any priority of any of said Debentures over any of the others. IT IS HEREBY COVENANTED, DECLARED AND AGREED that all the Debentures are to be issued, authenticated and delivered, and that all property, including cash, subject or to become subject hereto is to be held, subject to the further covenants, conditions, uses and trusts hereinafter set forth, and the Corporation, for itself and its successors and assigns, hereby covenants and agrees to and with the Trustee and its successors in said trust for the equal and proportionate benefit and security of those who shall hold the Debentures, as hereinafter set forth. Quote Link to comment Share on other sites More sharing options...
jetset Posted March 31, 2023 Share Posted March 31, 2023 15 minutes ago, HOME AUTOMATION said: To Have and to Hold!🔑 ...the Pledged Property unto the Trustee and its successors and assigns forever; BUT IN TRUST, NEVERTHELESS, for the equal and proportionate benefit and security of the holders from time to time of all the Debentures issued hereunder and Outstanding, without any priority of any of said Debentures over any of the others. IT IS HEREBY COVENANTED, DECLARED AND AGREED that all the Debentures are to be issued, authenticated and delivered, and that all property, including cash, subject or to become subject hereto is to be held, subject to the further covenants, conditions, uses and trusts hereinafter set forth, and the Corporation, for itself and its successors and assigns, hereby covenants and agrees to and with the Trustee and its successors in said trust for the equal and proportionate benefit and security of those who shall hold the Debentures, as hereinafter set forth. My wife made me sign something like that when we got married. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 31, 2023 Share Posted March 31, 2023 1 hour ago, MikeV said: Actually it fully (seems to) supports the TI. If you download the full zip file bundle ~5mb, you will find the A1RLOCK_ti99.dsk in the bundle. It also has just about every other format one can think of off hand. Support for: 40 col., 80 col via F18A and 9938/9958 systems. Yes I know and I have tried it already on the TI I was actually referring to an actual boxed package like the Hibernated one. Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted March 31, 2023 Author Share Posted March 31, 2023 you could contact the author (the Italian Marco Innocenti, https://jpking.itch.io/) and ask him if he intends to make a physical release. Quote Link to comment Share on other sites More sharing options...
MikeV Posted April 1, 2023 Share Posted April 1, 2023 18 hours ago, Vorticon said: Yes I know and I have tried it already on the TI I was actually referring to an actual boxed package like the Hibernated one. Thank you for the correction. I thought you were referring to playing on line vs a local system! 1 Quote Link to comment Share on other sites More sharing options...
