TissueLint Posted March 31, 2023 Share Posted March 31, 2023 Hey guys, I was doing some testing on one of my 5200s that doesn’t display picture and found that my color oscillator crystal isn’t putting out anything. So my question is, are the color oscillators from the 2600 compatible with the 5200? Only reason why im asking is because console5 lists the crystal as a 2600 part but nowhere does it mention if it’s compatible with the 5200. They seem to have identical part numbers but just wanted to check and make sure before I ordered a replacement. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted March 31, 2023 Share Posted March 31, 2023 According to the service manuals for both the 2600 and 5200 it's the same part. Quote Link to comment Share on other sites More sharing options...
TissueLint Posted April 1, 2023 Author Share Posted April 1, 2023 9 hours ago, ApolloBoy said: According to the service manuals for both the 2600 and 5200 it's the same part. Okay, I kinda figured it would be but just wanted to check and make sure. Didn’t think about comparing both manuals. Thanks! Quote Link to comment Share on other sites More sharing options...
atari-dna Posted July 13, 2023 Share Posted July 13, 2023 Your problem may not be the xtal. If you don't have a clock then you should also check Q1 and Q2 for proper voltages as they are the drivers for the clock to oscillate. Faulty transistors (or associated components) could be the culprit. Quote Link to comment Share on other sites More sharing options...
