ZOMB0BBY Posted April 10, 2023 Share Posted April 10, 2023 Consistently receiving this error message after not using Gamedrive for a couple months."Cart Connection FaultPlease remove, clean and reinsert the Gamedrive cart" Cart is new and has been used less than 5 times prior, and the console itself is also in immaculate condition. My copy of Cybermorph plays perfectly, loads every time. I was also able to successfully run an update, so I'm assuming the connection to the SD card is not part of the issue... The cart is under warranty at Stone Age Gamer, but I'd love to get it working on my own, preferably without voiding the warranty. So with that being said, any type of help is welcomed Quote Link to comment Share on other sites More sharing options...
SainT Posted April 12, 2023 Share Posted April 12, 2023 Have you tried removing the cart and cleaning the cart edge with something like IPA and a cue tip? This error means there is a bad connection between the Jag and the cart somewhere on the data / address bus. Quote Link to comment Share on other sites More sharing options...
ZOMB0BBY Posted April 12, 2023 Author Share Posted April 12, 2023 Yes, of course! And just did it again and still same error. I was able to update the firmware and also tested an original cart on my Jag, if that is useful info. Quote Link to comment Share on other sites More sharing options...
SainT Posted April 12, 2023 Share Posted April 12, 2023 That is odd, it's possible it could be the cart if other games are running ok. Although to be fair I don't think I've actually had anyone with this problem before which ended up being the cart, but there's always a first. The other thing to give a clean is the cartridge port on the Jag itself if you've not done that as well. Quote Link to comment Share on other sites More sharing options...
ZOMB0BBY Posted April 13, 2023 Author Share Posted April 13, 2023 OK well, It's still under warranty at Stone Age Gamer. But I wanted to do whatever I could before sending it back to them. If cleaning the console doesn't work, should I send it back? I did pick up Humble Bazookas Jaguar Bluetooth controller adapter, do you think that could have fried the cart? Quote Link to comment Share on other sites More sharing options...
SainT Posted April 13, 2023 Share Posted April 13, 2023 If cleaning the cart port doesn’t help then I’d suggest returning it would be the next step. As I say, it’s not something I’ve heard of as a problem, but it’s certainly possible. And there’s no way a controller adapter could affect the cartridge that I am aware. 1 Quote Link to comment Share on other sites More sharing options...
ZOMB0BBY Posted April 13, 2023 Author Share Posted April 13, 2023 alright, well thank you kindly for the help! 1 Quote Link to comment Share on other sites More sharing options...
SainT Posted April 14, 2023 Share Posted April 14, 2023 Please let me know the outcome, I'm always keen to hear the cause of any problems. Quote Link to comment Share on other sites More sharing options...
Lunar Posted August 6, 2023 Share Posted August 6, 2023 I'm having the same issue with a brand new Game Drive from SAG. Did you ever find a solution? Quote Link to comment Share on other sites More sharing options...
Graveyard Generation Posted October 23, 2023 Share Posted October 23, 2023 i had this issue when i was using a super nintendo power supply. eventually i figured out the power supply wasn't good for the system. obviously i'm assuming most people here are smarter than me about this stuff, but just in case, this isn't the only system where i've found out i've used the wrong power supply and its caused cartridge read errors frequently so its worth at least putting in the thread just in case anyone else is having my specific issue 1 Quote Link to comment Share on other sites More sharing options...
SainT Posted October 23, 2023 Share Posted October 23, 2023 Interesting to know, thanks for the post! The SNES PSU is actually rated high enough in terms of current (1.3A vs 1.2A for the Jaguar), my guess is more that the PSU was failing due to age and most likely causing voltage sag under load. Using 30 year old PSU’s in general isn’t recommended, although I still use mine! Quote Link to comment Share on other sites More sharing options...
