+Lee Stewart Posted June 18 Share Posted June 18 3 hours ago, Ti Treker said: If there is an IC that replaces the 74LS379 directly , or with minor rewiring , that makes my boards non-inverting , that would be fine too . The 74LS379 can be used either way. Jim ( @Ksarul ) will know what re-wiring/jumpering you would need to do to effect that scenario. ..lee Quote Link to comment Share on other sites More sharing options...
Ti Treker Posted June 18 Share Posted June 18 Thank You , Lee . I appreciate it . Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted June 18 Share Posted June 18 7 hours ago, Ti Treker said: Is there a utility that will run in Windows or Windows DOS prompt that will convert Inverted rom bin files to Non-Inverted roms bin files and vice versa ? ( Up to 32k ) For my purposes , I need to operate out of actual physical cartridges with roms . The non-inverted rom boards are hard for me to obtain ( always sold out ) . I do have a few spare inverted rom boards I can use on hand though . ( Uses the 74LS379 ) If there is an IC that replaces the 74LS379 directly , or with minor rewiring , that makes my boards non-inverting , that would be fine too . Thanks . On the various boards: I always keep a bunch of the bare boards in stock, so they are always available from someone. @arcadeshopper gets supplies from me for his web store, but whenever he runs out, I try to make sure he gets some more. As to an inversion tool, @Asmusr made a really nice tool to invert a set of cartridge files to allow seamless flipping between the inverted and non-inverted formats. I use it all the time, as I build a lot of cartridges and generally adapt the files to fit onto the boards I have built at the time I need to make cartridges out of them. I am attaching it here. bankinvert.zip 4 Quote Link to comment Share on other sites More sharing options...
Ti Treker Posted June 19 Share Posted June 19 Thanks !!! Quote Link to comment Share on other sites More sharing options...
