+llabnip Posted June 4 Author Share Posted June 4 https://github.com/wavemotion-dave/A8DS V3.7 : 04-June-2023 by wavemotion-dave Update to Screen Blur to have just 3 settings: NONE, LIGHT and HEAVY. Default is LIGHT. Improvements to memory layout to gain back additional resources. Fix for 576K COMPY RAM so that it properly handles separate ANTIC memory access. Minor fixes and cleanup as time permitted. This is probably it for a while... just a few minor cleanups. A bit of spit-and-polish. I've got some other projects that call for attention so I'm going to let this one sit for a bit. 4 2 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted June 4 Share Posted June 4 @llabnip could you please try Space Taxi? https://www.santellocco.com/atari/spacetaxi.htm It works but I don't hear thrust sounds. 1 Quote Link to comment Share on other sites More sharing options...
+llabnip Posted June 4 Author Share Posted June 4 5 hours ago, Philsan said: @llabnip could you please try Space Taxi? https://www.santellocco.com/atari/spacetaxi.htm It works but I don't hear thrust sounds. Well, at least I can confirm I'm seeing the same. There is atari800-nds which is a newer version of Atari800 for the DS (though runs much slower and often the sound is not right) and that does seem to have the thrust sounds (though the speech is significantly worse than A8DS which is already pretty bad!) I've been through the code and don't see anything obvious - but I'll keep looking. 2 Quote Link to comment Share on other sites More sharing options...
