Sound effect not working
Posted (edited)
Hey!!
I am trying out the PSG Envelope tool that helps you create sound effects. It gave me the following code which I implemented in my game, but it doesn't work for me:
Here is the code it gave:
  sound 4,$0f,$0007
  sound 2,$0BB8,$30
  sound 3,$0800,$0004
I am not sure if I am doing something wrong.. below is my code. Any help is appreciated :)
if throw_sound = 1 then
 snd = snd + 1
 if snd < 20 then
  sound 4,$0f,$0007
  sound 2,$0BB8,$30
  sound 3,$0800,$0004
 end if
if snd = 20 then
  SOUND 4,,0
  SOUND 2,,0
  SOUND 3,,0
  snd = 0
  throw_sound = 0
 end if
end if
Edited by Brian's Man Cave
SOUND 2 (voice C) takes a 12-bit frequency value and a volume 0-15 while you feed it $30 = 48. I think that might be one of your problems.
SOUND 4 takes a 5-bit noise value (0-31) and a mix register:
REM Mixer control (0 = Enable, 1 = Disable)
REM |   7   |   6   |   5   |   4   |   3   |   2   |   1   |   0   |
REM | I/O A | I/O B | Noi C | Noi B | Noi A | Ton C | Ton B | Ton A |
$0004 in this case means you enable noise on voices A, B, C and tone on voices A, B but not C, plus you set the noise frequency to $0F which is medium high. Since you never set voices A and B (SOUND 0 and 1), I think we can ignore those.
Based on the documentation in psg.txt (see jzintv installation, folder doc/programming), it seems the 16-bit value (here $0800) is the period and the type is $04 which visually is illustrated as
/|_________________________________
which then should be played using only noise with the fixed frequency $0F rather than the frequency $0BB8 you have it above.
Try SOUND 4,1,$38 and SOUND 2,$0BB8,$0F to see if it makes anything change. I suppose the routine is called by ON FRAME so it counts once per frame, rather than free running and counting to 20 as fast as possible?
Posted (edited)
I tried the code and it did make a sound, a short buzz noise. The sound I am trying to make is one kind of like the snake sound in D&D Cloudy Mountain. Its the first time I am trying that software...
I never tried the tool. I spent some time trying to figure out how the volume envelope works in regard to periods and how you set the sound volume - it seems $30 is a decent value for a voice volume after all once you bring envelopes into play.
Since you'd visit the routine anyway on every frame, I think you get more freedom adjusting volume manually instead of letting the PSG do it. I have attached a skeleton that I'm using, which probably is somewhat similar to what you already use.
sfx.bas
Posted (edited)
By the way, are you supposed to use it in a routine that sets the envelope on each frame?
Since the envelope contains a period, I'm thinking maybe the routine should be like this:
IF sound_state = 0 THEN
  SOUND blah blah blah
END IF
sound_state = sound_state + 1
IF sound_state = 20 THEN
  sound_effect = 0
END IF
meaning you count frames to determine when to turn off the effect, but the envelope handling the volume would be enabled once and then run its course.
However, I haven't tested my theory yet.
Edit: if that works out, you might not even need an ON FRAME based engine, since you could trigger sound from the main program and trigger a new sound effect when needed. Then again if you were to change the pitch etc at the same time the volume envelope runs, you still would need to call the engine per frame, just not trigger the envelope each time.
Edited by carlsson
When envelopes are used, the "command code" for the envelope should be loaded a single time at the start. Otherwise the envelope is "resetted" continuously creating a "motor" noise.
    IF SND = 0 THEN
      sound 4,$0f,$0007
      sound 2,$0BB8,$30
      sound 3,$0800,$0004
    END IF
    snd = snd + 1
if snd = 20 then
  SOUND 4,,0
  SOUND 2,,0
  SOUND 3,,0
  snd = 0
  throw_sound = 0
 end if
end if
    IF SND = 0 THEN
      sound 4,$0f,$0007
      sound 2,$0BB8,$30
      sound 3,$0800,$0004
    END IF
    snd = snd + 1
if snd = 20 then
  SOUND 4,,0
  SOUND 2,,0
  SOUND 3,,0
  snd = 0
  throw_sound = 0
 end if
end if
Thanks @carlsson and @nanochess!!  That is what solved my problem.
