Okay, I've had a filddle with this, and rather than modify the existing firmware, please find attached a single cart version of the firmware.   If you put a file named "AUTORUN.CAR" or "AUTORUN.ROM" in the root directory, it will run automatically on power up. Identification rules for ROMs as described in the manual (standard 8K & 16K or XEGs is assumed depending on the file size). If you want a different type (e.g. 128K AtariMax) - use a CAR file.   It will leave any oth
    • Thanks
    • Like
