DCS+ boilerplate?
Darkhog
Sorry, new to this and keep misspelling stuff. Anyway, I wanted an even simpler template, with no extra variables assigned beyond what's absolutely necessary, empty playfield/sprites and empty main loop.
See if this is stripped enough:
   ;  This program uses the DPC+ kernel.
   set kernel DPC+
   ;  Standard used in North America and most of South America.
   set tv ntsc
   ;  Helps player1 sprites register a collision with the playfield.
   set kernel_options collision(player1,playfield)
   goto __Bank_2 bank2
   bank 2
   temp1=temp1
__Bank_2
   ;  Program Start/Restart
__Start_Restart
   ;  Mutes volume of both sound channels.
   AUDV0 = 0 : AUDV1 = 0
   ;  Clears all normal variables and the extra 9.
   a = 0 : b = 0 : c = 0 : d = 0 : e = 0 : f = 0 : g = 0 : h = 0 : i = 0
   j = 0 : k = 0 : l = 0 : m = 0 : n = 0 : o = 0 : p = 0 : q = 0 : r = 0
   s = 0 : t = 0 : u = 0 : v = 0 : w = 0 : x = 0 : y = 0 : z = 0
   var0 = 0 : var1 = 0 : var2 = 0 : var3 = 0 : var4 = 0
   var5 = 0 : var6 = 0 : var7 = 0 : var8 = 0
   ;  Score colors.
   scorecolors:
   $1E
   $1C
   $1A
   $1A
   $18
   $18
   $16
   $16
end
   ;  Main Loop
__Main_Loop
   ;  Gameplay logic goes here.
   ;  88 rows that are 2 scanlines high.
   DF6FRACINC = 255 ; Background colors.
   DF4FRACINC = 255 ; Playfield colors.
   DF0FRACINC = 128 ; Column 0.
   DF1FRACINC = 128 ; Column 1.
   DF2FRACINC = 128 ; Column 2.
   DF3FRACINC = 128 ; Column 3.
   ;  Displays the screen.
   drawscreen
   goto __Main_Loop
   bank 3
   temp1=temp1
   bank 4
   temp1=temp1
   bank 5
   temp1=temp1
   bank 6
   temp1=temp1
