Yosikuma Posted May 30 Share Posted May 30 So I have been tinkering with IntyBASIC for a bit, and I have decided to go ahead and try to make an adventure game (a la a point and click game, though I feel a pointer may be a waist of my precious MOBs and figuring paths may be a pain!). However, in my mind, the controller would seem to be far more at home in something where you advance a story and solve puzzles than something more action oriented. Before I bite far far far more than I can chew, I had concerns about game size. Since the game would certainly be more dialogue heavy, this is a concern. Would I need to contemplate text compression? Hoping I can show some progress here in due time! 1 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 30 Share Posted May 30 8 hours ago, Yosikuma said: So I have been tinkering with IntyBASIC for a bit, and I have decided to go ahead and try to make an adventure game (a la a point and click game, though I feel a pointer may be a waist of my precious MOBs and figuring paths may be a pain!). However, in my mind, the controller would seem to be far more at home in something where you advance a story and solve puzzles than something more action oriented. Before I bite far far far more than I can chew, I had concerns about game size. Since the game would certainly be more dialogue heavy, this is a concern. Would I need to contemplate text compression? Hoping I can show some progress here in due time! There are many ways to compress text. I've been toying with a similar idea, and the approach I was planning to take is based on a technique employed by Infocom in their Z-Machine. It's rather clever and should be easy to implement. It works like this: They store each character in 5 bits, which allows them to store three characters in two 16-bit words. 5 bits allows up to 32 characters, which is not nearly enough for the full set, but is enough for complete groups of characters like say, all upper-case, or all lower-case. They call these contexts. They use special character codes to switch contexts and treat the text as a stream of characters in different contexts. If you use one context for all English lower-case characters and one for all lower-case characters, that'll take 26 special codes each. There are surely less punctuation characters than 26, and only 10 digits; which means that you can reserve about 6 special characters for contexts. We've already mentioned upper- and lower-case, punctuation and digits, so you have two more special codes to use for additional contexts, like paragraph justification, indentation, emphasis, etc. You could even reserve a special context code for commonly used words, like articles or pronouns, etc., so that you do not have to re-encode "the" and "their," all over the place. Anyway, this gives you a the ability to compact three characters into two DECLEs, which is no small thing. This approach may work better for a text adventure than typical compression because text compression gains typically come with larger texts; and, although your total amount of text may be large, in practice you will only be using a little at a time. You will have to compress the text is smaller chunks, which reduces its efficacy. Anyway, it worked for the Z-Machine, which was ported to some rather tiny platforms, so it may work for the Intellivision. dZ. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 30 Share Posted May 30 For further ideas on how to fit a large program into a small machine, check out the article entitled, er, How To Fit A Large Program Into A Small Machine, by Marc Blank and Stu Galley, veterans from Infocom. https://web.archive.org/web/20130113052554/http://www.csd.uwo.ca/Infocom/Articles/small.html They go through simple explanations on how they implemented other crucial components like linked lists, which is the cornerstone that holds their adventure world together. I think all of these techniques and implementation details can be very useful, as practical lessons from the past, even if you do not intend to build something as sophisticated as a Z-Machine. dZ. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted May 31 Share Posted May 31 It depends on how much dialogue you expect to have. My suggestion would be to code the first few screens, and then having a semi-playable game you can estimate/calculate the size of your dialogs. For a first game it is entirely possible everything can fit without compression. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 6 Share Posted June 6 One other point on this: encoding strings into some compact format should be fine, and actually preferable. However, compression may make text string searches when parsing input, etc. more expensive or impractical. -dZ. Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 6 Share Posted June 6 If it is point and click, there should not be any need for a lexical parser. Only text output to accompany the graphics. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 6 Share Posted June 6 40 minutes ago, carlsson said: If it is point and click, there should not be any need for a lexical parser. Only text output to accompany the graphics. DOH! You are right. Still, unpacking one string at a time may be more practical than extracting a single string from a compressed block. dZ. Quote Link to comment Share on other sites More sharing options...
