8bitwidgets.com Posted June 7, 2023 Share Posted June 7, 2023 (edited) Hi everyone, I felt like the older post I was asking more of a question, might have created confusion. I have working / tested Odyssey 2 adapter cables now available. I have enough to make 5 more pairs if anyone wants them. Just PM me or reply here and I'll let you know. If I run out it's ok I can put you on a short backlist and let you know. I just try to not have a bunch of unused stuff laying around.. (I have too much of that already! ) NOTE: this is only tested with actual 2600 compatible joysticks. I tested several different sega controllers and had odd results. In the video I mention these would work with it, but I should have tested before I said that, which was an assumption on my part. its $25 for a pair of them with O2 KC Munchkin Face on them to distinguish them from my Intellivision Flashback Adapter These are for the flashback of course.. but just imagine KC on there instead and wired correctly for O2.. heh Thanks, Caleb P.S. I'm excited to be able to start work soon on the Wired adapter kit.. I have a wired O2 system now to test against. This will be a kit that gives wired systems make DB9 ports out the back + enclosure to put around your now untethered O2 controllers to become useable both with your system AND existing systems that have removeable controllers. Edited June 7, 2023 by Caleb Garner 1 Quote Link to comment Share on other sites More sharing options...
