RetroBat (Windows 11 EmulationStation Frontend) using .rpk format (MAME64 or Libretro/MAME)
RetroBat (Windows 11 Emulation Station Frontend) using .rpk format (MAME64 or Libretro/MAME)
Why?
* With Batocera I need to reboot my PC go to the BIOS to switch each time between Batocera and Windows (and for laptops, I need to reconfigure the BIOS to disable secure boot)
   I like Batocera, which is a Linux based Emulation Station) running from a USB drive  (it can be installed dedicated on a PC), but I am using this device with Windows and other purposes (e.g. watch TV channels)
   https://forums.atariage.com/topic/335490-batocera-emulation-system-and-ti-994a
* RetroBat solves that issue as it runs on Windows 11 (64 Bit), but for the TI-99/4A it relies on the .zip file structure for roms.
   It has the same Emulation Station interface, but I did not want to redo all the work done for the Batocera configuration
* It is very straight forward to install and to customize it
  The only issues I currently have
   1.  Bezel backdrop does not work (works with Libretro/MAME, not with MAME64 starting from RetroBat, but from command prompt mame it shows the Bezel)
   2.  When using Libretro/MAME it sometimes start the TI-99/4A, sometimes not (very similar issue as in Batocera setup).   MAME64 (v253) is stable in startup
   3.  USB-DB9 Joystick works in MAME64,  but a PS4 controller does not work  (but PS4 controller works with Libretro/MAME)
   4.  Hotkey using a keyboard does not work.   (now using ALT TAB to exit), but the PS4 controller works with SHARE + OPTION buttons as hotkeys to exit)
Posted (edited)
Detailed instructions how to install RetroBat for a TI-99/4A system on Windows 11 (64-bit).
TI99-Retrobat-Setup.zip
  (the directory you can copy it over the installed directories it will overwrite / merge into those directories)
  for /roms/ti99, with preview of images, videos (see the Batocera thread https://forums.atariage.com/topic/335490-batocera-emulation-system-and-ti-994a)
This video is Batocera based, but RetroBat has the same Emulation Station interface:
Edited by globeron
Posted (edited)
Item 1 (Bezel of TI99) and 3 (PS4 controller) seems to be resolved magically on my other PC which I normally use.  For item 2 i use now Mame64.
Only item 4 left. Hotkey on the keyboard with TI99 (other emulators Shift + Esc works).
But I am using the PS4 controller hockey (PS + OPTIONS).
Also updated with another TI-Logo (file called mess.png)  for the system (C:\RetroBat\emulationstation\.emulationstation\themes\es-theme-carbon\art\logos)
Edited by globeron
  • 3 weeks later...
Update:
TI99-Retrobat-Setup-v2.zip
in the logo's directory either delete "mess.svg"  (or overwrite it with a Ti-logo mess.svg) otherwise the MESS logo remains.
Re issue 4 fix  * added the /Retrobat/bios/mame/ini/mame.ini file  (UI_Active    1),  so that the ESC (Keyboard) works to exit back to Retrobat
                     (or create a mame.ini file  using  mame  -createconfig and copy that into the directory above)
Re issue 2 - use MAME64 it is more stable and starts the emulator (Libretro does not start the emulator)
Items to sort out:
Re issue 3 - when using a USB-Controller everything works and sometimes the Bluetooth connected PS4-type controller also works normally.
                  (I have not figured out yet when the PS4 controller works and when not).
Issue 1:
   2.  Fixed (use MAME64) - When using Libretro/MAME it sometimes start the TI-99/4A, sometimes not (very similar issue as in Batocera setup).   MAME64 (v253) is stable in startup
   4.  (Fixed, UI Active  1 in mame.ini)  - Hotkey using a keyboard does not work.   (now using ALT TAB to exit), but the PS4 controller works with SHARE + OPTION buttons as hotkeys to exit)
On 6/10/2023 at 8:59 AM, globeron said:
Why?
I'll try RetroBat, however it's possible to install Windows 11 without TPM 2.0 and Secure Boot creating a bootable USB stick (try Rufus 4.1). ;-)
  • 2 weeks later...
Fixed item 1 - Bezel backdrop
TI-99/4A Bezel.
files are in this zip:
TI99-Retrobat-Setup-v3.zip
For the Bezels, this is the directory that worked for me (using a TI-99/4A and using MAME)
C:\RetroBat\saves\mame\artwork
put here genhorizontal.zip
and horizont.ini in C:\Retrobat\bios\mame\ini
horizont.ini:
# CORE ARTWORK OPTIONS
fallback_artwork genhorizontal
# Uncomment next line to use this for all games
override_artwork genhorizont
These posts helped:
https://mrdo.mameworld.info/mame_artwork_generic.php (e.g. download genhorizont.zip)
https://forums.launchbox-app.com/topic/54304-default-mame-bezels/
(Not working via Retrobat yet to start MAME,  not sure if both Retrobat/Emulstation and MAME can use the Bluetooth PS4 Controllers, but all other systems work fine).
When using MAME directly it works partially.
(Via UI Mode,  press TAB):
* Bluetooth PS4 controller gets detected in MAME under Joystick (number 1 means Joystick 1,  if you have more you see Joystick 2)
* Often I see all 0  under Device ID
* Then I turn off the Bluetooth controller and turned it on, then all is working  (you see these values)
   (this works directly with MAME, but with Retrobat,  it remains all 0 and turn on/off the PS4 controller sometimes shows -65536, etc. but does not work)
7 hours ago, gferluga said:
I follow the instructions but when I select a cart in Mame I get a message that required rom is missing or incorrect.
Please advise...
Thanks in advance.
My guess is that the
C:\RetroBat\roms\ti99  directory  is empty ?  (no .rpk)
(see ti99 directory here):
https://ftp.whtech.com/Cartridges/Batocera/Batocera-ti99v2.zip
4 hours ago, mizapf said:
Please tell us the precise error message; this will likely give the answer.
For the Wireless Controllers issue - there is no error message
(I can see them being connected as 1 and 2, but no input, unless I turn them on/off sometimes it works in MAME,  I guess a bluetooth / Windows issue and if 2 programs use the controllers (retrobat/emulstation and mame)
I am using MAME 256  (but tried earlier versions as well)
When using USB (for Joystick controllers) it works fine (as long they are assigned wireless port 1 and 2 of course,  means to turn of all other controllers as they dynamically might take port 1 and 2)
(it can be configured statically to use port 1 and 2 for the specific controllers I saw)
And your console ROMs? (ti99_4a.zip)
(Note: The RPKs may be put wherever you want; they need not be put in a preset path, since you have to provide the full path name anyway. Only the *.zip files must be put into the rompath.)
I could reproduce this error message when I removed the ti99_4a.zip file, so it seems that your installation does not find the file in the dedicated path. If you have a mame.ini, what does your rompath setting say? (for me, 11th line from the top)
I usually run MAME from a command line, not by clicking the mame executable, so your situation may vary from mine.
Reinstalled from scratch, but no success. Same errors.
From command line I get:
C:\RetroBat\emulators\mame>mame ti99_4a
994a_rom_hb.u610 NOT FOUND (tried in ti99_4a)
994a_rom_lb.u611 NOT FOUND (tried in ti99_4a)
994a_grom0.u500 NOT FOUND (tried in ti99_4a)
994a_grom1.u501 NOT FOUND (tried in ti99_4a)
994a_grom2.u502 NOT FOUND (tried in ti99_4a)
Fatal error: Required files are missing, the machine cannot be run.
6 hours ago, gferluga said:
It's working. I have had to copy the mame.ini file into C:\RetroBat\emulators\mame
glad to hear it works!
I thought when starting MAME from Retrobat it uses the mame.ini from this directory - C:\RetroBat\bios\mame\ini   (I will add it to this in the TI-99.zip file)
and starting mame directly it uses C:\RetroBat\emulators\mame
(and similar with the bezel artwork it uses another directory from the saves\mame\artwork directory vs  \emulators\mame\artwork
