+Gemintronic Posted June 21 Share Posted June 21 So, using Al_Nafurs technique I was able to use 0, 4, 8 and C as sprite data. But, since I no not what I be do, I can't figure out how to set the pointers for the other digits. So far this is what I got: When a is 0/$00 then I get sprite data for "0" When a is 32/$20 then I get sprite data for "4" When a is 64/$40 then I get sprite data for "8" When a is 96/$60 then I get sprite data for "C" const _Pxhi_ScrSprite = >scoretable const _Pxlo_ScrSprite = <scoretable player1pointerlo = _Pxlo_ScrSprite + a player1pointerhi = _Pxhi_ScrSprite + a scoresprite001.bas Quote Link to comment Share on other sites More sharing options...
+Karl G Posted June 22 Share Posted June 22 scoretable is where the score digit data starts, starting at digit 0. Each digit is 8 lines long, one byte per line, so each digit after 0 is 8 bytes more, up to adding 72 for digit 9. Anything after 9 depends on what you have defined, e.g. hex digits or symbols. You should have to only add a to player1pointerlo and not player1pointerlo as the scoretable data is page-aligned, and the high byte wouldn't increment within the range of the score digits. 1 Quote Link to comment Share on other sites More sharing options...
