Black screen on Atari, but in Stella is working.
kikipdph
Sometimes it happens that a game works on the Stella emulator but not on the Atari console. Later, by moving the "call sub" from the upper section to a lower position towards "drawscreen," I solved that problem. Now I have the same problem again, but the "call sub" is close to "drawscreen." Essentially, does anyone know exactly what is causing the problem, so that I can understand what it is about? DPC+
Edited by kikipdph
If you post the file of your source code, then one of us could possibly help figuring out what's going on. My first guess as a stab in the dark: a gosub without a return statement.
The game works on the emulator but not on the Atari. And this happens with the latest version of Batari BASIC. If you slightly move the "Call Sub" towards "drawscreen", the game works on the Atari too. Everything else is the same, no changes in the code, just the positions. I'm using "Return" and that's not the issue. Similarly, in one game, when I placed "goto" at the beginning of the loop, the game didn't work on the Atari. That "goto" was exiting the loop. When I moved it towards "drawscreen", the game worked. This didn't happen in the previous version of BB, and it's very strange.
Here's an example where it doesn't work on the Atari.
__Main_Loop
   ;  88 rows that are 2 scanlines high.
   DF6FRACINC = 255 ; Background colors.
   DF4FRACINC = 255 ; Playfield colors.
   DF0FRACINC = 128 ; Column 0.
   DF1FRACINC = 128 ; Column 1.
   DF2FRACINC = 128 ; Column 2.
   DF3FRACINC = 128 ; Column 3.
   ;  Simple fix for the top two lines having the same color.
   asm
   lda DF6FRACDATA
   lda DF4FRACDATA
end
 gosub __Pozadina_10
     if n = 1 then goto iskok
        if joy0fire then n = 1 :  goto skiptitle
iskok
        if !joy0fire then n = 0
       drawscreen
   goto __Main_Loop
skiptitle
Here's an example where it works. (two drawscreen)
__Main_Loop
   asm
   lda DF6FRACDATA
   lda DF4FRACDATA
end
  drawscreen
 gosub __Pozadina_10
iskok
       drawscreen
   goto __Main_Loop
The subroutine being called isn't included in the source. If you can, just attach your whole source file to the post, which makes things easier to troubleshoot. If you want to keep the source private, then I would be willing to have a look at it myself if you send it via private message.
Posted (edited)
Let's say the sub that calls is empty. You won't find an error in the code. Put the same code in an older version of BB and it will work. A substance is some kind of structure or lack of memory on a real atari. The emulator shows no errors and game works.
Just move the callsub position or add another drawscreen and it works on the atari. But I don't know why that is. It's my PC. Is it my way of structuring or something else?
Edited by kikipdph
Without code to demonstrate the issue, then it's hard for me to identify the root cause of the issue. If you could produce a minimal example that shows a blank screen where it shouldn't (whether on the Atari or Stella) then that would be helpful. If not, try turning on developer settings on Stella, and try running the version that just shows the blank screen. The results may be different than when you use the player settings, and you might possibly get a useful message that could show the possible cause.
Because I successfully fixed it, I don't have the exact code now when it didn't work on Atari. When it happens again, I will post the code. For now, I can only state that I fix it by adding another "drawscreen" or by moving "go sub" closer to "drawscreen" in the loop.
When I first started using BASIC languages, I didn't use SAVE AS. If I messed something up, I couldn't go back to a previous version of the program. I'd spend hours or days trying to figure out what I did wrong. I eventually got a little wiser and used SAVE AS before making any major changes to the code.
https://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#use_save_as
  • Sad 1
Same. I usually make a new save each day I start work. Could be minor or could be major. If I decide to make a big change after work in a certain day or I want to try a couple different methods I will then make a second save file with a letter and then each branch would maintain that letter designation until it becomes the main save I work off.
I copy the project and place it in another folder. That serves as my backup. But in this example, the game is finished and everything is working, so I didn't save when it wasn't working on the Atari. I thought someone might have had similar issues and knows the answer, so I posted this. Is it happening only to me, and logically I can't figure out what the problem is. I know how to "fix" it, but it's not really fixing because there are no actual errors in the code.
I make a new folder for a new project, then SAVE AS my .bas file before making any significant changes. Some programs I've worked on have had a boatload of versions. Here's an example:
That's just what would fit within a screenshot. It keeps going and going.
I know I have had similar, though not exactly the same issues.  Where everything seemed fine and worked good in emulation but it would give me issues on hardware and it would sometimes be something like I accidentally left a colon somewhere.
I think those are some kind of Batari Basic bugs because I didn't have that problem in the older version. I've also encountered some other bugs that are inexplicable and illogical.
