Retrocactus Posted July 28, 2023 Share Posted July 28, 2023 I've had this 800xl in my garage for well over a decade. It appears to work fine (I'm using a newly made USB power supply cable and composite out cable) with my carts, Fujinet, etc. But I can't get it into self test mode to see if anything has gone bad. Holding OPTION down at boot (Fujinet not connected) just seems to freeze things on the blue screen with a cursor. Any tips to get it to work or alternate testing apps I can load to do it via Fujinet? Or should I just not worry about it since everything else appears to be working just fine? It appears to be a Rev B (Peek 43234 returned 96) and is NTSC (I'm in Canada) Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted July 28, 2023 Share Posted July 28, 2023 (edited) It sounds like the Option key is being detected. I'd try re-seating the MMU (U3) and the PIA (U23) first. Edited July 28, 2023 by reifsnyderb 1 Quote Link to comment Share on other sites More sharing options...
+David_P Posted July 28, 2023 Share Posted July 28, 2023 In BASIC, try this program: 10 PRINT PEEK(53279):GOTO 10 RUN Check that the number is changing depending on which console key (START, SELECT OPTION) is being pressed. Quote Link to comment Share on other sites More sharing options...
Retrocactus Posted July 28, 2023 Author Share Posted July 28, 2023 I should mention that the Option key definitely works…it’s needed for Fujinet to boot disk images and works just fine. 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted July 28, 2023 Share Posted July 28, 2023 Have you booted to basic and typed bye or dos? Quote Link to comment Share on other sites More sharing options...
Retrocactus Posted July 28, 2023 Author Share Posted July 28, 2023 Just now, kheller2 said: Have you booted to basic and typed bye or dos? Yes. BYE doesn’t do anything. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted July 28, 2023 Share Posted July 28, 2023 1 hour ago, Retrocactus said: Yes. BYE doesn’t do anything. If the MMU or PIA isn't working properly, BYE may not work. I'd re-seat those chips first and see if it changes anything. If it doesn't, a PIA can easily be obtained and an MMU can either be obtained or programmed. 1 Quote Link to comment Share on other sites More sharing options...
