+Vorticon Posted August 8 Share Posted August 8 Algorithm to draw a circle What else have you got? 4 Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 8 Share Posted August 8 Yours is nicer .... 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 8 Share Posted August 8 Can I play? You could use 30 sprites at 12 degree spacing... \ CIRClE of sprites Aug 2023 Brian Fox \ NEEDS DUMP FROM DSK1.TOOLS NEEDS SIN FROM DSK1.TRIG NEEDS SPRITE FROM DSK1.DIRSPRIT DECIMAL 14 CONSTANT magenta 15 CONSTANT gray 92 CONSTANT Xbias 122 CONSTANT Ybias 130 CONSTANT Scale 128 CONSTANT BALL S" 3C7EFFFFFFFF7E3C" BALL CALLCHAR : SIN() ( n -- x) 12 * SIN Scale / Xbias + ; : COS() ( n -- y) 12 * COS Scale / Ybias + ; : CIRCLE 30 0 DO BALL magenta I COS() I SIN() I SPRITE LOOP ; : RUN PAGE CIRCLE KEY DROP DELALL ; sprite-circle.mp4 6 Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted August 8 Share Posted August 8 Circle Illusion.mov 3 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 8 Share Posted August 8 ... and now a weird one ... based on the distance from the center call clear R=10 D=5 PX = 15 PY = 12 R2 = R * R for y=1 to 24 for x=1 to 32 if abs((Px-X)*(Px-X)+(Py-Y)*(Py-Y)-R2)<D then c=42 else c=32 call hchar(y,x,c) next x next y call waitkey When you change to "120 D=32" you get: 4 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 8 Author Share Posted August 8 3 hours ago, Reciprocating Bill said: Circle Illusion.mov Ooooh! Very cool! Source code please? 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 8 Author Share Posted August 8 5 hours ago, SteveB said: Yours is nicer .... Interesting way of doing this. Is it faster than my version? 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 8 Author Share Posted August 8 1 hour ago, SteveB said: ... and now a weird one ... based on the distance from the center call clear R=10 D=5 PX = 15 PY = 12 R2 = R * R for y=1 to 24 for x=1 to 32 if abs((Px-X)*(Px-X)+(Py-Y)*(Py-Y)-R2)<D then c=42 else c=32 call hchar(y,x,c) next x next y call waitkey When you change to "120 D=32" you get: I'm having a little trouble understanding that one. Quote Link to comment Share on other sites More sharing options...
jrhodes Posted August 8 Share Posted August 8 4 hours ago, TheBF said: Can I play? You could use 30 sprites at 12 degree spacing... \ CIRClE of sprites Aug 2023 Brian Fox \ NEEDS DUMP FROM DSK1.TOOLS NEEDS SIN FROM DSK1.TRIG NEEDS SPRITE FROM DSK1.DIRSPRIT DECIMAL 14 CONSTANT magenta 15 CONSTANT gray 92 CONSTANT Xbias 122 CONSTANT Ybias 130 CONSTANT Scale 128 CONSTANT BALL S" 3C7EFFFFFFFF7E3C" BALL CALLCHAR : SIN() ( n -- x) 12 * SIN Scale / Xbias + ; : COS() ( n -- y) 12 * COS Scale / Ybias + ; : CIRCLE 30 0 DO BALL magenta I COS() I SIN() I SPRITE LOOP ; : RUN PAGE CIRCLE KEY DROP DELALL ; sprite-circle.mp4 After reading the first post and seeing that we only ever had 2x "*'s" on the same line, sprites is exactly what came to mind. But you did it in Forth instead of XB. How about something else now?: examples of programs to display the golden mean. Quote Link to comment Share on other sites More sharing options...
Reciprocating Bill Posted August 9 Share Posted August 9 38 minutes ago, Vorticon said: Ooooh! Very cool! Source code please? It's written in FBForth, and running on real iron, so it's tricky to get a listing. As a workaround I've pasted the four screens of which the program is composed here - not sure what the result will be... 3 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 9 Share Posted August 9 Alternatively you could paste your block file in a post here and we could get at it that way. (I have wanted to see this code since the first day you posted it back when) Oops: It's on real iron so that might be tricky. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 9 Share Posted August 9 39 minutes ago, jrhodes said: After reading the first post and seeing that we only ever had 2x "*'s" on the same line, sprites is exactly what came to mind. But you did it in Forth instead of XB. How about something else now?: examples of programs to display the golden mean. Whenever I said "Great minds think alike" to my mother she would say "Or fools seldom differ". We can choose whatever fits. Never did a Golden mean program. Now I have to go read stuff. 2 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 9 Share Posted August 9 100 f=33::n=f::call clear 110 x=cos(i)*80+90::y=sin(i)*80+90::gosub 120::i=i+0.05::goto 110 120 c=int(x/8)::l=int(y/8)::call gchar(l+1,c+1,g)::if g>=f then 140 130 g=n::n=n+1::call char(g,"")::call hchar(l+1,c+1,g) 140 call charpat(g,p$)::cx=int(x)-8*c::cy=int(y)-8*l::p=int(cx/4)+cy*2::h=cx-int(cx/4)*4 150 p$=seg$(p$,1,p)&seg$("8421",h+1,1)&seg$(p$,p+2,15)::call char(g,p$)::return run 8 Quote Link to comment Share on other sites More sharing options...
SteveB Posted August 9 Share Posted August 9 19 hours ago, Vorticon said: I'm having a little trouble understanding that one. I am testing the distance of each "pixel" from the center of the circle P(Px,Py). The distance would actually be R = sqr((Px-X)^2+(Py-Y)^2) . If this value is the radius R, I would draw the asterisk. The square root is an expensive operation I actually don't need, I just square the equation: R^2 = (Px-X)^2 + (Py-Y)^2 Since the circle hardly hit exactly on the top left edge of character, I introduce a "tolerance" Delta 😧 abs( (Px-X)^2+(Py-Y)^2) - R^2 ) < D abs((Px-X)*(Px-X)+(Py-Y)*(Py-Y)-R2)<D I hope this is comprehensible, I never had to explain mathematics in english, so please apologize if translated a mathematics term incorrectly to english. Steve 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 9 Share Posted August 9 12 hours ago, sometimes99er said: 100 f=33::n=f::call clear 110 x=cos(i)*80+90::y=sin(i)*80+90::gosub 120::i=i+0.05::goto 110 120 c=int(x/8)::l=int(y/8)::call gchar(l+1,c+1,g)::if g>=f then 140 130 g=n::n=n+1::call char(g,"")::call hchar(l+1,c+1,g) 140 call charpat(g,p$)::cx=int(x)-8*c::cy=int(y)-8*l::p=int(cx/4)+cy*2::h=cx-int(cx/4)*4 150 p$=seg$(p$,1,p)&seg$("8421",h+1,1)&seg$(p$,p+2,15)::call char(g,p$)::return run That kind blows my mind. Well done. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted August 9 Share Posted August 9 I forgot that I have a new Graphics2 mode library so I had to give that a go. It's not really fast but it plots. \ Circle in bitmap mode for Camel99 Forth NEEDS DUMP FROM DSK1.TOOLS NEEDS VALUE FROM DSK1.VALUES NEEDS MARKER FROM DSK1.MARKER NEEDS PLOT FROM DSK1.GRAPHICS2 NEEDS SIN FROM DSK1.TRIG DECIMAL 96 VALUE Xbias 127 VALUE Ybias 130 VALUE Scale 0 VALUE XCNTR 0 VALUE YCNTR : ENUM ( 0 <text> -- n) DUP CONSTANT 1+ ; 0 ( set 1st color) ENUM TRANS ENUM BLACK ENUM GREEN ENUM LIME ENUM BLUE ENUM SKY ENUM RED ENUM CYAN ENUM RUST ENUM ORANGE ENUM YELLOW ENUM LEMON ENUM OLIVE ENUM MAGENTA ENUM GRAY ENUM WHITE DROP : PAINT ( color ) 4 LSHIFT INK ! ; : SIN() ( n -- x) SIN Scale / Ybias + ; : COS() ( n -- y) COS Scale / Xbias + ; : DIAMETER ( n -- n') 20000 SWAP / TO Scale ; : CENTER ( 0 0 -- ) 2/ TO YCNTR 2/ TO XCNTR ; : CIRCLE ( x y diameter -- ) DIAMETER CENTER 360 0 DO I SIN() XCNTR + I COS() YCNTR + PLOT LOOP ; DECIMAL : RUN GRAPHICS2 RED PAINT -70 0 10 CIRCLE MAGENTA PAINT -60 0 40 CIRCLE LIME PAINT -50 0 80 CIRCLE YELLOW PAINT 30 0 190 CIRCLE BEGIN KEY? UNTIL TEXT ; CIRCLES.mp4 6 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted August 10 Share Posted August 10 Now I got tempted to try this in Pascal. Turtlegraphics is convenient for a circle, since you can repeat the sequence draw a line X long then turn 360/Y degrees and repeat that Y times, and then you have a circle. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 10 Author Share Posted August 10 19 hours ago, SteveB said: I am testing the distance of each "pixel" from the center of the circle P(Px,Py). The distance would actually be R = sqr((Px-X)^2+(Py-Y)^2) . If this value is the radius R, I would draw the asterisk. The square root is an expensive operation I actually don't need, I just square the equation: R^2 = (Px-X)^2 + (Py-Y)^2 Since the circle hardly hit exactly on the top left edge of character, I introduce a "tolerance" Delta 😧 abs( (Px-X)^2+(Py-Y)^2) - R^2 ) < D abs((Px-X)*(Px-X)+(Py-Y)*(Py-Y)-R2)<D I hope this is comprehensible, I never had to explain mathematics in english, so please apologize if translated a mathematics term incorrectly to english. Steve Ah ha! Very nice! 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted August 10 Author Share Posted August 10 On 8/9/2023 at 3:46 AM, sometimes99er said: 100 f=33::n=f::call clear 110 x=cos(i)*80+90::y=sin(i)*80+90::gosub 120::i=i+0.05::goto 110 120 c=int(x/8)::l=int(y/8)::call gchar(l+1,c+1,g)::if g>=f then 140 130 g=n::n=n+1::call char(g,"")::call hchar(l+1,c+1,g) 140 call charpat(g,p$)::cx=int(x)-8*c::cy=int(y)-8*l::p=int(cx/4)+cy*2::h=cx-int(cx/4)*4 150 p$=seg$(p$,1,p)&seg$("8421",h+1,1)&seg$(p$,p+2,15)::call char(g,p$)::return run What devious mind came up with this algorithm???? It took me almost an hour to understand how it works while tracing it on paper. Outstanding! I had done pseudo hires with character redefinition in the past (archimede's hat), but nothing as elegant as this... 4 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 10 Share Posted August 10 38 minutes ago, Vorticon said: What devious mind came up with this algorithm???? It took me almost an hour to understand how it works while tracing it on paper. Outstanding! I had done pseudo hires with character redefinition in the past (archimede's hat), but nothing as elegant as this... I got more ideas, but only played around for fun ... someday ... 😉 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 10 Share Posted August 10 CALL POKEV might be slightly more elegant ... 🍺(Mini Memory) ... Didn't even look at RXB ... Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 10 Share Posted August 10 Bresenham's circle algorithm. Only integer math. 10 CALL CLEAR::CALL CHAR(42,"FFFFFFFFFFFFFFFF") 20 XC=15::YC=12::R=11 30 X=0::Y=R 40 D=5-4*R 50 DA=(-2*R+5)*4::DB=12 60 IF Y<X THEN 170 70 CALL HCHAR(YC+Y,XC+X,42) 80 CALL HCHAR(YC+Y,XC-X,42) 90 CALL HCHAR(YC-Y,XC+X,42) 100 CALL HCHAR(YC-Y,XC-X,42) 110 CALL HCHAR(YC+X,XC+Y,42) 120 CALL HCHAR(YC+X,XC-Y,42) 130 CALL HCHAR(YC-X,XC+Y,42) 140 CALL HCHAR(YC-X,XC-Y,42) 150 IF D>0 THEN X=X+1::Y=Y-1::D=D+DA::DA=DA+16::DB=DB+4::GOTO 60 160 X=X+1::D=D+DB::DA=DA+8::DB=DB+8::GOTO 60 170 GOTO 170 4 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 10 Share Posted August 10 11 minutes ago, Asmusr said: Bresenham's circle algorithm. Only integer math. 10 CALL CLEAR::CALL CHAR(42,"FFFFFFFFFFFFFFFF") 20 XC=15::YC=12::R=11 30 X=0::Y=R 40 D=5-4*R 50 DA=(-2*R+5)*4::DB=12 60 IF Y<X THEN 170 70 CALL HCHAR(YC+Y,XC+X,42) 80 CALL HCHAR(YC+Y,XC-X,42) 90 CALL HCHAR(YC-Y,XC+X,42) 100 CALL HCHAR(YC-Y,XC-X,42) 110 CALL HCHAR(YC+X,XC+Y,42) 120 CALL HCHAR(YC+X,XC-Y,42) 130 CALL HCHAR(YC-X,XC+Y,42) 140 CALL HCHAR(YC-X,XC-Y,42) 150 IF D>0 THEN X=X+1::Y=Y-1::D=D+DA::DA=DA+16::DB=DB+4::GOTO 60 160 X=X+1::D=D+DB::DA=DA+8::DB=DB+8::GOTO 60 170 GOTO 170 Quick and dirty ... and why not ... 👍 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 11 Share Posted August 11 22 hours ago, sometimes99er said: Quick and dirty ... and why not ... 👍 It's definitely quick, but whether it's dirty is more of an individual taste. 🙂 The algorithm only calculates the points for the 45 degrees from the top of the circle moving clockwise until it meets the diagonal where x=y . The remaining 7/8s of the circle are plotted by flipping and mirroring the points in that first section (any algorithm could do the same). The algorithm ensures that each point on the circle is plotted exactly once. As you can see from the code in lines 150-160, for each step it either moves left (starting from the top) or left and down based on the value of D. There are many sources on the net explaining how that works. AFAIK, it's the algorithm to choose if you want to draw a circle fast. 5 Quote Link to comment Share on other sites More sharing options...
jschultzpedersen Posted August 11 Share Posted August 11 Hi I wrote an article for the TI*MES magazine, vol.2 no. 20. June 2023,that is relevant to this discussion. The article discussed using Extended Basic - compiled, of course - to plot graphics, and supplied code for plotting pixels, lines and circles etc. In case you do not know it... The TI*MES magazine is a magazine, issued twice per year, from the TIUGUK user group. The code supplied here is a partial extract of that article. It demonstrates the basic task of redefining character patterns continuously - like it is done in LOGO II. I have also included the code for drawing circles and how to do clipping. sub setclip(ymin,xmin,ymax,xmax,clip()) if ymin<1 or ymin=0 then ymin=1 else if ymin>192 then ymin=192 if xmin<1 or xmin=0 then xmin=1 else if xmin>256 then xmin=256 if ymax>192 or ymax=0 then ymax=192 else if ymax<1 then ymax=1 if xmax>256 or xmax=0 then xmax=256 else if xmax<1 then xmax=1 if xmin>xmax then tmp=xmax :: xmax=xmin :: xmin=tmp if ymin>ymax then tmp=ymax :: ymax=ymin :: ymin=tmp clip(1)=ymin :: clip(2)=xmin :: clip(3)=ymax :: clip(4)=xmax subend sub plotpix(x,y,ch,clip()) if x<clip(1) or y<clip(2) or x>clip(3) or y>clip(4) then subexit hx$="0123456789ABCDEF" fx=int((x-1)/8)+1 :: fy=24-int((y-1)/8) px=x-8*fx+8 :: py=1-y+8*(25-fy) hex=px-int(px/4)*4 :: hex=hex-(hex=0)*4 :: hex=2^(4-hex) call gchar(fy,fx,chc) :: call charpat(chc,ch$) if chc=32 then chc=ch :: ch=ch+1 :: call char(chc,"0") c=2*(py-1)+2+(px<5) :: tmp$=seg$(ch$,c,1) :: tmp=(pos(hx$,tmp$,1)-1) or hex nch$=seg$(ch$,1,c-1)&seg$(hx$,tmp+1,1)&seg$(ch$,c+1,16-c) call char(chc,nch$) :: call hchar(fy,fx,chc) subend Drawing circles or parts of circles normally depend on the use of trig functions like SIN and COS. They are available in Extended Basic, but they are not supported by the compiler, because it only works with integers. Drawing entire circles can still be done easily with the equation x^2 + y^2 = r^2. But drawing parts of a circle is hard without the trig functions. This routine therefore always draws an entire circle. I should add that the manual for the compiler has an example of how to add your own SIN tables to a program. So, it can be done. sub circle(x2,y2,r,ch,clip(),cx,cy) cx=x2 :: cy=y2 d=int(r*7/10) for dy=-d to d dx=int(sqr(abs(r^2-dy^2))) call plotpix(x2+dx,y2+dy,ch,clip()) call plotpix(x2-dx,y2+dy,ch,clip()) next dy for dx=-d to d dy=int(sqr(abs(r^2-dx^2))) call plotpix(x2+dx,y2+dy,ch,clip()) call plotpix(x2+dx,y2-dy,ch,clip()) next dx subend Notice that the center of the circle may lie outside the clipped area (usually the screen area). Only those parts of the circle, that are inside the clipped area, will be drawn. One benefit if this is, that you can draw, say, a half-circle by redefining the clipping area, so the other part is chopped off. Here is an example: SETCLIP(100,0,0,0,ch,clip()) :: CIRCLE(100,100,50,ch,clip(),cx,cy) This code will draw a circle with its center at 100,100 and a radius of 50. But since only pixels larger than XMIN, which is 100, are drawn, we get a half-circle. Of course, being Extended Basic - even compiled - it cannot compete speed wise with solutions in Forth or Assembler. But you do get pseudo HIRES graphics in the bargain - until you run out of ink, that is! regards Jesper 3 Quote Link to comment Share on other sites More sharing options...
