tibasic Posted August 10 Share Posted August 10 (edited) Here's a lunar lander type game. It's taken a couple of years to finish it because it got a bit too complex but I picked it up again recently and managed to finish it. The idea of the game is you have to collect cargo from an asteroid belt and deliver to the landing pad. You can land without the cargo but you get less points. There's the possibility to refuel as well. There are different planets and moons to land on. At the end of the game a table is presented of your scores for each planet or moon. The engines of the landers are designed for each particular gravity. So for the moon the engines are quite weak and slow to accelerate the lander. So that needs to be taken into account when moving around. The name of the file on the disk is CARGO. Listing is below in the spoiler thing. Spoiler 100 A$(8)="00000000000000FF" 110 A$(7)="000000000000FF" 120 A$(6)="0000000000FF" 130 A$(5)="00000000FF" 140 A$(4)="000000FF" 150 A$(3)="0000FF" 160 A$(2)="00FF" 170 A$(1)="FF" 180 RESTORE 4220 190 FOR I=1 TO 22 200 READ C1,C2$ 210 CALL CHAR(C1,C2$) 220 NEXT I 230 CALL CLEAR 240 CALL SCREEN(11) 250 PRINT " C A R G O L A N D E R"::::: 260 PRINT "COLLECT THE CARGO AND TAKE":: 270 PRINT "IT TO THE LANDING PAD":: 280 PRINT "E MAXIMUM THRUST" 290 PRINT "W MEDIUM THRUST" 300 PRINT "X ZERO THRUST" 310 PRINT "S LEFT" 320 PRINT "D RIGHT":: 330 PRINT "PAD TURNS RED IF GOING UP":: 340 PRINT "GO SIDEWAYS LANDER TURNS RED"::::: 350 PRINT " P R E S S A N Y K E Y" 360 CALL KEY(0,K,S) 370 IF S=0 THEN 360 380 CALL CLEAR 390 PLANET=0 400 DIFFI=2 410 TIME=65*(4-DIFFI) 420 REM 430 CALL SCREEN(2) 440 TOTAL=MASS(1)+MASS(2)+MASS(3)+MASS(4)+MASS(5)+MASS(6)+MASS(7)+MASS(8) 450 PLANET=PLANET+1 460 IF PLANET=9 THEN 1070 ELSE 560 470 PRINT ::::"TOTAL SCORE:";INT(TOTAL)::: 480 PRINT "SCORE BREAKDOWN:":: 490 FOR I=1 TO 8 500 PRINT PLNT$(I);" ";TAB(11);INT(MASS(I)) 510 MASS(I)=0 520 NEXT I 530 PRINT :::: 540 INPUT "PRESS ENTER TO PLAY AGAIN":B$ 550 GOTO 390 560 ON PLANET GOTO 570,630,700,760,830,890,960,1020 570 PLNT$(1)="MERCURY" 580 M_PLANET=3.3E23 590 SURFAC=2.44E6 600 SKY=2 610 SUR=5 620 GOTO 1070 630 PLNT$(2)="VENUS" 640 M_PLANET=4.87E24 650 SURFAC=6.05E6 660 SKY=11 670 SKY2=12 680 SUR=7 690 GOTO 1070 700 PLNT$(3)="THE MOON" 710 M_PLANET=7.35E22 720 SURFAC=1.74E6 730 SKY=2 740 SUR=15 750 GOTO 1070 760 PLNT$(4)="MARS" 770 M_PLANET=6.418542E23 780 SURFAC=3389920 790 SKY=10 800 SKY2=9 810 SUR=7 820 GOTO 1070 830 PLNT$(5)="IO" 840 M_PLANET=8.93E22 850 SURFAC=1.81E6 860 SKY=2 870 SUR=12 880 GOTO 1070 890 PLNT$(6)="TITAN" 900 M_PLANET=1.35E23 910 SURFAC=2.58E6 920 SKY=4 930 SKY2=3 940 SUR=9 950 GOTO 1070 960 PLNT$(7)="TITANIA" 970 M_PLANET=3.49E21 980 SURFAC=0.79E6 990 SKY=2 1000 SUR=8 1010 GOTO 1070 1020 PLNT$(8)="TRITON" 1030 M_PLANET=2.14E22 1040 SURFAC=1.35E6 1050 SKY=15 1060 SUR=16 1070 IF PLANET>1 THEN 1080 ELSE 1130 1080 IF (PLANET>1)*(MASS(PLANET-1)>0)THEN 1090 ELSE 1130 1090 P$="POINTS FOR LANDING ARE "&STR$(POINTS+GBARS*1000) 1100 Y=3 1110 X=19 1120 GOSUB 2900 1130 IF PLANET=9 THEN 470 1140 GBARS=0 1150 V1=10 1160 V2=5 1170 M_LDR=50000.0 1180 FUEL=12000.0 1190 M=M_LDR 1200 MAXT=300000 1210 ISP=327.0*9.81 1220 W=0.0 1230 V=V1 1240 ALT=980 1250 TH_ALT=1000 1260 TK=1 1270 PI=4*ATN(1) 1280 FOR I=1 TO 16 1290 CALL COLOR(I,16,1) 1300 NEXT I 1310 G=6.67E-11*M_PLANET/SURFAC^2 1320 MAXT=INT(M_LDR*(G+V1*V1/TH_ALT))*(4-DIFFI) 1330 FUEL=INT((TIME*MAXT/ISP)/2) 1340 PMASS=M_LDR-FUEL 1350 PRINT :::"GET READY FOR ";PLNT$(PLANET)::: 1360 IF G>3.3 THEN 1380 1370 PRINT PLNT$(PLANET);" HAS LOW GRAVITY"::: 1380 IF (G>3.3)*(G<6.6)THEN 1390 ELSE 1400 1390 PRINT PLNT$(PLANET);" HAS MEDIUM GRAVITY"::: 1400 IF G>6.6 THEN 1410 ELSE 1420 1410 PRINT PLNT$(PLANET);" HAS HIGH GRAVITY"::: 1420 M_BAR=FUEL*0.5 1430 POINTS=PLANET*100 1440 PRO$="" 1450 INPUT "PRESS ENTER TO PROCEED":PRO$ 1460 IF PRO$="" THEN 1470 ELSE 1450 1470 SC=INT(TH_ALT/22) 1480 SC2=INT(60/12) 1490 WR=ABS(W*SURFAC) 1500 DR=INT(RND*30*SC)+1 1510 OLD_DR=DR 1520 OLD_ALT=ALT 1530 ZOOM=0 1540 CALL CLEAR 1550 CALL SCREEN(SKY) 1560 FOR I=1 TO 16 1570 CALL COLOR(I,16,1) 1580 NEXT I 1590 CALL COLOR(14,14,1) 1600 CALL COLOR(12,SUR,1) 1610 CALL COLOR(11,9,1) 1620 GOSUB 3010 1630 CALL CHAR(145,"18244281817E42E7") 1640 IF (PLANET=1)+(PLANET=3)+(PLANET=5)+(PLANET=7)+(PLANET=8)THEN 1650 ELSE 1660 1650 CALL CHAR(145,"3C42423C427E42E7") 1660 CALL COLOR(15,16,1) 1670 CALL CHAR(152,"FEFEFEFEFEFEFE00") 1680 CALL COLOR(16,16,1) 1690 P$="FUEL:" 1700 Y=1 1710 X=1 1720 GOSUB 2900 1730 P$="FINE POS Y: X:" 1740 Y=1 1750 X=2 1760 GOSUB 2900 1770 DT=1 1780 V_DESC=0 1790 OLD_ALT=ALT 1800 REM START 1810 CALL KEY(0,K,S) 1820 IF K=ASC("D")THEN 1830 ELSE 1840 1830 WR=WR+10 1840 IF K=ASC("S")THEN 1850 ELSE 1860 1850 WR=WR-10 1860 IF ABS(WR)>0 THEN 1870 ELSE 1890 1870 CALL COLOR(15,7,1) 1880 GOTO 1910 1890 IF WR=0 THEN 1900 ELSE 1910 1900 CALL COLOR(15,16,1) 1910 DV=V-V1 1920 IF V>0 THEN 1930 ELSE 1940 1930 CALL COLOR(11,16,1) 1940 IF V<=0 THEN 1950 ELSE 1960 1950 CALL COLOR(11,9,1) 1960 IF V<V1 THEN 1970 ELSE 1990 1970 THRUST=0 1980 GOTO 2020 1990 THRUST=TK*(DV/DT+G)*M 2000 IF THRUST>MAXT THEN 2010 ELSE 2020 2010 THRUST=MAXT 2020 IF (M_LDR-M)>=FUEL THEN 2030 ELSE 2070 2030 THRUST=0 2040 TK=0 2050 M=M_LDR-FUEL 2060 GOTO 2160 2070 IF K=ASC("E")THEN 2080 ELSE 2090 2080 THRUST=MAXT 2090 IF K=ASC("X")THEN 2100 ELSE 2110 2100 THRUST=0 2110 IF K=ASC("W")THEN 2120 ELSE 2130 2120 THRUST=MAXT*0.5 2130 A=THRUST/M 2140 CALL COLOR(14,1-15*(THRUST>0),1) 2150 CALL SOUND(-2000,-7,30-THRUST*30/MAXT) 2160 V=V+G*DT 2170 A=THRUST/M 2180 V=V-A*DT 2190 ALT=ALT-V*DT 2200 IF ALT>1000 THEN 2210 ELSE 2230 2210 ALT=1000 2220 V=V1 2230 DR=DR+WR 2240 RATE=THRUST/ISP 2250 M=M-TK*RATE*DT 2260 IF ((ALT-PAD)>60)*(ZOOM=0)THEN 2270 ELSE 2290 2270 GOSUB 3460 2280 GOTO 2320 2290 IF (XPOS>=15)*(XPOS<=17)THEN 2300 ELSE 2270 2300 IF (ALT-PAD)<=5 THEN 2330 2310 GOSUB 3780 2320 GOTO 1800 2330 IF OBJ=112 THEN 2350 ELSE 2340 2340 IF (OBJ=120)+(OBJ=121)+(OBJ=122)+(OBJ=123)THEN 2450 2350 IF ZOOM=1 THEN 2360 ELSE 2390 2360 CALL HCHAR(YPOS,1,32,32) 2370 CALL CHAR(42,A$(1)) 2380 CALL HCHAR(13,1,42,32) 2390 IF V>V2 THEN 2450 2400 CALL SOUND(150,2000,0) 2410 P$="WELCOME TO "&PLNT$(PLANET) 2420 POINTS=INT((FUEL-(M_LDR-M))*1000/FUEL) 2430 MASS(PLANET)=POINTS+GBARS*1000 2440 GOTO 2530 2450 IF ZOOM=0 THEN 2510 2460 CALL HCHAR(1,6,96,INT(V)) 2470 CALL HCHAR(12,15,103,3) 2480 CALL HCHAR(11,15,32,3) 2490 CALL HCHAR(10,15,32,3) 2500 GOTO 2520 2510 CALL HCHAR(YPOS,XPOS,103) 2520 P$="CRASH ON "&PLNT$(PLANET) 2530 X=17 2540 Y=7 2550 GOSUB 2900 2560 FOR DELAY=1 TO 500 2570 NEXT DELAY 2580 TIME=TIME-(3-DIFFI)*8 2590 GOTO 420 2600 RESTORE 4290 2610 FOR I=1 TO 6 2620 READ C1,C2$ 2630 CALL CHAR(C1,C2$) 2640 NEXT I 2650 CALL HCHAR(Y,X,152) 2660 CALL HCHAR(Y,X+1,153) 2670 CALL HCHAR(Y+1,X,154) 2680 CALL HCHAR(Y+1,X+1,155) 2690 CALL HCHAR(Y+2,X,156) 2700 CALL HCHAR(Y+2,X+1,157) 2710 CALL HCHAR(Y+3,X,138) 2720 CALL HCHAR(Y+3,X+1,139) 2730 RETURN 2740 RESTORE 4310 2750 FOR I=1 TO 9 2760 READ C1,C2$ 2770 CALL CHAR(C1,C2$) 2780 NEXT I 2790 CALL HCHAR(Y,X,151) 2800 CALL HCHAR(Y,X+1,152) 2810 CALL HCHAR(Y,X+2,153) 2820 CALL HCHAR(Y+1,X,154) 2830 CALL HCHAR(Y+1,X+1,155) 2840 CALL HCHAR(Y+1,X+2,156) 2850 CALL HCHAR(Y+2,X,157) 2860 CALL HCHAR(Y+2,X+1,158) 2870 CALL HCHAR(Y+2,X+2,159) 2880 CALL HCHAR(Y+3,X+1,137) 2890 RETURN 2900 FOR J=1 TO LEN(P$) 2910 IF Y<=32 THEN 2940 2920 Y=1 2930 X=X+1 2940 IF X<=24 THEN 2960 2950 X=1 2960 CH=ASC(SEG$(P$,J,1)) 2970 CALL HCHAR(X,Y,CH) 2980 Y=Y+1 2990 NEXT J 3000 RETURN 3010 TOP=0.7 3020 J=2 3030 OLD_J=J 3040 DIR=1 3050 DIR2=1 3060 DT=1 3070 FOR I=1 TO 32 3080 IF (I>=15)*(I<=17)THEN 3090 ELSE 3140 3090 CH=112 3100 IF (DIR=-1)*(J>2)THEN 3110 ELSE 3120 3110 J_PLOT=J-1 3120 PAD=J_PLOT*SC 3130 GOTO 3270 3140 R=RND 3150 IF R>TOP THEN 3160 ELSE 3180 3160 DIR=-DIR 3170 J=J-DIR 3180 IF J+DIR>11 THEN 3080 3190 J=J+DIR 3200 CH=121+DIR 3210 IF J<2 THEN 3220 ELSE 3230 3220 J=2 3230 IF (J=OLD_J)*(R<=TOP)THEN 3240 ELSE 3260 3240 J=OLD_J 3250 CH=121 3260 J_PLOT=J 3270 CALL HCHAR(25-J_PLOT,I,CH) 3280 IF (DIR<>DIR2)*(DIR=-1)*(I>1)THEN 3290 ELSE 3320 3290 IF (PLANET=2)+(PLANET=5)THEN 3300 ELSE 3320 3300 CALL HCHAR(25-J_PLOT,I-1,125) 3310 CALL HCHAR(25-J_PLOT,I,126) 3320 CALL VCHAR(25-J_PLOT+1,I,124,J_PLOT-1) 3330 DIR2=DIR 3340 IF (CH=120)*((25-J_PLOT+2)<25)THEN 3350 ELSE 3360 3350 CALL VCHAR(25-J_PLOT+2,I,123) 3360 CALL HCHAR(INT(5*RND)+5,I,INT(RND*4)+98) 3370 OLD_J=J 3380 NEXT I 3390 CALL COLOR(13,5,1) 3400 CALL COLOR(10,14,1) 3410 FOR I=1 TO 1-(PLANET>=4)-(PLANET>=7) 3420 CALL HCHAR(10,-10*(I=1)-20*(I=2)-(I=3)+INT(RND*10),104) 3430 CALL HCHAR(9,-10*(I=1)-20*(I=2)-(I=3)+INT(RND*10),128) 3440 NEXT I 3450 RETURN 3460 CALL VCHAR(24-INT(OLD_ALT/SC),INT(OLD_DR/SC)+1-OS,32,SPC) 3470 IF DR/SC>OS+32 THEN 3480 ELSE 3510 3480 OS=OS+32 3490 CALL HCHAR(4,1,32,672) 3500 GOSUB 3010 3510 OLD_ALT=ALT 3520 OLD_DR=DR 3530 YPOS=24-INT(OLD_ALT/SC) 3540 XPOS=INT(DR/SC)+1-OS 3550 CALL GCHAR(YPOS+1,XPOS,EXHAUST) 3560 CALL GCHAR(YPOS,XPOS,OBJ) 3570 IF (OBJ=112)+(OBJ=120)+(OBJ=121)+(OBJ=122)+(OBJ=123)THEN 2330 3580 IF (OBJ>=98)*(OBJ<=101)THEN 2450 3590 IF (OBJ=104)+(OBJ=128)+(OBJ=129)THEN 3600 ELSE 3650 3600 M=-M_LDR*(OBJ=104)-(M+M_BAR)*(OBJ=128) 3610 M_LDR=M_LDR-(M_BAR)*(OBJ=128) 3620 GBARS=GBARS-(OBJ=128)-(OBJ=129) 3630 CALL SOUND(300,200,0) 3640 CALL SOUND(300,800,0) 3650 CALL HCHAR(YPOS,XPOS,145) 3660 SPC=1 3670 IF (EXHAUST<>32)+(THRUST=0)THEN 3710 3680 CALL HCHAR(1+YPOS,XPOS,136) 3690 CALL COLOR(14,1-13*(THRUST>0),1) 3700 SPC=2 3710 CALL HCHAR(2,12,48+(OLD_ALT/SC-INT(OLD_ALT/SC))*10) 3720 CALL HCHAR(2,16,48+(DR/SC-INT(DR/SC))*10) 3730 CALL HCHAR(1,6,97,27) 3740 BAR_L=INT((FUEL-(M_LDR-M))*27/FUEL) 3750 IF BAR_L<1 THEN 3770 3760 CALL HCHAR(1,6,152,BAR_L) 3770 RETURN 3780 IF ZOOM=0 THEN 3790 ELSE 4060 3790 IF ABS(WR)>0 THEN 2450 3800 PRINT :::"PROCEEDING TO ZOOM VIEW"::::::::::::: 3810 CALL CLEAR 3820 X=15 3830 Y=10 3840 DT=0.5 3850 IF (PLANET=2)+(PLANET=4)+(PLANET=6)THEN 3860 ELSE 3950 3860 FOR I=1 TO 16 3870 CALL COLOR(I,SUR,1) 3880 NEXT I 3890 CALL COLOR(13,16,1) 3900 CALL COLOR(15,16,1) 3910 CALL COLOR(16,16,1) 3920 CALL SCREEN(SKY) 3930 GOSUB 2740 3940 GOTO 3980 3950 CALL COLOR(10,SUR,1) 3960 CALL COLOR(2,SUR,1) 3970 GOSUB 2600 3980 YPOS_OLD=24 3990 P$="VEL: 20" 4000 X=1 4010 Y=1 4020 GOSUB 2900 4030 ZOOM=1 4040 V1=10 4050 MAXT=INT(M_LDR*(G+400/TH_ALT))*1.2 4060 YPOS_OLD=YPOS 4070 YP=(ALT-PAD)/SC2 4080 YPOS=12+INT(YP) 4090 IF YPOS>24 THEN 4100 ELSE 4110 4100 YPOS=24 4110 XPOS=INT(DR/SC)+1-OS 4120 FINE=INT((YP-INT(YP))*8)+1 4130 IF (YPOS<>YPOS_OLD)*(YPOS>12)THEN 4140 ELSE 4150 4140 CALL HCHAR(YPOS_OLD,1,32,32) 4150 CALL CHAR(42,A$(FINE)) 4160 CALL HCHAR(YPOS,1,42,32) 4170 IF (V<=20)*(V>=1)THEN 4180 ELSE 4210 4180 CALL HCHAR(1,6,97,20) 4190 CALL HCHAR(1,6,96,INT(V)) 4200 CALL COLOR(9,-SUR*(V>5.0)-16*(V<=5),1) 4210 RETURN 4220 DATA 96,FEFEFEFEFEFEFE00,97,FE8282828282FE00,98,3C46472322241800,99,0018384830000000 4230 DATA 100,3C7E9F8F8781720C,101,3078544424180000,103,C0DB1B00C3DB18C3,104,007CC6DECEDEDE7C 4240 DATA 112,FF10101038383838,121,00000000000000FF 4250 DATA 123,7FBFDFEFF7FBFDFE,124,FFFFFFFFFFFFFFFF,128,007CC6BEBEBEC67C,129,001818303C30101C 4260 DATA 136,003C3C3C18181800,137,00A5915A42242408,138,0A0A090504020200,139,505010A020404080 4270 DATA 126,0000000000040E3F,125,00000000002070FC 4280 DATA 120,80C0E0F0F8FCFEFF,122,0103070F1F3F7FFF 4290 DATA 152,0000000003070B13,153,00000000C0E0D0C8,154,131F1F0F07030F0F,155,C8F8F8F0E0C0F0F0 4300 DATA 156,3F5F7F5F414343E0,157,FCFAFEFA82C2C207 4310 DATA 151,0000010103030706,152,7FFFFFFFFFFFFF7F,153,0080C0C0E0E0F030,154,0C0C1F1F3F3F7F7F 4320 DATA 155,7F7FFFFFFFFFFFFF,156,1818FCFCFEFEFFFF,157,7F1F030202020F0F,158,FFFFFF0000008080 4330 DATA 159,FFFCE0202020F8F8 CARGO.zip Cargo.dsk Edited August 10 by tibasic 14 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 10 Share Posted August 10 Looks good. 🙂 You're a master of TI Basic. I played it twice - and advanced. So I knew what keys should do, but I just crashed twice - and advanced. I'm not getting it. Should probably give it more time. 😐 2 Quote Link to comment Share on other sites More sharing options...
tibasic Posted August 10 Author Share Posted August 10 Thanks sometimes99er for giving it a whirl! There's no levels as such as the 'levels' are of similar difficulty. What I could do is only let the player advance to the next planet or moon once they have completed the preceding screen. I forgot to mention the lander has an autopilot for the vertical velocity. This limits the lander's descent rate to 10 m/s and is on unless a thrust key is pressed. This was to make it a bit easier to play and so the player can spend some time planning their route through the asteroid belt or rather asteroid maze. 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted August 10 Share Posted August 10 2 minutes ago, tibasic said: Thanks sometimes99er for giving it a whirl! There's no levels as such as the 'levels' are of similar difficulty. What I could do is only let the player advance to the next planet or moon once they have completed the preceding screen. I forgot to mention the lander has an autopilot for the vertical velocity. This limits the lander's descent rate to 10 m/s and is on unless a thrust key is pressed. This was to make it a bit easier to play and so the player can spend some time planning their route through the asteroid belt or rather asteroid maze. At second run, I gathered it might be a kind of a "maze", but really didn't think so. Kinda strange in a way. 😬 1 Quote Link to comment Share on other sites More sharing options...
+Retrospect Posted August 10 Share Posted August 10 Excellent! Another good one to add to my TI Basic game collection 2 Quote Link to comment Share on other sites More sharing options...
tibasic Posted August 10 Author Share Posted August 10 10 minutes ago, sometimes99er said: At second run, I gathered it might be a kind of a "maze", but really didn't think so. Kinda strange in a way. 😬 Yeah I don't know what it is really ... 😀 12 minutes ago, Retrospect said: Excellent! Another good one to add to my TI Basic game collection Great, thanks! 3 Quote Link to comment Share on other sites More sharing options...
AtariNostalgia Posted August 17 Share Posted August 17 Can this be compiled? Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted August 18 Share Posted August 18 On 8/17/2023 at 10:41 AM, AtariNostalgia said: Can this be compiled? There is lots of floating point math in the program, so there would have to be many of adjustments for it to work. 1 Quote Link to comment Share on other sites More sharing options...
