Slender303YT Posted August 12 Share Posted August 12 (edited) This is an Batari Basic Dev-Kit that i made while i was bored, this was made for make Atari 2600 games more faster, like Visual bB. Now the compiler finds the game name folder itself. Download after how to use. HOW TO USE: To make an game, first, you need to download "bB Dev-Kit.zip", then open the Project creator Tool and insert your game name, MAKE SURE THAT IS ON THE KIT FOLDER. Your code will be on "main.bas" file, please, don't change the name of it. For sprites, create an file called "sprites" that can be on png, jpg or even bmp format, then you open it with the sprite tool and copy and paste the sprites into your game code (every sprite is 8x8 pixels wide, make sure that your sprite sheet size is at the table of multiplication of 8, like 8x8, 16x16, 24x24, etc). For the playfield, create an with the name that you want, the file can be on png, jpg or even bmp format, then you open it with the playfield tool and copy and paste the playfield into your game code. If you wanna create a project, open project_creator.bat and insert your project name. And use the tone tool for create sounds effects. Here is the download: bB Dev-Kit v1.3.zip Edited August 14 by Slender303YT I just updated the kit. 3 1 Quote Link to comment Share on other sites More sharing options...
r_chase Posted August 13 Share Posted August 13 Sounds impressive, but I do have one question: is it compatible with Linux? Because I use Linux Mint as a daily driver rather than Windows. 1 Quote Link to comment Share on other sites More sharing options...
Slender303YT Posted August 13 Author Share Posted August 13 9 hours ago, r_chase said: Sounds impressive, but I do have one question: is it compatible with Linux? Because I use Linux Mint as a daily driver rather than Windows. I don't known, i haven't tried it. Quote Link to comment Share on other sites More sharing options...
r_chase Posted August 13 Share Posted August 13 1 hour ago, Slender303YT said: I don't known, i haven't tried it. Well, either way, I find it impressive. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
