JLP Acceleration vs RAM vs FLASH
This stated here where I had some confusion on the config vars for JLP use:
1 hour ago, mr_me said:
Ideally, jlp ram and jlp acceleration activation should be separated. That's because it's possible for a game on a jlp cartridge to to use it's ram but not the hardware acceleration functions.  Since such a game could possibly run on cartridges and emulators that don't support jlp hardware acceleration, your work around is reasonable.
Okay... I almost get it...  :)
According to @intvnut, he documented the following uses of the flags here on the forums:
; To enable JLP accelerators and RAM only CFG_VAR "jlp" = 1 ;
; To enable JLP accelerators and flash save area CFG_VAR "jlp" = 3 CFG_VAR "jlp_flash" = 4 ; change 4 to however many 1.5K byte flash sectors you need
But it goes a bit more in-depth in the Locutus guide in the cfg vars section:
As near as I can tell, you always get RAM support with Acceleration support but there are clearly games that utilize RAM and not acceleration functions.. And for A-F, I see jlp=1 which shouldn't allow flash support but it clearly uses it (and has jlpflash = 16 ... notice the missing underscore).
Right now, with Nintellivision, I treat jlp=1 and jlp=3 as basically the same (Acceleration enabled and RAM enabled) and look to either jlpflash or jlp_flash as the indicator for flash support.
I've also noticed that most of the jlp_flash/jlpflash settings are just some default value... I see jlpflash=100 for TNT Cowboy but it never appears to erase/write past 32K (and it only appears to be using a fraction of that for save data).
Is there a better table explaining jlp values vs jlp_flash/jlpflash values?  I looked at the JLP Programmers View pdf which is great technical information but didn't go into more detail on the config vars.
@mr_me provides this documentation from jzintv which is rather more concrete and doesn't tie Accelerator Functions to RAM.
http://spatula-city.org/~im14u2c/intv/jzintv/doc/utilities/as1600.txt
The jlp_accel value (aka. jlp) takes on one of 4 values:
    0       JLP disabled
    1       JLP accelerators enabled at reset, no JLP flash
    2       JLP accelerators disabled at reset, JLP flash storage present
    3       JLP accelerators enabled at reset, JLP flash storage present
For jlp_accel >= 2, the jlp_flash value should be non-zero.  If missing,
it will take on a minimum value of 4.  If set to 0, jlp_flash support will
be disabled.
I still see games that use jlp=1 and then define jlp_flash (in the case of A-F, they typo it to jlpflash and although the game does use JLP Flash, proper interpretation would disable it).
I also see games that use a minimum flash size of 64h (=100d) which must be some kind of default for some toolset.  I'm almost to the point of ignoring it... this is 150K of storage which is fine for a PC but takes time on an embedded emulator on the DS - and when I look at what actually gets written, it's often just a dozen bytes or so.
On 8/14/2023 at 11:52 AM, llabnip said:
...And for A-F, I see jlp=1 which shouldn't allow flash support but it clearly uses it (and has jlpflash = 16 ... notice the missing underscore).
Looks like bin2luigi does the same thing, and I presume Jzintv as well.  The following is from the luigi documentation.
"bin2luigi  upgrades  jlp_accel  = 1;  jlp_flash  > 0 to  jlp_accel  = 3 when encoding a LUIGI."
