New 22" monitor that works with the ST
Shift838
On 9/6/2023 at 6:22 PM, Jfcatari said:
Nice I have the 27inch dell that works with the ST as well.
  Good to know a  22inch version exists that works!
cool, i have 27inch works in all res.
Can the 22inch do ALL resolutions ST Low, Med and high?
Edited by JamesWD
So, does this monitor work or not?  Jfcatari, did you use the switching cable with it?  If you used a regular VGA cable then it won't work.  I'm interested since the 27" would just be too large for my space.  I have a switching VGA cable that I built years ago.  Shift838, any chance of getting some pictures of the different resolutions.  Also can the monitor be set to 4:3 resolution to avoid stretching?
Yes I used an ST switching cable with the 22".  It only works in HighRes.
I also tried the box from Shift838, same deal.
The 22 does support 4:3.
The only monitor that works in all resolutions is the 27" Dell.
I have the 27" and I think it is a great monitor over all.   Works well on all modern stuff along with the ST (low, med, high)!
I do wish the 22" worked like the 27", I was also afraid of the size of the 27", but have gotten used to it.
At least I can save others from making the mistake and picking up the 22"!
  • 3 months later...
  • 6 months later...
Hello
Any chance of listing this monitor again, say from Amazon or the full part number so I can find if Amazon does not have
The link to Microcentre just gives me a 403 Forbidden message
Regards
Found these in the UK
Dell SE2722H 27in FHD VA 4ms 75Hz AMD FreeSync Monitor (3 Year Warranty) : Amazon.co.uk: Computers & Accessories
Dell 27 FHD Computer Monitor - SE2722H | Dell UK
Both SE2722H models
Do the smaller SE2422H and SE2222H also have this freesync facility for the Ataris?
Edited by npturton
Look further up this thread, @Jfcatari bought one and said it doesn't work, there's also another tread on this subject where other found the same thing
27" works 22" does not
Not all AMD FreeSync's are equal, I have several different monitors that have this, but none work with the ST (I have a switcher cable) all work in Hi-res
none in Med/Low Res
Both SE2722H models
From my experience having bought the 22 inch.  Mine does not work in low/med.
I have 4 of the 27 inch models all work in all resolutions.
  • 1 month later...
Does the Dell SE2722H work in all three resolutions at both 50hz and 60hz?
TGB1718 appears to have made an incorrect statement.
I can confirm the 27 inch SE2722H definitely works at 60 Hz Low rez and Medium Rez - both color modes. I have not tried it in High Rez Monochrome. Most games don’t work in High Rez
Does it also work in low/med at 50hz? If it can do all three modes in both 50 and 60hz, it absolutely is a great modern solution worth seeking out.
A great many games and demos switch to 50hz making 50hz capability a must even though our USA consoles boot up at 60hz.
I am attaching 5060hz.PRG that will switch between 50 and 60hz if someone can be so kind to test on a ntsc SE2722H. Hopefully with a ST2VGA
5060HZ.PRG
