Fabrice Labrousse Posted September 13, 2023 Share Posted September 13, 2023 Hi. I just recap an ASP34-4 power supply for my Atari 1040 STF (also found on some STEs). I followed the Exxos page and Exxos values for improvment https://exxosforum.co.uk/atari/last/psu/#ASP34 C5, C4 : 47uF 350V (33uF 350v replacement) C15, C14, C7 : 680uF 35V (330uF 35v replacement) C13 : 4700uF 16V C12 : 4700uF 16V (2200uF 16V replacement) I also changed transistors Q2 (BU508) and Q1 (2SC1384). Here is the schematic of the ASP34-4 Astec_ASP34-4_PSU_schematic.pdf After reassembly I tested the output power supplies using a 2.2 Ohm (20W) load for the 5v output and a 10 Ohm (20W) load for the 12V output rail. Now when reading the output voltages, I obtain: 6.4V instead of the expected 5V 14v instead of the expected 12v Not being an electronics specialist, could you tell me on which components acting to try to bring the voltage rails back to 5v and 12v? Thank you for your help. Quote Link to comment https://forums.atariage.com/topic/354836-atari-st-asp34-4-psu-recap-bad-ouput-voltages/ Share on other sites More sharing options...
guus.assmann Posted September 13, 2023 Share Posted September 13, 2023 Hello, The component Q3 is the voltage reference. It's a TL431. (Datasheet on internet...) And the resistors around that component determine the 5V reference. Resistors can be checked with an Ohm meter. Best regards, Guus Quote Link to comment https://forums.atariage.com/topic/354836-atari-st-asp34-4-psu-recap-bad-ouput-voltages/#findComment-5316093 Share on other sites More sharing options...
Fabrice Labrousse Posted September 14, 2023 Author Share Posted September 14, 2023 Thank you for the reply I tested all resistors R10, R11, R12, R13, R14 et R15 and they are fine. Q3 (TL431) is also fine. Output voltages are still 6.28V and 14.23V Quote Link to comment https://forums.atariage.com/topic/354836-atari-st-asp34-4-psu-recap-bad-ouput-voltages/#findComment-5316756 Share on other sites More sharing options...
TGB1718 Posted September 15, 2023 Share Posted September 15, 2023 (edited) There's obviously something wrong with the feedback circuit, have you checked the optocoupler PC1 which is a PC817 https://html.alldatasheet.com/html-pdf/43368/SHARP/PC817/124/1/PC817.html Edited September 15, 2023 by TGB1718 Quote Link to comment https://forums.atariage.com/topic/354836-atari-st-asp34-4-psu-recap-bad-ouput-voltages/#findComment-5317258 Share on other sites More sharing options...
Fabrice Labrousse Posted September 15, 2023 Author Share Posted September 15, 2023 Yes it's a brand new and tested CNY65B Quote Link to comment https://forums.atariage.com/topic/354836-atari-st-asp34-4-psu-recap-bad-ouput-voltages/#findComment-5317302 Share on other sites More sharing options...
