Atari SH204 hard disk
robbo007
Hi guys,
I've sourced an Atari SH204 external harddisk. Troubleshooting I've found that if the actual Tandon hard disk is connected to the case power it seems to short the PSU. Makes a ticking sound on the PSU and the fan does not spin. When I disconnect the hard disk the case turns on and LED lights up and fan spins. What could be causing the soft? Is the hard disk stuffed?
Regards,
Rob
Hi, its the MFM Tandon Tm362 21mb.. Its gotta be something on the hard disk board. As it only seems to "short" when the hard disk is plugged in. I need a schematic I think of the hard disk board so I can see where the power is going. Would be nice to fix it as the owner said it did work a few years back but when he took it out of storage it did not work. hmmmm
Edited by robbo007
14 hours ago, robbo007 said:
Hi guys,
Regards,
Rob
I had the exact same problem. Ended up being a blown capacitor on the hard drive mother board. It was a 20 cent part to replace. Suggest you have a look at the main board of the hard drive and see if you can see any failed/burnt components.
Good luck!
33 minutes ago, robbo007 said:
Thanks. Yeah I will remove and test each ceramic cap one at a time until I find it. A visual inspection shows now blown caps. Regards.
It was actually a tantalum cap that blew in my unit.
I forgot to mention I gave the drive a couple of good "thumps" as I suspected there was head "stuction" causing the drive not to spin and hence burning out the capacitor. I was 100% right as drive spun up fine after a few good thumps and replacing the cap.
Hi, Well its seems to be Capacitor C5. I removed C1 C2 and C51 tested and then C5. They are all the same type "106 +25 K" What are these? Polarized Tantalum? Would they be 10uF 25v ?What I can't see it the indication on the motherboard for negative if they are polarized. Did not take note in which way they were facing.
Thanks,
Rob
