Action! snippets
EDITOR PREFERENCES
Quote
; ACTION! Screen setup routine
;   by Piotr D. Kaczorowski
; lang tips
DEFINE DEF="PROC", END="RETURN"
       ,puts="PrintE"
DEFINE _color2            = "$02"
DEFINE _keyclick          = "$FF"
DEFINE _krepdelay         = "$0C"
DEFINE _keyrep            = "$04"
DEFINE _lmargin           = "$00"
DEFINE _lowerlett         = "$00"
DEFINE _bellon            = "$4C"
DEFINE _belloff           = "$60"
DEFINE _inserton          = "$FF"
CARD dosini_vec           = $0C
BYTE POINTER sixpage      = $600
; screen setup's routine
BYTE ARRAY code           = [
  $48              ;  PHA
  $A9 _color2      ;  LDA #$02
  $8D $C6 $02      ;  STA $02C6 ;COLOR2
  $A9 _keyclick    ;  LDA #$FF
  $8D $DB $02      ;  STA $02DB ;NOCLIK
  $A9 _krepdelay   ;  LDA #$0F
  $8D $D9 $02      ;  STA $02D9 ;KRPDER
  $A9 _keyrep      ;  LDA #$08
  $8D $DA $02      ;  STA $02DA ;KEYREPd
  $A9 _lmargin     ;  LDA #$00
  $85 $52          ;  STA $52   ;LMARGN
  $A9 _lowerlett   ;  LDA #$00
  $8D $BE $02      ;  STA $02BE ;SHFLOK
  $A9 _belloff     ;  LDA #$60
  $8D $E0 $04      ;  STA $04E0 ;Action! Monitor BELL OFF
  $A9 _inserton    ;  LDA #$FF
  $85 $9D          ;  STA $9D
  $68              ;  PLA
  $4C $00 $00      ;  JMP <pholder>
  $60              ;  RTS
DEFINE code_size          = "44"
CARD POINTER code_pholder = $29
; Program start
DEF main()
  ; install code at sixpage
  MoveBlock(sixpage, code, code_size)
  ; copy old dosini vec to code_pholder
  ; shifted to sixpage and set dosini
  ; vector to the sixpage
  code_pholder  ==+ sixpage
  code_pholder^   = dosini_vec
  dosini_vec      = sixpage
  puts("Pimp your Action!")
  puts("=================")
  puts("- set background to dark grey")
  puts("- set keyboard click off")
  puts("- set keyboard repeat delay")
  puts("- set left margin to 0")
  puts("- set lower letters")
  puts("- set monitor's bell off")
  puts("- set insert mode on")
  puts("")
  puts("Now please press the RESET key...")
END
  1. Write the program in the editor and save it on the disk.
  2. Clear Action! or restart the computer.
  3. Turn on Action! and go to the monitor.
  4. Run the program from the disk, which will install the RESET key handler.
  5. Go to the editor.
  6. Press RESET.
@JAC!,  maybe there is a possibility to add editor preferences without extra handler ?
Edited by Piotr D. Kaczorowski
Which type of preferences/settings do you mean? The settings in the editor you get by pressing CTRL-M/O?
Quote
For my own convenience, and from observing what people do (as seen on YouTube videos), I decided that an interesting solution would be to create a special RESET key handler, which sets the options as above. Such settings could be introduced in the next version of Action! in the preferences file. Then they should be taken into account when starting the editor and after returning from monitor mode to the editor.
