+Lee Stewart Posted September 20 Share Posted September 20 I have decided to take this DSRLNK discussion out of my fbForth thread so that I can get more non-Forth eyes on it. One of the changes I am seriously considering for fbForth 3.0 is revamping the file management system—especially, how DSRLNK works. I will likely replace the MG DSRLNK currently in place. I am looking into an implementation of Paolo Bagnaresi’s version as modified by Bill R. Sullivan (@Bill R Sullivan & @FDOS). I do not want to include Bill’s optional use of CPU RAM PABs and buffers, but I definitely want to use the 5 saved parameters after the first call to DSRLNK so CRU and device/program searches can be minimized with subsequent DSRLNK calls. Whereas Bill suggests a stack for multiple open files, I am thinking of adding those parameters to the head of each PAB. Though others have addressed some or all of my issues, trying to follow the logic of the various DSRLNKs, especially with some (several?) misleading comments, has been unsettling, to say the least. I am also considering using a linked list of PABs, much as TI Basic does—we’ll see. ...lee 4 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 20 Author Share Posted September 20 On 9/16/2023 at 6:01 PM, TheBF said: I am not sure which 5 parameters you are referring to but the one that seems to be missing in a standard PAB is the address of the "." character. I call that the "real PAB address" since it is used to reference the PAB if I recall correctly. The five parameters are SAVCRU DATA 0 CRU Address of the Peripheral SAVENT DATA 0 Entry Address of DSR or Subprogram SAVLEN DATA 0 Device or Subprogram name length SAVPAB DATA 0 Pointer to Device or Subprogram in the PAB SAVVER DATA 0 Version # of DSR from the files in this WHTech directory, which are various versions of Paolo’s DSRLNK routine. Of course, they are also present in the DSRLNK from TI Forth (pretty much identical to the E/A version), but I am not sure if they are actually reused anywhere (I will check). I need to parse one of them very carefully to make more descriptive comments as a starting point for fleshing out what I want to do. With “DSK1.FBLOCKS” as an example, SAVLEN seems to be correctly described in that “DSK1” would have a length of 4. However, SAVPAB appears to point to the position after the ‘.’ following the device name (not relevant for subprogram name), which is the actual filename of “FBLOCKS” following “DSK1.” in my example. Just before the DSR/subprogram is called >8356 also has that filename pointer. I guess that is what the DSR needs for level 3 calls. Of course, it would be irrelevant for level 1 and level 2 calls. I have work to do! ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 20 Author Share Posted September 20 On 9/16/2023 at 8:43 PM, Lee Stewart said: I need to parse one of them very carefully to make more descriptive comments as a starting point for fleshing out what I want to do. FLGPTR is a prime example of what I intend to clarify in this commented code: FLGPTR DATA 0 Pointer to Flag in PAB (Byte 1 in PAB) * ⋮ MOV @SCNAME,R0 Fetch pointer into PAB MOV R0,R9 Save pointer MOV R0,@FLGPTR Save again pointer to PAB+1 * for DSRLNK DATA 8 AI R9,-8 Adjust pointer to flag byte * ⋮ * NOW CHECK IF ANY DSR ERROR OCCURRED LWPI DLNKWS Load back LOADER workspace MOV @FLGPTR,R0 Get back pointer to PAB+1 JMP FRMDSR - 2008.8.15 - Keep on as * - 2008.8.15 - with a Normal DSRLNK As far as I can tell, nowhere is FLGPTR updated to point to the flag byte (PAB+1). It actually, always points to the file-descriptor length byte (PAB+9). The only pointer to the flag byte is R9 in the DSRLNK workspace. In fact the last move above from FLGPTR to R0 cannot possibly work when the branch to FRMDSR is taken. I definitely have work to do! ...lee 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted September 20 Share Posted September 20 Just a quick comment: there were a few iterations of the dsrlnk that made their way through the list server long ago. Some of the participants are still active in this forum. If the conversations were preserved, they may be of some value as well. I do not recall if the final iteration was well documented. 2 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted September 21 Share Posted September 21 (edited) In Sweden, we had a version of DSRLNK that was modified so the same DSRLNK could be used to find DSR in GROM as well. Particularily useful if you wanted to be able to use disk files or cassette recorder in the same program. No need to do any special checking, just call that DSRLNK and it will sort it out. You can find that DSRLNK on page 23 of this newsletter Programbiten. Note that the listing was printed with a daisy wheel printer, which replaced @ with '. So CLR 'HERE should be read as CLR @HERE. The p-system is designed a bit according to the same ideas. It scans for devices it wants to use at startup, then store CRU and entry address in a PCB (Peripheral Control Block). It's like you envision here, a PAB with some added information. Then that information is used to accomplish a quicker access when the device is really used. Edited September 21 by apersson850 2 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 21 Author Share Posted September 21 1 hour ago, apersson850 said: In Sweden, we had a version of DSRLNK that was modified so the same DSRLNK could be used to find DSR in GROM as well. Particularly useful if you wanted to be able to use disk files or cassette recorder in the same program. No need to do any special checking, just call that DSRLNK and it will sort it out. Yeah, the MG DSRLNK I am currently using uses the GPL version in GROM 0, but I see no way to use either of these for direct, repeat calls to a specific DSR/subprogram. My plan is to provide separate instructions for cassette tape access and to work here on a DSRLNK for ROM (>4000 – >5FFF) access to DSRs/subprograms—unless, of course, there arises a compelling reason to do otherwise. ...lee 4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted September 22 Share Posted September 22 (edited) No, it's probably less well aimed for such secondary quick access functions. I never bothered to sort that out, since the p-system does it from scratch and that was the only thing I used for any serious work. But you did write you want this better documented, and then a reference to this method should be included, in my opinion. Edited September 22 by apersson850 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 24 Author Share Posted September 24 The spoiler below has the working copy of the ALC of the DSRLNK I am editing: Spoiler * ---------------------------------------------------------------------------- * * NEW DSRLNK * * --- DIRECT ACCESS TO THE FDC DEVICES --- * * This code came from Paolo Bagnaresi, who started with the standard TI DSRLNK. * It was subsequently edited by Bill R. Sullivan in cooperation with Paolo. * * I (Lee Stewart) am in the process of editing this ALC further. This current * version already has extenxive edits. * * SCLEN EQU >8354 Device Name Length SCNAME EQU >8356 Pointer to Device Name Length in PAB CRULST EQU >83D0 Save last used CRU address SADDR EQU >83D2 Save last used Devicew Name pointer GPLWS EQU >83E0 GPL Workspace *++ GPLWS Registers (for clarity)... GR0 EQU R0 GR1 EQU R1 GR2 EQU R2 GR3 EQU R3 GR4 EQU R4 GR5 EQU R5 GR6 EQU R6 GR7 EQU R7 GR8 EQU R8 GR9 EQU R9 GR10 EQU R10 GR11 EQU R11 GR12 EQU R12 GR13 EQU R13 GR14 EQU R14 GR15 EQU R15 MSCRU DATA >1100 Start searching DSR from this address DLNKWS DATA 0,0,0,0,0 DSRLNK workspace. TIPE is R5 of this TIPE DATA 0,0,0,0,0 workspace DATA 0,0,0,0,0,0 NAMBUF BYTE 0,0,0,0,0,0,0,0,0,0,0 C100 DATA 100 H20 EVEN H2000 DATA >2000 DECMAL TEXT '.' HAA BYTE >AA EVEN DATA8 DATA >8 - 8 is the normal DATA that * follows a BLWP @DSRLNK * Save parameters here SAV8A DATA 0 Save data following BLWP @DSRLNK (8 or >A) SAVCRU DATA 0 CRU Address of the Peripheral SAVENT DATA 0 Entry Address of DSR or Subprogram SAVLEN DATA 0 Device or Subprogram name length SAVPAB DATA 0 PAB address of filename following device name (level 3).. * ..not relevant for subprogram (levels 1 & 2) SAVVER DATA 0 Version # of DSR FLGPTR DATA 0 Pointer to Flag byte in PAB (PAB+1) * * Utility Vectors * *======================================== * DSRLNK *======================================== DSRLNK DATA DLNKWS,DLENTR *** Link to device service routine * DLENTR MOV *R14+,R5 Fetch program type for link MOV R5,@SAV8A Save data after BLWP @DSRLNK (8 or >A) LI R8,>0F00 Starting point for new search SZCB @H20,R15 Reset equal bit MOV @SCNAME,R0 Fetch pointer to PAB+9 (pathname length) MOV R0,R9 Save pointer AI R9,-8 Adjust saved pointer to flag byte MOV R9,@FLGPTR Save pointer to PAB+1 for DSRLNK DATA 8 BLWP @VSBR Read device name length MOVB R1,R3 Store it elsewhere SRL R3,8 Make it a word value SETO R4 Initialize a counter LI R2,NAMBUF Point to NAMBUF LNK$LP INC R0 Point to next char of name INC R4 Increment character counter CI R4,7 Is name length >7? JGT LNKERR Yes, error C R4,R3 End of name? JEQ LNK$LN Yes BLWP @VSBR Read current character MOVB R1,*R2+ Move it to NAMBUF CB R1,@DECMAL Is it a decimal point? JNE LNK$LP No LNK$LN MOV R4,R4 Is name length zero? JEQ LNKERR Yes, error CLR @CRULST MOV R4,@SCLEN Store device name length for DSR search MOV R4,@SAVLEN Save device name length INC R4 Adjust it to point.. A R4,@SCNAME ..to start of filename after '.' (level 3 use only) MOV @SCNAME,@SAVPAB Save pointer to filename after device name '.' * *** Search ROMs at >4000 for DSR * SROM LWPI GPLWS Use GPL workspace to search CLR GR1 Version found of DSR etc. MOV @MSCRU,GR12 Starting CRU address is in MSCRU from Forth JMP NOOFF2 CRU selected NOROM SBZ 0 Yes, turn it off CLR @CRULST Reset in case we are finished (label NOOFF removed) AI GR12,>0100 No, point to next ROM NOOFF1 C GR12,@MSCRU Did we cycle back to the original CRU? JEQ NODSR Yes, end the scan CI GR12,>2000 At the end JNE NOOFF2 no LI GR12,>1000 Yes, restart * Paolo 15.2.2010 Save a few CPU cycles JMP NOOFF1 restart properly - don't fall through NOOFF2 MOV GR12,@CRULST Save address of current CRU SBO 0 Turn on ROM LI GR2,>4000 Start at beginning CB *GR2,@HAA Is it a valid ROM? JNE NOROM No A @TIPE,GR2 Go to first pointer (TYPE already used - BRS) JMP SGO2 SGO MOV @SADDR,GR2 Continue where we left off SBO 0 Turn ROM back on SGO2 MOV *GR2,GR2 Is address a zero JEQ NOROM Yes, no program to look at MOV GR2,@SADDR Remember where we go next INCT GR2 Go to entry point MOV *GR2+,GR9 Get entry address * *** See if name matches * MOVB @SCLEN+1,GR5 Get devicename/subprogram length to GR5 MSB JEQ NAME2 Zero length, don't do match CB GR5,*GR2+ Does length match next device/subprogram in DSR? JNE SGO No SRL GR5,8 Yes..move to LSB for counting LI GR6,NAMBUF Point to NAMBUF NAME1 CB *GR6+,*GR2+ Is character correct? JNE SGO No DEC GR5 More to look at? JNE NAME1 Yes NAME2 INC GR1 Next version found MOV GR1,@SAVVER Save version number MOV GR9,@SAVENT Save entry address MOV GR12,@SAVCRU Save CRU address BL *GR9 Match, call subroutine * This jump executes only if no DSR to advance return vector past it. JMP SGO Not right version SBZ 0 Turn off ROM LWPI DLNKWS Select DSRLNK workspace MOV R9,R0 Point to flag byte in level-3 PAB FRMDSR MOV @SAV8A,R1 Get back data after BLWP @DSRLNK (8 or >A) CI R1,8 Was it 8? JEQ DSRDT8 Yes, jump: Normal DSRLNK MOVB @>8350,R1 No, we have a DATA >A. Get Error byte from >8350 JMP DSRDTA Go and return error byte to the caller DSRDT8 BLWP @VSBR Read flag byte *++ Error codes for both DSRs and subprograms are in high 3 bits DSRDTA SRL R1,13 Just want the error flags JNE IOERR Error! RTWP * *** Error handling * NODSR LWPI DLNKWS Select DSRLNK workspace LNKERR CLR R1 Clear the error flags IOERR SWPB R1 MOVB R1,*R13 Store error flags in calling R0 SOCB @H20,R15 Indicate an error occured RTWP Return to caller *----------------* * ACCESS ONCE AGAIN THE SAME DSRLNK *----------------* DSRAGN EQU $ DATA DLNKWS DATA LDGETR LDGETR SZCB @H20,R15 Reset Equal Bit in STATUS (V2) LWPI GPLWS * Paolo 15.2.2010 - Use GR11 instead of GR0 of GPLWS. We will be using GR11 * anyway later on with the BL *GR9 LI GR11,SAVCRU pointer to last used CRU address MOV *GR11+,GR12 SAVCRU..CRU address MOV *GR11+,GR9 SAVENT..DSR entry address MOV *GR11+,@SCLEN SAVLEN..device name/subprogram namelength MOV *GR11+,@SCNAME SAVPAB..PAB filename addr after dev name..lvl 3 MOV *GR11+,GR1 SAVVER..DSR version Number SBO 0 Open CARD CB @>4000,@HAA Valid Indentifier? JNE NODSR No, Error Code 0 = Bad Device Name.. * ..The above jump to NODSR may happen only in case * ..of either card hardware malfunctioning or if * ..there are 2 cards opened at the same time BL *GR9 Execute DSR * This jump executes only if no DSR to advance return vector past it. JMP NODSR issue Error Code 0 = Bad Device Name SBZ 0 Otherwise, close CARD * NOW CHECK IF ANY DSR ERROR OCCURRED LWPI DLNKWS Load back LOADER workspace MOV @FLGPTR,R0 Get back pointer to PAB+1 JMP FRMDSR - 2008.8.15 - continue as with a normal DSRLNK * DSRLNK code ends here! I have fixed the FLGPTR issue (never pointing to the PAB flag byte, PAB+1) mentioned in a previous post. I was thinking of changing the use in the routine of the term, “version”, because it has nothing to do with the version of the DSR listed in the second byte at >4001. It has, rather, to do with how many successful matches have been made of the device/subprogram name in the course of finding a routine associated with that name that actually works. That is to say, if a particular routine for, say, DSK1.FILENAME, that runs without error, has a version number of 3, it means that two previous routines with the same name (DSK1) were found, but errored out before this one succeeded. If we cannot find a better descriptor, I will just clarify it in the comments. While we are discussing “version”, I noticed that the code five instructions above NAME1, jumps to NAME2 if the device/subprogram name-length byte (at >8355) is zero. That increments the version number without there having actually been a name match in the DSR. I should think it would be better to send it to LNKERR, where a similar test, at the beginning, sends it. It is probably a moot point, because the name length should never be zero at that spot in the routine. If the byte at >8355 is zero, it will exit the routine at the beginning. It seems to me that the test is superfluous and could be removed. I’ll stop talking now... ...lee 1 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 27 Author Share Posted September 27 Considering 23 hours ago, Vorticon said: <snip> One thing I want to test as well is disabling the RS232 card prior to saving the image. My program uses that card to receive outside info from a camera via the parallel port, and I only disable the card just prior to exiting the program. I wonder if that might make a difference... 22 hours ago, InsaneMultitasker said: If the RS232's ROM is enabled and visible at the >4000 space, then yes, it could definitely interfere with other DSR operations. The DSRLNK routine scans the peripherals by turning each card on and off to find the requested device name or subroutine. Perhaps the DSRLNK is turning off the RS232 during the first save operation, which sets up the second save operation for success (since the RS232 is now off). You may have found the answer <fingers crossed> 8 hours ago, apersson850 said: Vary probable. A "standard" DSRLNK call will turn each card in the CRU address range first on, then off, in the search for the correct DSR. If you are looking for a disk controller DSR, which normally is at >1100, it will not be found if the card at >1300 is enabled at the same time. Two data buffers will try to overdrive each other. Scanning will continue and soon enable the card at >1300 (which doesn't change anything, since it already is enabled), find the RS232 card, realize it's not the card searched for, disable the card and continue the search. But the disk controller at >1100 will not be found, because looking for that has already passed. Next time the DSRLNK is called, provided nothing turned that RS 232 card on again in between, all cards are off and the disk controller will be found at >1100. from another thread, I wonder whether it might not be a good idea for DSRLNK to turn off all peripheral cards before doing any DSR checking, just to be certain there are no conflicts. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted September 27 Share Posted September 27 36 minutes ago, Lee Stewart said: from another thread, I wonder whether it might not be a good idea for DSRLNK to turn off all peripheral cards before doing any DSR checking, just to be certain there are no conflicts. This may be a good idea in hindsight, but the premise would be to assume that assembly language programmers mess with the CRU bits, which they should not. I suppose TI's vision was that there are these nice DSRs, so there would be no need to use CRU bits directly. In systems like the 99xxx, access to CRU bits can be limited to privileged mode. But more importantly, you don't know whether bit 0 is the only bit to reset. 3 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted September 27 Share Posted September 27 48 minutes ago, Lee Stewart said: from another thread, I wonder whether it might not be a good idea for DSRLNK to turn off all peripheral cards before doing any DSR checking, just to be certain there are no conflicts. This seems like it might be a case of a good, cautious DSRLNK approach that isn't needed for most programs, provided the programmer follows existing device access conventions. Turning off all of the cards each time would also add some overhead and execution time, especially during heavy record-based IO. (As an aside, the Geneve OS and boot eprom start by turning off all cards prior to executing the standard ROM powerups, to ensure that any cards that were not turned off by a hardware reset, e.g., the TIPI card, are in a known state. DSRLNK operates in the same standard manner as the /4a.) 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted September 27 Share Posted September 27 55 minutes ago, mizapf said: This may be a good idea in hindsight, but the premise would be to assume that assembly language programmers mess with the CRU bits, which they should not. I suppose TI's vision was that there are these nice DSRs, so there would be no need to use CRU bits directly. In systems like the 99xxx, access to CRU bits can be limited to privileged mode. But more importantly, you don't know whether bit 0 is the only bit to reset. Messing with the CRU bits is necessary to activate and access the parallel port at the low level for interfacing purposes. One just has to remember to clean up afterwards 3 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted September 27 Share Posted September 27 Then you're doing things without TI's blessing. (I won't doubt it is necessary, and I confess to have played with CRU bits every now and then.) Quote Link to comment Share on other sites More sharing options...
apersson850 Posted September 28 Share Posted September 28 (edited) On 9/27/2023 at 7:02 PM, mizapf said: But more importantly, you don't know whether bit 0 is the only bit to reset. Well, that you should know, since the specification says that cards with a DSR should be enabled/disabled by the first bit in the CRU address space for the card. Which is bit 0 relative to the base address, of course. If other bits are left on, they should not make the DSR program visible in the memory address range >4000-5FFF. The parallel port is a hybrid, since the 8 data bits are read/written with a memory access, but the additional handshake bits are implemented as CRU bits. I use CRU bits to enable/disable banks in my internal 16-bit wide RAM expansion. But then that wasn't anticipated by TI either. Edited September 28 by apersson850 4 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted September 28 Share Posted September 28 A neat feature of the TI RS232 is that the serial port can be used without turning on bit 0 to enable the ROM. I debugged a few of the nasty Horizon ROS bugs from 'within' the ROS/DSR, by sending debug & trace information to the serial port. I'm sure TI wouldn't have blessed this either. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 28 Share Posted September 28 27 minutes ago, InsaneMultitasker said: A neat feature of the TI RS232 is that the serial port can be used without turning on bit 0 to enable the ROM. I debugged a few of the nasty Horizon ROS bugs from 'within' the ROS/DSR, by sending debug & trace information to the serial port. I'm sure TI wouldn't have blessed this either. LOL. I had to do a double check to confirm that my RS232 driver never turns on the "card", only the LED. Once I saw signals on the connector it never occurred to me to "turn on" the card. Does turning on the card just put the ROM on CPU buss? I push R12 before using the UART and POP it back when I am done using it so I play nice in the sandbox ... kind of. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted September 28 Share Posted September 28 On 9/20/2023 at 10:44 AM, Lee Stewart said: The only pointer to the flag byte is R9 in the DSRLNK workspace. In fact the last move above from FLGPTR to R0 cannot possibly work when the branch to FRMDSR is taken. I definitely have work to do! I believe the last move was intended to restore R0 for the upcoming VSBR, when the 'quick' routine DSRAGN is called. Should FLGPTR store the value of R9 (not R0) after it is adjusted to point to the flag byte? MOV R0,R9 Save pointer MOV R0,@FLGPTR Save again pointer to PAB+1 * for DSRLNK DATA 8 AI R9,-8 Adjust pointer to flag byte MOV R9,@FLGPTR Save again pointer to PAB+1 BLWP @VSBR Read device name length Maybe R9 could be used in place of FLGPTR, regardless of entry, if the jump to FRMDSR was changed to the MOV R9,R0 statement. I didn't trace the entire routine to verify whether this would work. MOV R9,R0 Point to flag byte in PAB FRMDSR MOV @SAV8A,R1 Get back data * following BLWP @DSRLNK (8 or >A) 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted September 29 Author Share Posted September 29 3 hours ago, InsaneMultitasker said: I believe the last move was intended to restore R0 for the upcoming VSBR, when the 'quick' routine DSRAGN is called. Should FLGPTR store the value of R9 (not R0) after it is adjusted to point to the flag byte? MOV R0,R9 Save pointer MOV R0,@FLGPTR Save again pointer to PAB+1 * for DSRLNK DATA 8 AI R9,-8 Adjust pointer to flag byte MOV R9,@FLGPTR Save again pointer to PAB+1 BLWP @VSBR Read device name length Yeah—that is what I did in my subsequent post. 3 hours ago, InsaneMultitasker said: Maybe R9 could be used in place of FLGPTR, regardless of entry, if the jump to FRMDSR was changed to the MOV R9,R0 statement. I didn't trace the entire routine to verify whether this would work. MOV R9,R0 Point to flag byte in PAB FRMDSR MOV @SAV8A,R1 Get back data * following BLWP @DSRLNK (8 or >A) I did think of that and it should work because the DSR workspace is not used by any other routine. Even in the E/A DSRLNK, where the DSR WS overlaps a utility WS, R9 is safe between calls to DSRLNK. Ultimately, however, I want to be able to deal with more than one PAB. For example, copying records from one file to another. This would require storing DSR calling information with the PABs or, per Bill Sullivan’s suggestion, on a stack. I think it will work better stored with the PABs, even though that involves VRAM access. Of course, I could always do something in RAM. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted September 29 Share Posted September 29 (edited) 1 hour ago, Lee Stewart said: Ultimately, however, I want to be able to deal with more than one PAB. For example, copying records from one file to another. This would require storing DSR calling information with the PABs or, per Bill Sullivan’s suggestion, on a stack. I think it will work better stored with the PABs, even though that involves VRAM access. Of course, I could always do something in RAM. ...lee Not sure if it helps your work, but I took the approach of making a VDP stack that allocates PAB+buffer descending from system reported end of VDP RAM. Buffers are always maximum size for simplicity and speed of access. I found it advantageous in a Forth environment to use VDP memory operators to read/write the VDP PAB directly rather that duplicating anything in RAM. Block read/write with VDP ram is as fast as RAM-to-RAM move on the 8 bit buss, from what I can see. Word-wide fetch store operators are about 50% slower than the RAM equivalent in Forth, but you don't do many of those. These tradeoffs might not make any sense in an assembler environment. Edited September 29 by TheBF typo 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 4 Author Share Posted October 4 (edited) In dissecting the various DSRLNK incarnations before the Bagnaresi/Sullivan DSRLNK, I am wondering why all of them, including the E/A version from which they were all derived (as far as I can tell) save the following (labels vary), even though they are not used within the routine or elsewhere (that I can find—maybe someone knows?): SAVCRU DATA 0 CRU Address of the Peripheral SAVENT DATA 0 Entry Address of DSR or Subprogram SAVLEN DATA 0 Device or Subprogram name length SAVPAB DATA 0 Pointer to Device or Subprogram in the PAB SAVVER DATA 0 Version # of DSR Most or all of these persist long enough to be captured after return to the calling routine without the need to save them in the above manner—even in the console DSRLNK, which does not save them elsewhere. The only one that surely does not survive is SAVVER (GPLWS R1)—and I am not sure it is necessary. Perhaps these saved values were intended for debugging. I am even considering keeping the MG DSRLNK and trying to manage reruns of the various DSRs/subprograms in its shadow. The only feature I would like to have that will likely not be possible is starting the DSR search at a particular CRU address and circling around back to it to complete the search. Folks are probably used to managing CRU addresses in hardware to manage search order, but starting the DSR search at any desired CRU address from >1000 to >1F00 and circling back around to the starting address is a nifty feature of the Bagnaresi/Sullivan DSRLNK, which I kind of hate to give up. Just thinking out loud here.... ...lee Edited October 4 by Lee Stewart correction 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted October 4 Share Posted October 4 16 hours ago, Lee Stewart said: In dissecting the various DSRLNK incarnations before the Bagnaresi/Sullivan DSRLNK, I am wondering why all of them, including the E/A version from which they were all derived (as far as I can tell) save the following (labels vary), even though they are not used within the routine or elsewhere (that I can find—maybe someone knows?): SAVCRU DATA 0 CRU Address of the Peripheral SAVENT DATA 0 Entry Address of DSR or Subprogram SAVLEN DATA 0 Device or Subprogram name length SAVPAB DATA 0 Pointer to Device or Subprogram in the PAB SAVVER DATA 0 Version # of DSR This looks like the authors had plans to allow re-entering the DSR code without searching through everything every time but it was never completed. ? 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted October 4 Share Posted October 4 The re-entry routine (at least in the latest version that I am aware of) populates registers using the SAVCRU "structure", in order to bypass the scanning and setup of a standard DSRLNK call. As I recall, R11 is set to the address of SAVCRU and the registers are populated via moves, e.g., MOV *R11+,<target>. 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 4 Author Share Posted October 4 1 hour ago, InsaneMultitasker said: The re-entry routine (at least in the latest version that I am aware of) populates registers using the SAVCRU "structure", in order to bypass the scanning and setup of a standard DSRLNK call. As I recall, R11 is set to the address of SAVCRU and the registers are populated via moves, e.g., MOV *R11+,<target>. I do understand that. That is what I was referencing with my opening phrase. It is all the others that save those same values and addresses and never use them that puzzles me. What @TheBF said above about possible intentions for re-entry down the road (as the Bagnaresi/Sullivan version actually does, per your post) is a good guess. I think it is even possible it was used by TI programmers on the 990 computers (@FarmerPotato?), but just not passed on to us in the E/A manual. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted October 4 Share Posted October 4 2 hours ago, Lee Stewart said: I do understand that. That is what I was referencing with my opening phrase Ah hah! I read your post a few more times before I figured out that the orangish font (on this particular monitor of mine) doesn't play nicely with my eyes. I will return to lurking and learning 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted October 5 Author Share Posted October 5 3 hours ago, InsaneMultitasker said: Ah hah! I read your post a few more times before I figured out that the orangish font (on this particular monitor of mine) doesn't play nicely with my eyes. I will return to lurking and learning Yeah...I should try another font. It works fine on a black background, but not so well on white. And...I have learned far more from you over the years than you have likely learned from me! ...lee Quote Link to comment Share on other sites More sharing options...
