Atari 520STfm ... copying games to floppy disk!
somacast
hi,
I am really in a vortex trying to get a single copied game to work on real atari hardware with no luck, below are list of things done/ checked so far:
1- brand new floppy disks used
2- used makedisk in free dos , by trying (makedisk /write xxx.st /auto) , when the program starts it auto detects and says 2 sides, but i don't really understand, I did cover the second hole, it means this disk should be 1 sided right? or am I missing something?!
3- no matter how many times i try, the atari says disk is not responding .. it seems that the floppy drive in it is single sided as it has on top head only foam-like pad not another reading head..
4- tried formatting in the atari first, didn't help !!
5- tried many roms from different sources, msa and st ..
6- replaced pc fdd , no luck.
i am new to atari , a commodore&amiga person entire life , so I would really appreciate any good info , i dont want to buy stuff unnecessarily.
thnx
You should take pictures of your drive so we can say if it’s single sided (360k) present on early machines, double sided (720k) all machines up to MegaSTe with high density (1.44MB) drives. TT and Falcon only had 1.44 drives IIRC
You seem to have 1.44MB high density floppies and covering the second hole is a “trick” to make the host system think it has a low density disc and format it and write to it, but the media is slightly different so your results will vary.
if you have a very old drive (and they all are one way or another now), cleaning the mechanism is essential and sometimes even caps replacement
I haver never tried nor remember hearing about trying to format a high density disc to 360k.
if you have a single sided drive you really need either a dual sided drive or an alternative like USB
Edited by anzac
I think "second hole" indicates that it is a high-density disk, and they never worked properly in my double-density ST drive,  maybe others will have other luck,  but I'd recommend trying to find double density disks, if you can.    Or skip floppies and go to a gotek drive.
I too always found HD (1.44) disks in my Atari ST's to be problematic (unless they were already
equipped with 1.44 drives like my Mega STe and STacy)
You can still get DS/DD disks from places like Amazon and more:
https://tinyurl.com/26bzjenr
I think Best Electronics still has some:
https://www.best-electronics-ca.com/accesori.htm
You can also search Ebay and find items... HTH's.  :)
Thank you all for the useful tips, as requested please find some photos, i know the drive isn't as clean as it should but its not the reason of the issue as i have cleaned the reading head tip with alcohol , i have taken photos of the disks i used
the system serial number is a17 6 j4013987 , its 520 stfm
so far tried (i think) 1943.st , F1 something .st , sysinfo.msa , barbarian . st
faulty drive of the st is really highly possible
thnx
@somacast those floppy's are not going to work, as others have said, they have a different format/media, I've certainly
never had one even format.
Your drive is a single sided 360K drive, so any double sided disks are not going to work either even with the right floppy's.
You need to get some 720K floppy disks and try format one single sided to see if the drive is ok.
You said you were an Amiga person, do you have any spare disks from that system, unless it's been upgraded to HD floppy's
it's highly likely they will be 720K disks.
Thanks , in fact i do have some.. might try and see
but its 90% a bad drive in the atari , I've used those floppies with excellent success rate for the even more stubborn amiga format and made about 30 disks all working, struggled a bit with MSX but got 1 to work finally, however the same irresponsive behavior of the drive at first read attempt makes me doubt.
now I am also confused, how do i change settings auto created by makedisk ? for instance it says your rom is 820kb , so it auto selects 2 sides !! i wanna make it 1 side , funny is that it writes and verifies error free 2 sides as it says despite the fact that i have the other hole covered !! weired stuff..
also, if i buy a double side atari floppy disk drive, is it just plug & play? thnx
anyway i will try and c
13 minutes ago, anzac said:
You have fundamental misconceptions about how floppy drives work.
you've been told that the second hole has NOTHING to do with single or double sided and you keep fixated on that
hi , thnx for replying, i might have missed a line in the replies, no intention of opposing those who answers my lack of knowledge/ forgotten info due to long time since last done ..
Yes, as long as it's a 720K model, the 1.44MB one requires some modifications to the ST.
https://www.exxosforum.co.uk/atari/store2/
I don't know anything about how the Amiga formatter works or what Floppy Disk controller is in the Amiga, that might be the controller
is the reason why you have some success with 1.44MB disk on the Amiga, but the ST just does not like those floppies, I've got
box fulls of them from my PC days and I know not a single one will format correctly.
Edited by TGB1718
As you now know, the hole is not for the sides, one is the write protect and the other is HD floppy detect.
As for the format completing, during the format, the software looks like it's only writing to the floppy, so will not
detect errors, when it write the FAT(disk directory) it only writes it to side A of the floppy so it will be successful.
Just down to poorly written software.
update : tried an original Amiga disk , formatted it, copied barbarian to it, doesn't read it on atari.
however before I give up i will need an iso thats originally just correct sized to fit , because still makedisk suggests and forces 2 sides , which wont work on my single side drive (as confirmed as per photo above)
If you have 720k discs just try and format them on the Atari
if a known to be working on Amiga disc doesn’t format on the Atari to 360k you have a faulty drive, fixes to do on the power rails, you said you cleaned the drive already so if it doesn’t work…
if you have an Amiga, you can use its drive on the Atari. They are both 720k drives. You might have to change DS1 to DS0, might be a jumper or a resistor
I know this is valid for PC drives not sure for Amiga drives
thanks alot
in fact for the few diskettes I've been using, i first attempted formatting on the atari , most of them were formatted successfully (single side selected of course to match the drive type).
good info about atari power rails check , never knew its known for issues there , i will have to dig on that ..
i remember having a spare amiga floppy drive , i will c if that just works ..
now for trying purposes, is there an Atari game rom that is 360 kb ? it will help me verify things too..
in fact this atari when i bought came with 2 original atari disks , they just lead to quickly go to disk top, however when i access it from floppy a folder it says some bla bla not responding.. the only difference with those i copy is that the ones i copy are not even causing fast load to desktop so they are not even recognized..
I’m sorry
im Getting confused.
please remember that we, as readers, don’t necessarily know by instinct to what you’re exactly referring when you say “this” or “the ones before”.
when possible be specific to what you’re referencing, an old 360k disc that is probably 40yo or a known to be working 720k disc.
also, if you really have a single sided drive, my memory says that the dual sided option to format shouldn’t even appear as an option…. 🤷‍♂️
should be greyed out at least
in your photo of the drive I didn’t see a label with model number.
my steps would be to take a KNOWN to work 720k disc, format it on PC internal drive (not USB) using the proper command, copy a text file to the disc and try
you can also image an empty 360k floppy on steem and copy sysinfo
final update I guess as I figured out the case:
my Atari 520st is equipped with single sided drive
it formats all disks (original dd, or hd with left hole closed) , formats them to single sided
how did i know? well , floimg software has the ability to read what the inserted disk is and it recognized all formatted by Atari as single sided
and as I have requested multiple times above i wanted a 320 kb game to confirm,  so i searched by date for oldest games nearest possible to 1985 release date and found borderzone to be so , copy , working , tried even the hd floppy with hole batched , working too ..
so i need to buy a double sided floppy drive , as most of roms are so ..
now the thing is , it looks like this atari is 512kb ram ? because post this screen with music in the game when i hit space it reads as if it will play then goes to desktop again .. ram ?
thnx
Edited by somacast
1 minute ago, somacast said:
here is another meaningless (((game))) ,a bouncing ball, the game is called Boeing, lol , it doesn't even auto play i had to start the file manually from disktop
Boing,  I know the game well
One thing that's important to know-    There are three main methods of auto-booting games
boot loader - game is loaded from master boot record and just loads
Auto Folder - You can put apps in here, and they will auto load as long as they don't require GEM calls
Auto Loading GEM Apps-  this is only supported by TOS 1.4 and up, you edit the properties of the app, and set it to auto-load, then save your desktop to create a new desktop.inf,  next time you boot, that game should auto load.
