somacast Posted September 29, 2023 Share Posted September 29, 2023 Hi , I found good almost new sony floppy drive , did the easy part which is the jumper mod .. works fine.. now for the known issues: how to remove that original floppy cable from the atari motherboard? is it removable? because the cable has to be flipped for the sony drive second thing is the face plate of the original, this is the type with large button in the center, again, it doesn't want to come off the original single sided drive , any hints please, it shouldn't break.. thanks Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/ Share on other sites More sharing options...
TGB1718 Posted September 29, 2023 Share Posted September 29, 2023 9 minutes ago, somacast said: how to remove that original floppy cable from the atari motherboard? is it removable? because the cable has to be flipped for the sony drive Have to do the same for a GOEX drive, unless you want to try unsoldering the header and putting in a socket, the only way is to use a short extender cable allowing the twist. Sorry can't help with the faceplate, usually they are just pushed on with the plastic providing "spring clips" to hold it on. 1 Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5325810 Share on other sites More sharing options...
somacast Posted September 29, 2023 Author Share Posted September 29, 2023 Noted with thanks i think headers could be easier here , lemme give it a try Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5325844 Share on other sites More sharing options...
somacast Posted September 29, 2023 Author Share Posted September 29, 2023 (edited) 1 hour ago, TGB1718 said: Have to do the same for a GOEX drive, unless you want to try unsoldering the header and putting in a socket, the only way is to use a short extender cable allowing the twist. Sorry can't help with the faceplate, usually they are just pushed on with the plastic providing "spring clips" to hold it on. Thanks again , header installed, worked too, now i need some mechanical works for the eject button here I come StarField ... i wonder how many floppies shall i prepare for 100 GB .. Edited September 29, 2023 by somacast Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5325860 Share on other sites More sharing options...
JamesWD Posted September 30, 2023 Share Posted September 30, 2023 An easy solution of flipping cable and changing ID : FLOPPY CABLE FLIP KIT https://exxosforum.co.uk/atari/store2/#0208 1 Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5326189 Share on other sites More sharing options...
somacast Posted September 30, 2023 Author Share Posted September 30, 2023 thank you very much Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5326202 Share on other sites More sharing options...
somacast Posted September 30, 2023 Author Share Posted September 30, 2023 it is a great website, now other than the factthatt I have installed pins header is this cable usable with atari? or do i need one without twist? it worked at first , but i am seeing issues now.. thanks Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5326209 Share on other sites More sharing options...
somacast Posted September 30, 2023 Author Share Posted September 30, 2023 just to add , yes , it can't have a twist to use it with Atari .. secondly, I was able to mod internally a samsung drive to work, but again it needs some mechanical solution for eject as its face-less type , so no button even Quote Link to comment https://forums.atariage.com/topic/355275-atari-520stfm-sony-920-mod/#findComment-5326350 Share on other sites More sharing options...
