Why does the text change color?
Gedalya
I am new to programming the Jaguar. I am testing things out and learning. I have a simple Hello World example I am working with:
do
	vsync                       ' Sync to VBLANK and Update ALL RAPTOR objects
	jsfSetFontIndx(0)			' Set font style
	jsfSetFontSize(1)			' Set font size
	rapLocate 140,175
	rapPrint "Hello World!"
	jsfLoadClut(strptr(BACKGROUND_clut),0,255)
loop                            ' Loop around!
What I am seeing is that without the jsfLoadClut line (without the background image) the "Hello World" text prints as white text; with the jsfLoadClut line included (with the background image) the text prints as a shade of blue. Why does the text change color? Or more to the point, how can I ensure the text stays the color I want.
To try and solve this issue I converted the image to 16 color palette (4bpp) and then the following:
do
	rapLocate 140,175
	jsfLoadClut(strptr(BACKGROUND_clut),0,16)
loop                            ' Loop around!
With the following entry in rapinit.s:
; BACKGROUND
	dc.l	1								; (REPEAT COUNTER) 				; Create this many objects of this type (or 1 for a single object)
	dc.l	is_active						; sprite_active					; sprite active flag
	dc.w	0,0								; sprite_x						; 16.16 x value to position at
	dc.w	0,0							    ; sprite_y						; 16.16 y value to position at
	dc.w	0,0								; sprite_xadd					; 16.16 x addition for sprite movement
	dc.w	0,0								; sprite_yadd					; 16.16 y addition for sprite movement
	dc.l	352								; sprite_width					; width of sprite (in pixels)
	dc.l	240								; sprite_height					; height of sprite (in pixels)
	dc.l	is_normal						; sprite_flip					; flag for mirroring data left<>right
	dc.l	0								; sprite_coffx					; x offset from center for collision box center
	dc.l	0								; sprite_coffy					; y offset from center for collision box center
	dc.l	352/2							; sprite_hbox					; width of collision box
	dc.l	240/2							; sprite_vbox					; height of collision box
	dc.l	BACKGROUND						; sprite_gfxbase				; start of bitmap data
	dc.l	4								; (BIT DEPTH)					; bitmap depth (1/2/4/8/16/24)
	dc.l	is_RGB							; (CRY/RGB)						; bitmap GFX type
	dc.l	is_opaque						; (TRANSPARENCY)				; bitmap TRANS flag
	dc.l	352*240						    ; sprite_framesz				; size per frame in bytes of sprite data
	dc.l	352							    ; sprite_bytewid				; width in bytes of one line of sprite data
	dc.l	0								; sprite_animspd				; frame delay between animation changes
	dc.l	0								; sprite_maxframe				; number of frames in animation chain
	dc.l	ani_rept						; sprite_animloop				; repeat or play once
	dc.l	edge_wrap						; sprite_wrap					; wrap on screen exit, or remove
	dc.l	spr_inf							; sprite_timer					; frames sprite is active for (or spr_inf)
	dc.l	spr_linear						; sprite_track					; use 16.16 xadd/yadd or point to 16.16 x/y table
	dc.l	0								; sprite_tracktop				; pointer to loop point in track table (if used)
	dc.l	spr_unscale						; sprite_scaled					; flag for scaleable object
	dc.l	%00100000						; sprite_scale_x				; x scale factor (if scaled)
	dc.l	%00100000						; sprite_scale_y				; y scale factor (if scaled)
	dc.l	-1								; sprite_was_hit				; initially flagged as not hit
	dc.l	no_CLUT							; sprite_CLUT					; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit)
	dc.l	cant_hit						; sprite_colchk					; if sprite can collide with another
	dc.l	cd_keep							; sprite_remhit					; flag to remove (or keep) on collision
	dc.l	single							; sprite_bboxlink				; single for normal bounding box, else pointer to table
	dc.l	1								; sprite_hitpoint				; Hitpoints before death
	dc.l	2								; sprite_damage					; Hitpoints deducted from target
	dc.l	352        						; sprite_gwidth					; GFX width (of data)
The color issue is resolved but now the image is skewed:
@CyranoJ, is there anything obviously wrong with what I am trying to do? Thanks!
The sprite_CLUT in your object definition should really be 0 since your jsfLoadClut is loading the 16 colours into CLUT 0.
That wouldn't cause the corruption though (unless the no_clut is actually causing it)..
Perhaps post your assets txt entry and also the actual image you are displaying so they can be checked.
Edited by Sporadic
4 minutes ago, Sporadic said:
The sprite_CLUT in your object definition should really be 0 since your jsfLoadClit is loading the 16 colours into CLUT 0.
@Sporadic thank you. This is the assets entry:
I have tried several different background images, here is one of them attached to this post: background.bmp
31 minutes ago, Sporadic said:
You just want gfx_clut in there, no 8 on the end
Thank you @Sporadic! I'm still seeing the issue but I feel like my code is slowly getting cleaned up. Regarding the use of gfx_clut vs gfx_clut8, what is the difference? I presume from reading the notes in assets.txt that gfx_clut8 is for 8-bit images, the one I am using in GIMP is labeled as "Indexed color 8-bit gamma integer." so I just assumed gfx_clut8 was the right choice.
There is no gfx_clut8.  For 1,2,4 or 8 bit palette images, just use gfx_clut. That will create the clut index asset for you. Then as you have done, in the object definition you tell it the bit depth you're using.
For a 16-bit image, just use gfx_clut16.
I'm not in a position to check your graphic file at preset to confirm it's 4bit. I couldn't spot anything else wrong though.
"For graphics conversion you can use "gfx_clut" or "gfx_noclut" to convert a .BMP file into jaguar raw format and optionally export the paletter or not (clut=yes, noclut=no).
' This applies to 1-, 2-, 4- and 8-bit graphics only.
' For 16-bit and 24-bit graphics no clut is created (because there isn't a need for one).
' Finally for 16-bit images you have to use gfx_clut16 or gfx_noclut16."
EDIT: I've just noticed in your original post that you said it was 4bits (16 colour). But in your later post you said you used "Indexed color 8-bit". Which would be a 256 colour 8 bit image. If it is 8bit, then you still need gfx_clut in assets, but your object definition would be wrong. You need to put 8 in the bitdepth and remove the /2 in all the "size" properties. LoadClut would also need adjusting to 256. This should be detailed in the rapinit.s sample object and in the documentation in the docs folder.
Edited by Sporadic
Thank you @Sporadic that makes sense. Regarding the format of the image, I believe it is correct but I cannot say with certainty as I lack the experience. This is the image properties in GIMP:
I have another program I use which says of the same file that it is 4bpp (16 colors).
bytewid and gwidth are wrong - they need /2
Thank you! Thats fixed it!
The rapinit.s file should have an example object that lists the relevant changes you need to make.
If not, then look at that file in some of the examples. It should tell you where to put a
/2 or /4 or *2 etc etc.
If you can't find it then I'll paste it in here when next at the computer.
Thank you! I see what you are referring to.
After some learning on my part I have had some success working with a number of images including (I am pleased to say) animated images. The only part I seem to be tripping on is with a 1bpp monochrome image I am attempting to use. Is there a gotcha I am not aware of for working with a monochrome image? The settings seem easy enough to figure it with respect to rapinit.s:
; SHIPSELECTED
	dc.w	-48,0						    ; sprite_y						; 16.16 y value to position at
	dc.l	48								; sprite_width					; width of sprite (in pixels)
	dc.l	48								; sprite_height					; height of sprite (in pixels)
	dc.l	48/2							; sprite_hbox					; width of collision box
	dc.l	48/2							; sprite_vbox					; height of collision box
	dc.l	SHIPSELECTED					; sprite_gfxbase				; start of bitmap data
	dc.l	1								; (BIT DEPTH)					; bitmap depth (1/2/4/8/16/24)
	dc.l	is_trans						; (TRANSPARENCY)				; bitmap TRANS flag
	dc.l	48*48/8						    ; sprite_framesz				; size per frame in bytes of sprite data
	dc.l	48/8					    	; sprite_bytewid				; width in bytes of one line of sprite data
	dc.l	2								; sprite_animspd				; frame delay between animation changes
	dc.l	1								; sprite_maxframe				; number of frames in animation chain
	dc.l	1								; sprite_CLUT					; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit)
	dc.l	48/8     						; sprite_gwidth					; GFX width (of data)
The image itself is simple enough: shipselected.bmp
