Kchula-Rrit Posted October 29 Share Posted October 29 Just wondering what the power-supply noise immunity for the console is... I bought a MeanWell RT-65A power supply (from Jameco Electronics) for the BATcomputer until I can fix the battery power supply. The data sheet says the noise should be 80mV peak-to-peak. I measured it to be roughly +60mV, -50mV with my storage scope and tried combinations of capacitors and inductors to reduce the noise, with little effect. Then I just turned the power supply off and checked the noise, which was +30mV, -24mV. If the "unpowered" noise is a component of the total noise, then the noise contributed by the power supply would be +30mV, -26mV. K-R. Quote Link to comment Share on other sites More sharing options...
JJB Posted October 29 Share Posted October 29 For what it's worth, I have replaced the power supply board of both my 99/4a consoles with a combination of small switching buck and boost converters. I did spend considerable time trying to reduce the ripple. For +5V I ended up at ~40mV (from ~60mV) by adding some capacitance and inductance at the output, purely by experimenting. I didn't bother with the other rails (+12V and -5V) even though the ripple was a bit higher on both (I think). I haven't seen any negative side effects whatsoever but definitely one positive one: cool to the touch 🙂 FYI I am building a Geneve stand-alone system and have replaced all those local linear regulators with the same sort of power supply you're using. It works a treat (haven't measured ripple). 3 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted October 29 Share Posted October 29 I'm starting to change out regulators on my Foundation z80 card, HFDC's, and other to these type of units from Mouser, VXO7805-1000 https://www.mouser.com/ProductDetail/CUI-Inc/VXO7805-1000., Non-Isolated DC/DC Converters 8-36Vin 5Vout 1A 5W SIP. I'm waiting for the 12 volt version to come in too. Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted October 30 Author Share Posted October 30 1 hour ago, JJB said: For what it's worth, I have replaced the power supply board of both my 99/4a consoles with a combination of small switching buck and boost converters. I did spend considerable time trying to reduce the ripple. For +5V I ended up at ~40mV (from ~60mV) by adding some capacitance and inductance at the output, purely by experimenting. I didn't bother with the other rails (+12V and -5V) even though the ripple was a bit higher on both (I think). I haven't seen any negative side effects whatsoever but definitely one positive one: cool to the touch 🙂 FYI I am building a Geneve stand-alone system and have replaced all those local linear regulators with the same sort of power supply you're using. It works a treat (haven't measured ripple). Thanks for your info, and I am glad that your new supply works. My console has a USB keyboard adapter and a reset switch where the "coffee boiler" went, so any power is external. I should have mentioned that my tests were with no load on the supply. I will have to see if adding the console as a load will help with the ripple. Quote Link to comment Share on other sites More sharing options...
Kchula-Rrit Posted October 30 Author Share Posted October 30 35 minutes ago, RickyDean said: I'm starting to change out regulators on my Foundation z80 card, HFDC's, and other to these type of units from Mouser, VXO7805-1000 https://www.mouser.com/ProductDetail/CUI-Inc/VXO7805-1000., Non-Isolated DC/DC Converters 8-36Vin 5Vout 1A 5W SIP. I'm waiting for the 12 volt version to come in too. I have been thinking of doing the same thing with my PE boards, also. Shift838 gave me a Mouser part number for a 2-amp part that does the same thing. He mentioned it here, in the conversation about the new IDE board. K-R. 1 Quote Link to comment Share on other sites More sharing options...
