doctorclu Posted October 31, 2023 Share Posted October 31, 2023 Something had me wondering last night. Never have luck disabling basic in the XL/XE environment 100% of the time. I know it sounds silly, but always found having to disable basic to be an unnecessary step. Would it be possible to make a stand in rom for basic? So the computer will look where basic is, but automatically just say "nothing to see here, move along..." Perhaps something to just simply activate option without having the hold down option? Quote Link to comment Share on other sites More sharing options...
Pab Posted October 31, 2023 Share Posted October 31, 2023 If you plug in any cartridge, it's going to swap out the RAM from $A000-$BFFF (or $8000-$9FFF with 800 right cartridge) so it's defeating the purpose. BASIC would be disabled, but you would still not have RAM there. I assume you're not using SpartaDOS. You could probably write a quick AUTORUN.SYS program to toggle the "BASIC enabled" byte in PORTB. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted October 31, 2023 Share Posted October 31, 2023 I did that once with a 1090XL firmware board. It could easily be done with a cartridge. The cartridge should have it's own latch, via a $D5xx address, to disable itself. It would also have to copy a little bit of code to RAM. So, it would be like this: 1. OS runs cartridge 2. Cartridge code disables BASIC via PORTB. 3. Cartridge code copies a small section of code to main memory. (This section turns off the cartridge bank, sets the new top of RAM, and exits back to the OS..) 4. Cartridge code runs the section it just copied to main memory. Quote Link to comment Share on other sites More sharing options...
Pab Posted October 31, 2023 Share Posted October 31, 2023 (edited) Here, for ASM/ED: 10 *=$600 20 PORTB=$D301 30 LDA PORTB 40 AND #$FD 50 STA PORTB 60 RTS I'm at work without access to my 800 or Altirra, so I'll leave it to you to compile and save. Edited October 31, 2023 by Pab Oops. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted October 31, 2023 Share Posted October 31, 2023 (edited) Some carts can bank the Rom out. Possibly the INIT section could do that and return but much of it would need to run from Ram, although the sequence could be as little as STA $D5xx / RTS. That code could be pushed to the stack, then stack adjusted and jumped to. For the trouble you'd be better off just doing a custom OS that defaults to Basic off. Edited November 1, 2023 by Rybags Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 1, 2023 Share Posted November 1, 2023 This highlights how spoiled I have been for decades now. Starting with Tucker's 32-in-1 OS upgrade, then moving onto U1MB. I don't even have a machine any more that has the stock OS. I get so many benefits from custom OS. Reverse BASIC, hi-speed SIO, etc. 1 Quote Link to comment Share on other sites More sharing options...
doctorclu Posted November 1, 2023 Author Share Posted November 1, 2023 1 hour ago, Stephen said: This highlights how spoiled I have been for decades now. Starting with Tucker's 32-in-1 OS upgrade, then moving onto U1MB. I don't even have a machine any more that has the stock OS. I get so many benefits from custom OS. Reverse BASIC, hi-speed SIO, etc. The U1MB should in a lot of ways be what the Incogneto is. But of the XE and XE OS they have listed, they all have basic as a default. (I try to load like the IRC chat under XL/XE 320k and it either comes up in basic, memory test, etc.) Thanks for the answers to my questions all! Quote Link to comment Share on other sites More sharing options...
pcrow Posted December 9, 2023 Share Posted December 9, 2023 On 10/31/2023 at 2:28 PM, reifsnyderb said: I did that once with a 1090XL firmware board. It could easily be done with a cartridge. The cartridge should have it's own latch, via a $D5xx address, to disable itself. It would also have to copy a little bit of code to RAM. So, it would be like this: 1. OS runs cartridge 2. Cartridge code disables BASIC via PORTB. 3. Cartridge code copies a small section of code to main memory. (This section turns off the cartridge bank, sets the new top of RAM, and exits back to the OS..) 4. Cartridge code runs the section it just copied to main memory. No need for code in RAM. Just have the init address for the cartridge be in the register space, and have the cartridge set so reads from the register space come from the ROM. So reads from D5xx would be from the ROM, and the cartridge initialization address would be D500. The code there would, as described, disable BASIC in PORTB and then disable the cartridge itself, but leaving the D5xx window open. The key here is that the D5xx window doesn't have to be just hardware registers, especially if they're write-only. Related: I was thinking you could have a cartridge that did everything in the D5xx window and immediately re-enabled the RAM under it on initialization. In theory it could use writes to page swap the ROM into that window. With some extremely clever hacking, you might be able to get something like DOS to run that way, taking up no code space. And this would work the same as a left or right cartridge on an 800. 1 Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted December 9, 2023 Share Posted December 9, 2023 (edited) Reads from /cctl area mapped to the ROM and writes to /cctl set a register? Should be workable. I like it. 🙂 Edited December 9, 2023 by reifsnyderb Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 9, 2023 Share Posted December 9, 2023 The problem with a cart present is that the memory map (screen, top of Ram pointer etc) will reflect that even after the cart disables itself. So you'd get a boot situation where it's possible that the game or whatever thinks you only have 40K. In theory you could disable cart, re-open screen etc but it starts to get complicated and you can have unwanted residual data left in parts of Ram. Quote Link to comment Share on other sites More sharing options...
pcrow Posted December 9, 2023 Share Posted December 9, 2023 6 hours ago, Rybags said: The problem with a cart present is that the memory map (screen, top of Ram pointer etc) will reflect that even after the cart disables itself. So you'd get a boot situation where it's possible that the game or whatever thinks you only have 40K. In theory you could disable cart, re-open screen etc but it starts to get complicated and you can have unwanted residual data left in parts of Ram. True, you would have to manually verify that the memory exists (not 600XL or 400/800 with less than 48K). Then update RAMTOP and issue GR.0. Wiping the old display list below 40K would be a bonus. If RAMTOP were below A0, then you know it's not RAM under the cartridge, so the only issue would be an 800 with two 16K RAM boards and one 8K board (exactly 40K). I bet it could all be done in 32 bytes of code. Easy in 256 bytes in D5xx. Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted December 9, 2023 Share Posted December 9, 2023 11 hours ago, Rybags said: The problem with a cart present is that the memory map (screen, top of Ram pointer etc) will reflect that even after the cart disables itself. So you'd get a boot situation where it's possible that the game or whatever thinks you only have 40K. In theory you could disable cart, re-open screen etc but it starts to get complicated and you can have unwanted residual data left in parts of Ram. The following code works for putting BASIC in the right cartridge slot on an 800. The right cartridge is a banked cartridge and can turn off all banks. I've made up the cartridge and keep it in the right slot of my 800. However, if reading from CCTL would read the ROM code that turns off the cartridge, any cartridge disabling code would not have to be copied to RAM like I did. Here's the code: .INCLUDE "camac.inc" ; Right cartridge BASIC loader ; Written by Brian E. Reifsnyder ; Address Equates TSTDAT EQU $0007 DOSVEC EQU $000A RAMTOP EQU $006A TSADR EQU $00CC TDADR EQU $00CE RAMSIZ EQU $02E4 LCARTF EQU $4FE0 CONSOL EQU $D01F RCCTL EQU $D5A0 ; LCARTF Equates LCNONE EQU $00 ; No cartridge at all. LCRC EQU $7F ; Right cartridge copied to left RAM. LCALC EQU $FF ; Actual left cartridge. ;** FIX - Fix Address ;* ;* FIX sets the origin counter to the value specified as an ;* argument. If the current origin counter is less than the ;* argument, FIX fills the intervening bytes with zero and ;* issues a message to document the location and number of ;* bytes that are zero filled. ;* ;* "Borrowed" from Atari OS source code. .macro FIX address .if * > address .error .sprintf("$%04x precedes current origin counter of $%04x", address, *) .elseif * < address .out .sprintf("$%04x free bytes from $%04x to $%04x", address-*, *, address-1) .res address-*, $00 .endif .endmacro ORG $8000 ; Copy main program to $4000 then jump to main program. LDA #$00 ; Setup source and destination addresses STA TSADR STA TDADR LDA #$90 STA TSADR+1 LDA #$40 STA TDADR+1 LDX #$03 ; Copy only 256 bytes * 4 (or 1024) bytes. This should be plenty. CPYOL1 ; Outer loop running 4 times. LDY #$FF CPYIL ; Inner loop copying 256 bytes at a time. LDA (TSADR),Y STA (TDADR),Y CPY #$00 BEQ CPYOL2 DEY JMP CPYIL CPYOL2 INC TSADR+1 INC TDADR+1 DEX BPL CPYOL1 ; Jump to main program JMP MAIN ; Main program, starting at $4000 FIX $9000 LOC $4000 MAIN LDA #LCNONE ; Assume no cartridge in left slot. STA LCARTF ; Check for physical cartridge in left slot ; If there is a physical cartridge, disable the right cartridge, reset RAM, and exit. LDX $BFFF ; Store byte LDA #$22 STA $BFFF ; Save test byte LDA $BFFF CMP #$22 ; Has test byte been saved? BNE LCROM ; It hasn't. ROM is in this location. STX $BFFF ; Test byte was saved. Put original back. We have RAM here. ; Check for Select key down LDA CONSOL AND #$02 ; Is SELECT key pressed? BNE NOLOAD ; SELECT key is not pressed. JMP INSBAS ; Install BASIC from right cartridge. LCROM LDA #LCALC ; An actual ROM is in the left cartridge slot. STA LCARTF ; Store this. NOLOAD JMP DONE ; Change cartridge bank to Altirra BASIC bank ; (Altirra BASIC bank is bank 2, set as #%00000001) INSBAS LDA #%00000001 STA RCCTL ; Copy BASIC from $8000-$9FFF to $A000-$BFFF LDA #$00 ; Setup source and destination addresses STA TSADR STA TDADR LDA #$80 ; Source page STA TSADR+1 LDA #$A0 ; Dest page STA TDADR+1 LDX #$1F ; Copy $20 pages. BCPOL1 ; Outer loop running $20 times. LDY #$FF BCPIL ; Inner loop copying 256 bytes at a time. LDA (TSADR),Y STA (TDADR),Y CPY #$00 BEQ BCPOL2 DEY JMP BCPIL BCPOL2 INC TSADR+1 INC TDADR+1 DEX BPL BCPOL1 LDA #LCRC ; Consider the loaded BASIC to be a cartridge and STA LCARTF ; set it as so. DONE ; Set OS right cartridge flag to indicate cartridge doesn't exist. LDA #$00 STA TSTDAT ; Reset banks and turn off right cartridge LDA #%00001100 STA RCCTL ; Set top of RAM (RAMTOP) ; Note that for this to work, the Atari must have 48k of base memory. LDA LCARTF BEQ DNOCT ; = LCNONE BPL DRCT ; = LCRC BMI DALC ; = LCALC DNOCT ; No left cartridge installed LDA #$C0 BNE DSRT DRCT ; Right cartridge copied to left RAM LDA #$A0 BNE DSRT DALC ; Actual physical cartridge found LDA #$A0 DSRT STA RAMTOP STA RAMSIZ ; Return RTS FIX $4FFA ORG $9FFA DW $0000 ; CARTCS DB $00 ; CART DB $00 ; CARTFG DW $8000 ; CARTAD 1 1 Quote Link to comment Share on other sites More sharing options...
