IDE v3 Prototype and Pre-order link online
Shift838
IDEV3 prototype order link (I have 3 left).  Tested thoroughly with both the TI-99 and the Geneve (with MDOS 7.42 Development).
838-IDE V3 Prototype (shift838.com)
IDEV3 Pre-order will is currently open and will be closed on December 1, 2023 @ 9:00 a.m. CST.
838-IDE V3 - PREORDER (shift838.com)
Attached photo is of the prototype, but the production board will be the same layout.  Prototype has 1 correction on the back side of the board.
Note: for anyone buying just the blank board a BOM will be supplied to you via email.
  • Like 6
13 hours ago, Kchula-Rrit said:
Just put in an order for one, to build without sockets.  Is there a list of needed sockets available?  I am going to order sockets for another project, so I thought I would add them to my socket order.
K-R.
8 x    14 Pin  IC Socket (7.62mm/.300in wide) - Dual Wipe or Machined
5 x    16 pin IC Socket (7.62mm/.300in wide) - Dual Wipe or Machined
7 x    20 pin IC Socket (7.62mm/.300in wide) - Dual Wipe or Machined
2 x    24 pin  IC Socket (7.62mm/.300in wide) - Dual Wipe or Machined
1 x    28 pin  IC Socket (machined - 15.24mm/.600in wide) - For RTC
1 x    32 pin IC Socket -  (15.24mm/.600in wide) - Dual Wipe or Machined
Edited by Shift838
10 hours ago, Shift838 said:
I have added a page to my site that also has a link to a manual I put together for it.
SHIFT838 Homepage
I will be making a video over the next couple of days and get it posted of it working on both the TI-99/4A and Geneve computers.
On Page 5 of the PDF file, under CRU Select, the switch is described as a "16-bit hexadecimal switch."  May I suggest it read a 16-position hexadecimal switch?
K-R.
K-R.
good catch..
Nice work.
Initially, I was going to ask you to change the reference to the minimum MDOS version from 7.42 to 7.40.  However, 7.42 fixes a bug that impacts the IDE (and Horizon) devices, so I suppose this is appropriate even if it is a development version.  @9640News and I haven't settled on a release date for 7.42 but it should be 'soon'.
24 minutes ago, dhe said:
Hi @Shift838
 I looked in the manual before asking - great job on the manual.
 When hooking up the power cable, Red cable closest (up) to IDE connector?
The power calbe for the 3.5 molex only plugs in one way.  The 5v (red) is closest to the IDE connector.  5v and GND are lined up directly behind on the 2-pin header as well.
