Posted (edited)
On 1/4/2024 at 8:53 PM, fabrice montupet said:
I already change colors here but this option is only for the color fonts and background of the directory view, not the text viewer window.
Also make a note of this Fabrice. The text viewer window uses the default Windows settings, ussualy white for read/write text and light gray for read only (grayed out) text. I will add some extra options to the configuration window for this.
Edited by F.G. Kaal
  • 2 weeks later...
@F.G. Kaal I downloaded the latest version to a freshly-built Win10 machine. When I run TI99Dir, I get the error message "VCRUNTIME140.DLL was not found".  I downloaded and ran the visual studio C++ redistributable package but that didn't solve the problem.  Please advise :)
Do you have both runtimes installed x86 and x64?  I've had several emulation utilities that needed both installed to run properly.
I usually have all the VC++ redistributable runtimes installed 2005, 2008, 2010, 2012, 2013, 2015-19.  Both the x86 and x64 packages.
And keep them in a folder that can be transfer to a USB stick for new builds (clean installs).
This usually cleans up any issues for windows programs.  You never know what VC++ version was used there.
Hope this helps.
I ran into the same issue. Searched, found, copied and pasted VCRUNTIME140.DLL from the CONVERT 9918 directory and was good to go.
22 hours ago, InsaneMultitasker said:
Thanks.  I installed the x64 runtimes not the x86.   I will try the latter tonight.
Ti99Dir is a 32 bit program. At least it uses my 32bit DLL LibXBTKN32.dll for converting program-text to tokenized (Ext.) BASIC.
From the bottom of @F.G. Kaal's TI99Dir web page:
The latest version of Ti99Dir is build on Windows 11 as a 32 bit program and should still run on XP / Vista / 7 / 8 / 8.1 (Not all tested by myself).
So install both runtimes, x86 & x64, for a Windows 64bit system.
Check out the following page: "https://www.techpowerup.com/download/visual-c-redistributable-runtime-package-all-in-one/"
  • Like 4
