Dropcheck Posted November 8, 2023 Share Posted November 8, 2023 I need to know what the pin # progression on the back of a SF314 Female 7pin DIN power jack is. The earlier 5 pin DIN went left to right on the back 1(+5V), 4(+12V), 2(GND), 5(NC) and 3(GND), but carried both +5V and +12V. The only manual I have is for the earlier dual voltage male 5pin DIN version. Thanks! Quote Link to comment https://forums.atariage.com/topic/356596-info-on-sf314-female-7pin-din-needed/ Share on other sites More sharing options...
snarkdluG Posted November 8, 2023 Share Posted November 8, 2023 Maybe this will help. Quote Link to comment https://forums.atariage.com/topic/356596-info-on-sf314-female-7pin-din-needed/#findComment-5345555 Share on other sites More sharing options...
TZJB Posted November 8, 2023 Share Posted November 8, 2023 (edited) 1 hour ago, Dropcheck said: I need to know what the pin # progression on the back of a SF314 Female 7pin DIN power jack is. The earlier 5 pin DIN went left to right on the back 1(+5V), 4(+12V), 2(GND), 5(NC) and 3(GND), but carried both +5V and +12V. The only manual I have is for the earlier dual voltage male 5pin DIN version. Thanks! Hi @Dropcheck. I have read that the SF314 floppy drive requires a 5V supply and that an Atari 8-bit supply would be suitable as it seems that the pinouts are the same. Plug solder side diagram below. 1 - +5V DC 2 - NC 3 - GND 4 - +5V DC 5 - GND 6 - +5V DC 7 - GND Edited November 8, 2023 by TZJB Quote Link to comment https://forums.atariage.com/topic/356596-info-on-sf314-female-7pin-din-needed/#findComment-5345559 Share on other sites More sharing options...
Dropcheck Posted November 8, 2023 Author Share Posted November 8, 2023 (edited) 1 hour ago, TZJB said: Hi @Dropcheck. I have read that the SF314 floppy drive requires a 5V supply and that an Atari 8-bit supply would be suitable as it seems that the pinouts are the same. Plug solder side diagram below. 1 - +5V DC 2 - NC 3 - GND 4 - +5V DC 5 - GND 6 - +5V DC 7 - GND I appreciate the effort, but I need the progression of pins left to right on the back side of the power jack on the pcb itself, not the power supply plug. I'm trying to develop a dual pcb footprint for either 5DIN or 7DIN power jacks. Not wanting to mix GND and power when I match the two footprints on the pcb. Like I indicated earlier, the 5Din jack does not follow a straight 1,2,3 progression and I doubt the 7pin DIN does either. A close replacement would be something like this. Atari 260ST power jack I just need the pin numbering on the back of the jack. Edited November 8, 2023 by Dropcheck Quote Link to comment https://forums.atariage.com/topic/356596-info-on-sf314-female-7pin-din-needed/#findComment-5345605 Share on other sites More sharing options...
TZJB Posted November 10, 2023 Share Posted November 10, 2023 On 11/8/2023 at 10:03 PM, Dropcheck said: I appreciate the effort, but I need the progression of pins left to right on the back side of the power jack on the pcb itself, not the power supply plug. I'm trying to develop a dual pcb footprint for either 5DIN or 7DIN power jacks. Not wanting to mix GND and power when I match the two footprints on the pcb. Like I indicated earlier, the 5Din jack does not follow a straight 1,2,3 progression and I doubt the 7pin DIN does either. A close replacement would be something like this. Atari 260ST power jack I just need the pin numbering on the back of the jack. Thank you the additional clarification 😁. Obviously the power jack socket pins are the mirror image of the plug, the PCB pinout connections I have found as below for both 5 and 7 pin DIN sockets. I am not sure that you will be able to do what you hoped for without jumpers to select what the pins connect to. Best of luck with your design. Quote Link to comment https://forums.atariage.com/topic/356596-info-on-sf314-female-7pin-din-needed/#findComment-5346498 Share on other sites More sharing options...
